I would like to calculate engineering stress using array; but the following piece of codes do not seem to work. *EngineeringStress = force / area *Define force is an array of measurements of force. crossArea:= 3.2 * 19.1 (not the "*" is really a "." in Maple editor; it is multiplication) force := array ([0., 1380.0, 2780.0, 5630.0]) engineeringStress := force/crossArea; engineeringStress[1] ({0., 1380.0, 2780.0, 5630.0}/crossArea)[1] it suppose to be 0!!!
When i input something like sqrt(30) I just get back 30 with a square root symbol over it. How can I make maple evaluate it?
How do I generate a gaussian random matrix (2x2).
Is this the default setting already in maple or is there code I need to use?
I'm to generate a random matrix ie > with(LinearAlgebra); > RandomMatrix(2, 2, generator = -1 .. 1); and find the eigenvalues of each matrix ten times. How do I put random Matrix in the for loop with Maple?
I have two vector here
X:= vector([-1,0,1])
Y:=vector([1+I*2,3+I,4+3*I], datatype=complex)
I want to fit them in the form a*exp(-I*10*t)+b*exp(I*10*t), a and b may be complex.
How should I do?
I have two vector here, and I want to fit them with the form a*exp(-I*4375*t)+b*exp(I*4375*t), a and b should be complex. How should I do?
X := Vector([-0.000163, 0, 0.000163], datatype = complex);
Y := Vector([-8.84352*10^(-13)+(I*1.71511)*10^(-12), 1.49867*10^(-13)+(I*1.45355)*10^(-12), 1.15763*10^(-12)+(I*9.08261)*10^(-13)], datatype = complex[8]);
I am trying to built in 3d function of recurrence relation
V(i)=a*V(i-1)-V(i-2); a=const; initial conditions: V(i-1)=-1; V(i-2)=-2.
An axes of a three-dimensional surface have to be: V(i); V(i-1); i.
I created these two procedures, I want to introduce within a mla.
 But I have the following two problems that I need you guys help me
solve:
Hi, I want to build recursively defined, piecewise functions.
I first defined my zero-order functions
N40(xi)=piecewise(0<xi and xi<=1);
N50(xi)=piecewise(1<xi and xi<=2);
and I can plot them with desired result
but, how do I combine them, to make first order functions?
 for instance, I want to have a function matematichally defined by:
N41 = (xi-1)*N40 + (2-xi)*N51
I've searched all over, and I can't figure this out: I'm hoping to have a result expressed in symbolic notation.  For example, if my result is x_1+x_2+...+x_n, how can I have maple express this answer as summation of x_i i=1 to n.
I actually have a matrix, each element of which is a ratio of summations.  In order to more easily comprehend it, I'm hoping to view it in summation notation.
Paul Burkander
So far I have a circle with a cornu spiral joining where their curvatures are equal as below.
S1:=unapply(u*FresnelS(u)+((1/Pi)*cos((1/2)*Pi*u^2))-(1/Pi),u);
C1:=unapply(u*FresnelC(u)-((1/Pi)*sin((1/2)*Pi*u^2)),u);
R1:=1;
u1:=evalf(sqrt(0.4));
E1:=evalf(Pi*R1*S1(u1)+R1);
D1:=evalf(Pi*R1*C1(u1));
with(plottools);
c1 := circle([D1, E1], R1);
display(c1);
a:=evalf(Pi*R1*u1);
I am trying to use the output of an equation to set the value of a slider. In other words, how do I display the output of an equation in a slider / meter form ?
Hi im new to maple. How would i input this story problem into maple. In 600 days, an unknown radioactive substance decay to 62 percent of its size. (a) What is the half life of this substance? (b) How long will it take for a sample of 100mg to decay to 48 mg?
I find that the position of the labels (x, y, and z) on the axes of plots from implicitplot3d are not ideal. I prefer them to be close to the ends of the axes, while maple seems to place them nearer the middle. Can this position be changed with an option?
I'm using Maple 13 for Mac OS X.
How do I get Maple to recognize the Chain rule symbolically?
I have an ODE that looks like this:
u = a[0] + a[1]*w(q) + a[2]*w'(q) + a[3]*w(q)^2
where u,a[i],q are all functions of (x,y,t), so W is really W(q(x,y,t)).  W' is d/dq(W).  I am having trouble figuring out how to get Maple to recognize W' and still being able to take derivatives with respect to x,y, or t.
I want to get the following:
diff(W',x) = W''*q_x or in words: two derivatives of W with respect to q times q_x.
How can I do this?
First 2042 2043 2044 2045 2046 2047 2048 Last Page 2044 of 2431
