so i need to check that these solutions are in fact solutions. they are obviously very close but i can't get the boolean output to be "true".
eqn1:=tan(x)=x;
N:=10;
soln_array:=Array(1..N):
for m from 1 to N do
this_soln:=fsolve( eqn1 , x=(m-1/2)*Pi..(m+1/2)*Pi );
soln_array[m]:=[this_soln, tan(this_soln)];
soln_array;
evalb(simplify(tan(this_soln)-this_soln)=0);
I was playing around with loops and came up with this simple while loop that is reacting different than I am expecting
a:=rand(1..10):
while a() <> 4 do print(a()); od:
the output includes 4's ??
I'm new here so apologies if the solution to this is is obvious.
I am getting the following message in Maplesim 3 when I try and run a simulation. At least I think it is an error message, could just be a statement?
Starting simulation...
Preparing model...
(in MapleSim:-Modelica:-Flatten) duplicate definition of `Main.Turbo.C`
Any tips on what this might mean would be appreciated as it means nothing to me...
I'm trying to pointplot two arrays (vectors) but no matter what I change in the listing below Maple 11 keeps considering the second vector as an option.
Hi, continuing on from my previous question. The question now is that how many times do I need to roll the dice to have at least 1 one, 2 twos, 3 threes, 4 fours, 5 fives, and 6 sixes.
Thanks for all the help!
Can Maple embed ActiveX objects ?
such as discussed here www.quaccess.com/index.html
I want to plot y=f(x) where f(x) may be in the form: f(x) = kx... I need to supply several values, or parameters, for the constant k. For example, k=2,4,8,10. If I can get someone's help on this plotting question, I think I'll be on my way to figuring out other issues using the Mable Help menus. I'm a self-study student, so I don't have a professor to check with. Thx. (I realize this is extremely simple)
In principle I think this should be pretty easy. I need to make a MAPLE code that uses loops and arrays to carry out the prcedure described here: http://people.revoledu.com/kardi/tutorial/ContinuedFraction/Decimal-Fraction-Conversion.htm
I've compared that with the Math Input Panel associated with Windows 7 just by mouse
,and another software made by my handwriting pen's manufacturer.
What's your point?
Wish a great progress in the following version of Maple,I think the Ocr function can also be associated.
I lunch a .mpl maple program in a bash shell.
Between the other things, the program shoud print in a file a line that gives the user informations about the elapsed time
I've put inthe code this line
appendto("./out.txt"):
printf("\n The total elapsed time has been of %d hour(s)  %d minute(s) and %a seconds \n",hou, mini,seci):
the problem is that the out file contains not only the formatted answer, but also the very call:
I am struggling with GlobalSolve (in Maple 12) and would really appreciate some help.
The problem is that a non-optimal solution is being found
I have a die and I want to keep rolling it until I get all the 6 numbers on the die at least once.
What could be a possible code?
Hi, all,
I want to implement F4 computing Groebner basis in maple. However, when I read the paper described the F4 algorithm, it is terribly difficult to understand that example and I am pretty much sure there are mistakes in that paper.
Do you guys have some advice or documents to let me really get through the F4 algorithm?
Many thanks.
gepo
I'm looking for all of the Maple product brochures for a project I plan to put together.  Does anyone have any of the product brochures?  They are certainly a quick reference between versions to see what has changed.
Sadly I cannot find the older pdf brochures for all the Maple V releases, Maple 6, Maple 7,  Maple 8, and Maple 9 anywhere online.
So far I was able to locate all of the brochures for 9.5 and up.
First 2044 2045 2046 2047 2048 2049 2050 Last Page 2046 of 2431
