Hello everyone
I create a curved space ( with Physics) and create a metric tensor of
a sphere . I see some Christoffel correcly . Is it possible to visualize all non zero Christoffel in one shot ?
Thank's a lot
Best Regards
restart; with(Physics)
Physics:-Setup(mathematicalnotation = true)
[mathematicalnotation = true]
Physics:-Setup(spacetimeindices, dimension = 2, signature = "++")
[dimension = 2, signature = `+ +`, spacetimeindices = greek]
Physics:-Coordinates(X)
{X}
ds2 := Physics:-`^`(dx1, 2)+Physics:-`*`(Physics:-`^`(sin(x1), 2), Physics:-`^`(dx2, 2))
dx1^2+sin(x1)^2*dx2^2
Physics:-Setup(metric = ds2)
[metric = {(1, 1) = 1, (2, 2) = sin(x1)^2}]
g_[]
g[mu, nu] = (Matrix(2, 2, {(1, 1) = 1, (1, 2) = 0, (2, 2) = sin(x1)^2}, storage = triangular[upper], shape = [symmetric]))
Physics:-Christoffel[`~k`, i, j]
Physics:-Christoffel[`~1`, 2, 2]
-sin(x1)*cos(x1)
Physics:-Christoffel[`~2`, 1, 2]
cos(x1)/sin(x1)
Physics:-Christoffel[`~1`, 1, 1]
Download Approfondimento_1_-_Calcolo_Sfera_2D.mw
I have JPG images and plots from a CAD code and from Matlab. I want to insert them into a Maple worksheet and do the following:
      1. Resize the images or plots while preserving aspect ratio
      2. Add a figure number and caption to the image or plot.
          I would prefer automatic numbering if that is available in Maple.
          I would also prefer to have the caption "linked" to the image or plot so that they can be moved together
I assumed that these kinds of tools were available in Maple, but I sure cannot find them. Any help will be greatly appreciated.
Thanks, Neill Smith
I just downloaded maple 2021 (I get i free from my school). I used maple for the last 4 years but, now when i opdatede to maple 2021 from version 2020, its just keep freezing i have try to uninstall 3 times by now and it still keep freezing.
Hi.
plot([cos(t), sin(t), t = 0 .. 2*Pi]) give a nice circle.
but
plot([cos(t), sin(t), t = 0 .. 2*Pi*10000])
have the whole circle filled.
Is this a bug or expected behavior?
Huajun
That is to say, a generalized map
E.g., here is a nested list:
nl := [[[[s, t]], [u, [v, w]]], [[x, [y, z]]]]:
We can use map to apply the mapped function F to "each operand" (i.e., the first‐level parts) of :
:-map(F, nl);
         [F([[[s, t]], [u, [v, w]]]), F([[x, [y, z]]])]
But in Mathematica, we can make further explorations:
In[1]:= nl = {{{{s, t}}, {u, {v, w}}}, {{x, {y, z}}}};
In[2]:= Map[F, nl, {1}] (*Maple's result*)
Out[2]= {F[{{{s, t}}, {u, {v, w}}}], F[{{x, {y, z}}}]}
In[3]:= Map[F, nl, {2, -2}]
Out[3]= {{F[{F[{s, t}]}], F[{u, F[{v, w}]}]}, {F[{x, F[{y, z}]}]}}
In[4]:= Map[F, nl, {-3, 3}]
Out[4]= {{F[{F[{s, t}]}], F[{F[u], F[{v, w}]}]}, {F[{F[x], F[{y, z}]}]}}
In[5]:= Map[F, nl, {0, \[Infinity]}, Heads -> \[Not] True]
Out[5]= F[{F[{F[{F[{F[s], F[t]}]}], F[{F[u], F[{F[v], F[w]}]}]}], F[{F[{F[x], F[{F[y], F[z]}]}]}]}]
Note that the last case has been implemented in Maple as MmaTranslator[Mma][MapAll]:
MmaTranslator:-Mma:-MapAll(F,nl);
   F([F([F([F([F(s), F(t)])]), F([F(u), F([F(v), F(w)])])]),
     F([F([F(x), F([F(y), F(z)])])])])
Naturally, how to reproduce the other two results in Maple programmatically? (The output may not be easy to read or understand; I have added an addendum below.)
Addendum. It is also possible to display in "tree" structure (like dismantle) manually:
                s
                t
            u
                v
                w
            x
                y
                z
As you can see, the "depth" of  is five (0, 1, 2, 3, and 4), while the classical map just maps at the first "level". (Moreover, such descriptions may lead to a confusion.)
Supplement. Unfortunately, there remains a bug in the MmaTranslator[Mma][Level]. Compare:
MmaTranslator:-Mma:-Level(nl, [4]); (*Maple*)
                             [v, w]
MmaTranslator:-Mma:-Level(nl, [-1]); (*Maple*)
          [s, t, u, v, w, x, y, z, -1, x, c, r, y, 2]
In[6]:= Level[nl, {4}] (*Mathematica*)
Out[6]= {s, t, v, w, y, z}
In[7]:= Level[nl, {-1}] (*Mathematica*)
Out[7]= {s, t, u, v, w, x, y, z}
Hey guys.
I want to replace _Z1, _Z2 and _B2 with n but it doesn't work. Can anyone help?
An example is attached.
Oliveira
Example3.mw
I have noticed this before few times. I wonder if others have seen it.
When I have Maple open, (with may be few worksheets open) and not being used at all for anything and it is not running anything, after sometime (say 2-4 hrs or more), when I go back to using Maple, I find the GUI unresponsive. Nothing happens. Clicking on anything does nothing, It is frozen. Resizing the window, it become black and does not repaint.
But If I wait about 5-10 minutes after doing this window resizing, it suddenly becomes responsive again and it become alive again.  This happened twice this week, where I was about to just kill Maple. Good thing I did not.
It feels like the Maple process/frontend went to sleep when not being used, and it takes few minutes to wake it up by shaking the window. I do not know what else could explain this.
This is windows 10. Latest updates and lots of RAM and nothing else is running on the PC at this time.
I go take a nap, come back and notice this. It does not happen all the time, but noticed it twice this week.
Any others seen this problem? Does Maple process go to sleep or hibernate when it detects it is not being used for sometime? Looking at task manager when this happens, I see no CPU activity at all and no memory changes at all in any of the servers.exe. So I think this might be a GUI issue, where Java go to sleep or something.
Or it could be a windows 10 issue and not Maple. But I only noticed this with Maple where it seems to go to sleep when not used.
Maple can be set to calculate approximately/numerically for instance by adding af . e.g. calculate f(4.) instead of f(4), but it is possible to set Maple to default calculate, as if alle numbers were entered as "4." (even though I enter "4")?
How to slove this equation in Maple (get the optimal w), where y is a vector R(n*1), X is a matrix R(n*m), and w is a vector R(m*1),lambda is a scalar.
From a list of strings say
L:=[k$1,y$23,f$25,........]
A particular type of delimiter will their which is  common to all elements in the list the right side is always a number
The function takes the list, and the delimiter as input
Then it outputs a list of
Numbers which is on the right side of the delimiter
Output will be like
[1,23,25,...]
The delimiters could be a space
Or
Space on both sides of dollars
That is in understanding space should also be considered in delimiter that is anything significant
Hello there,
Is there any chance to ask this one question?
The attached (following) worksheet shows the result of LieDerivative operation, which is not correct.
The correct answer is given in the image in the middle of the worksheet. Is there any particular reason regarding Maple's way of conducting the operation in that way?
with(DifferentialGeometry):
with(LieAlgebras):
DGsetup([x1, x2], M, verbose);
`The following coordinates have been protected:`
[x1, x2]
`The following vector fields have been defined and protected:`
[_DG([["vector", M, []], [[[1], 1]]]), _DG([["vector", M, []], [[[2], 1]]])]
`The following differential 1-forms have been defined and protected:`
[_DG([["form", M, 1], [[[1], 1]]]), _DG([["form", M, 1], [[[2], 1]]])]
`frame name: M`
M >
f := evalDG((x2)*D_x1 + (c1 * (1 - x1^2) * x2 - c2 * x1)*D_x2);
_DG([["vector", M, []], [[[1], x2], [[2], -c1*x1^2*x2+c1*x2-c2*x1]]])
M >
h := evalDG((x1)*D_x1 + (0)*D_x2);
_DG([["vector", M, []], [[[1], x1]]])
M >
###### answer
M >
M >
LieDerivative(f, h);
_DG([["vector", M, []], [[[1], x2], [[2], x1*(2*c1*x1*x2+c2)]]])
M >
Download Q20230307.mw
As2_v2.mw
What should I fix my code in order to work?
Thanks in advance,
I am a newbie in the use of the Physics package.
As I'm interested in modeling dynamic articulated systems, I began reading the example about Mechanics (Statics).
My question is quite simple: let F some vector force of components a * _i and b * _j , what does abs(F) represent?
I naively thought that abs(F)  was the modulus of F and expected it to be non negative. But I get some negative values (as in the tutorial example for some values of angle alpha.
I am trying to test types inside lists on the input to a procedure. Sometimes I can get this concept to work.
This is a sample to show the problem. I need to know if the list has [ list[ $3] , Vector[column]($3) ] , or [ Vector[row]($3] , Vector [column]($3) ]
        test:=proc(l1::[{[algebraic $ 3],'Vector[row](3, algebraic)'},'Vector[column](3, algebraic)'],l2::[{[algebraic $ 3],'Vector[row](3, algebraic)'},'Vector[column](3,algebraic)'])
        print("inputs recognised");
proc (l1::[{'Vector[row](3, algebraic)', [`$`(algebraic, 3)]}, 'Vector[column](3, algebraic)'], l2::[{'Vector[row](3, algebraic)', [`$`(algebraic, 3)]}, 'Vector[column](3, algebraic)']) print("inputs recognised") end proc
#  3d lines
l1:= [<1 | 5 | 7>, <3, 7, 9>]
[Vector[row](3, {(1) = 1, (2) = 5, (3) = 7}), Vector(3, {(1) = 3, (2) = 7, (3) = 9})]
l2:=[<-4 | 2 | 1>, <3, 8, -9>]
[Vector[row](3, {(1) = -4, (2) = 2, (3) = 1}), Vector(3, {(1) = 3, (2) = 8, (3) = -9})]
test(l1,l2)
Error, invalid input: test expects its 1st argument, l1, to be of type [{'Vector[row](3,algebraic)', [algebraic $ 3]}, 'Vector[column](3,algebraic)'], but received [Vector[row](3, [1,5,7]), Vector(3, [3,7,9])]
l3:= [[1 , 5 , 7], <3, 7, 9>]
[[1, 5, 7], Vector(3, {(1) = 3, (2) = 7, (3) = 9})]
l4:=[[-4 , 2 , 1], <3, 2, -9>]
[[-4, 2, 1], Vector(3, {(1) = 3, (2) = 2, (3) = -9})]
test(l3,l4)
Error, invalid input: test expects its 1st argument, l1, to be of type [{'Vector[row](3,algebraic)', [algebraic $ 3]}, 'Vector[column](3,algebraic)'], but received [[1, 5, 7], Vector(3, [3,7,9])]
type(l3[1],[algebraic $ 3])
type(l1[1],[algebraic $ 3])
type(l1[1],'Vector[row](3, algebraic)')
type(l1[2],'Vector[column](3, algebraic)')
Download Q_2023-03-06_Proc_types_in_list_inputs.mw
This is second order ode solved using series method. This problem from textbook. The solution given by Maple does not match the book. I also solved this by hand and my hand solution agrees with the text book. I also solved this using Mathematica and its solution agrees with the book.
Maple solution does not agree with the book for y2.  i.e. the general solution for this problem has the form
    y= c_1 * y1 + c_2* (  y1 * ln(x)  +  y2 )
This is a Frobenius series method, since regular singular point and it falls into the hard case, where roots of indicial equation has difference of integer and where the second solution y2 can't be obtained using same method as y1 due to being undefined if using same method. So it require adjustment to the Frobenius series method.
This is ode
Order:=10;
ode:=x*diff(y(x),x$2)-3*diff(y(x),x)+x*y(x)=0;
dsolve(ode,y(x),'series')
Maple says that
   y2 = -144 - 36*x^2 + 1/2*x^6 - 25/1024*x^8 + ...)
First, it is missing x^4. And not able to make other coefficients match book. Book says y2 should be
   y2 = 1 + x^2/4 + x^4/64 - (11 x^6)/2304 + ....
And that is what I get and also Mathematica:
I do not have screen shot now of the page from the book to show. It is from an old textbook. Will try to make screen shot if needed.  This is problem 5, page 212 from SCHAUM's "differential equations" by Frank Ayers. 1952 edition. There is free PDF files on the net. Here is screen shot
My question is, why is Maple's series soluiton for the second basis solution y2 different? Could someone verify this? It also failes to verify it
Order:=10;
sol:=dsolve(ode,y(x),'series');
odetest(sol,ode,'series','point'=0)
Update
I've testsed few more problems, solved by hand and verified using Mathematica. All these problems give wrong solution by Maple for y_2. At least the solutions do not match the book and do not match my hand solution and do not match Mathematica. In all cases Mathematica's solution and my hand solution match the book.
All these problem fall into the same difficult case of Frobenius series, where roots of indicial equation differ by integer and where y_2 can not be obtained directly using similar method used to obtain y_1. Other cases of Frobenius roots, Maple give complete correct general solutions. It is only this case where there seems to be something wrong.
In all of these problems below, y_1 solution is correct. It is the last series in y_2 shown which does not agree with book and it is this part which require using modifed method to obtain as explained on the book where these problems are solved from the above links. All the books used can be found online.
Please see attached worksheet.
#problem  problem 5, page 212 from SCHAUM's "differential equations" by Frank Ayers. 1952 edition.
ode:=x*diff(y(x),x$2)-3*diff(y(x),x)+x*y(x)=0:
y(x) = c__1*x^4*(series(1-(1/12)*x^2+(1/384)*x^4-(1/23040)*x^6+(1/2211840)*x^8+O(x^10),x,10))+c__2*(ln(x)*(series(9*x^4-(3/4)*x^6+(3/128)*x^8+O(x^10),x,10))+(series(-144-36*x^2+(1/2)*x^6-(25/1024)*x^8+O(x^10),x,10)))
Warning, unable to compute series necessary to test the given solution
FAIL
#page 19, example 5. NASA report TR R-390. By Gabriel Allen (PDF online)
ode:=x^2*diff(y(x),x$2)+x*diff(y(x),x)+(x^2-4)*y(x)=0:
y(x) = c__1*x^2*(series(1-(1/12)*x^2+(1/384)*x^4-(1/23040)*x^6+(1/2211840)*x^8+O(x^10),x,10))+c__2*(ln(x)*(series(9*x^4-(3/4)*x^6+(3/128)*x^8+O(x^10),x,10))/x^2+(series(-144-36*x^2+(1/2)*x^6-(25/1024)*x^8+O(x^10),x,10))/x^2)
FAIL
# problem 20.6, page 114 from SCHAUM's "differential equations" by Richard Bronson. 1978 edition.
ode:=x^2*diff(y(x),x$2)+(x^2-2*x)*diff(y(x),x)+2*y(x)=0:
y(x) = c__1*x^2*(series(1-x+(1/2)*x^2-(1/6)*x^3+(1/24)*x^4-(1/120)*x^5+(1/720)*x^6-(1/5040)*x^7+(1/40320)*x^8-(1/362880)*x^9+O(x^10),x,10))+c__2*(x*ln(x)*(series(-x+x^2-(1/2)*x^3+(1/6)*x^4-(1/24)*x^5+(1/120)*x^6-(1/720)*x^7+(1/5040)*x^8-(1/40320)*x^9+O(x^10),x,10))+x*(series(1-x+(1/4)*x^3-(5/36)*x^4+(13/288)*x^5-(77/7200)*x^6+(29/14400)*x^7-(223/705600)*x^8+(481/11289600)*x^9+O(x^10),x,10)))
FAIL
# problem 20.7, page 115 from SCHAUM's "differential equations" by Richard Bronson. 1978 edition.
ode:=x^2*diff(y(x),x$2)+x*diff(y(x),x)+(x^2-1)*y(x)=0:
y(x) = c__1*x*(series(1-(1/8)*x^2+(1/192)*x^4-(1/9216)*x^6+(1/737280)*x^8+O(x^10),x,10))+c__2*(ln(x)*(series(x^2-(1/8)*x^4+(1/192)*x^6-(1/9216)*x^8+O(x^10),x,10))/x+(series(-2+(3/32)*x^4-(7/1152)*x^6+(35/221184)*x^8+O(x^10),x,10))/x)
FAIL
Download series_solutions_Frob_difference_integer.mw
First 226 227 228 229 230 231 232 Last Page 228 of 2430
