Hi, I'm new to Maple so please forgive me if this seems really easy but I can't seem to find it in help anywhere. Basically, I have an equation that is a function of x, y, and t (where t is time). Instead of a 3-D plot, I would like to display a 2-D plot with x-axis and y-axis and have 5 lines of the equation at various intervals of t (t=0, t=1, t=3, t=5, t=20, etc.). Thank you very much for the help, KC
Does anyone know if there is a way to save plots in a maplet? The following does not produce the expected .ps file:
hey all,i finding how to solve integration on maple rather tricky.I need 2 find the numerical area of the region above the x-axis which is restricted by the curve y=5sinx-3x^2+5 and the x-axis. how can i do this? any suggestions will be gratefully received.
Hi, i'm new to using maple, and so far been ok solving equations, by figuring out the code forthis has got me stumped and would appreciate any help people can give me. basically i'm trying to find the smallest value of x>0 for which the function f(x)=sinx/x has a minimum and to find the coressponding value of the function. However i keep getting error messages, as my code probably does not make sense. could any one help pls? thanks.
hi, I want to solve linear equations with the assumption that Maple round every step of the evaluation accurate to 2 decimal places. for example: > solve({1.11 x - 2.13 y + 1.14 z = 1.23, 0.32 x + 1.44 y + 3.02 z = 4.10, 1.27 x - 1.14 y + 2.54 z = 5.67}, [x, y, z]) x=19.59 y=7.38 z=-4.24 and not [[x = 19.09759807, y = 7.184806478, z = -4.091838645]] thx for your help
Does anybody know of a way to extract derivatives of a specified function from an expression? For example, if I have the expression, int(D[6](F)(x,t,y(x,t),diff(y(x,t),x),diff(y(x,t),t),diff(diff(y(x,t),t),x))*diff(diff(yv(x,t),t),x),t = t1 .. t2); I'd like to be able to get the derivatives of yv(x,t) which in this case would be, diff(diff(yv(x,t),t),x). I ask because I'm trying to systematically integrate a set of expressions by parts where I know that the dv term always contains a certain function's derivatives and I can stop integrating by parts once I have just the function.
Hello, I am new to maple and I am trying to create letters with the arrows and hats over them so they can represent vectors. I looked at all of the different fonts included in Maple and none of them that I saw had any characters with arrows over them. I looked at all of the shortcuts and I didn't see a way to type stuff directly above a letter, beacuse maple has letters and it has arrows so if there were a way to do a superscript of the arrow except directly over the letter that would work. I also looked at the symbol definitions, and I looked through maple help. I found an overwhelming amount of help for the commands, but nothing for a simple formatting issue.
How much is MapleSoft charging High School teachers for a copy of Maple 10? Do they get the full version??
I tried to install Maple 10. At the end the Maple installer prompts me to restart my computer. ONce I press the restart button , the installer just sits there. I rebooted the machine by depressing the on/off button. Maple seems to be working on my computer for now. Should I install Maple again (after removing it) or should I leave it alone? Has anyone else experienced the same installation situation?? Thanks!!
Hi, I'm having trouble getting the collect function to do what I want. Namely, I would expect collect( a*x^b + x^b, x) to return (a+1)*x^b. Here, a and b are variables. Collect only seems to work if either a or b has a defined value (e.g. a=2, b is undetermined). What am I doing wrong here?
I have the following: arrays arrC of type double in a C code and a fct in Maple allowing arrM of type Array(datatype = float[8]) as argument. I want to evaluate the fct using arrC as input. For that one can either use 'MapleAssignIndexed' (looping through the elements if there are not very much of them), or 'RTableCreate' (details omitted). Both seem to need some overhead which costs time. Is there a way to use something like the C function memcpy to copy the array to Maple (assuming the correct space can be supplied) to speed it up? Does one have to work with byte arrays instead for that - or is it
Hi! The Maple 10 installation worked fine. No problems at all. I've installed the 2 updates 01 and 02. The command line maple works. BUT xmaple denies to start. I see no error message. May a java related problem which I am not able to fix myself. Help is very apreciated! Regards, Arno
Hi! Can sombody tell me when a native version for Intel based Macs will be available. I tried the G5 binary installer which didn't start. Thanks, Arno
Hello, I was wondering whether there is any way to protect a table. I have the following situation: > f := table([ a = table([ a1 = 1, a2 = 2 ]), b = table([ b1 = 3, b2 = 4 ]) ]); That is, f[a] returns another indexed table. Now, when I do protect(f), protect(f[a]) or even protect(f[a][a1]), I cannot change its value any more: > protect(f); > f[a][a1] := test; Error, attempting to assign to array/table `f` which is protected But if I assign f[a] to a new variable g, then I can do it: > g := f[a]; > g[a1] := test; > eval(f); table([a = table([a1 = test, a2 = c]), d = table([d1 = i, d2 = j])])
I encountered the pair command in order to zip a pair of variabels. This is usefull for 2d plot. Is there's a way to do it for 3d plot, meaning zipping three parameters?
First 2397 2398 2399 2400 2401 2402 2403 Last Page 2399 of 2429
