Hi to all.. Maybe a beginner's question: How to configure Maple to automatically execute a worksheet as soon as it is loaded? I use Maple 8 on Windows XP and don't want to do Edit/Execute worksheet. Maple is opened via an external batch file. Also, that worksheet produces a graphic file. How to modify the worksheet so that the graphic is automatically saved in a c:\Picture directory after being produced? Thanks for your kind help, Pierre
Hi, I am using Maple to carry out some structural analysis of a beam member. Now, i am facing with a programing problem and I need your help desperately. The beam member being studied can either be in tension or compression. Compressive or tensile reponses are governed by an equilibrium equation and whether or not this equation produces a valid solution. At first, the member is assumed to be in compression and compressive reponses lead to the equilibrium equation. If this equilirium equation does not produce any solutions then the initial assumption is incorrect and the tension case is considered. My problem starts here. I want to make the program switch automatically between compression and tension cases but I dont know how to construct the 'switching criteria' which is " the equilibrium equation does not produce any solution"..So my questions are:
I currently have some MathMLViewers in my maplet and I don't want them to have vertical scroll bar at all times. Does anyone know how to switch vertical scroll bar off for MathMLViewer? Also, is any way that I can have two windows dispaly at same time so I can change window focus by clicking window? Last question, is it possible to display multiple items in ListBox by using Set("ListBox_Name"('value') = blah, blah, blah); Looking forward for your respond, thank you. Tracy
Hi, All, I am calculating the staircase fraction ...............................1 ..........f(n) = 1 + ------------- .................................1 .......................2 + --------- ...................................1 ...........................3 + ----- ................................4 + x ........................................x ............................................x ................................................n (I have to use the dots to fill the space, all below input format deblank the front space) I have no idea on how to write a loop to calculate this.
Is there a link to download a demo copy of Maple 10? THanks!!
Hi there. I'm trying to make a 3d pointplot by calling an xyz .txt file. It's for a simulation I'm running in Maple, but with results that need to be viewed with gnuplot. It's simply easier to interact with the plot in Maple while I'm still building the code. The data looks something like below (okay, what you see isn't monospaced, so it doesn't line up as nicely as I had in the original post. You get the idea though - first number is x, the next is y, the other is the intensity): (x) (y) (intensity) #these titles aren't actually there 0 0 1 0 1 2 0 2 3
Is it possible for Maple to remove non-linear terms from an equation? I want to use taylors therom on F(V+v, S+s) and get the answer back without its non-linear terms. (N.B. V,S are constants and v,s are variable) cheers gillersuk
Hello, My name is Kostas and I am new in the forum. I am new in Matlab as well. I am trying to get some advice in executing a code that I found on a book "Numerical Methods using Matlab". The code is as follows: function [xo,fo] = opt_steep(f,x0,TolX,TolFun,alpha0,MaxIter) % minimize the function f by the steepest descent method. %input: f = ftn to be given as a string ’f’ % x0 = the initial guess of the solution %output: x0 = the minimum point reached % f0 = f(x(0)) if nargin < 6, MaxIter = 100; end %maximum # of iteration if nargin < 5, alpha0 = 10; end %initial step size if nargin < 4, TolFun = 1e-8; end %|f(x)| < TolFun wanted
How do I append lists? An example is a1:=[1,2,3]; a2:=[4,5,6]; Desired result is [1,2,3,4,5,6]. Now I a3:=[seq(a1[i],i=1..3),seq(a2[i],i=1..3)]; That is not very elegant. Also how do I find the dimension of a list? Like dimension(a1); 3
Hi again people, I have just another little quick question and that is if I graph two polynomial functions on an interval is there a way to find where the two polynomial intersect each other? Can it be done without graphing? Again I need accuracy to 3 decimal places. Thanks again.
Hi people, I am actually taking a maple practice test and am wondering how would I go about doing a higher order derivative of this function. f(x) = sin(x^2/(x^10+2))*e^(2*x) I would like to find the 8th deriavtive at x = 0 to 3 decimal places. The answer is 112.000 but i would still like to know how to solve it as in the real test there will be one just like it. If someone could give the algorithm that i would put it in that would be great. Used the help feature but it was not all that helpful. Thanks in advance. Tabish
Before I upgraded, I would input Δx:=2 and Δx would be a single variable. Now I input Δx:=2 and I get "Error, illegal use of an object as a name" If I input Δx [enter] it returns Δ x as though they are multiplied. How do I input greek-alpha combo variables again? Thanks for any help. BE
Hi, I have a problem with fit parameters restrictions. I would like to give restrictions of the parameters of my fit in order to get the best fit parameters, but the "parameterranges" seems to be not in function. my function is following: > y1 := piecewise(0 <><>
I'm trying to write a document in Maple 10 that includes some ODEs. I want these to be either text or math inputted in the form dV/dt = V [f(S)-r] (where V is a function depending on t and f is a function dependent on S that I want to introduce later in the document). It would be good if they could be inputted in math form so that they have labels but ideally i want them in a clear non-Maple form like above rather than somthing like V'(x)= V(x)*[f(S) - r] which is what I keep getting (or other similar things like it including Maple solving V'(t) and outputting zero which is not at all what i need)
I am trying to use the subs command to take a general solution to a differential equation and apply some numerical values. I can't seem to get the system to recognize the values I am substituting for. Consider the following: m*diff(y(t),t,t)=-m*g+sigma*A*diff(y(t),t); (1) y(0)=h,D(y)(0)=0; (2) dsolve( {(1),(2)} ); (3) subs( {A=2,m=50},rhs((3)) ); Everything works fine. If, on the other hand I impose any kind of constraint on A or m in the original equation then the substitution fails (nothing happens). Clearly the system has tagged the value for A and m as something other than their original name. Since the system doesn't report this name change how can I make substitutions after a symbolic manipulation like this?
First 2396 2397 2398 2399 2400 2401 2402 Last Page 2398 of 2429
