Is there a special command in Maple (whatever the version) which returns all functions available?
ex: ?*sol* which at least will return solve,dsolve etc.
Thank you and kind regards to everyone.
Jean-Michel
As I was numerically investigating this recent question I incidentally discovered a strange behaviour of Maple 2015 (which maybe exists in more recent versions?)
The attached worksheet presents an erratic behaviour (plus a remanance isssue because saving it, and opening it again changes the displays).
Note that this strange behaviour seems to occur only when tickmarks use the atomic name `#mo("2")`.
display_issue.mw
Here is a pdf print of this same worksheet: as I hope you will see (because I don't know what you are about to see when opening the attached worksheet) its content differs from the worksheet's.
display_issue.pdf
Here are 3 screen captures which show what MY worksheet looks like
PAGE 1
PAGE 2
There is a typo in the comment below: read "void" instead of "coid", sorry for the mistake.
PAGE 3
Is this a Maple 2015 issue which has been fixed in earlier versions?
Is there a way to fix these issues?
The attached file "test" asks for the largest power of two contained as a factor in a term. This is easily solved using "simplify." How can this be achieved using factorization?
test.mw
I'm updating to Maple 2025. Are there any feature differences between Linux and Windows versions?
Thanks for the help with the recursion problem, here's a very challenging problem for the weekend ;-). It should be solvable in Maple, at least for examples. I only know of one very theoretical, unfinished solution that I'm still working on:
Given a closed convex curve in the Euclidean plane. It is multiply continuously differentiable, and the curvature is also continuous.
Then there are at least three pairs of points on the curve with the following property:
The tangents at the points of each pair are parallel to each other, and the curvatures are equal.
A lot of time i finded but i have a dubt about this why this is happen each time number of equation for finding parameter a_12 is 4 but this time is 28 which i thoght some thing must be mistake also the author of paper use  u=2(ln(f))_xx which is wronge and not satisfy but i try to find R which is strange again is not number contain parameter but is satisfy also in equation 14 i don't know each i is 2 or 1 or it can be i remain itself?
thanks for any help ?
t1.mw
According to the attached file "test" I would like to determine the limit of the function f(n,x) for n-->00 as an exercise. I'm asking for advice on using "rsolve". I also want to calculate the limit of sqrt((n/3))*f(n,x) for n-->00 using f(n,x) from the file "test". I also need help with this. (This isn't a school assignment ;-).)
test.mw
How can I upload and attach a file here?
Either a worksheet or a text file?
"Approximation of ODE's with Cubic Splines.mw"
or
package "ODECSplines.mpl"
I encountered this bizarre inconsistency issue that Maple18 generates different outputs when executing the same command:
test_res2:= factor( simplify( expand( value( subs( Perturbation_Sol, EQ_PX2_order_7 ) ) ) ) )
'EQ_PX2_order_7' is a rational expression in sin(i0), cos(i0), sin(uL), and cos(uL) with rational coefficient terms. It also has inert differentiation terms Diff( * , uL ).
'Perturbation_Sol' is a set of 171 elements in the form of 'parameter_name = expression'.
My goal is to check if substituting 'Perturbation_Sol' into 'EQ_PX2_order_7' yields 0. Since 'EQ_PX2_order_7' has inert differentiation terms, I've applied 'value' after using 'subs'. Then I apply 'expand', 'simplify', and 'factor' to reduce the result to the simplest form.
However, Maple18 generates different outputs when I just execute this repeatedly. Please see the worksheet "test.mw" for details. Any insight will be greatly appreciated! Also, I wonder if the same issue would happen when the worksheet is executed with newer versions of Maple.
EQN_SOL_test1.mla
test.mw
I encountered the problem with .m files originally. But MaplePrimes doesn't allow uploading .m files, so I had to save the expressions into the file "EQN_SOL_test1.mla", which is included in this question. Below we load the expressions from the .mla file first, and then save them into a .m file in order to recreate the problem that I encountered.
read "EQN_SOL_test1.mla":
# Load 'EQ_PX2_order_7' and 'Perturbation_Sol'
save
EQ_PX2_order_7,
Perturbation_Sol,
"EQN_SOL_test1_m.m";
# Save the expressions into a .m file
Now we demonstrate the inconsistency problem with .m files. Notice that Maple generates 3 possible outputs:
test_res2 := 0
test_res2 := -(1/4)*rho0^2*a0^2*Be^2*cos(uL)*J2re*R_earth^2*(5*cos(i0)^2*cos(uL)^2-7*cos(i0)^2-5*cos(uL)^2+4)/sha
test_res2 := -(1/8)*rho0^2*a0^2*Be^2*cos(uL)*J2re*R_earth^2*(5*cos(i0)^2*cos(uL)^2-7*cos(i0)^2-5*cos(uL)^2+4)/sha
The last 2 outputs cannot be reduced to 0 since 5*cos(i0)^2*cos(uL)^2-7*cos(i0)^2-5*cos(uL)^2+4 is nonzero as shown below.
plot3d( 5*cos(i0)^2*cos(uL)^2-7*cos(i0)^2-5*cos(uL)^2+4 , uL=0..2*Pi, i0=0..2*Pi );
read "EQN_SOL_test1_m.m":
length( EQ_PX2_order_7 );
939346
length( Perturbation_Sol );
2082306
numelems( Perturbation_Sol );
171
Perturbation_Sol[1..5];
# Just to give an example of what the elements in 'Perturbation_Sol' look like
{PX1[1] = 0, PX1[2] = 0, PX1[3] = -(1/4)*rho0*a0*Be, PX1[4] = (1/2)*rho0*a0*Be*WEra*cos(i0)-(3/16)*R_earth^2*a0*rho0*(3*cos(i0)^2-1)*J2re*Be/sha+(1/4)*Be*a0*rho0*X10[3]/sha, PX1[5] = (1/4)*rho0*a0*X10[4]*Be/sha-(1/256)*R_earth^4*a0*rho0*(163*cos(i0)^4-110*cos(i0)^2+19)*J2re^2*Be/sha^2+(3/16)*R_earth^2*a0*rho0*(3*cos(i0)^2-1)*J2re*Be*X10[3]/sha^2+(3/8)*cos(i0)*R_earth^2*WEra*a0*rho0*(3*cos(i0)^2-1)*J2re*Be/sha-(1/48)*Be^3*a0^3*rho0^3*s1/sha^2-(1/8)*Be*a0*rho0*X10[3]^2/sha^2-(1/2)*cos(i0)*WEra*a0*rho0*Be*X10[3]/sha-(1/16)*rho0*a0*(3*cos(i0)^2+1)*Be*WEra^2-(1/32)*Be^2*J2re*R_earth^2*a0^2*rho0^2*sin(i0)^2*sin(2*uL)/sha^2}
for j from 1 to 50 do
    test_res2:= factor( simplify( expand( value( subs( Perturbation_Sol, EQ_PX2_order_7 ) ) ) ) );
-(1/4)*rho0^2*a0^2*Be^2*cos(uL)*R_earth^2*J2re*(5*cos(uL)^2*cos(i0)^2-5*cos(uL)^2-7*cos(i0)^2+4)/sha
-(1/8)*rho0^2*a0^2*Be^2*cos(uL)*R_earth^2*J2re*(5*cos(uL)^2*cos(i0)^2-5*cos(uL)^2-7*cos(i0)^2+4)/sha
It seems that with .mla files the problem occurs in a different way! With "EQN_SOL_test1.mla", the outputs for all 50 iterations stay the same as
test_res2 := -(1/4)*rho0^2*a0^2*Be^2*cos(uL)*J2re*R_earth^2*(5*cos(i0)^2*cos(uL)^2-7*cos(i0)^2-5*cos(uL)^2+4)/sha               (A)
but they may all change to the following different result after retarting many times:
test_res2 := -(1/8)*rho0^2*a0^2*Be^2*cos(uL)*J2re*R_earth^2*(5*cos(i0)^2*cos(uL)^2-7*cos(i0)^2-5*cos(uL)^2+4)/sha               (B)
In particular, after a large number of test runs (i.e., open the file "test.mw", execute the worksheet, close the file, and repeat), the result (B) has only occured twice. The second appearance is saved here for you to view. Once you re-execute this worksheet, most likely all outputs below will change back to (A), and (B) will only reappear after a large number of reruns.
Download test.mw
Only for my understanding:
Why is the concatenation operator not working in this assignment on the righthand side
for i to 5 do
  x_ || i := x_ ||(i-1);
                           x_1 := x_0
                           x_2 := x_0
                           x_3 := x_0
                           x_4 := x_0
                           x_5 := x_0
Somehow i in (i-1) equals always 1
Why do I have to use
for i to 5 do
  x_ || i := cat(x_,i-1);
                           x_1 := x_0
                           x_2 := x_1
                           x_3 := x_2
                           x_4 := x_3
                           x_5 := x_4
I’m trying to simplify the results I obtained from two scenarios. In the first scenario, I have results labeled g1,g2,g3​, and in the second scenario, I have g_1, g_2, g_3​. The issue is that the expressions are quite lengthy, and I want to shorten them by identifying and substituting common sub-expressions.
Is there a method or syntax that can help me automatically detect repeated terms and substitute them with a variable to improve readability?
For example:
Let’s say:
x=2f+3d+4(d+h+k)j+f
y=1(d+h+k)+hf+4d
Here, the expression d+h+k appears in both x and y, so I can define a new variable:
A=d+h+k
and substitute it into the equations to make them more concise and readable.
Attaching the sheet: Difference_two_model.mw
Historically, when the Maple program is open and I double-click on a Maple document in my file manager (Windows), the document appears in a new tab of the open program.
With version 2025.0, I performed a completely clean install, deleting files and inheriting no properties from 2024. Now, when I repeat this process, a new window/program is created with the document appearing there. The document does not appear in another tab of the original window/program. Changing the option of sharing the same Maple math engine does not affect this unexpected behavior.
Do others observe this behavior? Is there an option in one of the "Maple.ini" files that I could change? Or is this a bug?
I should note that this behavior is identical on multiple Windows 11 machines. The 2nd one was not a clean install.
I am looking for an efficient code that calculates all partitions of a positive integer n into parts >1. Example:
for n=8 the program should return
[2,6],[3,5],[4,4],[2,2,4],[2,3,3],[[2,2,2,2].
The program should be able to calculate these partitions for n=1..10000 in reasonable time
Who can help me?
I have functions using define_external to call a .dll  In uploaded file "dll_test.mw" I'm showing one such function.  Immediately after defining the function I call it and it works.  There are a lot more similarly defined functions and once defined in the worksheet they are working as hoped.
My question is can I make the functions avaliable across multiple worksheets somehow?  google ai suggested using "read" but in uploaded file "read and load test.mw" you can see that it's not working for me.  using read I get an error I don't understand and using load doesn't return an error but it also doesn't result in an executable KinAddCurveData function.
Any help would be very appreciated.
KinAddCurveData := define_external('AddCurveData', 'LIB' = "C:\\Users\\tom\\Documents\\Excel docs\\kinexa dll solver\\equilibriumdll\\Equilibrium.dll")
KinAddCurveData()
Download dll_test.mw
read "C:/Users/tom/Documents/maple docs/KinExA tools/dll_test.mw"
Error, on line %1, syntax error, character `?` unexpected:
<?xml version="1.0" encoding="UTF-8"?>
Error, while reading `%1`
load("C:/Users/tom/Documents/maple docs/KinExA tools/dll_test.mw")
KinAddCurveData()
KinAddCurveData()
jhdladjkh()
jhdladjkh()
Download read_and_load_test.mw
I ran the Fourier Transform about 6 months ago.
The out put was 23 lines long, and then used the Simplify/Simplify option for the result to obtain
, a relatively easier result.
I tried to re-run it today but it just gave me
with the result
Do you have any idea as to why this happens?? I seem to recall there may be similar “memory” problem
that occurred in the past.
First 24 25 26 27 28 29 30 Last Page 26 of 2429
