hallo every body
please can you help me
how do i solve this differential linear system with respect lambda is positive number
i use maple 18
Let the differential system with $\lambda>0$
\begin{equation}
\begin{array}{ccc}
\dot{x}=y(t)\\
\dot{y}=z(t)\\
\dot{z}=-\lambda y(t)-h(t)
\end{array}
\end{equation}
prob.pdf
Is there any chance to sort the array in maple and add the non-zero values? PFA the screenshot. I actually intend to add the non-zero values (leaving behind the dumX entries). How can I add the numerical values only?
I installed just today the 15-day trial version of Maple Flow.
I could get simple 2D plots of functions but did not succeeded in using fieldplot.
Does fieldplot() work in Maple Flow?
.Hello everybody
.In the attached code how I can compute \lambda2(t,s) and Vbar(s) symbolically
 when I run them, some parts can't be computed. how should I solve this problem?
2.mw
Question 1: Given: c^3 = 1000
How can I have MapleFlow 2022 solve for c?
I can do this manually, of course... by entering...
c=1000^1/3 =
But I haven't been able to figgure out how to have MapleFlow solve for "c" automatically.
Question 2: How to find the log to the base 10?
As it  seems the default is base e.
Question 3: What is antilog function for a given base?
Thanks for any help.
Why maple give empty solutions? See ref. (12) in the attached wokrsheet. Is there anything missing when deriving Sols?
sols_tw.mw
hi im currently doing my thesis and can somebody help me to develope the code? pls im stuck..
_local(I);
Digits := 15;
de1 := (1 - p)*(diff(S(t), t) + mu*S(t)) + p*(diff(S(t), t) + mu*S(t) + beta*S(t)*I(t) - rho*R(t) - varepsilon);
de2 := (1 - p)*(diff(E(t), t) + (alpha1 + mu)*E(t)) + p*(diff(E(t), t) + (alpha1 + mu)*E(t) - beta*S(t)*I(t));
de3 := (1 - p)*(diff(I(t), t) + (alpha2 + delta + mu)*I(t)) + p*(diff(I(t), t) + (alpha2 + delta + mu)*I(t) - alpha1*E(t));
de4 := (1 - p)*(diff(R(t), t) + (mu + rho)*R(t)) + p*(diff(R(t), t) + (mu + rho)*R(t) - alpha2*I(t));
ibvc := S(0) = 2304219, E(0) = 84929, I(0) = 299, R(0) = 71411;
sys1 := eval([de1, de2, de3, de4], p = 1);
dsolve(sys1);
sys0 := eval~(sys1, [{I = 0, R = 0}, {I = 0, S = 0}, {E = 0}, {I = 0}]);
sys_p := `*`~(1 - p, sys0) +~ `*`~(p, sys1);
ode1, ode2, ode3, ode4 := seq(sys_p[j], j = 1 .. 4);
ode1;
de1;
collect(expand(ode1 - de1), S(t), factor);
ode2 - de2;
ode3 - de3;
ode4 - de4;
mu := 0.133*10^(-5);
varepsilon := 0.99879;
delta := 0.004554;
beta := 0.1009*10^(-6);
alpha1 := 0.0008999;
alpha2 := 0.1997;
rho := 0.00090021;
res := dsolve({ibvc, ode1, ode2, ode3, ode4}, numeric, parameters = [p], abserr = 0.1*10^(-14), relerr = 0.1*10^(-12));
res(parameters = [0.5]);
res(50);
plots:-odeplot(res, [t, S(t)], 0 .. 100);
res(parameters = [1]);
Q := proc(p, {scene::list := [t, S(t)], range::range := 0 .. 100}) if not p::realcons then return 'procname(_passed)'; end if; res(parameters = [p]); plots:-odeplot(res, scene, range, _rest); end proc;
Q(0.5, color = blue);
plots:-animate(Q, [p, range = 0 .. 50], p = 0 .. 1, trace = 24);
n := 4;
s := unapply(add(g[k](t)*p^k, k = 0 .. n), t);
e := unapply(add(h[k](t)*p^k, k = 0 .. n), t);
i := unapply(add(i[k](t)*p^k, k = 0 .. n), t);
r := unapply(add(j[k](t)*p^k, k = 0 .. n), t);
Error, (in i[0]) too many levels of recursion
DE1 := series(eval(ode1, {E = e, I = i, R = r, S = s}), p = 0, n + 1);
DE2 := series(eval(ode2, {E = e, I = i, R = r, S = s}), p = 0, n + 1);
DE3 := series(eval(ode3, {E = e, I = i, R = r, S = s}), p = 0, n + 1);
DE4 := series(eval(ode4, {E = e, I = i, R = r, S = s}), p = 0, n + 1);
M := eval([ibvc], {E(0) = e(0), I(0) = i(0), R(0) = r(0), S(0) = s(0)});
I have say  I am taking for example purpose only i need in general
v:="1:1":
k:=4
printf("%s]  is %g, v, k)
Now i want the %s] part in some other color say green or red some dark color.
the %s is inside which need to replaced by the v which will keep coming
I want it for a general say for some part of the printf in some color
At present atleast i want
let F be a function say F(v,k) and it prints out
printf("%s]  is %g, v, k)  where it prints out the %s] part in dark color
I want to collect up the equation terms by the numerical value of the terms coefficient? Have tried sort collect combine...
So far the best I have come up with is nops(indets(on each term). And put them in seperate lists. This still doesn't quiet do the trick.
I am looking to achieve. Would to happy to have then as seperate lists or equations.
(a_1^5+a_2^5...)+5(a_1^4a_2+a_1^4a_3....)+10(a_1^3a_2^2 ....)+20(  ....   )+......+60(a_1^2a_2a_3a_4+ a_1a_2^2a_3a_4....)
pn := (a[1]+a[2]+a[3]+a[4])^5
pn1 := expand(pn)
a[1]^5+5*a[1]^4*a[2]+5*a[1]^4*a[3]+5*a[1]^4*a[4]+10*a[1]^3*a[2]^2+20*a[1]^3*a[2]*a[3]+20*a[1]^3*a[2]*a[4]+10*a[1]^3*a[3]^2+20*a[1]^3*a[3]*a[4]+10*a[1]^3*a[4]^2+10*a[1]^2*a[2]^3+30*a[1]^2*a[2]^2*a[3]+30*a[1]^2*a[2]^2*a[4]+30*a[1]^2*a[2]*a[3]^2+60*a[1]^2*a[2]*a[3]*a[4]+30*a[1]^2*a[2]*a[4]^2+10*a[1]^2*a[3]^3+30*a[1]^2*a[3]^2*a[4]+30*a[1]^2*a[3]*a[4]^2+10*a[1]^2*a[4]^3+5*a[1]*a[2]^4+20*a[1]*a[2]^3*a[3]+20*a[1]*a[2]^3*a[4]+30*a[1]*a[2]^2*a[3]^2+60*a[1]*a[2]^2*a[3]*a[4]+30*a[1]*a[2]^2*a[4]^2+20*a[1]*a[2]*a[3]^3+60*a[1]*a[2]*a[3]^2*a[4]+60*a[1]*a[2]*a[3]*a[4]^2+20*a[1]*a[2]*a[4]^3+5*a[1]*a[3]^4+20*a[1]*a[3]^3*a[4]+30*a[1]*a[3]^2*a[4]^2+20*a[1]*a[3]*a[4]^3+5*a[1]*a[4]^4+a[2]^5+5*a[2]^4*a[3]+5*a[2]^4*a[4]+10*a[2]^3*a[3]^2+20*a[2]^3*a[3]*a[4]+10*a[2]^3*a[4]^2+10*a[2]^2*a[3]^3+30*a[2]^2*a[3]^2*a[4]+30*a[2]^2*a[3]*a[4]^2+10*a[2]^2*a[4]^3+5*a[2]*a[3]^4+20*a[2]*a[3]^3*a[4]+30*a[2]*a[3]^2*a[4]^2+20*a[2]*a[3]*a[4]^3+5*a[2]*a[4]^4+a[3]^5+5*a[3]^4*a[4]+10*a[3]^3*a[4]^2+10*a[3]^2*a[4]^3+5*a[3]*a[4]^4+a[4]^5
els := convert({op(pn1)}, list)
[a[1]^5, a[2]^5, a[3]^5, a[4]^5, 5*a[1]*a[2]^4, 5*a[1]*a[3]^4, 5*a[1]*a[4]^4, 10*a[1]^2*a[2]^3, 10*a[1]^2*a[3]^3, 10*a[1]^2*a[4]^3, 10*a[1]^3*a[2]^2, 10*a[1]^3*a[3]^2, 10*a[1]^3*a[4]^2, 5*a[1]^4*a[2], 5*a[1]^4*a[3], 5*a[1]^4*a[4], 5*a[2]*a[3]^4, 5*a[2]*a[4]^4, 10*a[2]^2*a[3]^3, 10*a[2]^2*a[4]^3, 10*a[2]^3*a[3]^2, 10*a[2]^3*a[4]^2, 5*a[2]^4*a[3], 5*a[2]^4*a[4], 5*a[3]*a[4]^4, 10*a[3]^2*a[4]^3, 10*a[3]^3*a[4]^2, 5*a[3]^4*a[4], 20*a[1]*a[2]*a[3]^3, 20*a[1]*a[2]*a[4]^3, 30*a[1]*a[2]^2*a[3]^2, 30*a[1]*a[2]^2*a[4]^2, 20*a[1]*a[2]^3*a[3], 20*a[1]*a[2]^3*a[4], 20*a[1]*a[3]*a[4]^3, 30*a[1]*a[3]^2*a[4]^2, 20*a[1]*a[3]^3*a[4], 30*a[1]^2*a[2]*a[3]^2, 30*a[1]^2*a[2]*a[4]^2, 30*a[1]^2*a[2]^2*a[3], 30*a[1]^2*a[2]^2*a[4], 30*a[1]^2*a[3]*a[4]^2, 30*a[1]^2*a[3]^2*a[4], 20*a[1]^3*a[2]*a[3], 20*a[1]^3*a[2]*a[4], 20*a[1]^3*a[3]*a[4], 20*a[2]*a[3]*a[4]^3, 30*a[2]*a[3]^2*a[4]^2, 20*a[2]*a[3]^3*a[4], 30*a[2]^2*a[3]*a[4]^2, 30*a[2]^2*a[3]^2*a[4], 20*a[2]^3*a[3]*a[4], 60*a[1]*a[2]*a[3]*a[4]^2, 60*a[1]*a[2]*a[3]^2*a[4], 60*a[1]*a[2]^2*a[3]*a[4], 60*a[1]^2*a[2]*a[3]*a[4]]
add(els[i], i = 1 .. nops(els))
L1 := []; L2 := []; L3 := []; L4 := []; for i to nops(els) do if nops(indets(els[i])) = 1 then L1 := [op(L1), els[i]] elif nops(indets(els[i])) = 2 then L2 := [op(L2), els[i]] elif nops(indets(els[i])) = 3 then L3 := [op(L3), els[i]] else L4 := [op(L4), els[i]] end if end do; L1; L2; L3; L4
[60*a[1]*a[2]*a[3]*a[4]^2, 60*a[1]*a[2]*a[3]^2*a[4], 60*a[1]*a[2]^2*a[3]*a[4], 60*a[1]^2*a[2]*a[3]*a[4]]
indets(els[7])
{a[1], a[4]}
indets(els(5))
`~`[op](1 .. -1, L2)
[5, a[1], a[2]^4, 5, a[1], a[3]^4, 5, a[1], a[4]^4, 10, a[1]^2, a[2]^3, 10, a[1]^2, a[3]^3, 10, a[1]^2, a[4]^3, 10, a[1]^3, a[2]^2, 10, a[1]^3, a[3]^2, 10, a[1]^3, a[4]^2, 5, a[1]^4, a[2], 5, a[1]^4, a[3], 5, a[1]^4, a[4], 5, a[2], a[3]^4, 5, a[2], a[4]^4, 10, a[2]^2, a[3]^3, 10, a[2]^2, a[4]^3, 10, a[2]^3, a[3]^2, 10, a[2]^3, a[4]^2, 5, a[2]^4, a[3], 5, a[2]^4, a[4], 5, a[3], a[4]^4, 10, a[3]^2, a[4]^3, 10, a[3]^3, a[4]^2, 5, a[3]^4, a[4]]
op(2, L2[1])
a[1]
op(3, L2[1])
a[2]^4``
Download 30-7-22_Q_sort_equation_by_numerical_coeffs.mw
Why maple return trivial solution after integration (see (11) in the attached .mw))? The result should be some non-trivial solution.
solutionsg.mw
Hello everybody.
I wrote the attached code. this code gives a good result when "H" parameter is equal to 0.5. Even in this condition if I change other parameters, I can get a true result as well. But when I change "H" parameter to 0.6,0.7,0.8 or 0.9 the code can't be executed anymore and I can't get a result.
based on the paper, for H=0.6,0.7,0.8 or 0.9. we have a result.
what's the problem?
can anyone please help me to solve this problem?
thank you for your help in advance.
1.mw
I need your help to plot
1)   First:  a three dimensionl curve, that is plot F(X,Y), where X, Y, and F(X,y) is given
curve_three_d.mw
2) Second: can plot all the curves in the same graph ( 2-dimensional curve)  obtained from the following idea
for j from 0 by 5 to 40
plot( F(X,j), X)
end for
Need help to use DrawGraph to align vertices and edges and length etc for very large large size graph which i want to analyze
even if the graph even if it requires to writen to a file to make it more big and neatly visible.
kind kind help please it will be acknowledged
Program attached those cartesian product graphs are huge extra parameters and layouts and may others may be required to make such big big graphs visible. Kind help please.
Please help i am not that great on the stylesheet options please please help
Some kind of patterned way to set vertex positions for least crossings in grid form say I am trying but not able to achive kind help.
Any progression type loop based on size number of vertices et.
Graph_draw.mw
I am making good progress in getting Maple to do the simple tasks I need it to do, but there are a few things that I am unable to get looking the way I want. I have looked repeatedly for answers, but I have come up empty every time.
1. No Leading Zero: If I have a variable equal to 0.75, I want it to display as 0.75 not .75. This is not a problem when I do calculations, but when I, for example, display the value in a plot legend, I would like it to have a leading zero.
2. Scientific Notation Threshold: Is there a threshold defining when the display of a value changes from a regular decimal number to a number in scientific notation? For example, I have a number with a value of 0.0094, and I would like it to display (again, in a plot legend) as 0.0094, but it keeps coming out as .94e-2. Yes, it is the same value.
3. Scientific Notation Format: The number in #2 shows up as .94e-2, but it seems like it should be 9.4e-3. Am I missing something? It seems like I was always taught that the mantissa should be between 1 and 10, but Maple seems to want to give me a number between 0 and 1.
John
First 293 294 295 296 297 298 299 Last Page 295 of 2430
