i did a solution of this ODE equation but the solution of paper is different from mine also in other some equation i have same problem i can't get exactly and pretty solution
how  define a function for computing multi-variable adomian polynomial  what is wrong with this? what i did mistake
I have a function like
F[1] := (x, y) -> x*y/(1 + 10.35841093*(1 - x)*((-1)*0.9*x + 1)*(1 - y)*((-1)*0.9*y + 1))
This function is continuous on D = [0,1]x[0,1]. I'm interested in the (approximate) value of the double integral over D.
Unfortunately the entry
int(int(F[1](x,y),x=0..1.),y=0..1.)
produces Float(infinity).
Thanks Nicola
Dear Maple users Help me to  get the desire graph for this codes.
with(IntegrationTools):
h:=z->piecewise( z<=d+1,   1,
                 z<=d+4,   1-(delta/(2))(1 + cos(2(Pi)*(z - 1 - 1/2))),                                                           z<=d+6,   1 ):
w0:=(-c*h(z)^2/4)+(3/64)(b*c-4*a)*h(z)^4+(19/2304)*b(b-4*a)*h(z)^6:
w1:=(c/4)+(1/16)*(4*a-b*c)*h(z)^2:
w2:=(1/256)(4(b*c-4*a)-b*h(z)^2):
w3:=(1/2304)b(b-4*a):
a:=(x4*S*Gr)*sin(alpha)/(4*x1*x5):
b:=(1/Da)+(x3*M/(x1*(1+m^2))):
c:=(1/x1)*Dp:
Dp:=96*x1/((6-b*h(z)^2)h(z)^4)(F+(a*h(z)/24)-((11/6144)b(b-4*a)*h(z)^8)):
x1:=1/((1-phi1)^2.5*(1-phi2)^2.5):
x2:=(1-phi2)((1-phi1)+phi1*Rs1/Rf)+phi2(Rs2/Rf):
x3:=(shnf)/(sf):
x4:=(1-phi2)((1-phi1)+phi1(RBs1)/(RBf))+phi2*((RBs2)/(RBf)):
x5:=khnf/kf:
shnf:=sbf*((ss2+2*sbf-2*phi2*(sbf-ss2))/(ss2+2*sbf+phi2*(sbf-ss2))):
sbf:=sf*((ss1+2*sf-2*phi1*(sf-ss1))/(ss1+2*sf+phi1*(sf-ss1))):
khnf:=kbf*((ks2+2*kbf-2*phi2*(kbf-ks2))/(ks2+2*kbf+phi2*(kbf-ks2))):
kbf:=kf*((ks1+2*kf-2*phi1*(kf-ks1))/(ks1+2*kf+phi1*(kf-ks1))):
RBs1:=(8933*16.7*10^6):
RBf:=(1063*1.8*10^6):
RBs2:=6320*18*10^6:
kf:=0.492:
sbf:=6.67*10^(-1): ss2:=2.7*10^(-8):
sf:=6.67*10^(-1):ss1:=59.6*10^(6):
ks2:=76.5:kf:=0.492: ks1:=401:
phi1:=0.01: phi2:=0.02:alpha:=Pi/4:m:=0.5:Da:=0.1:Gr:=5:delta:=1:S:=0.5:  d:=1:
W1:=w0+w1*r^2+w2*r^4+w3*r^6:
by varing M =2,5,7 and r varies from 0 to 1 i want this type of graphs.  please see the sample graphs
Why Maple return 0 when I try to find coefficients of different power of lambda's.coeff.mw
I need to check if Maple can solve a specific PDE. Since I don't know much about the PDEtools package, I wonder if a user familiar with it and experienced in solving PDEs could help me.
with(PDEtools);
declare(u(x,y,z,w));
PDE1:=alpha*(y+b*(w))*diff(u(x,y,z,w),x)+(x+z-b*(w))*diff(u(x,y,z,w),y)-c*y*diff(u(x,y,z,w),z)+d*(y-x)*diff(u(x,y,z,w),w)=0;
Sol1:=pdsolve(PDE1);
Maple returns NULL as the solution. Any ideas on how to obtain a solution, if possible? In other similar PDEs, u(x,y,w,z) has a quadratic form.
Many thanks,
When you look at negative horiztonal values on a basic plot, the axis labels can be obscured by gridlines or the plot itself. I have been told many times to keep axis labels and gradation labels outside of the plotting area to avoid adding more information than is neccessary in the actual plotting area. Is there a way to move the label to the other side and rotate it by 180 degree? How do people normally deal with this issue?
See my example of how the axis labels can be obscured by gridlines.
axis_label_on_wrong_side_of_axis.mw
Hi all guys, first I would express my gratitude to @mmcdara . He helped me construct the matrix polynomial properly. Then on basis of it, I explore more but meet with issues. Notation : v1 and v2 is eigenvalues which consists of complicated expression containg component v and z, now I wanna implicitplot the region: abs(v1)<=1 & abs(v2)<=1 (satisfy at the same time). But I don't know how to command the code. So I define eq1:=( abs(v1)-1)* (abs(v2)<=1) and implicit it. (I know it is false but I just wanna try first). But I command the implicitplot code, the evaluating time is so long(25mins no end still). So I recall the smartplot, I once I have triggered this command, it seems that I put the mouse on the expression result (the end of the blue font), and implicit3d appears in the work bar on the right (of course this is in another file). In the file I uploaded, I tried this but failed. So I want to understand how to ensure that smartplot is triggered 100%? (Because I feel that smartplot runs very fast) and how to draw the desired region (abs(v1)<=1 & abs(v2)<=1)?
v=lambda*h;
z=mu*h;
k=lambda/mu;
v = lambda*h
z = mu*h
k = lambda/mu
A := Matrix([[0, 0, 0], [-(cos(alpha*v)-1)/v^2, 0, 0], [0, -(cos(beta*v)-1)/(cos(alpha*v)*v^2), 0]]);
Matrix(3, 3, {(1, 1) = 0, (1, 2) = 0, (1, 3) = 0, (2, 1) = -(cos(alpha*v)-1)/v^2, (2, 2) = 0, (2, 3) = 0, (3, 1) = 0, (3, 2) = -(cos(beta*v)-1)/(cos(alpha*v)*v^2), (3, 3) = 0})
C := Matrix([0, alpha, -beta])
Vector[row](3, {(1) = 0, (2) = alpha, (3) = -beta})
e := Vector(3, 1)
Vector(3, {(1) = 1, (2) = 1, (3) = 1})
E := IdentityMatrix(3)
Matrix(3, 3, {(1, 1) = 1, (1, 2) = 0, (1, 3) = 0, (2, 1) = 0, (2, 2) = 1, (2, 3) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 1})
G := Matrix([[0], [sin(alpha*v)/(alpha*v)], [((sin(beta*v)*cos(alpha*v)+sin(alpha*v)*cos(beta*v)-sin(alpha*v)))/(v*cos(alpha*v)*(beta))]])
Vector(3, {(1) = 0, (2) = sin(alpha*v)/(alpha*v), (3) = (sin(beta*v)*cos(alpha*v)+sin(alpha*v)*cos(beta*v)-sin(alpha*v))/(v*cos(alpha*v)*beta)})
b := Vector(3, [1/24, (-sin(beta*v)*v^3+12*cos(beta*v)*v^2+24*cos(beta*v)*cos(v)-24*sin(beta*v)*sin(v)+24*sin(beta*v)*v-24*cos(beta*v))/(24*v^3*(cos(beta*v)*sin(alpha*v)+sin(beta*v)*cos(alpha*v))), -(sin(alpha*v)*v^3+12*cos(alpha*v)*v^2+24*cos(v)*cos(alpha*v)+24*sin(v)*sin(alpha*v)-24*v*sin(alpha*v)-24*cos(alpha*v))/(24*v^3*(cos(beta*v)*sin(alpha*v)+sin(beta*v)*cos(alpha*v)))])
Vector(3, {(1) = 1/24, (2) = (1/24)*(-sin(beta*v)*v^3+12*cos(beta*v)*v^2+24*cos(beta*v)*cos(v)-24*sin(beta*v)*sin(v)+24*sin(beta*v)*v-24*cos(beta*v))/(v^3*(sin(beta*v)*cos(alpha*v)+sin(alpha*v)*cos(beta*v))), (3) = -(1/24)*(sin(alpha*v)*v^3+12*cos(alpha*v)*v^2+24*cos(v)*cos(alpha*v)+24*sin(v)*sin(alpha*v)-24*v*sin(alpha*v)-24*cos(alpha*v))/(v^3*(sin(beta*v)*cos(alpha*v)+sin(alpha*v)*cos(beta*v)))})
bp := Vector(3, [1/12, -(sin(beta*v)*v^2+12*cos(beta*v)*sin(v)-12*cos(beta*v)*v+12*cos(v)*sin(beta*v)-12*sin(beta*v))/(12*v^2*(cos(beta*v)*sin(alpha*v)+sin(beta*v)*cos(alpha*v))), -(sin(alpha*v)*v^2+12*cos(v)*sin(alpha*v)-12*cos(alpha*v)*sin(v)+12*cos(alpha*v)*v-12*sin(alpha*v))/(12*v^2*(cos(beta*v)*sin(alpha*v)+sin(beta*v)*cos(alpha*v)))])
Vector(3, {(1) = 1/12, (2) = -(1/12)*(sin(beta*v)*v^2+12*cos(beta*v)*sin(v)-12*cos(beta*v)*v+12*cos(v)*sin(beta*v)-12*sin(beta*v))/(v^2*(sin(alpha*v)*cos(beta*v)+sin(beta*v)*cos(alpha*v))), (3) = -(1/12)*(sin(alpha*v)*v^2+12*cos(v)*sin(alpha*v)-12*cos(alpha*v)*sin(v)+12*cos(alpha*v)*v-12*sin(alpha*v))/(v^2*(sin(alpha*v)*cos(beta*v)+sin(beta*v)*cos(alpha*v)))})
L0 := E + z^2 *~ A
Matrix(3, 3, {(1, 1) = 1, (1, 2) = 0, (1, 3) = 0, (2, 1) = -z^2*(cos(alpha*v)-1)/v^2, (2, 2) = 1, (2, 3) = 0, (3, 1) = 0, (3, 2) = -z^2*(cos(beta*v)-1)/(cos(alpha*v)*v^2), (3, 3) = 1})
L1 := simplify(L0^(-1))
Matrix(3, 3, {(1, 1) = 1, (1, 2) = 0, (1, 3) = 0, (2, 1) = z^2*(cos(alpha*v)-1)/v^2, (2, 2) = 1, (2, 3) = 0, (3, 1) = z^4*(cos(beta*v)-1)*(1-sec(alpha*v))/v^4, (3, 2) = z^2*(cos(beta*v)-1)*sec(alpha*v)/v^2, (3, 3) = 1})
AUX := simplify(L1 . G . C . e, size)
Vector(3, {(1) = 0, (2) = sin(alpha*v)*(alpha-beta)/(alpha*v), (3) = -((z^2*beta*sec(alpha*v)*(cos(beta*v)-1)*sin(alpha*v)+v^2*alpha*sin(beta*v))*cos(alpha*v)+sin(alpha*v)*alpha*v^2*(cos(beta*v)-1))*(-alpha+beta)/(v^3*alpha*cos(alpha*v)*beta)})
N1 := simplify((1 - z^2/2) + z^4 * (b^+ . AUX), size)
(1/24)*(z^4*(cos(beta*v)-1)*(v^3-24*v+24*sin(v))*(-alpha+beta)*(sec(alpha*v)*z^2*beta*cos(alpha*v)+v^2*alpha)*sin(alpha*v)^2-12*(-sec(alpha*v)*z^6*beta*(cos(beta*v)-1)*(v^2+2*cos(v)-2)*(-alpha+beta)*cos(alpha*v)+((2*z^4*(-alpha+beta)^2*cos(v)+(-alpha+beta)^2*(v^2-2)*z^4+v^4*z^2*beta*alpha-2*v^4*beta*alpha)*cos(beta*v)-(1/12)*(-alpha+beta)*z^4*((v^3-24*v+24*sin(v))*(beta+alpha)*sin(beta*v)-12*alpha*(v^2+2*cos(v)-2)))*v^2)*cos(alpha*v)*sin(alpha*v)-12*sin(beta*v)*(-2*(-alpha+beta)*z^4*cos(v)-(v^2-2)*(-alpha+beta)*z^4+v^4*z^2*beta-2*v^4*beta)*v^2*alpha*cos(alpha*v)^2)/(v^6*(sin(alpha*v)*cos(beta*v)+sin(beta*v)*cos(alpha*v))*alpha*cos(alpha*v)*beta)
N2 := simplify(1 - z^2 * (b^+ . L1 . e), size)
(1/24)*((12*z^4*(v-z)*(v+z)*(v^2+2*cos(v)-2)*(sec(alpha*v)-1)*cos(beta*v)-12*z^4*(v-z)*(v+z)*(v^2+2*cos(v)-2)*sec(alpha*v)-(-24*z^4*sin(v)+(-v^3+24*v)*z^4+v^5*z^2-24*v^5)*v^2*sin(beta*v)+12*z^2*(v-z)*(v+z)*(v^2+z^2)*(v^2+2*cos(v)-2))*cos(alpha*v)+(sin(alpha*v)*z^4*(v-z)*(v+z)*(v^3-24*v+24*sin(v))*sec(alpha*v)+(24*z^6*sin(v)+(v^3-24*v)*z^6-v^7*z^2+24*v^7)*sin(alpha*v)-12*v^2*z^2*(v-z)*(v+z)*(v^2+2*cos(v)-2))*cos(beta*v)+(v^3-24*v+24*sin(v))*(-sin(alpha*v)*z^2*sec(alpha*v)+(v^2+z^2)*sin(alpha*v)+sin(beta*v)*v^2)*z^2*(v+z)*(v-z))/(v^7*(sin(alpha*v)*cos(beta*v)+sin(beta*v)*cos(alpha*v)))
N3 := simplify(-z^2 + z^4 * (bp^+ . AUX), size)
-(-(1/12)*z^2*(cos(beta*v)-1)*(v^2+12*cos(v)-12)*(-alpha+beta)*(sec(alpha*v)*z^2*beta*cos(alpha*v)+v^2*alpha)*sin(alpha*v)^2+(-sec(alpha*v)*z^4*beta*(cos(beta*v)-1)*(-alpha+beta)*(v-sin(v))*cos(alpha*v)+((-z^2*(-alpha+beta)^2*sin(v)+(z^2*(-alpha+beta)^2+v^2*beta*alpha)*v)*cos(beta*v)-(1/12)*(-alpha+beta)*z^2*((v^2+12*cos(v)-12)*(beta+alpha)*sin(beta*v)-12*alpha*(v-sin(v))))*v^2)*cos(alpha*v)*sin(alpha*v)+sin(beta*v)*((-alpha+beta)*z^2*sin(v)+v*((alpha-beta)*z^2+v^2*beta))*v^2*alpha*cos(alpha*v)^2)*z^2/(v^5*(sin(alpha*v)*cos(beta*v)+sin(beta*v)*cos(alpha*v))*alpha*cos(alpha*v)*beta)
(14)
N4 := simplify(1 - z^2 * (bp^+ . L1 . e), size):
alpha:= 1/2 + 1/10*sqrt(5);
beta:= -1/2 + 1/10*sqrt(5);
det := simplify(N1*N4 - N2*N3, size):
tr := simplify(N1 + N4, size):
#eq1:=algsubs(v=lambda*h,det):
#eq2:=algsubs(z=mu*h,eq1):
#eq3:=algsubs(lambda=mu*k,eq2):
#eq4:=algsubs(v=lambda*h,eq3):
#csgn(sqrt(mu^10*k^10/v^10)*h^5):=1:
#simplify(series(sqrt(eq4),h,10));
#series(simplify(algsubs(v=,simplify(series(1-sqrt(det),z,8)))),z,8);
#eq1:=(sec(sqrt(5)*z/10)*(-cos(z/2)*z + 12*sin(z/2)) - 5*z)/(24*z*k);
#simplify(eq1);
1/2+(1/10)*5^(1/2)
-1/2+(1/10)*5^(1/2)
(15)
lambda1 := (tr-sqrt(tr^2-4*det))*(1/2); lambda2 := (tr+sqrt(tr^2-4*det))*(1/2)
with(plots); with(plots, implicitplot)
eq11 := lambda1*lambda2-abs(lambda1)-abs(lambda2)+1 <= 0
Download 2d_implicit_plot_[v_z].mw
How to get remainder of this two polynomials?
with(Algebraic);
Remainder(a*x^3 + b*x^2 + c*x + d, 3*a*x^2 + 2*b*x + c, x);
I am trying to improve the positioning of the gammas in the diagram (at bottom) as they are too close to the points and lines. gamma1 and gamma2 have been assigned values. This best I could come up with is shown below.
with(plots):with(plottools):
with(Typesetting):
`gamma2`:=<3|5|2>
Vector[row](3, {(1) = 3, (2) = 5, (3) = 2})
Pgamma2:=[3/2,5/2]
[3/2, 5/2]
display(point(Pbeta2,symbol=solidcircle,symbolsize=14),textplot([Pgamma2[],Typeset((`gamma2` )),align={above}]))
Download 2024-07-10_Typeset_gamma.mw
I am trying to solve some PDEs using Maple.  In one of them, Maple returns
SolL:= HL(x, y, z) = f__1(1/2*(2*sigma*z - x^2)/sigma, rho^2 - 2*rho*z + y^2 + z^2)
How to retrieve only the arguments of f__1?
Many thanks
I think the question speaks for itself. I tried the search engine and he bring me one link on that subject. But when I click on it, he sent me inside many answers on everyting but that. Not even the right month. So that is why I am asking here again. Of course, I would like to keep the thickmarks and the labels on both axes. Thank you in advance for your help.
The change from _C1 to c__1 is causing me so many problems as I still do not fully understand it.
I have nothing in my Maple ini file.
I was solving from a solution to an ode for the constant of integration, which I know is c__1 inside a proc.
But this was failing to solve for it. When I copy same code to global (worksheet), it works. So it is clearly issue of name space related to c__1 vs. _C1.
So even though the solution now has the subscripted version and not the traditional one (since that is the default now), it does not solve for it when inside a proc.
If instead I solve for _C1, then it works. Even though the solution has c__1. This is bizzar to me.
I also tried adding   global c__1; inside the proc, but this did not help. (did not show this version in the worksheet).
Why is solving for c__1 fail inside a proc but works outside? Clearly the c__1 in the solution of the ode is not the same c__1 I typed in to solve for, even though on the screen they look the same.
So c__1 is not really the same as _C1 in all aspects. Right?
Here is worksheet. Example 1 below shows how it fails inside proc
Maple 2024.1. Does this happen for others on Linux or the Mac?
`The "Physics Updates" version in the MapleCloud is 1767 and is the same as the version installed in this computer, created 2024, June 28, 12:19 hours Pacific Time.`
Example (1) solving for constant of integration fails inside proc but works outside
foo:=proc(ode::`=`)
local sol,the_constant;
   sol:=dsolve(ode);
   print("sol is ",sol);
   the_constant:=solve(sol,c__1);
   print("the constant is ",the_constant);
proc (ode::`=`) local sol, the_constant; sol := dsolve(ode); print("sol is ", sol); the_constant := solve(sol, c__1); print("the constant is ", the_constant) end proc
#this does not work
ode:=diff(y(x),x) = 3/4*y(x)/x;
foo(ode)
diff(y(x), x) = (3/4)*y(x)/x
"sol is ", y(x) = c__1*x^(3/4)
"the constant is "
#this works
sol:=dsolve(ode);
y(x) = c__1*x^(3/4)
y(x)/x^(3/4)
Example (2). Solving for _C1 works, even though the ode has c__1  , why??
foo:=proc(ode::`=`)
   sol:=dsolve(ode);
   the_constant:=solve(sol,_C1);  #notice solving for _C1 now
proc (ode::`=`) local sol, the_constant; sol := dsolve(ode); print("sol is ", sol); the_constant := solve(sol, _C1); print("the constant is ", the_constant) end proc
foo(ode)
"the constant is ", y(x)/x^(3/4)
sol:=dsolve(ode);
the_constant:=solve(sol,c__1); #these both work OK in global
the_constant:=solve(sol,_C1);  #these both work OK in global
y(x) = c__1*x^(3/4)
y(x)/x^(3/4)
y(x)/x^(3/4)
Example (3). Forcing arbitraryconstants = subscripted it still does not work inside proc. Why??
foo:=proc(ode::`=`)
   sol:=dsolve(ode,arbitraryconstants = subscripted);
proc (ode::`=`) local sol, the_constant; sol := dsolve(ode, arbitraryconstants = subscripted); print("sol is ", sol); the_constant := solve(sol, c__1); print("the constant is ", the_constant) end proc
foo(ode)
"the constant is "
Download constant_of_integration_solving_july_9_2024_maple_2024.mw
If I'm not mistaken Mapleprimes doesn't accept m files nor folders.
TIA
Hi all guys, when i am doing error analysis but I meet with an problem. I get the trace and determinant of one matrix which consists a lot trigonometric functions. I wanna get the approximation error order of trace and determinant (Like tr=2+O(v^6),det=1+O(v^6)). But I use Taylor expansion and series, it displays can't compute the series. How to know the other ways to get the error order of it? Thanks all !phase_error_try.mw
c[2] := 1/2+(1/10)*sqrt(5); c[3] := 1/2-(1/10)*sqrt(5)
1/2+(1/10)*5^(1/2)
1/2-(1/10)*5^(1/2)
with(LinearAlgebra)
A := Matrix([[0, 0, 0], [-(cos((1/10)*(5+sqrt(5))*v)-1)/v^2, 0, 0], [0, -(cos((1/10)*(-5+sqrt(5))*v)-1)/(cos((1/10)*(5+sqrt(5))*v)*v^2), 0]])
C := Matrix([0, 1/2+(1/10)*sqrt(5), 1/2-(1/10)*sqrt(5)])
Matrix(%id = 36893490461606184468)
e := Matrix([[1], [1], [1]])
Matrix(%id = 36893490461606180252)
E := Matrix([[1, 0, 0], [0, 1, 0], [0, 0, 1]])
Matrix(%id = 36893490461606177116)
G := Matrix([[0], [10*sin((1/10)*(5+sqrt(5))*v)/((5+sqrt(5))*v)], [(10*(sin((1/10)*(-5+sqrt(5))*v)*cos((1/10)*(5+sqrt(5))*v)+sin((1/10)*(5+sqrt(5))*v)*cos((1/10)*(-5+sqrt(5))*v)-sin((1/10)*(5+sqrt(5))*v)))/(v*cos((1/10)*(5+sqrt(5))*v)*(-5+sqrt(5)))]])
b := Matrix([1/24, (-sin((1/10)*v*(-5+sqrt(5)))*v^3+12*cos((1/10)*v*(-5+sqrt(5)))*v^2+24*cos((1/10)*v*(-5+sqrt(5)))*cos(v)-24*sin((1/10)*v*(-5+sqrt(5)))*sin(v)+24*sin((1/10)*v*(-5+sqrt(5)))*v-24*cos((1/10)*v*(-5+sqrt(5))))/(24*v^3*(cos((1/10)*v*(-5+sqrt(5)))*sin((1/10)*v*(5+sqrt(5)))+sin((1/10)*v*(-5+sqrt(5)))*cos((1/10)*v*(5+sqrt(5))))), -(sin((1/10)*v*(5+sqrt(5)))*v^3+12*cos((1/10)*v*(5+sqrt(5)))*v^2+24*cos(v)*cos((1/10)*v*(5+sqrt(5)))+24*sin(v)*sin((1/10)*v*(5+sqrt(5)))-24*v*sin((1/10)*v*(5+sqrt(5)))-24*cos((1/10)*v*(5+sqrt(5))))/(24*v^3*(cos((1/10)*v*(-5+sqrt(5)))*sin((1/10)*v*(5+sqrt(5)))+sin((1/10)*v*(-5+sqrt(5)))*cos((1/10)*v*(5+sqrt(5)))))])
bp := Matrix([1/12, -(sin((1/10)*v*(-5+sqrt(5)))*v^2+12*cos((1/10)*v*(-5+sqrt(5)))*sin(v)-12*cos((1/10)*v*(-5+sqrt(5)))*v+12*cos(v)*sin((1/10)*v*(-5+sqrt(5)))-12*sin((1/10)*v*(-5+sqrt(5))))/(12*v^2*(cos((1/10)*v*(-5+sqrt(5)))*sin((1/10)*v*(5+sqrt(5)))+sin((1/10)*v*(-5+sqrt(5)))*cos((1/10)*v*(5+sqrt(5))))), -(sin((1/10)*v*(5+sqrt(5)))*v^2+12*cos(v)*sin((1/10)*v*(5+sqrt(5)))-12*cos((1/10)*v*(5+sqrt(5)))*sin(v)+12*cos((1/10)*v*(5+sqrt(5)))*v-12*sin((1/10)*v*(5+sqrt(5))))/(12*v^2*(cos((1/10)*v*(-5+sqrt(5)))*sin((1/10)*v*(5+sqrt(5)))+sin((1/10)*v*(-5+sqrt(5)))*cos((1/10)*v*(5+sqrt(5)))))])
L1 := 1/simplify(E+v^2.A); N1 := simplify(1-(1/2)*v^2+v^4*(b.L1.G.C.e)); N11 := (Typesetting[delayDotProduct](sin((1/10)*v*(5+sqrt(5)))*((v^3-24*v+24*sin(v))*sin((1/10)*v*(5+sqrt(5)))+12*cos((1/10)*v*(5+sqrt(5)))*(v^2+2*cos(v)-2))*(-5+sqrt(5)), v^2.((cos((1/10)*v*(-5+sqrt(5)))-1)*sec((1/10)*v*(5+sqrt(5)))/v^2), true)+((cos((1/10)*v*(-5+sqrt(5)))-1)*(v^3-24*v+24*sin(v))*(5+sqrt(5))*tan((1/10)*v*(5+sqrt(5)))+(96*v^2+240*cos(v)-192)*cos((1/10)*v*(-5+sqrt(5)))+2*sqrt(5)*(v^3-24*v+24*sin(v))*sin((1/10)*v*(-5+sqrt(5)))-(12*(v^2+2*cos(v)-2))*(5+sqrt(5)))*sin((1/10)*v*(5+sqrt(5)))+12*cos((1/10)*v*(5+sqrt(5)))*sin((1/10)*v*(-5+sqrt(5)))*(-6+(v^2+2*cos(v)-2)*sqrt(5)+3*v^2+10*cos(v)))/(48*sin((1/10)*v*(-5+sqrt(5)))*cos((1/10)*v*(5+sqrt(5)))+48*sin((1/10)*v*(5+sqrt(5)))*cos((1/10)*v*(-5+sqrt(5))))
Matrix(%id = 36893490461639877084)
N2 := simplify(1-v^2*b.L1.e); N22 := (Typesetting[delayDotProduct](((12*v^2+24*cos(v)-24)*cos((1/10)*(5+sqrt(5))*v)+(v^3-24*v+24*sin(v))*sin((1/10)*(5+sqrt(5))*v))*(v^2.((cos((1/10)*(5+sqrt(5))*v)-1)/v^2)+1), v^2.((cos((1/10)*(-5+sqrt(5))*v)-1)*sec((1/10)*(5+sqrt(5))*v)/v^2), true)+Typesetting[delayDotProduct]((-12*v^2-24*cos(v)+24)*cos((1/10)*(-5+sqrt(5))*v)+sin((1/10)*(-5+sqrt(5))*v)*(v^3-24*v+24*sin(v)), v^2.((cos((1/10)*(5+sqrt(5))*v)-1)/v^2), true)+((-v^3+24*v)*sin((1/10)*(-5+sqrt(5))*v)+12*v^2+24*cos(v)-24)*cos((1/10)*(5+sqrt(5))*v)+((-v^3+24*v)*cos((1/10)*(-5+sqrt(5))*v)+v^3-24*v+24*sin(v))*sin((1/10)*(5+sqrt(5))*v)+(-12*v^2-24*cos(v)+24)*cos((1/10)*(-5+sqrt(5))*v)+sin((1/10)*(-5+sqrt(5))*v)*(v^3-24*v+24*sin(v)))/(24*v*(sin((1/10)*(-5+sqrt(5))*v)*cos((1/10)*(5+sqrt(5))*v)+sin((1/10)*(5+sqrt(5))*v)*cos((1/10)*(-5+sqrt(5))*v)))
Matrix(%id = 36893490461606200972)
N3 := simplify(-v^2+v^4*bp.L1.G.C.e); N33 := v*(Typesetting[delayDotProduct](((v^2+12*cos(v)-12)*sin((1/10)*(5+sqrt(5))*v)+12*cos((1/10)*(5+sqrt(5))*v)*(v-sin(v)))*sin((1/10)*(5+sqrt(5))*v)*(-5+sqrt(5)), v^2.((cos((1/10)*(-5+sqrt(5))*v)-1)*sec((1/10)*(5+sqrt(5))*v)/v^2), true)+((cos((1/10)*(-5+sqrt(5))*v)-1)*(v^2+12*cos(v)-12)*(5+sqrt(5))*tan((1/10)*(5+sqrt(5))*v)+(96*v-120*sin(v))*cos((1/10)*(-5+sqrt(5))*v)+2*sqrt(5)*(v^2+12*cos(v)-12)*sin((1/10)*(-5+sqrt(5))*v)-(12*(5+sqrt(5)))*(v-sin(v)))*sin((1/10)*(5+sqrt(5))*v)+12*cos((1/10)*(5+sqrt(5))*v)*sin((1/10)*(-5+sqrt(5))*v)*((v-sin(v))*sqrt(5)+3*v-5*sin(v)))/(24*cos((1/10)*(5+sqrt(5))*v)*sin((1/10)*(-5+sqrt(5))*v)+24*sin((1/10)*(5+sqrt(5))*v)*cos((1/10)*(-5+sqrt(5))*v))
Matrix(%id = 36893490461733603676)
N4 := simplify(1-v^2*bp.L1.e); N44 := (Typesetting[delayDotProduct](((v^2+12*cos(v)-12)*sin((1/10)*(5+sqrt(5))*v)+12*cos((1/10)*(5+sqrt(5))*v)*(v-sin(v)))*(v^2.((cos((1/10)*(5+sqrt(5))*v)-1)/v^2)+1), v^2.((cos((1/10)*(-5+sqrt(5))*v)-1)*sec((1/10)*(5+sqrt(5))*v)/v^2), true)+Typesetting[delayDotProduct]((v^2+12*cos(v)-12)*sin((1/10)*(-5+sqrt(5))*v)-12*cos((1/10)*(-5+sqrt(5))*v)*(v-sin(v)), v^2.((cos((1/10)*(5+sqrt(5))*v)-1)/v^2), true)+(-cos((1/10)*(-5+sqrt(5))*v)*v^2+v^2+12*cos(v)+12*cos((1/10)*(-5+sqrt(5))*v)-12)*sin((1/10)*(5+sqrt(5))*v)+(-sin((1/10)*(-5+sqrt(5))*v)*v^2+12*v-12*sin(v)+12*sin((1/10)*(-5+sqrt(5))*v))*cos((1/10)*(5+sqrt(5))*v)+(v^2+12*cos(v)-12)*sin((1/10)*(-5+sqrt(5))*v)-12*cos((1/10)*(-5+sqrt(5))*v)*(v-sin(v)))/(12*sin((1/10)*(-5+sqrt(5))*v)*cos((1/10)*(5+sqrt(5))*v)+12*sin((1/10)*(5+sqrt(5))*v)*cos((1/10)*(-5+sqrt(5))*v))
Matrix(%id = 36893490461606185188)
tr := N11+N44
det := N11*N44-N22*N33
expand(det, v, 10)
Download phase_error_try.mw
pansion)
First 94 95 96 97 98 99 100 Last Page 96 of 2429
