Good day, all.
Please I want to solve the following delay differential equation:
ODE := diff(y(t), t$2) = (2*(1-y(t-1)^2))*(diff(y(t), t))-y(t)
ics := y(0) = 1, (D(y))(0) = 0
using the following codes but there is an error. Please kindly help to modify the codes.
Digits:=30:
f:=proc(n)
	2*(1-(y[n-1])^2)*delta[n]+y[n]:
g:=proc(n)
	-4*y[n-1]*delta[n-1]+2*(1-(y[n-1])^2)*f(n)-delta[n]:
e1:=y[n+2] = -y[n]+2*y[n+1]+(1/120)*h^2*(-3*h*g(n+2)+3*g(n)*h+16*f(n+2)+16*f(n)+88*f(n+1)):
e2:=h*delta[n] = -y[n]+y[n+1]-(1/1680)*h^2*(-128*h*g(n+1)-11*h*g(n+2)+59*g(n)*h+40*f(n+2)+520*f(n)+280*f(n+1)):
e3:=h*delta[n+1] = -y[n]+y[n+1]+(1/1680)*h^2*(-152*h*g(n+1)-10*h*g(n+2)+32*g(n)*h+37*f(n+2)+187*f(n)+616*f(n+1)):
e4:=h*delta[n+2] = -y[n]+y[n+1]+(1/1680)*h^2*(128*h*g(n+1)-101*h*g(n+2)+53*g(n)*h+744*f(n+2)+264*f(n)+1512*f(n+1)):
inx:=0:
ind:=0:
iny:=1:
h:=1/2:
n:=1:
omega:=10:
u:=omega*h:
N:=solve(h*p = 10, p):
err := Vector(round(N)):
exy_lst := Vector(round(N)):
numerical_y1:=Vector(round(N)):
c:=1:
for j from 0 to 2 do
	t[j]:=inx+j*h:
vars:=y[n+1],y[n+2],delta[n+1],delta[n+2]:
step := [seq](eval(x, x=c*h), c=1..N):
printf("%6s%45s%45s\n",
	"h","Num.y","Num.z");
#eval(<vars>, solve({e||(1..4)},{vars}));
st := time():
for k from 1 to N/2 do
	par1:=x[0]=t[0],x[1]=t[1],x[2]=t[2]:
	par2:=y[n]=iny,delta[n]=ind:
	res:=eval(<vars>, fsolve(eval({e||(1..4)},[par1,par2]), {vars}));
	for i from 1 to 2 do
		printf("%6.5f%45.30f%45.30f\n",
		h*c,res[i],res[i+2]):
		numerical_y1[c] := res[i]:
		c:=c+1:
	iny:=res[2]:
	ind:=res[4]:
	inx:=t[2]:
		t[j]:=inx + j*h:
v:=time() - st;
v/4;
printf("Maximum error is %.13g\n", max(err));
NFE=evalf((N/4*3)+1);
#get array of numerical and exact solutions for y1
numerical_array_y1 := [seq(numerical_y1[i], i = 1 .. N)]:
#exact_array_y1 := [seq(exy[i], i = 1 .. N)]:
#get array of time steps
time_t := [seq](step[i], i = 1 .. N):
#display graphs for y1
numerical_plot_y1 := plot(time_t, numerical_array_y1, style = [point], symbol = [asterisk],
				color = [blue,blue],symbolsize = 20, legend = ["TFIBF"]);
 Thank you, and best regards.
I can't isolate a variable from the constraint and move it to one side of the inequality. For example, it's like having theta <= all other terms. I've tried using the isolate and eval functions, but they aren't producing any results or simplifying the expression. What am I doing wrong?
Attaching sheet below (issue marked yellow in background): N_1.mw
I'd like to explore graphically a polynomial surface depending on two parameters a and b.
The problem is that, as soon as I start playing with the sliders, Maple freezes and I have to 'force quit'.
Can you please tell me if you have the same problem with this example?
K := 1 - y*x - (1 - x)*(b*x^3 + a*x^2 + x + 1)*(1 - y)*(b*y^3 + a*y^2 + y + 1)
1-y*x-(1-x)*(b*x^3+a*x^2+x+1)*(1-y)*(b*y^3+a*y^2+y+1)
Explore(plot3d(K, x=0..1, y=0..1,  font= [Times, bold, 20], labels= ['x', 'y','z'],   labelfont= [Times, bold, 40],  title = "K(x,y)"), b = 0..1., a=0..1.);
Download Explore.mw
Hello Dear Professional users,
I have a question regarding the "fsolve" command and also the "assign" command in Maple.
In my previous codes, I just used one time from "fsolve" and then "assign" command.
Today, I want to use "fsolve" and "assign" in a for loop. But, I can not get the results correctly.
For example, previously I reach a system of algebraic equations and the solve my problem easily:
N:=8:
y:=sum(a[n]*t^n,n=0..N):
y:=unapply(y,t):
*****some calculations with a[n] coefficients *****
A:={a set of nonlinear algebraic equations in terms of a[n]}%The number of equations is N+1 (same as the number of a[n] for n=0..N)
sol:=fsolve(A):
assign(sol)
plot(y(t),t=0..1)
Today, my problem is:
N:=8:
M:=4:
for i from 1 to M do
y[i]:=sum(a[i,n]*t^n,n=0..N):
y[i]:=unapply(y[i],t):
end do
@A[i]:={a set of nonlinear algebraic equations in terms of a[i,n]}%The number of equations is N+1 (same as the number of a[n] for n=0..N)
@sol[i]:=fsolve(A[i]):
@assign(sol[i])
@plot(y[i](t),t=0..1)
end do
What I should write instead of "A[i]", "sol[i]", and "assign(sol[i])" the lines started with
@A[i],....
@sol[i],...
@assign(sol[i]),....
Thanks for your attention in advance
With kind regards,
Emran
I am trying to understand how to use Maple to solve a PDE.  Below it is a problem (Henon-Heilles system) where the answer is known.
with(PDEtools);
infolevel[pdsolve]:=3:
declare(Hamil(x,y,u,v));
PDEHamil := u*diff(Hamil(x, y, u, v), x) + v*diff(Hamil(x, y, u, v), y) + (-2*x*y - x)*diff(Hamil(x, y, u, v), u) + (-x^2 + y^2 - y)*diff(Hamil(x, y, u, v), v) = 0;
pdsolve(PDEHamil)
Maple returns no solution, but one solution is:
sH:=1/2*(u^2+v^2)+1/2*(x^2+y^2-2/3*y^3)+x^2*y;
simplify(eval(subs(Hamil(x,y,u,v)=sH,PDEHamil)));
    0=0
What am I missing?
Many thanks.
I am trying to install Syrup in my home computer (I have it installed in my work computer).  I followed the instructions in the Readme file:
From Standard Maple:
    Open the file Syrup-Installer.mla.
    To do so, use File -> Open, choose file type
    "Maple Library Archive (.mla)", select the file, and
    click "Open".
Everything seemed to work and the help page opened up:  But, it is not the syrup help page.  furthermore, when I type ?Syrup, it doesn't open it either.
When I try to run a worksheet that uses Syrup (that works on my work computer), I get these errors:
I"m going to reboot now and try again.
Jorge
I was working with a Dataframe when I wanted to change the datatype of multiple columns at the same time as this is quite a large dataframe. I found in the helpfile that I can change datatype by the following command:
SubsDatatype(Data, plts, float) which then change the datatype of "plts" into float. I had hoped that using multiple columns in the command would work in this way: SubsDatatype(Data, [plts, act], float)  but apparently not. Is there a way to do this or do I have to do it column by column?
Additionally I have another question about dataframes. I would like to replace "0" in the dataframe by a "blank" as you can do in excel. How do you do this in a dataframe?
Thanks in advance for any help given!
with(DEtools);
ode := diff(y(x), x) = epsilon - y(x)^2;
                       d                       2
               ode := --- y(x) = epsilon - y(x)
                       dx
sol := dsolve(ode);
                  /           (1/2)            (1/2)\        (1/2)
sol := y(x) = tanh\_C1 epsilon      + x epsilon     / epsilon
P := particularsol(ode);
                          (1/2)                 (1/2)
       P := y(x) = epsilon     , y(x) = -epsilon     ,
                /    y(x)    \            (1/2)
         arctanh|------------| - x epsilon      + _C1 = 0
                |       (1/2)|
                \epsilon     /
i am looking for finding all solution of this equation like this picture below
I would like to find how I can calculate covariant derivative of Einstein tensor for an arbitrary metric ds_2=-A(r)*dt^2+B(r)*dr^2+dtheta^2+sin(theta)^2*dphi^2
with best
I have this polynomial function
G(x, y) := (-0.14*y^3 + 1.20000000000000*y^2 - 1.26000000000000*y + 0.200000000000000)*x^3 + (1.20*y^3 - 10.0800000000000*y^2 + 10.0800000000000*y - 1.20000000000000)*x^2 + (-8.82*y + 10.08*y^2 - 1.26*y^3)*x + 1. - 1.2*y^2 + 0.2*y^3
I don't understand why the command
minimize(G(x,y),x=0..1,y=0..1);
produces the error
Error, (in RootOf/RootOf:-algnum_in_range) invalid input: RootOf/RootOf:-rootof_in_range expects its 1st argument, rt, to be of type ('RootOf')(polynom(rational,_Z),identical(index) = posint), but received RootOf(7*_Z^3-93*_Z^2+327*_Z-187)
Thanks for your advices, Nicola
Using ScatterPlot (or ErrorPlot), one can add error bars to a 2d point plot of data. However, the bars are single lines. I wish to create a plot with H-type error bars in both the horizontal and vertical directions.  Below is an example showing how the bars should appear. (This image is taken from a previous question about adding error bars.)
I do not need to reproduce this figure exactly. The location of the data points and the size of the error bars are irrelevant. The closest I have seen is using BoxPlot.
Has this question been asked and answered? If so, I cannot find it.
there is any way for define conformable fractional derivative in partial differential equation
with(PDEtools);
pde := a*diff(psi(x, t), x $ 2) + (b*abs(psi(x, t))^(-2*n) + c*abs(psi(x, t))^(-n) + d*abs(psi(x, t))^n + f*abs(psi(x, t))^(2*n))*psi(x, t) = 0;
pde + i*diff(u(x, t), [t $ beta]) = 0;
how define a  fractional derivative in sense of conformable derivative
I don't understand where the the csgn(L) comes from in the solution below:
all the variables are defined as real:
coupled_network_vbat.mw
Jorge
I notice that the command gcd(a,b), if a and b are large degree polynomials, takes too much time and often crashes Windows (not only Maple).
As the euclidean algorithm is very efficient even for large numbers,why not for polynomials?
And how could I calculate the gcd between polynomials with a large degree?
Thanks Michele
Hi everyone:
I watn to create expressions like below expressions in "printf" command:
%15s
%15s%15s
%15s%15s%15s
%15s%15s%15s%15s
Can I write these form expressions with "for' command for i=1..n or "seq" command? infact I need those in print command so that I do not type manually.
First 93 94 95 96 97 98 99 Last Page 95 of 2429
