Dear All
I have a trignometric function and I plotted it in 2D. It is visible from the graph that the function has Maxima and Minima. My question is, can I located all values
0.12981e-1+0.80285e-1*cos(.9519256799*x)+0.41370e-1*cos(1.903851360*x)+0.35690e-1*cos(2.855777040*x)+0.147e-3*cos(3.807702720*x)
plot(diff(0.12981e-1+0.80285e-1*cos(.9519256799*x)+0.41370e-1*cos(1.903851360*x)+0.35690e-1*cos(2.855777040*x)+0.147e-3*cos(3.807702720*x), x), x = -6.2 .. 6.2)
Download Max_Min_from_Graph.mw
of "x" corresponding to these Max. and Min. ?
dy/dx=sqrt(1+(a*x)+(2*y))
for the case a=1, y=1 and x=0 construct a program for the runge-kutta method of order 2 with formulae as follows where f(x,y)=dy/dx.
k_1=h*f(x_n,y_n)
k_2=h*f(x_n+h,y_n+k_1)
y_(n+1)=y_n+1/2(k_1+k_2).
After creating a program obtain value of y correct to 4 decimal places when x=1 for h=0.1 and h =0.05.
Meanwhile, thank you so much for everything.
I know I'm asking a lot but if you have time, you can help me do this?
Building a system of interactive components that, taken a function, two points 'a' and 'b' values ​​and an integer n, the calculations point between a and b in which the function assumes the minimum value by using the following procedure:
• It divides the values ​​between a and b into n equal parts (these will distance the one with the other (b-n)/2);
• calculates the function in each of these points;
• located between these values,  what is the minimum (in case of a tie, take the one closest to a)
I think i have to create a vector for each  part and  prehaps with a fcycle for, calculate the function, finelly i'll use minimize with all function.
Do you think is the correct procedure? If yes, how can I do it?
yVal := 0.01
xVal := 0.01
p8 := plot([fdiff(('rhs')((pds:-value(f(x, y)))(x, yVal)[3]), [y, y], x = z)], z = 0 .. 20, color = [red])
I cant seem to plot the graph for yVal, but if I were to switch it around to (xVal,y), the graph works perfectly. How should I input the code such that I can obtain the f''(x,0) graph.
Any help will be greatly appreciated :) thanks
fyp3.mw
I work on the period doubling phenomenon by integrating the dynamical system at some particular parameter values. My main commands are as follows
with(DEtools): with(plots): with(plottools):
a:=-1: b:=-3: c:=3: d:=1: omega:=1: v1:=1: f:=-4: epsilon:=0.01:
sys:=diff(u1(t),t)=v1*u1(t)-(omega+u2(t)^2)*u2(t)+u1(t)*(a*(u1(t)^2+u2(t)^2)+b*z(t)^2),
     diff(u2(t),t)=(omega+u1(t)^2)*u1(t)+v1*u2(t)+u2(t)*(a*(u1(t)^2+u2(t)^2)+b*z(t)^2),
     diff(z(t),t)=z(t)*(-v1+c*(u1(t)^2+u2(t)^2)+z(t)^2)+epsilon*z(t)*(v2+f*z(t)^4):
solC:=dsolve({eval(sys, v2=2.0500014987),
              u1(0)=0.6,u2(0)=0.6,z(0)=0.1},
              type=numeric, method=rkf45, maxfun=10^7,
              range=350..750):
p1:=odeplot(solC, [sqrt(u1(t)^2+u2(t)^2),z(t)],
               refine=2,
               color=burgundy,
               thickness=1);
The resulting curves are quite blurring and furry. I have tried to increase the "refine" or the "numpoints" values, but with minimal improvement. I would like to know if there a way to obtain clean and sharp integral curves?
I would be very grateful if someone could help me!
Thank you in advance.
With kind wishes,
Wang Zhe
Hi, I try Aproximate integral with simpsons method, but i want value in function the a with number solution:
with(Student[Calculus1]);
ApproximateInt(a*tan(x)-2*x, x = -100 .. 100, method = simpson, output = plot, partition = 500);
This error.
How we can construct conservation laws of fractional differential equation with Maple?
Hi I try this integral:
m2 := int(exp(-(1/2)*z^2)*((exp(B*J*sqrt(q)*z))^2-1)/(sqrt(Pi)*sqrt(2)*((exp(B*J*sqrt(q)*z))^2+1)), z = -infinity .. infinity)
But not resolve.
How can i do?
Regards.
Basically what I'm trying to do is use Newton's method to find the root of f(x)=sqrt(x)+ln(0.1x) starting at x0=5 within a tolerance of 0.001.
f := proc (x) options operator, arrow; sqrt(x)+ln(.1*x) end proc
> xk := 1.0;
                              1.0
> for k to 6 do xk1 := xk-f(xk)/(D(f))(xk); xk := xk1 end do;
When I do that, Maple barfs out pages of nonsense when I'm looking for it to give numerical values. It seemed to work fine with a different function, so maybe that's part of the problem? But I need to do it with the function I asked about.
Respected member!
Please help me to find the solution of attached problem,  I am a new user so please forgive any mistakes.maple.mwmaple.mw
I have been trying to solve a simple nonlinear equation. Im interested in the solution per say rather than the plot but when I browsed about the commands to use, this came up. I tried it in my case and it is giving me the following errors:
ode.mw
eq5:=C*sqrt(y(x)*((diff(y(x),x))^2+1))-y(x)=0;
C*(y(x)*((diff(y(x), x))^2+1))^(1/2)-y(x) = 0
C:=1;
bcs:=y(-1)=1, y(1)=1;
y(-1) = 1, y(1) = 1
dsys:={eq5,bcs};
{(y(x)*((diff(y(x), x))^2+1))^(1/2)-y(x) = 0, y(-1) = 1, y(1) = 1}
dsol:=dsolve(dsys, numeric); odeplot(dsol,[x,y(x)],0..1,color=red,axes=box);
Download ode.mw
The question explores the family of differential equations dy/dx = sqrt(1+(a*x)+(2*y)) for various values of the parameter a.
This figure shows the tangent field in the case a=1.
sketch a tangent field in the case a=-2.
need the following diagram on maple:
hello,
Given f(x)=2x^2-4x, how do I define and plot the functions f(x), 2f(x), 4f(x), -f(x) and -4f(x) in maple 15?
Thank You.
How wired icon of motor to icon of sources?thanks
Can anyone solve,
eqn := diff(x(t), t, t)+omega^2*x(t)-epsilon*mu*(diff(x(t), t))+epsilon*alpha*x(t)^2*(diff(x(t), t))+epsilon*Zeta*cos(Omega*t)*x(t)=0;
This equation using MMS (Method of Multiple Scales) in maple.
Pls use Polar transformation function as (1/2)*a(t)*exp(-I*beta(t))
Please reply.
First 1048 1049 1050 1051 1052 1053 1054 Last Page 1050 of 2470
