search start from a, b, c, ... for each sequence if input a,b,c,d,e,f,g,h,i,j,k
is there a function like accumulate in haskell in maple instead of using for loop?
would like to search something if found, then return the length of it searched from the starting position
when start from a search a from b to g whether is a,  if find , return the length from c to the found position,
when start from b search b from c to h whether is b,  if find , return the length from c to the found position
then save the length into a list
a b c d e f g
   b c d e f g h
      c d e f g h i
         d e f g h i j
            ef g h i j k
I am trying to calculate the pressure required for a specific bend angle produced by my actuator
But when evaluating the triple integral for calculating the moment the error of too many level recursions is recieved
Any help or advice is appreciated
Code:
a = 0.11e-1;
b = 0.25e-2;
t = 0.25e-2;
theeta = (1/180)*pi;
L = 0.17e-1;
R = L/theeta;
shearmodulus = 314000;
0.011 = 0.011 0.0025 = 0.0025 0.0025 = 0.0025 1 1 --- Pi = --- pi 180 180 0.017 = 0.017 R = 0.9740282516 314000 = 314000 eq0 := Ma = int(int((x*sin(O)+b)*x^2*(cos(O)*cos(O)), O = 0 .. (1/2)*Pi), x = 0.9e-2 .. 0.11e-1); -9 eq0 := Ma = 1.067341412 10 assign(('t', 'b', 'L', 'shearmodulus', 'theeta', 'a') = (0.25e-2, 0.25e-2, 0.17e-1, 314000, (1/180)*Pi, 0.11e-1));
eq4 := Mo1 = int(int(2*shearmodulus*(1+Beeta*theeta/L-1/(1+Beeta*theeta/L)^3)*(O+t)*L, O = 0.9e-2 .. 0.11e-1), Beeta = 0 .. b);
eq4 := Mo1 = 0.000003416445428 simplify(Mo1 = int(int(2*shearmodulus*(1+Beeta*theeta/L-1/(1+Beeta*theeta/L)^3)*(O+t)*L, O = 0.9e-2 .. 0.11e-1), Beeta = 0 .. b)); Mo1 = 0.000003416445428 simplify(Mo1 = int(int(2*shearmodulus*(1+Beeta*theeta/L-1/(1+Beeta*theeta/L)^3)*(O+t)*L, O = 0.9e-2 .. 0.11e-1), Beeta = 0 .. b));
Mo1 = 0.000003416445428 Mo2 = 2*(int(int(int(shearmodulus*((R+b+sin(Phi)*(A+tao))/R-1/((R+b+sin(Phi)*(A+tao))/R)^3)*((A+tao)^2*sin(Phi)+b*(A+tao))*L, Phi = 0 .. (1/2)*Pi), A = 0.9e-2 .. 0.11e-1), tao = 0 .. t));
Error, (in depends) too many levels of recursion eq5 := Pressure = Mo/Ma; Mo eq5 := Pressure = -- Ma
I am not interested in the mapleprime group, so I want to delete my account in this group.
Hi, I ran the following code:
solve({a > 0, b*d*(abs(c)^2-abs(a)^2) = 0, -a*c*(abs(b)^2-abs(d)^2) = 0, -abs(b)^2*a*d+abs(d)^2*b*c = 0, abs(c)^2*a*d-abs(a)^2*b*c = 0}, {a, b, c, d})
and we can easily see that a=a, b=0, c=0, d=d, should be a solution but Maple does not give me that answer. The result is:
{b = 0, c = 0, d = 0, 0 < a}, {b = 0, c = a, d = 0, 0 < a}, {b = d, c = a, 0 < a, 0 < d}, {b = 0, c = -a, d = 0, 0 < a}, {b = -d, c = -a, 0 < a, d < 0}, {b = d, c = a, 0 < a, d < 0}, {b = -d, c = -a, 0 < a, 0 < d}
Am I missing something?
I am interested in taking a complex number and repeatedly raising it to a power and graphing the result to see if it looks cool (i think it will) to do this i wrote this program
iterativepower := proc (base, index, n)
local out, i;
out := vector(n+1, 1);
out[1] := base;
for i to n do out[i+1] := out[i]^index end do;
out;
this can be run with:
iterativepower(2, 2, 5)
This doesn't return a vector, it returns the word out. Why is that, and how do i fix it?
Is it just me, or did the insert->subsection disappear from the menus in the latest maple??
i'm using 2018.1 on linux.
My name's Rafael, I am a master's student in Dentistry in Brazil.
I need your help.
I have several points with X, Y and Z coordinates. I would like to create a curve that represents these points in a 3-dimensional plane.
I'm new using Maple and managed to use the "plots [pointplot3d]" function to represent the points in the chart. However I have a list in excel with several point (over 100) and would like to know how to import these points to use this function.
Thank you very much
How can you get maple to evaluate i^i?
when i type in
I^I
i just get
I^I
and similarly when i raise numbers to complex powers i get results like 2^(2I+6)
Recently, my questions are deleted. last month I ask 3 questions but that all questions are deleted without my knowledge. yesterday also i ask one question "how to plot3d graph" that also deleted. "https://www.mapleprimes.com/questions/225618-How-To-Plot-The-3d-Graph?sq=225618". In the mapleprime, I am following the ethics and rules.
This more a warning to focus your attention on a specific point than a true question.
I submit you this test case which works in Maple 2015 and Maple 2016 but not in Maple 2018.
In a few words:
  • let X and Y two independant random variables with respective distributions Normal(mu__x, sigma__x) and
    Normal(mu__y, sigma__y)
  • let Z := q -> cos(q)
  • You can easily verify that Maple can compute the formal expression of Mean(Z(X)) and Variance(Z(X))
    (which means that it could compute Z(X+Y) for X+Y is just another gaussian RV)
  • What I found is that:
    1. Mean(Z(X+Y)) returns same expressions in Maple 2015 and Maple 2016, but a different one in Maple 2018.
      Luckily the later is more readable than the former ones, and closer to the one of Mean(Z(U))  where U=X+Y is the RV of distribution Normal(mu__x+mu__y, sqrt(sigma__x^2+sigma__y^2))
      This suggest that the integration algorithm has evolved somewhere in between Maple 2016 and Maple 2018
    2. While Maple 2015 and Maple 2016 return an evaluated result for Variance(Z(X+Y)) Maple 2018 fails.
Can this "failure" be fixed by some adhoc option of Variance?
Or could it come from a "regression" in the implementation of this procedure (or of the underlying int procedure) in Maple 2018?
PS: I did not try to compute Variance(Z(X+Y)) from an explicit double integration
Stat_2015.mw
Why does the following not get simplified?
simplify(conjugate(b) * I - conjugate(a) + conjugate(b*I+a));
It seems Maple does not know conjugation is linear, since the following
simplify(conjugate(b) * I                + conjugate(b*I  ));
simplify(                 - conjugate(a) + conjugate(    a));
do get simplified to 0.
The function does simplify to 0, but it assumes my and are real, which they are not.
Why does the following code
evalb(a * conjugate(a) = abs(a) ^ 2);
not produce true?
In ScientificConstants, the density of carbon is given as 2.2 g/cm^3. That happens to be the value for graphite. Carbon comes in different states with different density, diamond being one of them, amorphous being another. Is this somewhere in ScientificConstants where just I cannot find it, or is it not there?
TIA,
M.D.
PS: I do know the values and where to find them (Particle Data Group). I'd like to use ScientificConstants so I can write a more general piece of code.
My worksheet is shown below. I am copying an example from a textbook and know that h = 26.4 is correct.
However, if I use !!! (execute entire worksheet) then I get h = -13
What an i doing wrong
I am having problems with the syntax/symbols i maple. I down know what "setting" has changed but + and - and so on, has change to K and C. anyone know how to fix this?
Morten
First 811 812 813 814 815 816 817 Last Page 813 of 2469
