Good day, everyone
I am trying to code HPM but it's giving me the error code "Error, invalid subscript selector
" once I increase the number of iterations above 2.
Attached below is the code.
HPM.mw
In a recent MaplePrimes question: https://mapleprimes.com/questions/240543-Maple-20251-On-Windows-11-How-To-Resize
a discussion of interrupting a computation also came up.
I gave some comments. In one of these I wanted to include a link to a screenshot.
I tried several times. It seemed that I only had the choice between the full image or a thumb nail.
So I chose the latter. That appeared to me as worthless. I tried a couple of times more, but decided to delete all 3.
Then I wrote a comment without a screenshot.
It looks silly to have these empty (and anonymous) "comments" still around.
Is there any way to remove these?
Hello, when I have a complex conjugate in the denominator of a fraction, the conjugate bar symbol and the division line of the fraction overlap. When this happens, it is not apparent that the variable is a conjugate, so I have had to just type the command conjugate() in order to make this clear.
Reference the linked sample document that illustrates this: Conjugate.flow
I would appreciate any suggestion on how to use the conjugate symbol in this case. I would prefer the symbol wherever possible rather than the text command for clarity in the flow document.
Hello, I have a procedure "timing" in the code editor that I am calling from the main canvas of a flow document. I would like to print the procedure description text string from the Description option in the procedure using the Describe command. However, Describe(timing) does not return anything.
The flow document is at this link: Procedure-Describe.flow
I would appreciate any suggestions.
I am new to Windows 11 (edit: I was forced to migrate from 10).
I am looking for an option to resize the Window that the interupt button becomes accessible (see red box)
Also: there are no window controls (maximize minimize) visble . (edit: the title bar is clipped off).
Window key + arrow key does not work.
I have also tried the Snap Layout option to resize but cannot find Maple 2025.1 under the selectable tasks.
What else can I try?
I checked the ConsistencyTest of the system of equations but no output with 'true' or 'False'. Is it not work in 'DEtools'? Download consistency.mw
I have a piecewise density function (f).  I am trying to find the median value.
I have tried the Median function and the Percentile function, but neither work for me.  I am not sure why.
I have also tried to integrate the density function on the (0,x) interval such that the area under the curve is 1/2 and then solve for x.  This works for simple problems, but not the one attached.
There is something very simple that I'm not doing, but I am not sure what.
kernelopts(version)
`Maple 2023.2, X86 64 WINDOWS, Nov 24 2023, Build ID 1762575`
with(Statistics)
f := 2*t*piecewise(t <= 0, 0, t <= 1, t^2+Pi-4*t, t <= sqrt(2), -(sqrt(t^2-1)*t^2+2*sqrt(t^2-1)*arcsin((t^2-2)/t^2)-4*t^2+2*sqrt(t^2-1)+4)/sqrt(t^2-1), sqrt(2) < t, 0)
2*t*piecewise(t <= 0, 0, t <= 1, t^2+Pi-4*t, t <= 2^(1/2), -((t^2-1)^(1/2)*t^2+2*(t^2-1)^(1/2)*arcsin((t^2-2)/t^2)-4*t^2+2*(t^2-1)^(1/2)+4)/(t^2-1)^(1/2), 2^(1/2) < t, 0)
plot(f, t = 0 .. sqrt(2))
Median(f)
Percentile(f, 50)
myMedian := solve(int(f, t = 0 .. x) = 1/2, x)
Download Median.mw
When calculating limits of real-valued functions, sometimes (especially in competitions) tricky approaches are taken using pen and paper. I repeatedly encountered the simple conclusion that, for example, for natural k, the value sin(k*pi) = 0. Thus, the function value is determined logically without specifying a specific number. There are numerous other examples of this that can easily be constructed.
My question after unsuccessful attempts using "assume" is:
How, for example, does Maple determine the value of sin(k*pi) from the assumption "k is natural" alone? Are such prominent values ​​implemented in tables?
As I was comparing visually the first terms of a priori identical sums produced by add , I was surprised to find them different.
So I suspected some error in what I have done, until I realized that add randomly permuted the terms.
Each term is of the form (R + P)2 where R is a random number and P a polynomial.
This behaviour is illustrated in worksheet add_changes_ranks.mw and appears only when random numbers are used (provided the seed is not forced to some constant value)
Does someone ever onserved that or have any idea of what happens here (maybe this behaviour no longer happens in recent versions?) ?
I am trying to find the standard deviation for a piecewise density function (f).  The interval is (0, sqrt(3))  I am convinced the density function is what I want.  I calculate the expected value of the density function (evE) and the answer is correct -- about 0.66145
When I try to calculate the standard deviation (stdE), I get an answer that is "off" by a large degree.  Via simulating values, I should get a value of about 0.24936.  Each time I "re-run" the calculation, I get varying results, all of which are "off" by a large degree.
I am only guessing, but my integration function might be missing some sort of assumption and/or option.
My work is attached.  Does anyone know what I am doing wrong?
with(Statistics)
f := -t*piecewise(t <= 0, 0, t <= 1, t*(t^3+6*Pi*t-8*t^2-4*Pi), t <= sqrt(2), -(2*(4*t^2*sqrt(t^2-1)*arcsin((t^2-2)/t^2)+4*t^2*arctan(sqrt(t^2-1))*sqrt(t^2-1)+(t^4+(2*Pi+3)*t^2-4*t*Pi+3*Pi-1/2)*sqrt(t^2-1)-8*t^4+4*t^2+4))/sqrt(t^2-1), t <= sqrt(3), (8*arctan((t^3+t^2-3*t-1)/(sqrt(t^2-2)*(t^3-t^2-t-1)))*t*sqrt(t^2-2)-4*arccot((t^2-t-1)/sqrt(t^2-2))*t^2*sqrt(t^2-2)+4*t*sqrt(t^2-2)*(t+2)*arctan((t^2+t-1)/sqrt(t^2-2))+(8*t^2-4)*sqrt(t^2-2)*arcsin((t^2-3)/(t^2-1))+16*arcsin(sqrt(t^2-2)/sqrt(t^2-1))*sqrt(t^2-2)-16*arcsin(1/sqrt(t^2-1))*sqrt(t^2-2)+((t^2+5)*sqrt(t^2-2)-8*t^2+16)*(t^2+1))/sqrt(t^2-2), sqrt(3) < t, 0)
-t*piecewise(t <= 0, 0, t <= 1, t*(t^3+6*Pi*t-8*t^2-4*Pi), t <= 2^(1/2), -2*(4*t^2*(t^2-1)^(1/2)*arcsin((t^2-2)/t^2)+4*t^2*arctan((t^2-1)^(1/2))*(t^2-1)^(1/2)+(t^4+(2*Pi+3)*t^2-4*t*Pi+3*Pi-1/2)*(t^2-1)^(1/2)-8*t^4+4*t^2+4)/(t^2-1)^(1/2), t <= 3^(1/2), (8*arctan((t^3+t^2-3*t-1)/((t^2-2)^(1/2)*(t^3-t^2-t-1)))*t*(t^2-2)^(1/2)-4*arccot((t^2-t-1)/(t^2-2)^(1/2))*t^2*(t^2-2)^(1/2)+4*t*(t^2-2)^(1/2)*(t+2)*arctan((t^2+t-1)/(t^2-2)^(1/2))+(8*t^2-4)*(t^2-2)^(1/2)*arcsin((t^2-3)/(t^2-1))+16*arcsin((t^2-2)^(1/2)/(t^2-1)^(1/2))*(t^2-2)^(1/2)-16*arcsin(1/(t^2-1)^(1/2))*(t^2-2)^(1/2)+((t^2+5)*(t^2-2)^(1/2)-8*t^2+16)*(t^2+1))/(t^2-2)^(1/2), 3^(1/2) < t, 0)
plot(f, t = 0 .. sqrt(3))
evE := simplify(int(t*f, t = 0 .. sqrt(3)))
(1/105)*(294*(2^(1/2)-3/2)*(-2+3^(1/2))*ln(1+2^(1/2))+168*(2^(1/2)-3/2)*(-2+3^(1/2))*ln(1+3^(1/2))-252*(2^(1/2)-3/2)*(-2+3^(1/2))*arccoth(2^(1/2))+((-14*Pi-84*ln(2)-19)*3^(1/2)+28*Pi+168*ln(2)+50)*2^(1/2)+(21*Pi+126*ln(2)+20)*3^(1/2)-42*Pi-252*ln(2)-58)/((2*2^(1/2)-3)*(-2+3^(1/2)))
evalf(evE)
.6617071838
stdE := simplify(sqrt(int(f*(t-evE)^2, t = 0 .. sqrt(3))))
(1/210)*(-4808607312140100*(2^(1/2)-3880899/2744210)*(3^(1/2)-70226/40545)*ln(1+2^(1/2))^2+(-5495551213874400*(2^(1/2)-3880899/2744210)*(3^(1/2)-70226/40545)*ln(1+3^(1/2))+8243326820811600*(2^(1/2)-3880899/2744210)*(3^(1/2)-70226/40545)*arccoth(2^(1/2))+((457962601156200*Pi+2747775606937200*ln(2)+631290043332900)*3^(1/2)-793214493249360*Pi-4759286959496160*ln(2)-1093426429714584)*2^(1/2)+(-647656921614780*Pi-3885941529688680*ln(2)-892778941072368)*3^(1/2)+1121774694224184*Pi+6730648165345104*ln(2)+1546338486359352)*ln(1+2^(1/2))-1570157489678400*(2^(1/2)-3880899/2744210)*(3^(1/2)-70226/40545)*ln(1+3^(1/2))^2+(4710472469035200*(2^(1/2)-3880899/2744210)*(3^(1/2)-70226/40545)*arccoth(2^(1/2))+((261692914946400*Pi+1570157489678400*ln(2)+360737167618800)*3^(1/2)-453265424713920*Pi-2719592548283520*ln(2)-624815102694048)*2^(1/2)+(-370089669494160*Pi-2220538016964960*ln(2)-510159394898496)*3^(1/2)+641014110985248*Pi+3846084665911488*ln(2)+883621992205344)*ln(1+3^(1/2))-3532854351776400*(2^(1/2)-3880899/2744210)*(3^(1/2)-70226/40545)*arccoth(2^(1/2))^2+(((-392539372419600*Pi-2355236234517600*ln(2)-541105751428200)*3^(1/2)+679898137070880*Pi+4079388822425280*ln(2)+937222654041072)*2^(1/2)+(555134504241240*Pi+3330807025447440*ln(2)+765239092347744)*3^(1/2)-961521166477872*Pi-5769126998867232*ln(2)-1325432988308016)*arccoth(2^(1/2))+((-392539372419600*ln(2)^2+(-130846457473200*Pi-180368583809400)*ln(2)-10903871456100*Pi^2-30061430634900*Pi+1205966071986042)*3^(1/2)+679898137070880*ln(2)^2+(226632712356960*Pi+312407551347024)*ln(2)+18886059363080*Pi^2+52067925224504*Pi-2088794509063308)*2^(1/2)+(555134504241240*ln(2)^2+(185044834747080*Pi+255079697449248)*ln(2)+15420402895590*Pi^2+42513282908208*Pi-1705493574764511)*3^(1/2)-961521166477872*ln(2)^2+(-320507055492624*Pi-441810996102672)*ln(2)-26708921291052*Pi^2-73635166017112*Pi+2954001523727854)^(1/2)*(5*2^(1/2)-7)*(-5+3*3^(1/2))/((70*2^(1/2)-99)*(15*3^(1/2)-26)*(-2+3^(1/2))*(4*3^(1/2)-7)*(12*2^(1/2)-17)*(2*2^(1/2)-3))
evalf(stdE)
7031348.295
Download StdE.mw
I’m currently a student working with vectors as part of my electrical AC calculations. Up until now, I’ve been using GeoGebra to add and plot vectors, but I’m trying to transition fully to Maple, since I already use it for everything else in my studies.
All of my assignments are either given in — or require answers in — polar form (magnitude and angle), so I would really like to work directly in polar coordinates without converting everything to Cartesian and back.
I’ve already tried to figure this out on my own, but so far, I’ve only been able to make it work using Cartesian notation. I’ve attached a PDF with a typical example of the kind of tasks I work on, in case that helps clarify my needs.
Could you guide me on how to best set up and work with polar vectors in Maple — including how to define, add, and plot them directly in polar notation?
Vector_Help.pdf
Best regards,
Mads Bach Nielsen
- Yes this was written with the help of Chat GPT
why this error is getting. but in the published paper for the same parameter it is converging. what is the mistake in this worksheet please rectify it in sachin_base_paper.mw
i need a way for making my loop working fast, i need something for calculating such term fast without showing result but thus term make a lot of time for coming out ?
fasting.mw
I want to substitute equation to equation, how?
Download r.mw
Someone should please help me compute the left and right eigenvectors of the system below. The purpose is to compute values for 'a' and 'b' in the bifurcation formula.
with(VectorCalculus)
interface(imaginaryunit = I)
I
I
I
diff(S(t), t) := `&Lambda;__p`-(`#mrow(mi("&varphi;",fontstyle = "normal"),mo("&sdot;"),msub(mi("&theta;",fontstyle = "normal"),mi("B")),mo("&sdot;"),msub(mi("I"),mi("B")))`/N[p]+µ__C)*S+`&omega;__B`*I__B
Lambda__p-(`#mrow(mi("&varphi;",fontstyle = "normal"),mo("&sdot;"),msub(mi("&theta;",fontstyle = "normal"),mi("B")),mo("&sdot;"),msub(mi("I"),mi("B")))`/N[p]+µ__C)*S+omega__B*I__B
diff(I__B(t), t) := `#mrow(mi("&varphi;",fontstyle = "normal"),mo("&sdot;"),msub(mi("&theta;",fontstyle = "normal"),mi("B")),mo("&sdot;"),msub(mi("I"),mi("B")))`*S/N[p]-`&omega;__B`*I__B-(`&sigma;__B`+µ__C)*I__B
`#mrow(mi("&varphi;",fontstyle = "normal"),mo("&sdot;"),msub(mi("&theta;",fontstyle = "normal"),mi("B")),mo("&sdot;"),msub(mi("I"),mi("B")))`*S/N[p]-omega__B*I__B-(sigma__B+µ__C)*I__B
diff(S__A(t), t) := `&Lambda;__A`-(µ__A+`#mrow(mi("&varphi;",fontstyle = "normal"),mo("&sdot;"),msub(mi("&alpha;",fontstyle = "normal"),mi("B")),mo("&sdot;"),msub(mi("I"),mi("B")))`/N[p])*S__A+`&delta;__A`*I__A
Lambda__A-(µ__A+`#mrow(mi("&varphi;",fontstyle = "normal"),mo("&sdot;"),msub(mi("&alpha;",fontstyle = "normal"),mi("B")),mo("&sdot;"),msub(mi("I"),mi("B")))`/N[p])*S__A+delta__A*I__A
diff(I__A(t), t) := `#mrow(mi("&varphi;",fontstyle = "normal"),mo("&sdot;"),msub(mi("&alpha;",fontstyle = "normal"),mi("B")),mo("&sdot;"),msub(mi("I"),mi("B")))`*S__A/N[p]-(µ__A+`&delta;__A`)*I__A
`#mrow(mi("&varphi;",fontstyle = "normal"),mo("&sdot;"),msub(mi("&alpha;",fontstyle = "normal"),mi("B")),mo("&sdot;"),msub(mi("I"),mi("B")))`*S__A/N[p]-(µ__A+delta__A)*I__A
Download CBD2.mw
First 8 9 10 11 12 13 14 Last Page 10 of 2430
