Maple formats output depending on typesetting options "extened" and "standard" for the GUI (or interface). An example taken from
ts_standard:=proc(k::anything)
     interface(typesetting=standard):
     print(k);
     interface(typesetting=extended):
     NULL;
k:=3/8*ln(55/52)+sin(x)+3/4*exp(x);
                    3   /55\            3
               k := - ln|--| + sin(x) + - exp(x)
                    8   \52/            4
ts_standard(k);
Why is the input two times returned and why one time as a list?
Somehow the first interface statement is responsible for that.
I am only interested in the reformated input inside the list.
Is it possible to fix the code?
Other observation with typesetting=standard:
interface(typesetting=standard);
expr:=cos(x)^2;
((x->x)=combine[trig])(expr);
((x->x)=combine[trig])(expr);#subsequent call
                          2   1            1
                    cos(x)  = - cos(2 x) + -
                              2            2
(with Maple 2024.1 this only accurs in Math-1D)
but
expr:=cos(x)^2;
                        expr := cos(x)
                            extended
                          2   1            1
                              2            2
I need to check inside typeset to see is something evaluates to 1. I can find if something contains 1 and have been using that. But got caught out last night because I forgot my work around. e.g. 1+H contains 1 and my work around is `1+H` so the check doesn't see the 1. The typeset is always the first item in the list.
foo:=proc(a,{S::list:=[]})
local i,perp::boolean;
if S<>NULL then
  if (S[1])=1 or S[1]::function and has(`or`(seq (op(S[1]),i=1..nops([op(S[1])]))),1)  then
   #if (S[1])=1 or S[1]::function and `or`(seq (is(op(S[1][i]),1),i=1..nops([op(S[1])])))  then  ;#  not working
     perp:=true;print(perp);
     perp:=false;print(perp);
foo(6,S=["cat"]);
foo(6,S=[1]);
foo(6,S=[typeset("cat=",H/H),align={above,left},color=green]); #good
foo(6,S=[typeset("cat=",H),align={above,left}])
foo(6,S=[typeset("cat=",1+H)],align={above,left},color=green);#want to fix this
foo(6,S=[typeset("cat=",`1+H`)]); #work around
foo(6,S=[typeset("cat=",`B/(H+1)`)]); #work around
foo(6,S=[typeset("cat=",`B/(H+1)`,"  height =",1)]); #correct
foo(6,S=[typeset("cat=",H^2/((2*H-H)*H),"  height =",`B/(H+1)`)]); #correct
op(typeset("cat=",B/(H+1)));# this would be false
"cat=", B/(1+H)
op(typeset("cat=",H^2/((2*H-H)*H),"  height =",`B/(H+1)`)) ;  # this would be true
"cat=", 1, "  height =", `B/(H+1)`
Download 2024-06-27_Q_check_inside_typeset.mw
When the limit approaches from left, the result must be zero. What cause the wrong? Will introducing an extra parameter M affect the result in W1?
W := -1/2+(1/2)*tanh(3.6*(tan(Pi*(r-2.1)/(2*7.9))-.6^2/tan(Pi*(r-2.1)/(2*7.9)))/Pi)
-1/2+(1/2)*tanh(1.145915590*tan(.1988349781*r-.4175534540)-.4125296124/tan(.1988349781*r-.4175534540))
limit(W, r = 10, left)
-1.000000000
W1 := -1/2+(1/2)*tanh(3.6*(tan(Pi*(r-2.1*M)/((2*7.9)*M))-.6^2/tan(Pi*(r-2.1*M)/((2*7.9)*M)))/Pi)
-1/2+(1/2)*tanh(1.145915590*tan(.1988349781*(r-2.1*M)/M)-.4125296124/tan(.1988349781*(r-2.1*M)/M))
limit(W1, r = 10*M, left)
-1.000000000
Download limit.mwlimit.mw
I want to write  in maple using summation notation for symbolic calculation. The output should come as
W_1exp(k_1.q)+W_2exp(k_2.q)+W_3exp(k_3.q)
where k_j.q are the dot product of the vectors k_j and q.
mp.mw
How to do this. Please help. The summation is not working for me, only suffix k is coming
Is there a way to define tensor components without addressing each component individually? Suppose I define a tensor A[a, mu], where Latin letters are space coordinates and Greek letters are space-time coordinates. Is there an easy way to define multiple components without having to define each component separately. For example, A[a,0] = 0 and A[a,i] = LeviCevita[a,i,j].
with(Physics);
Setup(spaceindices = lowercaselatin_ah)
g_[]
Define(A[a, mu])
A[a, 1] := 0
A[a, b] := LeviCivita[a, b, c]
TensorArray(A[a, mu])
A[1, 2] := 0
A[2, 3] := LeviCivita[2, 3, c]
The general writing method does not seem to change the tensor components, but the writing method in which I address the components individually does. What exactly am I doing wrong?
I use convert~([points1], list) command but the outcome is not I want. The code of shortscreen is attached. I wanna change the outermost curly braces of the sequence "points1" into square brackets. Thank you all guys to answer!
The below is I want.
This is not I want cause the outermost has three square brackets! I just wanna two.
GUI state after interupting with :
After switching to untitled 17 and back to test_timeout:
Sometimes it is necessary to switch back and forth twice.
Does this mean that the kernel did not receive the interupt?
eqn := B(n) = -sum(binomial(n + 1, k)*B(k), k = 0 .. n - 1)/(n + 1);
init := B(0) = 1, B(1) = -1/2;
sol := rsolve({eqn, init}, B(n));
Why doesn’t this give me any solution ? Thank you.
How to add x,y,z axis in plotsetup command? I need to enhance the quality of figure, so I use plotsetup command width=5000,height=5000. But in this case, the range of x,y,z axis vanish like this. The related code is attached.
I'm new to this software, I've started using it to build myself a spacemouse, and figuring out the "inverse kinematics" involved in its working. I've done a little research on how Maple works, I'm fortunate enough to have a student license, but maybe this problem is above my capacity.
Essentially, I want to control a 6-DOF platform by measuring six distances (with magnetic sensors, but that's not relevant, I believe), from three points forming an equiliateral triangle on the top platform, to six points on the bottom platform. So far I've been able to calculate the effect that each of the degrees of freedom has on the platform and on each of this distances that I want to measure.
But that's where the problem lies. Now I have a system of six equations with six variables and a few parameters, a system that's heavily nonlinear, involving a lot of trig functions and multiplications between them. I've tried to "brute force" a symbolic solution by simply typing in: solve(equations, variables) (note that both equations and variables were properly defined) but Maple just ran for a couple of hours without providing an answer. I don't know if this particular application reaches this software's limits, or if it's me who is doing something wrong.
I'll try to provide the maple Worksheet, I'm still not familiar with this site's formatting, sorry in advance:
L := Matrix(3, 3, [[cos(theta)*cos(psi), cos(theta)*sin(psi), -sin(theta)], [sin(phi)*sin(theta)*cos(psi) - cos(phi)*sin(psi), sin(phi)*sin(theta)*sin(psi) + cos(phi)*cos(psi), sin(phi)*cos(theta)], [cos(phi)*sin(theta)*cos(psi) + sin(psi)*sin(phi), cos(phi)*sin(theta)*sin(psi) - sin(phi)*cos(psi), cos(phi)*cos(theta)]]);
T := Matrix(3, 3, [[1, psi, -theta], [phi*theta - psi, phi*psi*theta + 1, phi], [phi*psi + theta, psi*theta - phi, 1]]);
p[ni] := Typesetting[delayDotProduct](R, Vector[column](3, [cos(theta[n]), -sin(theta[n]), 0]), true)
p__n := (T . (p[ni])) + Vector[column](3, [u, v, w])
m[m] := R*Vector[column](3, [cos(phi__m), -sin(phi__m), h/R])
`&Delta;p` := p__n - m[m]
with(VectorCalculus)
s[n] := sqrt(`&Delta;p` . `&Delta;p`)
theta[1] := -Pi/12;
theta[2] := Pi/12;
theta[3] := (2*Pi)/3 - Pi/12;
theta[4] := Pi/12 + (2*Pi)/3;
theta[5] := (4*Pi)/3 - Pi/12;
theta[6] := (4*Pi)/3 + Pi/12;
phi[1] := 0;
phi[2] := (2*Pi)/3;
phi[3] := (4*Pi)/3;
s[1] := eval(s[n], {phi__m = phi[1], theta[n] = theta[1]})
s[2] := eval(s[n], {phi__m = phi[1], theta[n] = theta[2]})
s[3] := eval(s[n], {phi__m = phi[2], theta[n] = theta[3]})
s[4] := eval(s[n], {phi__m = phi[2], theta[n] = theta[4]})
s[5] := eval(s[n], {phi__m = phi[3], theta[n] = theta[5]})
s[6] := eval(s[n], {phi__m = phi[3], theta[n] = theta[6]})
equations := [-d[1]^2 + s[1]^2 = 0, -d[2]^2 + s[2]^2 = 0, -d[3]^2 + s[3]^2 = 0, -d[4]^2 + s[4]^2 = 0, -d[5]^2 + s[5]^2 = 0, -d[6]^2 + s[6]^2 = 0]
variables := [u, v, w, psi, theta, phi]
So far this is what I've got, thanks in advance for the help.
EDIT: In the beginning of the worksheet two rotation matrices are declared, L and T. T is a "linearized" version of L, assuming small angles, and I'm using it to simplify the expressions. Still there is no luck.
There is an integration method called orering in Maple. But see no mention on it at help page
It shows up when using option
method=_RETURNVERBOSE
And that is how I knew about it.
It gives division by zero when asked to integrate zero !
Any one knows what is this method? Will send bug email to Maplesoft suport just in case also.
int(0,x)
int(0,x,method=orering)
Error, (in IntegrationTools:-Indefinite) numeric exception: division by zero
int(1,x,method=orering)
x
Download division_by_zero_int_orering_method.mw
Dear all, how can I simplify the following command by using nested SEQ?
tagsCornersPlot := textplot3d([[seq(cornerPoints[1 .. dim, 1]), cornerPoints[1 .. dim, 1]], [seq(cornerPoints[1 .. dim, 2]), cornerPoints[1 .. dim, 2]], [seq(cornerPoints[1 .. dim, 3]), cornerPoints[1 .. dim, 3]], [seq(cornerPoints[1 .. dim, 4]), cornerPoints[1 .. dim, 3]]], align = {above, right}, font = [Courier, bold, 20])
Hello Everyone
I created a file to sum up 5 vectors and display them in 3d space. (see below)
I would like to optimize my input so that I input the total length of the vector and the angle in the x-y plane and the angle in the x-z plane.
At the top of the document there is an idea from a different pots how to do it with 2d vectors but I can't get it to work with 3d vectors.
Any ideas?
Thanks in advance!
3d_vector.mw
I'm trying to replicate this video: https://www.youtube.com/watch?app=desktop&v=EUVPsxYIauo
Note that the variables a, b, c are integers.
Here is my Maple worksheet:
eq1 := a*b + c = 2020;
                     eq1 := a b + c = 2020
eq2 := b*c + a = 2021;
                     eq2 := b c + a = 2021
sol1 := isolve({eq1, eq2});
              sol1 := {a = 2021, b = 0, c = 2020}
However, there is another solution {a = 673, b = 2, c = 674}. Why does isolve not find the second solution? I tried 'allvalues', but it did not work.
Hello all,
I need to perform this numerical integration through maple. Having been a complete beginner I just wanted to ask if at all this is feasible using maple? I have done similar stuff using mathematica, but would like to try and calculate the same using maple, especially with the gamma function in the above equation.
W_{-} := M*sqrt(Pi)/(2*A*a)*(x*erf(a*x) + (1/(a*sqrt(Pi)))*exp(-a^2*x^2)) + (M/(A*a*sqrt(Pi)))*evalf(Int(exp(-epsilon^2/(4*a^2) - tau*epsilon^3)*(cos(epsilon*x) - 1)/epsilon^2, epsilon = 0..infinity)) + (2*m/Pi)*evalf(Int(exp(-tau*epsilon^3)*(cos(epsilon*x) - 1)/epsilon^2, epsilon = 0..infinity)) + (M/(A*a*sqrt(Pi)))*evalf(Int((1/(2*a^2) + 3*tau*epsilon)*exp(-epsilon^2/(4*a^2) - tau*epsilon^3), epsilon = 0..infinity)) - (2*m/Pi)*tau^(1/3)*GAMMA(2/3) -m*x;
W_{+} := M*sqrt(Pi)/(2*A*a)*(x*erf(a*x) + (1/(a*sqrt(Pi)))*exp(-a^2*x^2)) + (M/(A*a*sqrt(Pi)))*evalf(Int(exp(-epsilon^2/(4*a^2) - tau*epsilon^3)*(cos(epsilon*x) - 1)/epsilon^2, epsilon = 0..infinity)) + (2*m/Pi)*evalf(Int(exp(-tau*epsilon^3)*(cos(epsilon*x) - 1)/epsilon^2, epsilon = 0..infinity)) + (M/(A*a*sqrt(Pi)))*evalf(Int((1/(2*a^2) + 3*tau*epsilon)*exp(-epsilon^2/(4*a^2) - tau*epsilon^3), epsilon = 0..infinity)) - (2*m/Pi)*tau^(1/3)*GAMMA(2/3) + m*x;
M := 6.3*10^{17};
t := 7200;
a := 10^3 ;
m := 1;
D := 10^{-5};
Omega := 1.7*10^{23}
tau := 10^{-14}
A := tau/(D*Omega*t);
Any suggestions as how to proceed would be very helpful. Thanks.
EDIT: I would like plot the functions W_{+} and W_{-} as a function of x-axis, with both representing either side of x=0.
EDIT: for some reason I cannot reply to the comments but I have modified the question based on the comments below.
First 98 99 100 101 102 103 104 Last Page 100 of 2430
