is there any package out there to calculate Wigner J symbols and Clebsch-Gordon coefficients in Maple
Good day to all of you nice people.
I'm currently attempting to plot a vector field where each component of the vector is defined by the equations S_x, S_y, and S_z, which are functions of the radial coordinate. Here is a depiction of how the vectors change with respect to r:
The next step, which I'm unsure how to do, is to plot the vectors around the z-direction, or I should say, in phi direction, to achieve something similar to this example:
Thank you a lot for your kind help.
Here is my code:
Maple_Question.mw
I am running Maple 2023 - yes I should update - and I found a weird "bug" if you could call it that. For different versions of the Physics package I am getting different answers on the same problem.
This is what I was getting when I run Version 1410:
with(Physics):
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1744. The version installed in this computer is 1410 created 2023, March 11, 12:59 hours Pacific Time, found in the directory /Users/b2hull/maple/toolbox/2023/Physics Updates/lib/`
Setup(mathematicalnotation=true):
g_[arbitrary]:
`Systems of spacetime coordinates are:`*{X = (x1, x2, x3, x4)}
`Default differentiation variables for d_, D_ and dAlembertian are:`*{X = (x1, x2, x3, x4)}
`Setting `*lowercaselatin_is*` letters to represent `*space*` indices`
`The arbitrary metric in coordinates `*[x1, x2, x3, x4]
`Signature: `(`- - - +`)
LG :=(g_[~mu,~nu]*Ricci[mu,nu])*sqrt(-%g_[determinant]);
Physics:-g_[`~mu`, `~nu`]*Physics:-Ricci[mu, nu]*(-%g_[determinant])^(1/2)
SG:=Intc(LG,X)
Int(Int(Int(Int(Physics:-g_[`~mu`, `~nu`]*Physics:-Ricci[mu, nu]*(-%g_[determinant])^(1/2), x1 = -infinity .. infinity), x2 = -infinity .. infinity), x3 = -infinity .. infinity), x4 = -infinity .. infinity)
EQ:=Fundiff(SG,%g_[~delta,~gamma])/sqrt(-%g_[determinant])
((1/2)*%g_[`~mu`, `~nu`]*Physics:-Ricci[mu, nu]*%g_[delta, gamma]*%g_[determinant]/(-%g_[determinant])^(1/2)+Physics:-Ricci[mu, nu]*(-%g_[determinant])^(1/2)*%g_[delta, `~mu`]*%g_[gamma, `~nu`])/(-%g_[determinant])^(1/2)
Simplify(subs(%g_=g_,EQ))
-(1/2)*Physics:-g_[delta, gamma]*Physics:-Ricci[nu, `~nu`]+Physics:-Ricci[delta, gamma]
And this is what I get if I used the latet update for 2023, Version 1683:
with(Physics):
`The "Physics Updates" version in the MapleCloud is 1744. The version installed in this computer is 1683 created 2024, March 6, 17:43 hours Pacific Time, found in the directory /Users/b2hull/maple/toolbox/2023/Physics Updates/lib/`
g_[arbitrary]:
SG:=Intc(LG,X)
-(1/2)*%g_[delta, gamma]*Physics:-g_[`~mu`, `~nu`]*Physics:-Ricci[mu, nu]
Strange right? I bring this up because it makes me wonder about potential errors in other computations...
The answer - equation 6 - in 1410 is the correct answer. This is simply a derivation of the Einstein Tensor.
Or some other type of calculation in indexed set. I tried the maple android app with no luck. How is done in maple?
Hey there guys, was wondering if I could get some help with this - I'm pretty new to maple.
I'm trying to take a collection of coupled ODEs I have and get maple put them in state-space form for me. I've tried a few different approaches and messed around with a few different commands but havent managed to quite make it work. At the moment I'm trying to make a DiffEquation object and then use StateSpace to get the state space representation, but I keep getting this "diff-eq is not a polynomial" line as a warning when I run the DiffEquation command and as an error when I try to conver to state space.
Could anyone tell me why I'm getting this and what the best/correct way to go about this is?
Cheers
Triple Cart derivation
with(DynamicSystems)
cart1eom := `m__1 `*(diff(v__1(t), t, t))+c__1*(diff(v__1(t), t))+k*(v__1(t)-v__2(t)) = F
`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*(v__1(t)-v__2(t)) = F
cart2eom := m__2*(diff(v__2(t), t, t))+c__2*(diff(v__2(t), t))+k(v__2(t)-v__3(t)) = k*(v__1-v__2(t))
m__2*(diff(diff(v__2(t), t), t))+c__2*(diff(v__2(t), t))+k(v__2(t)-v__3(t)) = k*(v__1-v__2(t))
cart3eom := m__3*(diff(v__3(t), t, t))+c__3*(diff(v__3(t), t)) = k*(v__2-v__3(t))
m__3*(diff(diff(v__3(t), t), t))+c__3*(diff(v__3(t), t)) = k*(v__2-v__3(t))
F := alpha*k__m*k__g*V(t)/(R*r)-k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2)``
expand(cart1eom)
`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*v__1(t)-k*v__2(t) = alpha*k__m*k__g*V(t)/(R*r)-k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2)
`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*v__1(t)-k*v__2(t)-alpha*k__m*k__g*V(t)/(R*r)+k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2) = 0
collect(`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*v__1(t)-k*v__2(t)-alpha*k__m*k__g*V(t)/(R*r)+k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2) = 0, [v__1(t), v__2, diff(v__1(t), t, t), diff(v__1(t), t)])
k*v__1(t)-k*v__2(t)+`m__1 `*(diff(diff(v__1(t), t), t))+(c__1+k__m^2*k__g^2/(R*r^2))*(diff(v__1(t), t))-alpha*k__m*k__g*V(t)/(R*r) = 0
cart1eom``
eoms := [cart1eom, cart2eom, cart3eom]
[`m__1 `*(diff(diff(v__1(t), t), t))+c__1*(diff(v__1(t), t))+k*(v__1(t)-v__2(t)) = alpha*k__m*k__g*V(t)/(R*r)-k__m^2*k__g^2*(diff(v__1(t), t))/(R*r^2), m__2*(diff(diff(v__2(t), t), t))+c__2*(diff(v__2(t), t))+k(v__2(t)-v__3(t)) = k*(v__1-v__2(t)), m__3*(diff(diff(v__3(t), t), t))+c__3*(diff(v__3(t), t)) = k*(v__2-v__3(t))]
sys_1 := DiffEquation(eoms, [V], [v__3], statevariable = [v__1, v__2, v__3])
_m2358947700544
StateSpace(sys_1)
_m2358947252000
Download 403TripleCart.mw
I`m trying execute the example of Deeplearnig:
with(DeepLearning);
v1 := Vector(8, i -> i, datatype = float[8]);
v2 := Vector(8, [-1.0, 1.0, 5.0, 11.0, 19.0, 29.0, 41.0, 55.0], datatype = float[8]);
model := Sequential([DenseLayer(1, inputshape = [1])]);
model := Vector(2, {(1) = Typesetting:-mi("`DeepLearning
   Model`"), (2) = Typesetting:-mi("`<keras.engine.sequential.Se\
  quential object at 0x000001C5B6520700>`")})
model:-Compile(optimizer = "sgd", loss = "mean_squared_error");
model:-Fit(v1, v2, epochs = 500);
"<Python object: <keras.callbacks.History object at 0x000001C5CC\
  EE9DE0>>"
convert("<Python object: <keras.callbacks.History object at 0x000001C5CCEE9DE0>>", 'symbol');
<Python object: <keras.callbacks.History object at 0x000001C5CCE\
  E9DE0>>
model:-Predict([10]);
But, finally, there is this error:
Error, (in Predict) AttributeError: 'CatchOutErr' object has no attribute 'flush'
['Traceback (most recent call last):\n', '  File "C:\\Program Files\\Maple 2023\\Python.X86_64_WINDOWS\\lib\\site-packages\\keras\\utils\\traceback_utils.py", line 70, in error_handler\n    raise e.with_traceback(filtered_tb) from None\n', '  File "C:\\Program Files\\Maple 2023\\Python.X86_64_WINDOWS\\lib\\site-packages\\keras\\utils\\io_utils.py", line 80, in print_msg\n    sys.stdout.flush()\n', "AttributeError: 'CatchOutErr' object has no attribute 'flush'\n"]
What`s is happening?
I have a complicated bivariate function f(Gamma,rho) that is a RootOf of a quartic. I know that it is strictly positive (one of the four roots at least) for Gamma=0..10 and rho in (-1,+1), with bounds excluded.
I need to find the signs of its first and second derivatives (wrt to Gamma and wrt to rho: 4 derivatives in total).
I encounter numerical issues when I plot3d the derivatives using D[]() vs. fdiff() (numerical function evaluations of the RootOf). I was hoping for the two commands to produce the same output, but they don't it seems. What's going on?
Script:
_quartic := RootOf(-8*(rho + 1)^4*_Z^4 + 12*(rho + 1)^3*Gamma*(rho - 1)*_Z^3 - 5*(rho + 1)^2*(-4/5 + Gamma^2*rho^2 + 2*(-2/5 - Gamma^2)*rho + Gamma^2)*_Z^2 - 4*(rho + 1)*Gamma*(rho^2 - 1)*_Z + Gamma^2*(rho + 1)*(rho - 1)^2);
convert(_quartic,radical):
f(Gamma,rho) := simplify(%):
RootOf((8*rho^3+24*rho^2+24*rho+8)*_Z^4+(-12*Gamma*rho^3-12*Gamma*rho^2+12*Gamma*rho+12*Gamma)*_Z^3+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*_Z^2+(4*Gamma*rho^2-4*Gamma)*_Z-Gamma^2*rho^2+2*rho*Gamma^2-Gamma^2)
Synthetic representation of derivatives
der1_Gamma := diff(_quartic, Gamma):
der1_rho := diff(_quartic, rho):
Diff('f(Gamma,rho)', Gamma) = collect~(normal(eval(der1_Gamma, _quartic = 'f(Gamma,rho)')), 'f(Gamma,rho)');
Diff('f(Gamma,rho)', rho) = collect~(normal(eval(der1_rho, _quartic = 'f(Gamma,rho)')), 'f(Gamma,rho)');
der2_Gamma := diff(der1_Gamma, Gamma):
der2_rho := diff(der1_rho, rho):
Diff('f(Gamma,rho)', Gamma$2) = collect~(normal(eval(der2_Gamma, _quartic = 'f(Gamma,rho)')), 'f(Gamma,rho)');
Diff('f(Gamma,rho)', rho$2) = collect~(normal(eval(der2_rho, _quartic = 'f(Gamma,rho)')), 'f(Gamma,rho)');
Diff(f(Gamma, rho), Gamma) = -((-6*rho^3-6*rho^2+6*rho+6)*f(Gamma, rho)^3+(5*Gamma*rho^3-5*Gamma*rho^2-5*Gamma*rho+5*Gamma)*f(Gamma, rho)^2+(2*rho^2-2)*f(Gamma, rho)-Gamma*rho^2+2*Gamma*rho-Gamma)/((16*rho^3+48*rho^2+48*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^3-18*Gamma*rho^2+18*Gamma*rho+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*f(Gamma, rho)+2*Gamma*rho^2-2*Gamma)
Diff(f(Gamma, rho), rho) = -(1/2)*((24*rho^2+48*rho+24)*f(Gamma, rho)^4+(-36*Gamma*rho^2-24*Gamma*rho+12*Gamma)*f(Gamma, rho)^3+(15*Gamma^2*rho^2-10*Gamma^2*rho-5*Gamma^2-8*rho-8)*f(Gamma, rho)^2+8*Gamma*rho*f(Gamma, rho)-2*rho*Gamma^2+2*Gamma^2)/((16*rho^3+48*rho^2+48*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^3-18*Gamma*rho^2+18*Gamma*rho+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*f(Gamma, rho)+2*Gamma*rho^2-2*Gamma)
Diff(f(Gamma, rho), Gamma, Gamma) = ((448*rho^8+1792*rho^7+1792*rho^6-1792*rho^5-4480*rho^4-1792*rho^3+1792*rho^2+1792*rho+448)*f(Gamma, rho)^8+(-1632*Gamma*rho^8-3264*Gamma*rho^7+3264*Gamma*rho^6+9792*Gamma*rho^5-9792*Gamma*rho^3-3264*Gamma*rho^2+3264*Gamma*rho+1632*Gamma)*f(Gamma, rho)^7+(2120*Gamma^2*rho^8-8480*Gamma^2*rho^6-208*rho^7+12720*Gamma^2*rho^4-624*rho^6-208*rho^5-8480*Gamma^2*rho^2+1040*rho^4+1040*rho^3+2120*Gamma^2-208*rho^2-624*rho-208)*f(Gamma, rho)^6+(-1200*Gamma^3*rho^8+2400*Gamma^3*rho^7+2400*Gamma^3*rho^6-7200*Gamma^3*rho^5+640*Gamma*rho^7+640*Gamma*rho^6+7200*Gamma^3*rho^3-1920*Gamma*rho^5-2400*Gamma^3*rho^2-1920*Gamma*rho^4-2400*Gamma^3*rho+1920*Gamma*rho^3+1200*Gamma^3+1920*Gamma*rho^2-640*Gamma*rho-640*Gamma)*f(Gamma, rho)^5+(250*Gamma^4*rho^8-1000*Gamma^4*rho^7+1000*Gamma^4*rho^6+1000*Gamma^4*rho^5-632*Gamma^2*rho^7-2500*Gamma^4*rho^4+632*Gamma^2*rho^6+1000*Gamma^4*rho^3+1896*Gamma^2*rho^5+1000*Gamma^4*rho^2-1896*Gamma^2*rho^4+16*rho^6-1000*Gamma^4*rho-1896*Gamma^2*rho^3+32*rho^5+250*Gamma^4+1896*Gamma^2*rho^2-16*rho^4+632*Gamma^2*rho-64*rho^3-632*Gamma^2-16*rho^2+32*rho+16)*f(Gamma, rho)^4+(240*Gamma^3*rho^7-720*Gamma^3*rho^6+240*Gamma^3*rho^5+1200*Gamma^3*rho^4-32*Gamma*rho^6-1200*Gamma^3*rho^3-240*Gamma^3*rho^2+96*Gamma*rho^4+720*Gamma^3*rho-240*Gamma^3-96*Gamma*rho^2+32*Gamma)*f(Gamma, rho)^3+(-25*Gamma^4*rho^7+125*Gamma^4*rho^6-225*Gamma^4*rho^5+125*Gamma^4*rho^4+125*Gamma^4*rho^3-225*Gamma^4*rho^2+125*Gamma^4*rho-25*Gamma^4)*f(Gamma, rho)^2+(16*Gamma^3*rho^6-64*Gamma^3*rho^5+80*Gamma^3*rho^4-80*Gamma^3*rho^2+64*Gamma^3*rho-16*Gamma^3)*f(Gamma, rho)-5*Gamma^4*rho^6+30*Gamma^4*rho^5-75*Gamma^4*rho^4+100*Gamma^4*rho^3-75*Gamma^4*rho^2+30*Gamma^4*rho-5*Gamma^4)/(((16*rho^2+32*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^2+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^2-10*Gamma^2*rho+5*Gamma^2-4*rho-4)*f(Gamma, rho)+2*Gamma*rho-2*Gamma)*((16*rho^3+48*rho^2+48*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^3-18*Gamma*rho^2+18*Gamma*rho+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*f(Gamma, rho)+2*Gamma*rho^2-2*Gamma)^2)
Diff(f(Gamma, rho), rho, rho) = (1/4)*((21504*rho^6+129024*rho^5+322560*rho^4+430080*rho^3+322560*rho^2+129024*rho+21504)*f(Gamma, rho)^10+(-80640*Gamma*rho^6-347136*Gamma*rho^5-526080*Gamma*rho^4-245760*Gamma*rho^3+157440*Gamma*rho^2+199680*Gamma*rho+56064*Gamma)*f(Gamma, rho)^9+(127680*Gamma^2*rho^6+336512*Gamma^2*rho^5+122944*Gamma^2*rho^4-319744*Gamma^2*rho^3-18176*rho^5-246976*Gamma^2*rho^2-90880*rho^4+40576*Gamma^2*rho-181760*rho^3+53696*Gamma^2-181760*rho^2-90880*rho-18176)*f(Gamma, rho)^8+(-110016*Gamma^3*rho^6-112128*Gamma^3*rho^5+191808*Gamma^3*rho^4+172032*Gamma^3*rho^3+57344*Gamma*rho^5-105792*Gamma^3*rho^2+191488*Gamma*rho^4-59904*Gamma^3*rho+192512*Gamma*rho^3+24000*Gamma^3+2048*Gamma*rho^2-94208*Gamma*rho-37888*Gamma)*f(Gamma, rho)^7+(54960*Gamma^4*rho^6-28480*Gamma^4*rho^5-102480*Gamma^4*rho^4+56960*Gamma^4*rho^3-74176*Gamma^2*rho^5+40080*Gamma^4*rho^2-126144*Gamma^2*rho^4-28480*Gamma^4*rho+41088*Gamma^2*rho^3+7440*Gamma^4+138368*Gamma^2*rho^2+5120*rho^4+19776*Gamma^2*rho+20480*rho^3-25536*Gamma^2+30720*rho^2+20480*rho+5120)*f(Gamma, rho)^6+(-15300*Gamma^5*rho^6+30000*Gamma^5*rho^5-2100*Gamma^5*rho^4-24000*Gamma^5*rho^3+50048*Gamma^3*rho^5+14100*Gamma^5*rho^2+5632*Gamma^3*rho^4-6000*Gamma^5*rho-89856*Gamma^3*rho^3+3300*Gamma^5-1024*Gamma^3*rho^2-13056*Gamma*rho^4+39808*Gamma^3*rho-31232*Gamma*rho^3-4608*Gamma^3-15360*Gamma*rho^2+10752*Gamma*rho+7936*Gamma)*f(Gamma, rho)^5+(1875*Gamma^6*rho^6-6250*Gamma^6*rho^5+7125*Gamma^6*rho^4-3500*Gamma^6*rho^3-18316*Gamma^4*rho^5+2125*Gamma^6*rho^2+25540*Gamma^4*rho^4-2250*Gamma^6*rho+12072*Gamma^4*rho^3+875*Gamma^6-26520*Gamma^4*rho^2+12992*Gamma^2*rho^4+6244*Gamma^4*rho+10240*Gamma^2*rho^3+980*Gamma^4-15488*Gamma^2*rho^2-9728*Gamma^2*rho-512*rho^3+3008*Gamma^2-1536*rho^2-1536*rho-512)*f(Gamma, rho)^4+(3320*Gamma^5*rho^5-9240*Gamma^5*rho^4+7600*Gamma^5*rho^3-560*Gamma^5*rho^2-6144*Gamma^3*rho^4-1320*Gamma^5*rho+4992*Gamma^3*rho^3+200*Gamma^5+6784*Gamma^3*rho^2-4992*Gamma^3*rho+1024*Gamma*rho^3-640*Gamma^3+1536*Gamma*rho^2-512*Gamma)*f(Gamma, rho)^3+(-200*Gamma^6*rho^5+800*Gamma^6*rho^4-1200*Gamma^6*rho^3+800*Gamma^6*rho^2+1248*Gamma^4*rho^4-200*Gamma^6*rho-3136*Gamma^4*rho^3+1920*Gamma^4*rho^2+576*Gamma^4*rho-768*Gamma^2*rho^3-608*Gamma^4+768*Gamma^2*rho)*f(Gamma, rho)^2+(-16*Gamma^5*rho^4+192*Gamma^5*rho^3-480*Gamma^5*rho^2+448*Gamma^5*rho+256*Gamma^3*rho^3-144*Gamma^5-384*Gamma^3*rho^2+128*Gamma^3)*f(Gamma, rho)-20*Gamma^6*rho^4+80*Gamma^6*rho^3-120*Gamma^6*rho^2+80*Gamma^6*rho-32*Gamma^4*rho^3-20*Gamma^6+96*Gamma^4*rho^2-96*Gamma^4*rho+32*Gamma^4)/(((16*rho^2+32*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^2+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^2-10*Gamma^2*rho+5*Gamma^2-4*rho-4)*f(Gamma, rho)+2*Gamma*rho-2*Gamma)*((16*rho^3+48*rho^2+48*rho+16)*f(Gamma, rho)^3+(-18*Gamma*rho^3-18*Gamma*rho^2+18*Gamma*rho+18*Gamma)*f(Gamma, rho)^2+(5*Gamma^2*rho^3-5*Gamma^2*rho^2-5*Gamma^2*rho+5*Gamma^2-4*rho^2-8*rho-4)*f(Gamma, rho)+2*Gamma*rho^2-2*Gamma)^2)
Signs of derivatives: fdiff (numerical function evaluations of the RootOf) vs. D[]()
_quartic := RootOf(-8*(rho + 1)^4*_Z^4 + 12*(rho + 1)^3*Gamma*(rho - 1)*_Z^3 - 5*(rho + 1)^2*(-4/5 + Gamma^2*rho^2 + 2*(-2/5 - Gamma^2)*rho + Gamma^2)*_Z^2 - 4*(rho + 1)*Gamma*(rho^2 - 1)*_Z + Gamma^2*(rho + 1)*(rho - 1)^2):
plot3d(_quartic, Gamma=0..10, rho=-1..+1, labels=[Gamma,rho,Lambda(Gamma,rho)],axesfont=["helvetica","roman",20],labelfont=["helvetica","roman",30]);
Define it as a f and test it for Gamma=1 and rho=0.5
f := (Gamma,rho) -> RootOf(-8*(rho + 1)^4*_Z^4 + 12*(rho + 1)^3*Gamma*(rho - 1)*_Z^3 - 5*(rho + 1)^2*(-4/5 + Gamma^2*rho^2 + 2*(-2/5 - Gamma^2)*rho + Gamma^2)*_Z^2 - 4*(rho + 1)*Gamma*(rho^2 - 1)*_Z + Gamma^2*(rho + 1)*(rho - 1)^2):
evalf(f(1.0,0.5));
HFloat(0.5110796212870378)
Value at zero:
f(0,0):
allvalues(%):
fl := select(is, [allvalues(f(0,0))], positive)[];evalf(%);
(1/2)*2^(1/2)
.7071067810
Value at infinity (commented out because too slow)
#limit(f(x,y), {x = infinity, y = 0}):
#fh := select(is, [allvalues(%)], positive)[];evalf(%);
Derivative at zero:
allvalues([D[1](f)(0,0)]):
Dfl := %[1][];
-1/4
Derivative at a point, evaluated, vs numerical derivative at a point:
D[1](f)(1,0.5):
evalf(%);
fdiff(f(x,y), x, {x = 1.0, y = 0.5});
fdiff(f, [1], [1.0,0.5]);
D[2](f)(1,0.5):
evalf(%);
fdiff(f(x,y), y, {x = 1.0, y = 0.5});
fdiff(f, [2], [1.0,0.5]);
HFloat(-0.05086932918910799)
-0.5086932919e-1
-0.5086932919e-1
HFloat(-0.05166477232109392)
-0.5166477232e-1
-0.5166477232e-1
Can make a function out of fdiff
fDfG := (Gamma,rho) -> fdiff(f, [1], [Gamma,rho]);
fDfr := (Gamma,rho) -> fdiff(f, [2], [Gamma,rho]);
proc (Gamma, rho) options operator, arrow; fdiff(f, [1], [Gamma, rho]) end proc
proc (Gamma, rho) options operator, arrow; fdiff(f, [2], [Gamma, rho]) end proc
Check for numerical values close to thresholds:
Digits := 15:
evalf('D[1]'(f)(0.1e-8,0.5));fdiff(f, [1], [0.1e-8,0.5]);
evalf('D[1]'(f)(0.1e-7,0.5));fdiff(f, [1], [0.1e-7,0.5]);
evalf('D[1]'(f)(0.1e-5,0.5));fdiff(f, [1], [0.1e-5,0.5]);
evalf('D[1]'(f)(0.00001,0.5));fdiff(f, [1], [0.00001,0.5]);
evalf('D[1]'(f)(0.001,0.5));fdiff(f, [1], [0.001,0.5]);
evalf('D[2]'(f)(1,-0.99));fdiff(f, [2], [1,-0.99]);
evalf('D[2]'(f)(1,-0.97));fdiff(f, [2], [1,-0.97]);
evalf('D[2]'(f)(1,-0.1));fdiff(f, [2], [1,-0.1]);
evalf('D[2]'(f)(1,0.98));fdiff(f, [2], [1,0.98]);
57735026.8022959
57735026.8022959
-0.833333329724894e-1
-0.833332972489415e-1
-0.833329724894151e-1
-0.832972489466445e-1
-223.615892086941
-223.615892086941
-43.0236130145893
-43.0236130145893
-.212392503268663
-.212392503268663
-0.127828146340716e-2
-223.615892086941
-223.615892086941
Compare with D (vertical range here to prevent effect of large values from fdiff near zero):
d1G := plot3d([D[1](f), fDfG], 0..10, -0.95..+0.95, view=-0.3..0, color = [red, blue]);
d1r := plot3d([D[2](f), fDfr], 0..10, -0.95..+0.95, color = [red, blue]);
Second derivatives:
evalf('D[1,1]'(f)(1.0,0.5));
fdiff(f, [1, 1], [1.0,0.5]);
evalf('D[2,2]'(f)(1.0,0.5));
fdiff(f, [2, 2], [1.0,0.5]);
fD2fG := (Gamma,rho) -> fdiff(f, [1, 1], [Gamma]);
fD2fr := (Gamma,rho) -> fdiff(f, [2, 2], [Gamma]);
0.266607527050519e-1
.151600577769391
.151600577769391
proc (Gamma, rho) options operator, arrow; fdiff(f, [1, 1], [Gamma]) end proc
proc (Gamma, rho) options operator, arrow; fdiff(f, [2, 2], [Gamma]) end proc
d2G:= plot3d([D[1,1](f), fD2fG], 0..10, -0.9..+0.9, color = [red, blue]);
d2r:= plot3d([D[2,2](f), fD2fr], 0..10, -0.9..+0.9, color = [red, blue]);
d1d2G := plot3d([fDfG, fD2fG], 0.1e-6 .. 10, -0.98 .. +0.98, axesfont=["helvetica","roman",20],labelfont=["helvetica","roman",30], size=[1000,1000]);
d1d2r := plot3d([fDfr, fD2fr], 0.1e-6 .. 10, -0.98 .. +0.98, axesfont=["helvetica","roman",20],labelfont=["helvetica","roman",30], size=[1000,1000]);
Download signs_derivatves_bivariate.mw
Why does no substitution work on functions with s(n+1,t) (see eqns (2-8))? Also (&PartialD;)/(&PartialD; (sigma2*t))=1/(sigma2)(&PartialD;)/(&PartialD; t), how can I do it on Maple?shift.mw
I am trying to load the third-party package 'CPC Program Library (qub.ac.uk)' by following the instructions as in 'how to install wkptest? - MaplePrimes'. But encounter with Errors: '
Error, `:` unexpected
with(wkptest);
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received wkptest
sourcefolder:=cat(kernelopts('C:\Users\ahmed\Downloads\adty_v1_0'),"/wkptest");
installfolder:=cat(kernelopts('homedir'),"/maple/toolbox/wkptest/lib");
FileTools:-MakeDirectory(installfolder, 'recurse'=true);
libraryfile:=cat(installfolder,"/wkptest.mla");
try
  FileTools:-Remove(libraryfile);
catch:
end try:
LibraryTools:-Create(libraryfile);
libname:=libraryfile,libname;
read cat(sourcefolder,"/wkptest_cpc");
with(wkptest);
Download exam_wkptest1.mws
When I calculate the difference between two dates with the same day using the DateDifference Calendar function, I don't get an integer number of months, but results with extra days, hours, minutes, seconds and milliseconds. How can I calulate the actual number of months?
I appreciate any help.
with(Calendar)
d1 := Date(2024, 1, 5, 0, 0, 0)
_m4674925856
d2 := Date(2024, 5, 5, 0, 0, 0)
_m4881744064
DateDifference(d1, d2, 'units' = 'mixed')
4*Units:-Unit(mo)+2*Units:-Unit(d)+20*Units:-Unit(h)+3*Units:-Unit(min)+48*Units:-Unit(s)+800*Units:-Unit(ms)
Download DateDifference.mw
How can I calculate the integral of Legendre function P(n,theta) ?
int(cos(theta)*P(n,theta),theta=0..pi) ;
I never used Maple's StringTools:-RegSubs before.
I have a Latex string generated by Maple that has this form
"......    \\textrm{ ......   }  .... "
Where the dots mean anything, including space characters.  I need to change the part of the string  "\\textrm{ ...... }" to this
"......  \\begin{minipage}{\\linewidth}\\textrm{  ......   }\\end{minipage}  .... "
It is easy to change the opening part. Here is an example
s:="A& B& \\textrm{The fundamental matrix has } &C ";
s:=StringTools:-SubstituteAll(s,"\\textrm{","\\begin{minipage}{\\linewidth}\\textrm{");
Gives
The problem is how to replace the closing "}"  with "}\\end{minipage}".   I can't just replace "}" with "}\\end{minipage}" using SubstituteAll because I need to only change the "}" that closes the corresponding "\\textrm{" and not any other "}" that could be in the string.
So I need to use pattern matching or regular expression substitutions. The examples in help are not easy to understand.
Basically I need regular expression that matches
                        "\\textrm{ WILDCARD * }"
and change it to
                        "\\begin{minipage}{\\linewidth}\\textrm{ WILDCARD * }\\end{minipage}"
Any one know how to use Maple's egular expression to do this substitution using the above example?
Maple 2024 on windows 10.
Update
Thanks for the replies. I ended up writing small function that simply scan the string and do the replacement.
I want to analyze a quartic equation: rho-analysis.mw. I am interested in positive roots, which I need expressed in explicit/closed form.
I include four questions in the script.
EDIT (since my question was originally tagged as incomplete and even duplicate):
Above all I am trying to understand:
  1. Why implicitplot3d returns a unique strictly positive root for all rho and Gamma but plot() of the quartic evaluated for a specific pair of value returns three positive roots?
  2. rho is a correlation coefficient, thus bounded in (-1,+1): how to adjust the precision of the slider in Explore() so that I can play around with multiple rho values within said range?
Can this be better done in Maple ? , see worksheet.
First 112 113 114 115 116 117 118 Last Page 114 of 2430
