How to integrate the below term
int((n*p+exp(n*p))*exp(-p)*p^(s-1)*f^s/((n*p+exp(2*n*p))*factorial(s)), p = 0 .. 1);
eval(%);
Hey! I need help ASAP, because my maple file has been corrupted and i dont know what to do. Do you guys know how to recover a file? i can save it again as_mw. but should i change it to xml? or how? i have the link to my maple file attached, so if someone can help me, it could be helpful! Because i have an upcoming exam. Thanks youu
I noticed tags on the post
https://mapleprimes.com/questions/238161-Why-Maple-Gives-Solution-To-Euler-Ode
keep disappearing.
I added tags "differential equation" and "dsolve" and so on.
Later on when I visit this site again I found the tags are all gone.
Why does Mapleprimes remove the tags on post?
Or is someone else removing the tags? If so, why? is something wrong with the tags I've added?
This happend twice on this one post. I noticed earlier today the tags were gone, so I added them again. And now I see the same thing. They are all gone.
How could I find the volume of this equation (x^2+y^2+z^2+12)^2=64(x^2+y^2) using triple integrals in both spherical and cylindrical coords ? Thank you !
I found that sometimes Maple gives
               Error, (in Typesetting:-Parse) too many levels of recursion
When using the Latex command on the output of Student:-ODEs:-ODESteps
Below is worksheet showing it works for some and gives error for others. Is there a workaround for this? I'd like to convert the steps to Latex.
This happens in worksheet using either Display->Typesetting level as EXTENDED or STANDARD
`The "Physics Updates" version in the MapleCloud is 1722 and is the same as the version installed in this computer, created 2024, April 12, 17:58 hours Pacific Time.`
ode:=diff(y(x),x)=0;
the_output:=Student:-ODEs:-ODESteps(ode,y(x)):
latex(the_output)
diff(y(x), x) = 0
\begin{array}{ccc}
 & {} & \textrm{Let's solve}
 {} & {} & \frac{d}{d x}y \! \left(x \right)=0
 \textrm{•} & {} & \textrm{Highest derivative means the order of the ODE is}1
 \textrm{•} & {} & \textrm{Integrate both sides with respect to}x
 {} & {} & \int \left(\frac{d}{d x}y \! \left(x \right)\right)d x =\int 0d x +\mathit{C1}
 \textrm{•} & {} & \textrm{Evaluate integral}
 {} & {} & y \! \left(x \right)=\mathit{C1}
 \textrm{•} & {} & \textrm{Solve for}y \! \left(x \right)
\end{array}
ode := diff(y(x), x, x, x ) + 3*diff(y(x), x, x) + 4*diff(y(x), x) + 2*y(x) = 0;
latex(the_output)
diff(diff(diff(y(x), x), x), x)+3*(diff(diff(y(x), x), x))+4*(diff(y(x), x))+2*y(x) = 0
Download latex_error_ODE_steps_maple_2024_april_13_2024.mw
update: Reported to Maplesoft support.
I have a proceure that returns 7 values. I cac get it to return ang single specific value ousing e.g [2] to get the second.
Or a range[3..6] for the third to sixth.
Is there a way to get specific seperated values e.g [1] and[[6]. The procedure is burried in a package so it is difficult to post.
This second order (Euler type) ode has no solution for the given two initial conditions. but Maple gives solution with one unresolved constant of integration.
ode:=x^2*diff(y(x),x$2)-2*y(x)=0;
ic:=y(0)=4,D(y)(0)=-1;
sol_no_IC:=dsolve(ode)
The IC's are given at x=0 as a trick to see what Maple will do. We see that at x=0 there is division by zero. So no solution exist for these IC's. But see what happens
sol_with_IC:=dsolve([ode,ic])
It seems Maple simply threw away the part of the solution it could not handle due to the x=0 and just returned the rest.
odetest(sol_with_IC,[ode,ic])
The correct answer should have been the NULL solution (i.e. no solution).
What Am I missing here? Why does Maple do this? Should Maple have returned such a solution?
Maple 2024 on windows 10.
update:
update:
Here is another example ode. This is first order ode. Maple gives a solution that does not satisfy the initial condition also. I wish I can understand how Maple comes up with these solutions since when I solve these by hand I see it is not possible to satisfy the IC, hence no solution exist.
14876
ode:=diff(y(x),x)+y(x)/x=x^2;
ic:=y(0)=a;
diff(y(x), x)+y(x)/x = x^2
y(0) = a
dsolve(ode)
y(x) = ((1/4)*x^4+c__1)/x
sol:=dsolve([ode,ic])
y(x) = (1/4)*x^3
odetest(sol,[ode,ic])
[0, a]
Student:-ODEs:-ODESteps([ode,ic])
Error, (in Student:-ODEs:-applyICO1) numeric exception: division by zero
Download another_strange_solution_ode_maple_2024.mw
I can't figure out what Maple is complaining about with this error.  In fact, this is an exact copy/paste from another section in my document that runs fine.  This section, however, generates the error, "Error, missing operator `;`.
I appreciate any help!
for_mapleprimes_help.mw
If I set up
DGsetup([t, r, theta, phi, psi], M1, verbose)
then the frame-name M1 is displayed with every new execution group prompt as "M1 >"
How do I switch off the frame-name to be displayed at the prompt, so I only get ">" ?
It is irritating as heck !
The only way around this is to restart the kernel, then I can add new execution groups without frame-names displayed.
I am new to Maple Flow and am constantly having issues like the one shown below. A cell will become corrupted somehow, and the kernel will crash or freeze. I can save and quit, but if I re-open the file, the crash will happen again before I can diable evaluation. My questions:
  1. Has anyone else had this issue? Was it solvable?
  2. Can evaluation be disabled by default? Its possible in Maple but I don't see how in Flow.
  3. Can the kernel be restarted and reconnected (like Jupyter Lab)?
I cant expand the cell in question because of the crash, but this cell isn't the issue. This is happening all the time.
 is there anything to get hypergeo function to get algebric expression?
2*hypergeom([1/2, -k/2], [1 - k/2], csc(omega*T)^2)
how ca i change this expression to some function form?...i'm new to hypergeom functions..it somehow come to my thesis?
I have a simple tank design worksheet that calculates dimensions of a tank that I need to build to hold a given amount of liquid.  My question is this - when I include a "with(Units);" statement, the volume function gets rendered in operator prefix notation.  Why is this?  Is there a setting to prevent this from happening?  Thanks.
Without "with(Units);"...
With "with(Units);"...
I've included a worksheet that shows the function both with and without the inclusion of "with(Units);".
Tank_Design_Calculation_-_Units_Question_(v00).mw
Does Maple have built-in Finite Fourier Sine/Cosine Transformation which is defined as below?
2/L*int(f(x)*sin(n*Pi/L*x),x=0..L);
How can I get the finite Fourier transform for the derivatives of a function in terms of its own Fourier transform?
I know that the fouriersin/fouriercos commands of the inttrans package have the Fourier sine/cosine transformation for the interval from x=0 to infinity?
Best wishes
I am facing a kind of strange problem.  y'=y/x-5^y/x ,   y(0)=5 Cauche equation  it gives empty round brackets () . If I restart Maple engine and perform the same. Kindly help, what is this?
with(DEtools);
de1 := diff(y(x), x) = y(x)/x - 5^(-y(x)/x)
an := dsolve({de1, y(0) = 5}, y(x))
an := ()
I have two expressions, wo_theta and with_theta, which depend on multiple variables.
I would need your help to:
  1. Verify, as formally as possible, that wo_theta > with_theta always, i.e., for any value of theta different from zero (and regardless of the values taken up by the other variables)
  2. Show the above in a way that is easy and immediate to interpret (perhaps using some type of plot?)
In other words, I want to verify that as soon as I introduce any theta in my expression such expression becomes smaller:
local gamma;
gamma
assume(0 < gamma, 0 < nu__02, 0 < nu__01, 0 <= sigma__v, delta__1::real, delta__2::real, delta__3::real, theta::real);
interface(showassumed=0);
wo_theta := X__3*(-X__3*lambda__3 - delta__3*lambda__3 + DEV) + X__2*(-X__2*lambda__2 - delta__2*lambda__2 - nu__02) + X__1*(-X__1*lambda__1 - delta__1*lambda__1 - nu__01) + X__2*(nu__02 + DEV/2) + X__1*(nu__01 + DEV/2) - gamma*X__2^2*sigma__v^2/4 - gamma*X__1^2*sigma__v^2/4 + gamma*X__2*X__1*sigma__v^2/2;
X__3*(-X__3*lambda__3-delta__3*lambda__3+DEV)+X__2*(-X__2*lambda__2-delta__2*lambda__2-nu__02)+X__1*(-X__1*lambda__1-delta__1*lambda__1-nu__01)+X__2*(nu__02+(1/2)*DEV)+X__1*(nu__01+(1/2)*DEV)-(1/4)*gamma*X__2^2*sigma__v^2-(1/4)*gamma*X__1^2*sigma__v^2+(1/2)*gamma*X__2*X__1*sigma__v^2
with_theta := X__3*(-X__3*lambda__3 - theta*lambda__3 - delta__3*lambda__3 + DEV) + X__2*(-X__2*lambda__2 + theta*lambda__2 - delta__2*lambda__2 - nu__02) + X__1*(-X__1*lambda__1 + theta*lambda__1 - delta__1*lambda__1 - nu__01) + X__2*(nu__02 + DEV/2) + X__1*(nu__01 + DEV/2) - gamma*X__2^2*sigma__v^2/4 - gamma*X__1^2*sigma__v^2/4 + gamma*X__2*X__1*sigma__v^2/2 + theta*(lambda__1*(X__1 + delta__1 - theta) + lambda__2*(X__2 + delta__2 - theta) - lambda__3*(X__3 + delta__3 + theta));
X__3*(-X__3*lambda__3-theta*lambda__3-delta__3*lambda__3+DEV)+X__2*(-X__2*lambda__2+theta*lambda__2-delta__2*lambda__2-nu__02)+X__1*(-X__1*lambda__1+theta*lambda__1-delta__1*lambda__1-nu__01)+X__2*(nu__02+(1/2)*DEV)+X__1*(nu__01+(1/2)*DEV)-(1/4)*gamma*X__2^2*sigma__v^2-(1/4)*gamma*X__1^2*sigma__v^2+(1/2)*gamma*X__2*X__1*sigma__v^2+theta*(lambda__1*(X__1+delta__1-theta)+lambda__2*(X__2+delta__2-theta)-lambda__3*(X__3+delta__3+theta))
collect(with_theta, theta);
(-lambda__1-lambda__2-lambda__3)*theta^2+(-X__3*lambda__3+X__2*lambda__2+X__1*lambda__1+lambda__1*(X__1+delta__1)+lambda__2*(X__2+delta__2)-lambda__3*(X__3+delta__3))*theta+X__3*(-X__3*lambda__3-delta__3*lambda__3+DEV)+X__2*(-X__2*lambda__2-delta__2*lambda__2-nu__02)+X__1*(-X__1*lambda__1-delta__1*lambda__1-nu__01)+X__2*(nu__02+(1/2)*DEV)+X__1*(nu__01+(1/2)*DEV)-(1/4)*gamma*X__2^2*sigma__v^2-(1/4)*gamma*X__1^2*sigma__v^2+(1/2)*gamma*X__2*X__1*sigma__v^2
solve(wo_theta > with_theta, theta) assuming 0 < gamma, 0 < nu__02, 0 < nu__01, 0 < sigma__v, delta__1::real, delta__2::real, delta__3::real, theta::real;
solve(with_theta < wo_theta, theta);
Warning, solve may be ignoring assumptions on the input variables.
difference_term := (-lambda__1 - lambda__2 - lambda__3)*theta^2 + (X__1*lambda__1 + X__2*lambda__2 - X__3*lambda__3 + lambda__1*(X__1 + delta__1) + lambda__2*(X__2 + delta__2) - lambda__3*(X__3 + delta__3))*theta;
# I would expect such difference_term in theta to be always < 0, i.e., for any theta different from 0)
# (Note that lambda_1, lambda_2, and lambda_3 are always > 0, while theta, the three X and the three delta can be positive or negative. In other words, it suffices to show that the linear term in theta is always negative...)
solve(difference_term<0);
{X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0, lambda__2 < 0, lambda__3 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, X__2 < (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2, theta < 0, lambda__2 < 0, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__1, theta < 0, lambda__2 < 0, lambda__3 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, X__1 < (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0, lambda__3 < 0}, {X__1 = X__1, X__2 = X__2, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__2 = 0, theta < 0, lambda__3 < 0, -(1/2)*delta__3-(1/2)*theta < X__3}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < lambda__1, theta < 0, lambda__3 < 0, (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__2, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0, lambda__3 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < lambda__2, theta < 0, lambda__3 < 0, (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2 < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__1, 0 < lambda__2, theta < 0, lambda__3 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, X__1 < -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1, theta < 0, lambda__1 < 0, lambda__2 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__3 = 0, X__2 < -(1/2)*delta__2+(1/2)*theta, theta < 0, lambda__2 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < lambda__1, theta < 0, lambda__2 < 0, -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, lambda__3 = 0, X__1 < -(1/2)*delta__1+(1/2)*theta, theta < 0, lambda__1 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, lambda__3 = 0, 0 < lambda__1, theta < 0, -(1/2)*delta__1+(1/2)*theta < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < lambda__2, X__1 < -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1, theta < 0, lambda__1 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__3 = 0, 0 < lambda__2, theta < 0, -(1/2)*delta__2+(1/2)*theta < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < lambda__1, 0 < lambda__2, theta < 0, -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0, lambda__2 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < lambda__3, X__2 < (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2, theta < 0, lambda__2 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__1, 0 < lambda__3, theta < 0, lambda__2 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < lambda__3, X__1 < (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0}, {X__1 = X__1, X__2 = X__2, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__2 = 0, 0 < lambda__3, X__3 < -(1/2)*delta__3-(1/2)*theta, theta < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < lambda__1, 0 < lambda__3, theta < 0, (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__2, 0 < lambda__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, theta < 0, lambda__1 < 0}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < lambda__2, 0 < lambda__3, theta < 0, (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2 < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < lambda__1, 0 < lambda__2, 0 < lambda__3, theta < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, lambda__1 < 0, lambda__2 < 0, lambda__3 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < theta, lambda__2 < 0, lambda__3 < 0, (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2 < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__1, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, lambda__2 < 0, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < theta, lambda__1 < 0, lambda__3 < 0, (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__2 = X__2, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__2 = 0, 0 < theta, X__3 < -(1/2)*delta__3-(1/2)*theta, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < theta, 0 < lambda__1, X__1 < (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__2, lambda__1 < 0, lambda__3 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < theta, 0 < lambda__2, X__2 < (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__1, 0 < lambda__2, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, lambda__3 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < theta, lambda__1 < 0, lambda__2 < 0, -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__3 = 0, 0 < theta, lambda__2 < 0, -(1/2)*delta__2+(1/2)*theta < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < theta, 0 < lambda__1, X__1 < -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1, lambda__2 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, lambda__3 = 0, 0 < theta, lambda__1 < 0, -(1/2)*delta__1+(1/2)*theta < X__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, lambda__3 = 0, 0 < theta, 0 < lambda__1, X__1 < -(1/2)*delta__1+(1/2)*theta}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < theta, 0 < lambda__2, lambda__1 < 0, -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__3 = 0, 0 < theta, 0 < lambda__2, X__2 < -(1/2)*delta__2+(1/2)*theta}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__3 = 0, 0 < theta, 0 < lambda__1, 0 < lambda__2, X__1 < -(1/2)*(2*X__2*lambda__2-lambda__1*theta-lambda__2*theta+delta__1*lambda__1+delta__2*lambda__2)/lambda__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__3, lambda__1 < 0, lambda__2 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < theta, 0 < lambda__3, lambda__2 < 0, (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2 < X__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__1, 0 < lambda__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1, lambda__2 < 0}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < theta, 0 < lambda__3, lambda__1 < 0, (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__2 = X__2, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, lambda__2 = 0, 0 < theta, 0 < lambda__3, -(1/2)*delta__3-(1/2)*theta < X__3}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__2 = 0, 0 < theta, 0 < lambda__1, 0 < lambda__3, X__1 < (1/2)*(2*X__3*lambda__3+lambda__1*theta+lambda__3*theta-delta__1*lambda__1+delta__3*lambda__3)/lambda__1}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__2, 0 < lambda__3, lambda__1 < 0, -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1 < X__1}, {X__1 = X__1, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, lambda__1 = 0, 0 < theta, 0 < lambda__2, 0 < lambda__3, X__2 < (1/2)*(2*X__3*lambda__3+lambda__2*theta+lambda__3*theta-delta__2*lambda__2+delta__3*lambda__3)/lambda__2}, {X__2 = X__2, X__3 = X__3, delta__1 = delta__1, delta__2 = delta__2, delta__3 = delta__3, 0 < theta, 0 < lambda__1, 0 < lambda__2, 0 < lambda__3, X__1 < -(1/2)*(2*X__2*lambda__2-2*X__3*lambda__3-lambda__1*theta-lambda__2*theta-lambda__3*theta+delta__1*lambda__1+delta__2*lambda__2-delta__3*lambda__3)/lambda__1}
Download inequality.mw
First 118 119 120 121 122 123 124 Last Page 120 of 2430
