When I annotate a MapleFlow worksheet, I would like to typset some text as a superscript or a subscript for clarity, and to match the math expression. Is there a method to format text using superscripts and subscripts?
Does the Premium version of Maple Calculator for Android Smartphones come with Maple 2023 or does it have to be purchased separately. Thanking you in advance.
I want to simplify the following trigonometric expression, considering that m is an integer number. For this, I use the following command:
expr:= 4*cos(Pi*m)/(Pi*(2*m + 1));
simplify(%, assume=integer);
factor(%);
However, if I want to simplify the following trigonometric expression, m is an integer number, and alpha is a real number, using the following command will lead to the wrong answer because alpha is also considered an integer number. Please guide me.
4*cos(Pi*m+2*alpha*Pi)/(Pi*(2*m + 1));
factor(%);
Best wishes
I have noticed over a few questions I have asked recently.
I ask a question.                   It goes to top of active converstaions
Some  one answers                                            "
I Reply        *
A bit of time passes  so slides  of the top six/seven that show
Another Reply/Answer from someone                possibly does not show in active conversations.  I catch this by the orange flag or email notification
I reply                                 Does not appear in active conversations..
       This can kill the conversation chain.
I have even tried changing one of me replys to an answer but did not go to top active conversations again.
Has anyone else expperienced this?
If a type is not known, an error is thrown
type([],foo)
Error, type `foo` does not exist
Since no error is thrown, these types are known
type({},'{}');# why that output?
type([],'[]')
I would have expceted {} and [] to be listed as subtypes of set and list since their counterparts (nonemptylist and nonemptyset) exist. Technically the types {} and [] are not needed since negating
not(type([],nonemptylist));
not(type({},nonemptyset));
works.  However, the types exist, hence my question
How can I make a legend for this plot?
plot([17.85*(2.65*t^2 + 1 + 3*t)^2/t^2, 17.85*(2.65*t^2 - 47 + 3*t)^2/t^2, 17.85*(2.65*t^2 - 97 + 3*t)^2/t^2, 17.85*(2.65*t^2 - 147 + 3*t)^2/t^2, 17.85*(2.65*t^2 - 197 + 3*t)^2/t^2], t = 0 .. 25, labels = ['t', 'x'], labelfont = [Times, 12])
 I got the following figure.
Now I want to put a legend box in this plot for each color line. How can I do it?
I need help trying to remove some null elements from a listlist, that i converted from an Array.
Example: I have a list of coordinates r:=[[1,2],[1,3]], which i converted to an array, and nulled the first element.
r:=convert(r,Array):
r[1]:=NULL:
r:=convert(r,listlist):
I now have r=[[],[1,3]] after converting it back to a listlist. How do i remove the first element, which is an empty entry, such that i end up with r=[[1,3]]
Hi guys!
I'm looking for a way to type in the same "calculation" in Maple instead of the Word-package WordMat.
This is a screenshot from Word of the calculation I wanna do in Maple. But I can't figure out how to type it correct. Maybe you guys could post a screenshot of the same entered in Maple.
Note: (I'm a Maple-rookie, it might be a simple "trick")
I know how to assign/define fx IP, U and ZP. It's about calculating with the angle symbol in line, and getting a "readable" result.
Looking forward to hear from all of you...
I have a surface defined by C(x, y, x) = 0 that I visualize with implicitplot3d.
Using shading=shue does not suits me and I would like to define my own coloring function F(x, y, z).
The first error I got made me think that a coloring function cannot depend on 3 parameters.
But a simpler (and not visually satysfying function) F(x, y) already leads to an error, which makes me wonder if it is possible to use a colorig function with  implicitplot3d?
implicitplot3d_coloring.mw
_local(D, O);
A := [0, 0, 0];
B := [a, 0, 0];
C := [a, b, 0];
D := [0, b, 0];
S := [0, 0, h];
O := [x, y, z];
lineSC := Line(S, C);
lineSD := Line(S, D);
H := Projection(A, lineSC);
K := Projection(A, lineSD);
OH := H - O;
OK := K - O;
OC := C - O;
M := Matrix([OH, OK, OC]);
O := eval(O, %);
R := simplify(Distance(O, H));
                               O
Student:-MultivariateCalculus:-LineApplyFunction([0,0,h],
  [Typesetting:-mtable(Typesetting:-mtr(Typesetting:-mtd(a,
  rowalign = "", columnalign = "", groupalign = "",
  rowspan = "1", columnspan = "1"), rowalign = "",
  columnalign = "", groupalign = ""), Typesetting:-mtr(
  Typesetting:-mtd(b, rowalign = "", columnalign = "",
  groupalign = "", rowspan = "1", columnspan = "1"),
  rowalign = "", columnalign = "", groupalign = ""),
  Typesetting:-mtr(Typesetting:-mtd(uminus0h, rowalign = "",
  columnalign = "", groupalign = "", rowspan = "1",
  columnspan = "1"), rowalign = "", columnalign = "",
  groupalign = ""), foreground = "[0,0,0]", readonly = "false",
  align = "axis", rowalign = "baseline", columnalign = "center",
  groupalign = "{left}", alignmentscope = "true",
  columnwidth = "auto", width = "auto", rowspacing = "1.0ex",
  columnspacing = "0.8em", rowlines = "none",
  columnlines = "none", frame = "none",
  framespacing = "0.4em 0.5ex", equalrows = "false",
  equalcolumns = "false", displaystyle = "false", side = "right",
  minlabelspacing = "0.8em")],variables=[x,y,z],parameter=t,id=1)
  [Typesetting:-mtable(Typesetting:-mtr(Typesetting:-mtd(0,
  minlabelspacing = "0.8em")],variables=[x,y,z],parameter=t,id=2)
               /     2            2         / 2    2\ /
               |    h  a         h  b     h \a  + b / |
        HAssign|------------,------------,------------|
               | 2    2    2  2    2    2  2    2    2|
               \a  + b  + h  a  + b  + h  a  + b  + h \
                          /    2         2  /
                          |   h  b    h b   |
                   KAssign|0,-------,-------|
                          |   2    2  2    2|
                          \  b  + h  b  + h \
        /                2                       2
        |               h  a                    h  b
OHAssign|uminus0x + ------------,uminus0y + ------------,uminus0z
        |            2    2    2             2    2    2
        \           a  + b  + h             a  + b  + h
       / 2    2\ /
     h \a  + b / |
      2    2    2|
     a  + b  + h \
            /                      2                    2  /
            |                     h  b               h b   |
    OKAssign|uminus0x,uminus0y + -------,uminus0z + -------|
            |                     2    2             2    2|
            \                    b  + h             b  + h \
          OCAssign(uminus0x + a,uminus0y + b,uminus0z)
M := Matrix(3, 3, {(1, 1) = Typesetting:-mrow(Typesetting:-mo("&\
  uminus0;"), Typesetting:-mi("x"), Typesetting:-mo("+"),
   Typesetting:-mfrac(Typesetting:-mrow(Typesetting:-msup(Typese\
  tting:-mi("h"), Typesetting:-mn("2")), Typesetting:-mo("&Invis\
  ibleTimes;"), Typesetting:-mi("a")), Typesetting:-mrow(Typeset\
  ting:-msup(Typesetting:-mi("a"), Typesetting:-mn("2")),
   Typesetting:-mo("+"), Typesetting:-msup(Typesetting:-mi(\
  "b"), Typesetting:-mn("2")), Typesetting:-mo("+"),
   Typesetting:-msup(Typesetting:-mi("h"), Typesetting:-mn("2"))\
  ))), (1, 2) = Typesetting:-mrow(Typesetting:-mo("&uminus0;"),
   Typesetting:-mi("y"), Typesetting:-mo("+"), Typesetting:\
  -mfrac(Typesetting:-mrow(Typesetting:-msup(Typesetting:-mi("h"\
  ), Typesetting:-mn("2")), Typesetting:-mo("⁢"),\
   Typesetting:-mi("b")), Typesetting:-mrow(Typesetting:-msup(Ty\
  pesetting:-mi("a"), Typesetting:-mn("2")), Typesetting:-mo("&p\
  lus;"), Typesetting:-msup(Typesetting:-mi("b"), Typesetting:-m\
  n("2")), Typesetting:-mo("+"), Typesetting:-msup(Typesett\
  ing:-mi("h"), Typesetting:-mn("2"))))), (1, 3) = Typesetting:-\
  mrow(Typesetting:-mo("&uminus0;"), Typesetting:-mi("z"),
   Typesetting:-mo("+"), Typesetting:-mfrac(Typesetting:-mr\
  ow(Typesetting:-mi("h"), Typesetting:-mo("⁢"),
   Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-msup(Type\
  setting:-mi("a"), Typesetting:-mn("2")), Typesetting:-mo("&plu\
  s;"), Typesetting:-msup(Typesetting:-mi("b"), Typesetting:-mn(\
  "2"))))), Typesetting:-mrow(Typesetting:-msup(Typesetting:-mi(\
  "a"), Typesetting:-mn("2")), Typesetting:-mo("+"),
   Typesetting:-msup(Typesetting:-mi("b"), Typesetting:-mn("2"))\
  , Typesetting:-mo("+"), Typesetting:-msup(Typesetting:-mi\
  ("h"), Typesetting:-mn("2"))))), (2, 1) = Typesetting:-mrow(Ty\
  pesetting:-mo("&uminus0;"), Typesetting:-mi("x")), (2, 2) =
   Typesetting:-mrow(Typesetting:-mo("&uminus0;"), Typesetting:-\
  mi("y"), Typesetting:-mo("+"), Typesetting:-mfrac(Typeset\
  ting:-mrow(Typesetting:-msup(Typesetting:-mi("h"),
  pesetting:-mi("b"), Typesetting:-mn("2")), Typesetting:-mo("&p\
  lus;"), Typesetting:-msup(Typesetting:-mi("h"), Typesetting:-m\
  n("2"))))), (2, 3) = Typesetting:-mrow(Typesetting:-mo("&uminu\
  s0;"), Typesetting:-mi("z"), Typesetting:-mo("+"),
   Typesetting:-mfrac(Typesetting:-mrow(Typesetting:-mi("h"),
   Typesetting:-mo("⁢"), Typesetting:-msup(Typese\
  tting:-mi("b"), Typesetting:-mn("2"))), Typesetting:-mrow(Type\
  setting:-msup(Typesetting:-mi("b"), Typesetting:-mn("2")),
  "h"), Typesetting:-mn("2"))))), (3, 1) = Typesetting:-mrow(Typ\
  esetting:-mo("&uminus0;"), Typesetting:-mi("x"), Typesetting:-\
  mo("+"), Typesetting:-mi("a")), (3, 2) = Typesetting:-mro\
  w(Typesetting:-mo("&uminus0;"), Typesetting:-mi("y"),
   Typesetting:-mo("+"), Typesetting:-mi("b")), (3, 3) =
  mi("z"))})
Error, invalid input: eval received Matrix(3, 3, {(1, 1) = -x+h^2*a/(a^2+b^2+h^2), (1, 2) = -y+h^2*b/(a^2+b^2+h^2), (1, 3) = -z+h*(a^2+b^2)/(a^2+b^2+h^2), (2, 1) = -x, (2, 2) = -y+h^2*b/(b^2+h^2), (2, 3) = -z+h*b^2/(b^2+h^2), (3, 1) = -x+a, (3, 2) = -y+b, (3, 3) = -z}), which is not valid for its 2nd argument, eqns
       /     1       / 2  2      2        2  2    2  2    2  2
  R := |------------ \a  h  - 2 a  h z + a  x  + a  y  + a  z
       | 2    2    2
       \a  + b  + h
            2      2  2      2        2  2    2  2    2  2
     - 2 a h  x + b  h  - 2 b  h z + b  x  + b  y  + b  z
            2      2  2    2  2    2  2\\
     - 2 b h  y + h  x  + h  y  + h  z /|^(1/2)
Why this error ? Thank you.
I have a problem with the order  of the Eigenvalues and Vectors flipping. It is a bit random. I only found it trying to understand why a procedure sometimes rotated a conic one way and  then the other. This a really causing a quite a problem, I have only tried this in Maple 2024 so far. I have included screen shots to prove the effect.
M:=Matrix([[0,1],[1,0]]);
a,b:=Eigenvectors(M)  ;#click here and press enter again possible a 4 times, output can filp
Matrix(2, 2, {(1, 1) = 0, (1, 2) = 1, (2, 1) = 1, (2, 2) = 0})
Vector[column](%id = 36893491125752073860), Matrix(%id = 36893491125752073980)
a
Vector(2, {(1) = 1, (2) = -1})
b
Matrix(2, 2, {(1, 1) = 1, (1, 2) = -1, (2, 1) = 1, (2, 2) = 1})
Download 2024-03-21_Q_Eigenvector_output_flipping.mw
Hi I have an n×4 matrix of answer data to a questionnaire I would like to convert into a pivot table. So I can do a Chi2test.
How do I construct said table?
I have a complicated tensor expression that is defined wtih all indices down. However if i consider a one-up-one-down configuration it appears to introduce new terms that no longer produce the same result as the all down configuration. Not sure what to make of this.
IndexQuestion.mw
Hi, I am looking to color the area between the square and the circle (similar to the shadebetween command) and, in general, to color the area between two geometric shapes. Any suggestions? Thank you.
Couronne.mw
Just wonder if someone has any hints about correct code debugging.
Especially I'd like to know how often certain subroutines are called, and where from.
First 119 120 121 122 123 124 125 Last Page 121 of 2430
