I have done a complete clean reinstall of windows 10 and all programs on my pc.
In worksheet mode new files do not have the "default" red/brown text coluor ond the font is different.
Might not be a problem but thought that was the default?
What have I changed or have Maple defaults changed?
4
eq := x^3+x-7
x^3+x-7
Download 23-11-23_Q_inputs_to_worksheet_not_brown_red_colour.mw
Sorry if this is already known, but I haven't found the proper function call.
I just want to "print" this expression without evaluating the boolean calls
P(X <= 5) = P(-5 <= -X) = P(E(X) - 5 <= E(X) - X);
As it stands, this will evaluate to "false" which I obviously don't want.
I just want to use it as a displayer.
I have a problem in writing the Maple code of the image below, I don't know why the 3.5 answers are not available?
which one is better?
123.mw
0123.mw
I was trying to fill a Submit Software Change Request form a couple of times (with an interval of a couple of days) to report a small issue in Maple2023, which happens when I try to open an empty mpl-file. However, each time I received an error message. It looks like it is just broken.
Does anyone know if there is any reliable mechanism to provide feedback on MapleSoft products?
This is strange problem. I have matrix M. when doing latex(M), it works. But when doing latex(simplify(evalf[16](M))) it gives internal Maple error
Error, (in unknown) invalid input: ^ expects 2 arguments, but received 1
any workaround or ideas why it happens?
Maple 2023.2 on windows 10.
interface(version)
`Standard Worksheet Interface, Maple 2023.2, Windows 10, October 25 2023 Build ID 1753458`
`The "Physics Updates" version in the MapleCloud is 1590. The version installed in this computer is 1585 created 2023, October 29, 6:31 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2023\Physics Updates\lib\`
expr:=Matrix(3, 3, [[(-a^2-b^2-c^2)^(1/2),b*c/a,-b*c/a],[0,-(a^2+b^2)/(-a^2-b^2-c^2)^(1/2),c*a/b-c^2/(-a^2-b^2-c^2)^(1/2)],[0,0,0]]);
latex(expr);
Matrix(3, 3, {(1, 1) = sqrt(-a^2-b^2-c^2), (1, 2) = b*c/a, (1, 3) = -b*c/a, (2, 1) = 0, (2, 2) = -(a^2+b^2)/sqrt(-a^2-b^2-c^2), (2, 3) = c*a/b-c^2/sqrt(-a^2-b^2-c^2), (3, 1) = 0, (3, 2) = 0, (3, 3) = 0})
\left[\begin{array}{ccc}
\sqrt{-a^{2}-b^{2}-c^{2}} & \frac{b c}{a} & -\frac{b c}{a}
 0 & -\frac{a^{2}+b^{2}}{\sqrt{-a^{2}-b^{2}-c^{2}}} & \frac{c a}{b}-\frac{c^{2}}{\sqrt{-a^{2}-b^{2}-c^{2}}}
 0 & 0 & 0
\end{array}\right]
expr:=simplify(evalf[16](expr));
latex(expr);
Matrix(3, 3, {(1, 1) = 1.*sqrt(-a^2-b^2-c^2), (1, 2) = b*c/a, (1, 3) = -1.*b*c/a, (2, 1) = 0., (2, 2) = (-1.*a^2-1.*b^2)/sqrt(-a^2-b^2-c^2), (2, 3) = c*a/b-1.*c^2/sqrt(-1.000000000*a^2-1.000000000*b^2-1.000000000*c^2), (3, 1) = 0., (3, 2) = 0., (3, 3) = 0.})
(will send to Maplesoft)
Download latex_problem_after_using_evalf_nov_23_2023.mw
I want to write an if statement with a matrix R:
such that maple executes command 1 if R is Matrix(4, 4, [[0, 0, 0, 0], [0, 0, 0, 0], [0, 0, 0, 0], [0, 0, 0, 0]])
and command 2 if R is not zero.
What is the easiest way to go about this?
Anteriorly, I had done a question that you answered in the forum and it basically it was about the simplification of a equation. I'm posting the print of the screen and the code because the question of today is similarly, but not completely, because there are something that make more complicate the code that I devolved.
Hi := -Delta*S1^2 - J*S1*S2;
R1 := S1*exp(-beta*Hi);
R1 := add(R1, S1 = [--1, 0, 1]);
R2 := exp(-beta*Hi);
R2 := add(R2, S1 = [-1, 0, 1]);
S := R1/R2;
S := convert(S, trig, {J*S2});
S := simplify(S);
S := convert(S, exp, {Delta});
In this case I had to put in evidence the therm exp(Delta beta), where I simplified the expression. Now, we have more 2 variables (+2 and -2) to substitute in the equation. The code is:
R1 := add(R1, S1 = [-2, -1, 0, 1, 2]);
R2 := add(R2, S1 = [-2, -1, 0, 1, -2]);
S := R1/R2;
S := simplify(S);
In the last line we had the final equation
What should I change in the code for that my exponential function continue in evidence? This is, for my expression  be
(4*sinh(2*J*S2*beta) + 2*sinh(J*S2*beta)*exp(-3*Delta*beta))/(2*cosh(2*J*S2*beta) + 2*cosh(J*S2*beta)*exp(-3*Delta*beta) + exp(-4*Delta*beta))
Hi everybody and Acer
I have problems with this file I have, where it says “there where problems during the loading process” … Can anyone help med with my file?
Chemistry-Cheatsheet-Ramz_edition_Week_7-12_1_1.mw
i want to find fitted parameter value for G1,G2,G3,tau1,tau2,tau3 and plot stress-strain curve that fit to true_stress_strain curve(experimental data)
and i tried many times and still get error..can anyone please help me.here is my maple file...
 prony.mw
Good day to all of you.
I am working with a differential equation, got a first approximation setting all the constants equal to 1. But at the time to use the real values there appears the error numeric exception: division by zero.
I'll thanks any advice.
best regards
division_by_zero.mw
In the system below, I need to solve the solution algebraically (it is known in advance that from "V3" that a0=1,just open the V3 command).
V := exp(lambda*S) = S^4*a4 + S^3*a3 + S^2*a2 + S*a1 + a0;
V1 := subs(S = 2, V);
V2 := subs(S = 1, V);
V3 := subs(S = 0, V);
V4 := subs(S = -1, V);
V5 := subs(S = -2, V);
fsolve(subs(a0 = 1, {V1, V2, V4, V5}), {a1, a2, a3, a4});
I already know the answers, but I need maple to provide me with the command in the form
a1:=(1/6)*[8*sinh(lambda)-sinh(2*lambda)] and
a2:=(1/12)*[16*cosh(lambda)-cosh(2*lambda)-15],
a3:= ... etc.
What is the best way to do this?
Something to be aware of.  I realized you can't use rand in an equation with other rand's since the calculation affects the other call to it.
Here is an example:
A simulation of 3 six sided die rolls added together for 50 trials.
with(Statistics):
a:=[]:
for i from 1 to 50 do
  b:=rand(1..6)()+rand(1..6)()+rand(1..6)():
  a:=[op(a),b]:
Histogram(a,frequencyscale=absolute,discrete=true)
You'll notice the rand calls have affected the other calls to rand, and has eliminated some possible results.
[added by moderator, from a Reply by the OP]
The idea was to generate values from 1 to 20 (I just chose 20 as an example) using 6 sided dice, and one that which produces as uniform a distrubution as possible. I appreciate the explanations.  I chose 4 as the smallest number of rolls needed. In the physical world as n approaches large numbers rolling that many becomes increasingly more difficult and time consuming.
So just wondering what the best solution would be for a uniform distribution in a range from 1 to n using only six sided dice?
For plotting with a plot function that has not been upgraded to units I want to remove units from the following
5.818576570*10^(-7)*exp(`&ndash;`((1.827959741*10^(-6))*(x^2+y^2)/Unit('`&mu;m`')^2))/Unit('`&mu;m`')^2
0.5818576570e-6*exp(-0.1827959741e-5*(x^2+y^2)/Units:-Unit(`&mu;m`)^2)/Units:-Unit(`&mu;m`)^2
convert(0.5818576570e-6*exp(-0.1827959741e-5*(x^2+y^2)/Units:-Unit(`&mu;m`)^2)/Units:-Unit(`&mu;m`)^2, unit_free)
0.5818576570e-6*exp((-0.1827959741e-5*x^2-0.1827959741e-5*y^2)*Units:-Unit(1/`&mu;m`^2))
map(convert, 0.5818576570e-6*exp(-0.1827959741e-5*(x^2+y^2)/Units:-Unit(`&mu;m`)^2)/Units:-Unit(`&mu;m`)^2, unit_free)
Anything else I could try with convert or something better than this
subs(Unit(1/'`&mu;m`'^2) = 1, %)
I cannot conclude form the help page ?convert,unitfree if it should have worked on the expression.
Is the expression (1) non-scalar?
The term unit-free describes a scalar quantity with no (multiplicative) unit attached to it. Conversion to unit-free does not apply directly to any non-scalar Maple object or data structure, which may still have units embedded within it.
Download convert_unit_free_of_exp.mw
Download Exercises_all_lectures_1.mw
I have a Maple document that contains a lot of notes that I have an exam for tomorrow. I opened the document today and it suggests I save a copy of a corrupt document and also it gives me the message "There were problems during the loading process.
Your worksheet may be incomplete." when it finally does load.
Any suggestions for how I could fix this would be greatly greatly appreciated.
I have this equation:
and I need to do some manipulation to obtain this:
I manage to get it but my manipulation is too long for my liking. Can someone show me a shorter version. I have linked the Maple document.
Manipulating_polynomial.mw
Mario
First 155 156 157 158 159 160 161 Last Page 157 of 2430
