I'm using NLPSolve to minimize a complicated function. It works great, but the answers are not returned in numerical form which I need as they are then input for the next stage of my program.
How to I extract numbers?
S2 := NLPSolve(test, phi1 = 0 .. 2*Pi, phi2 = 1.0*Pi .. 2*Pi);
     S2 := [-1.00000000011810774,
       [phi1 = 0.773215730257661, phi2 = 5.98741001513872]]
==>The Result is a list and the solutions appear kind of string-like.
S2[2,1] returns 'phi=0.773...' not the number I need
I have a system of  second order difference equation.
How, can I update the iterate solution and solve the system
System_of_equations.mw
I would like to verify if the proposed solution u_exact of my partial differential equation defined on \mathbb{R}^2, with zero boundary condition
I write the  exact solution, how substitute this  to verify that the PDE is satisfied or not. I tried to substitute but I think someting missing.
Please check ...
solution_pde_check.mwsolution_pde_check.mw
  ra:=2: b1:=1.41: na:=0.7: we:=0.5: eta[1]:=4*0.1: d:=0.5:
  xi:=0.1: m:=na: ea:=0.5: pr:=21: gr:=0.1: R:=0.9323556933:
  PDE1:=ra*(diff(f(x,t),t))=+b1*(1+ea*cos(t))+(1/(R^2))*((diff(f(x,t),x,x))+(1/x)*diff(f(x,t),x));
  IBC:= {D[1](f)(0,t)=0,f(1,t)=0,f(x,0)=0};
2*(diff(f(x, t), t)) = 1.41+.705*cos(t)+1.150367877*(diff(diff(f(x, t), x), x))+1.150367877*(diff(f(x, t), x))/x
{f(1, t) = 0, f(x, 0) = 0, (D[1](f))(0, t) = 0}
sol := pdsolve({PDE1}, IBC, numeric); sol:-plot(f(x, t), t = 1.2, linestyle = "solid", title = "Velocity Profile", labels = ["r", "f"])
Download pde.mw
for different time plot of f(x,t) in single plot with different color
acer helped me out last week with converting strings to dates which was very helpful. However now I stumble on 2 other problems:
- I do not succeed to plot DS6 (time difference versus a numeric value) and to not understand why
- in the cvs data sheet the length of the columns is not equal. The empty cells are automatical filled with "". This prevents me to use numelems as it will also take into consideration the cells filled with "". Is there a way to prevent this
As usual I would like to thank you all, power users, for your patience and help
Test.mw
Hi all
Let us consider the set [f1=x-y, f2=-x^2+y^2, f3=x*y+x*z, f4=-x*y*z+z^3, f5=x*y^2+y*z^2-z^3] contain homogeneous polynomials in K[x,y,z]. It has the elements of degree 1,2, and 3. Now, we start from degree 1 so we have [x-y]. Now, we go to degree 2. Now, we shall multiply f1 by the variables and add to this set f2 and f3 i.e. we have now
[x-y], [x^2-x*y, x*y-y^2, x*z-y*z, -x^2+y^2, x*y+x*z]
 We have to continue to degree 3 and multiply f1 by all monomials in degree two in k[x,y,z] and multiply f2 and f3 by any variable and add them to f4 and f5 so we have finalyas a output:
[[x-y], [x^2-x*y, x*y-y^2, x*z-y*z, -x^2+y^2, x*y+x*z], [x^3-x^2*y, x^2*y-x*y^2, x^2*z-x*y*z, x*y^2-y^3, x*y*z-y^2*z, x*z^2-y*z^2, -x^3+x*y^2, -x^2*y+y^3, -x^2*z+y^2*z, x^2*y+x^2*z, x*y^2+x*y*z, x*y*z+x*z^2, -x*y*z+z^3, x*y^2+y*z^2-z^3]]. How can I do this automatically by a simple and efficient method in Maple?
Maple (2023.1) opens regularly but I cannot use "open" or "save" or "save as" and after opening Maple I no longer can close it.
That is a big problem for me.
The issue is on my new laptop Lenovo L13 Yoga with Windows 11.
Any suggestion? Thanks
hi i have a problem where maple dosent have a varible theta inside cos and sin and when i give it a size it dosent solve the equtation
The function f := x -> (x + 1)*(x^2 + (m - 5)*x - 7*m + 2) satifies
solve(discrim(f(x), x) = 0, m) has three solutions 1, -17, -1
How to find the integer numbers a, b, c, d, k, t so that the function
f := x -> x^3 + (a*m + b)*x^2 + (c*m + d)*x + k*m+t  satifies the equation
solve(discrim(f(x), x) = 0, m)  has three  integer numbers m?
Consider the function f:=x-> a*x^2 + b*m*x + x^3 + c*m.
I tried
f := x -> x^3 + a*x^2 + b*m*x + c*m;
solve(f(x) = 0, m);
g := x -> -x^2*(a + x)/(b*x + c);
solve(diff(g(x), x) = 0, x);
n := 0;
f := x -> -x^2*(a + x)/(b*x + c);
for a from -10 to 20 do
    for b to 20 do
for c from -10 to 20 do
mydelta := a^2*b^2 - 10*a*b*c + 9*c^2;
if 0 < mydelta and type(mydelta, integer) then
x1 := (-b*a - 3*c + sqrt(a^2*b^2 - 10*a*b*c + 9*c^2))/(4*b):
x2 := -(b*a + sqrt(a^2*b^2 - 10*a*b*c + 9*c^2) + 3*c)/(4*b):
x3 := 0:
if type(x1, integer) and type(x2, integer) and nops({0, x1, x2}) = 3 and type(f(x1), integer) and type(f(x2), integer) then n := n + 1; L[n] := [a, b, c]; end if; end if; end do; end do; end do;
L := convert(L, list);
I get
L := [[-10, 1, 6], [-10, 2, 12], [-9, 3, 5], [-8, 1, 10], [-5, 1, 3], [-4, 1, -6], [4, 1, 6], [5, 1, -3], [6, 3, 20], [7, 1, 15], [8, 1, -10], [8, 1, 12], [9, 3, -5], [10, 1, -6], [10, 1, 12], [12, 1, 18], [14, 1, -4], [15, 1, -9], [18, 1, 20], [18, 3, -10], [18, 3, 4], [20, 1, 2]]
With L[1], solve(discrim(x^3 - 10*x^2 + m*x + 6*m, x) = 0, m) ;
The equation has three integer solutions: 0, 12, -500
I have a PDE, with unknown u(t,x,t) ,  zero boundary condition and initial condition given
I converted the equaiton using finite difference to get a system of algebraic equation
The system is solved at each time step
I think i have a problem to update the solution inside the loop.
I hope find the problem or why the numerical solution is different to exact solution at last time
System_finite_difference.mw
Thank you for your help
Hi Everyone; I have plotted two different expressions separately and then shown them in a single graph. From the final display, we can observe that the peak of one expression, A is larger than that of another expression B. Now, the question is, how do I calculate the decrease or increase in the percentage of both curves? This means the peak of expression A is 20%, 8%, or 7% decreases or increases as of expression A.
Help_percentage_inccrease_or_decrease.mw
more explanation, each curve has its maximum point at some value of x, need to calculate that point for each curve. Then, we combined all curves we observed that the peak of each curve is smaller than others, so I am interested to observing that difference in percentage at the maximum value of x.
for reference, I uploading a file of which idea I want to implement for my problem. This is not my problem, but I want to implement it like this.
For_reference.mw
I have written a maple-code that is visualizing cycles or periods of inverse numbers in any base in a coloured plot.
For example 1/13=0,76923 076923 ... (so period-lenght is 6, the cycle-digits are visualized)
Now I would like to run the Maple Code wich produces the plot (via display-comand) on an ipad.
The ipad will be located in a museum or galerie. In the most easily way the user just touch a button on the ipad-screen and the maple-code produces a random plot which is displayed. Later some choosable parameters for the plot are added.
I have make some tests with embedded components in Maple.
So my idea is to do this with maple-player. I read about Maple Player features:
- Interact with applications that make use of embedded components, such as sliders, buttons, and math entry boxes. Maple will perform the computations and display updated results and visualizations
Questions:
1) how do I run Maple code in Maple Player (a little example with a button- and a plot-component will help)
2) do I need to upgrade Maple 2021  to do that ?
3) What does a mapleplayer license cost for each ipad ?
Thanks for support :)
Delay differential equations in Chebfun lists 15 examples "taken from the literature". Many of them can be (numerically) solved in Maple without difficulty, yet when I attempt to solve the  in the above link, Maple's internal solver `dsolve/numeric` just halts with an error.
plots:-odeplot(dsolve({D(u)(t) + u(t)**2 + 2*u(1/2*t) = 1/2*exp(t), u(0) = u(1/3)}, type = numeric, range = 0 .. 1/3), size = ["default", "golden"]);
Error, (in dsolve/numeric) delay equations are not supported for bvp solvers
Even if I guess an initial (or final) value artificially, the solution is still less reliable (For instance, what is the approximate endpoint value? 0.26344 or 0.2668?):
dde := D(u)(t) + u(t)**2 + u(t/2)*2 = exp(t)/2:
x__0 := 2668/10000:
sol0 := dsolve([dde, u(0) = x__0], type = numeric, 'delaymax' = 1/6, range = 0 .. 1/3):
plots['odeplot'](sol0, [[t, u(t)], [t, x__0]], 'size' = ["default", "golden"]);
x__1 := 26344/100000:
sol1 := dsolve([dde, u(1/3) = x__1], type = numeric, 'delaymax' = 1/6, range = 0 .. 1/3):
plots['odeplot'](sol1, [[t, u(t)], [t, x__1]], size = ["default", "golden"]);
Compare:  (Note that the reference numerical solution implies that its minimum should be no less than 0.258 (Is this incorrect?).).
And actually, the only known constraint is simply u(0)=u(⅓) (so neither value is known beforehand). Can Maple process this boundary condition automatically (that is, without the need for manual preprocessing and in absence of any other prior information)?
I have read the help page How to | Numeric Delay Differential Equations and Numerical Solution of Difficult ODE Boundary Value Problems, but it appears that those techniques are more or less ineffective here. So, how do I solve such a "first order nonlinear 'BVP' with pantograph delay" in Maple?
I'm unsure how to fix the error with sin, the help guide suggests using the command Describe (Sin)
#Clear memory.
#Initialise variables and arrays.
h:=((pi/20)^2);
n:=15;
k:=0.1;
m:=10;
t:=Array(0..m):
x:=Array(0..n):
u:=Array(0..n,0..m):
#Initialise the x array and the initial u(x,0) boundary.
   for i from 0 to n do
x[i]:=i*h;
u[i,0]:=x[i];
#Initialise the t array and the u(x,t)side boundaries.
  for j from 0 to m do
t[j]:=j*k;
u[0,j]:=0;
u[n,j]:=pi/2;
#Use the 2D explicit finite difference method.
for j from 0 to m-1 do
    for i from 1 to n-1 do
      u[i,j+1]:=(400*u[i-1,j]-400*u[i,j]+400*u[i+1,j]+1)/(pi^2)*(4*sin(2*x));
#Display the u(x,t) values.
printf("2D Explicit Finite Difference Method\n");
printf("------------------------------------\n");
printf(" x\t\t t\t\t u\n");
    printf("% 9.4f\t% 9.4f\t% 9.4f\n",x[i],t[m],u[i,m]);
(1/400)*pi^2
15
.1
10
Error, invalid input: sin expects its 1st argument, x, to be of type algebraic, but received Array(0..15, [0,1/200*pi^2,1/100*pi^2,3/200*pi^2,1/50*pi^2,1/40*pi^2,3/100*pi^2,7/200*pi^2,1/25*pi^2,9/200*pi^2,1/20*pi^2,11/200*pi^2,3/50*pi^2,13/200*pi^2,7/100*pi^2,3/40*pi^2])
 x                 t                 u
   0.0000           1.0000           0.0000
Error, (in fprintf) number expected for floating point format
Download Asst_2_Q3bcd.mw
#Clear memory.
h:=0.1;
n:=10;
x:=Array(0..n):
y:=Array(0..n):
x[0]:=0;
y[0]:=2;
yd:=-1;
#Initialise the x array.
for i from 1 to n do
    x[i]:=x[0]+i*h;
#Calculate the first y value.
y[1]:=(203*y[0]-22*yd+4)/220:
#Calculate the remaining y values.
    y[i+1]:=203*y[i]-110*y[i-1]+4*exp^(-3*x[i])/110;
#Display the x and y arrays.
printf("1D Explicit Finite Difference Method\n");
printf("x\t\ty\n");
     printf("%f\t %f\n",x[i],y[i]);
.1
10
-1
x                y
0.000000         2.000000
0.100000         1.963636
0.200000
Download Asst_2_Q1c.mw
I dont understand the cause of this error, can anyone please assist?
First 174 175 176 177 178 179 180 Last Page 176 of 2431
