How can an equation containing a logarithmic function be converted into a polynomial?
Is there a way in the physics package to get my index to run from 0 to 3 instead of 1 to 4/0?
I have a data structure/plotting question. How do I plot the 3 lambdas (singleaxis) and the 6 betas (dualaxis) for 12 calibrations (1000 runs each)? All the details are in the script 230523_different-calibrations.mw. Thank you!
For the beta plots and subplots, please follow the dualaxis example output format at the bottom of my script for each of the 12 calibrations.
For the lambda plots, I'd like to combine a few of them as follows (each plot with lambda_1 subplot, lambda_2 subplot, and lambda_3 subplot - note that the lambda plot example at the bottom of the script is dualaxis but I just need singleaxis):
PLOT 1 (singleaxis): lambda_1, _2, _3 for ncal2 and ncal3 (superimposed, 2 data series for each subplot)
PLOT 2 (singleaxis):  lambda_1, _2, _3 for ncal7 and ncal8 (superimposed, 2 data series for each subplot)
PLOT 3 (singleaxis):  lambda_1, _2, _3 for ncal4, ncal5, ncal6 (superimposed, 3 data series for each subplot)
PLOT 4 (singleaxis):  lambda_1, _2, _3 for ncal9, ncal10, ncal11 (superimposed, 3 data series for each subplot)
there’s few redundant values. I just want the positive values. How it can be done?
n := [80, 79, 83, 84, 83, 83, 81, 85, 86, 86, 83, 82, 83, 84, 81, 80, 83, 79, 82, 81, 85]
nops(n)
21
for i from 3 to 17 do f[i] := n[i-2]-3*n[i-1]+3*n[i]; i = i+1; f[i+1] := n[i-2]+4*n[i-1]-6*n[i]+n[i+1] end do
92
3 = 4
-18
82
4 = 5
-10
80
5 = 6
4
84
6 = 7
-1
77
7 = 8
14
95
8 = 9
-17
84
9 = 10
-9
85
10 = 11
-4
77
11 = 12
14
83
12 = 13
9
86
13 = 14
-3
85
14 = 15
-9
74
15 = 16
13
81
16 = 17
11
90
17 = 18
-18
Download fyp_2.mw
I am exploring the Grading package in Maple, and I want to create a random question about limits. (Question 9). Any ideas for the correct code? Thank you
QUIZZTestMaple.mw
I learned about Dodgson calculation of the determinant only recently (https://en.m.wikipedia.org/wiki/Dodgson_condensation).
I am only interested in symbolic expressions of the determinant.
Furthermore, I compared several methods. Not surprisingly, the build in method is the fastest. But why is the seq method slower than the proc method for the Dodgson method? Is there anything I could do to program it more efficiently?
restart; with(LinearAlgebra)
with(combinat); with(GroupTheory)
DetDef := proc (A) local i, n, sigma; description "Jeremy Johnson. Downloaded from https://www.cs.drexel.edu/~jjohnson/2016-17/winter/cs300/lectures/determinant.mw"; n := RowDimension(A); add(PermParity(Perm(sigma))*mul(A[i, sigma[i]], i = 1 .. n), `in`(sigma, permute([`$`(1 .. n)]))) end proc
InnerMatrix := proc (M::Matrix) SubMatrix(M, 2 .. RowDimension(M)-1, 2 .. ColumnDimension(M)-1) end proc
MatrixDet := proc (M::Matrix) local C, n, i, j; n := RowDimension(M)-1; C := Matrix(n, n); seq(seq(assign('C[i, j]', Determinant(M([i, i+1], [j, j+1]))), j = 1 .. n), i = 1 .. n); return C end proc
Dodgson := proc(M::Matrix)
 MatrixDet(M);
InnerMatrix(M) ^~ (-1) *~ MatrixDet(MatrixDet(M));
do if 1 < RowDimension(%) then InnerMatrix(`%%`) ^~ (-1) *~ MatrixDet(%);
until RowDimension(%) = 1;
Trace(%):
end proc:
Dodgsonseq := proc (E::Matrix) local w, dim, Z; dim := RowDimension(E); Z[dim] := E; Z[dim-1] := MatrixDet(E); Z[dim-2] := `~`[`*`](`~`[`^`](InnerMatrix(E), -1), MatrixDet(MatrixDet(E))); seq(assign('Z[w-1]', `~`[`*`](`~`[`^`](InnerMatrix(Z[w+1]), -1), MatrixDet(Z[w]))), w = dim-1 .. 1, -1); Trace(Z[1]) end proc
LaPlace := proc (M::Matrix) local c; add((-1)^(c+1)*M[1, c]*Minor(M, 1, c), c = 1 .. ColumnDimension(M)) end proc
dim := 7; A := Matrix(dim, dim, shape = symmetric, symbol = a)
7
start_time := time(); st := time[real](); Det1 := abs(A); CPUtime_used_Build_in_Determinant := time()-start_time; REALtime_used_Build_in_Determinant := time[real]()-st; start_time := time(); st := time[real](); Det2 := DetDef(A); CPUtime_used_Jeremy_Johnson_Determinant := time()-start_time; REALtime_used_Jeremy_Johnson_Determinant := time[real]()-st; start_time := time(); st := time[real](); Det3 := Dodgsonseq(A); CPUtime_usedDodgsonseq := time()-start_time; REALCPUtime_usedDodgsonseq := time[real]()-st; start_time := time(); st := time[real](); Det4 := Dodgson(A); CPUtime_usedDodgson := time()-start_time; REALtime_usedDodgson := time[real]()-st; start_time := time(); st := time[real](); Det5 := LaPlace(A); CPUtime_usedLaPlace := time()-start_time; REALtime_usedLaPlace := time[real]()-st; simplify(Det1-Det2); simplify(Det1-Det3); simplify(Det1-Det4); simplify(Det1-Det5)
0.32e-1
0.34e-1
0.93e-1
.108
47.094
41.295
40.766
38.158
0.31e-1
0.50e-1
Download test_Determinants_symbolic.mw
I had purchached reseach licience Maple 2022 towards the end of 2022 only and Quantum Chemistry Toolbox I purchased in Feb 2022 only.
Now i find significant update in toolbox in just 3 months. Now guide me how should i address this issuse.
I had to take loan in india to buy the toolbox.
It is only 3 months.
Can you suggest me how solve the problem to get the update without spending again.
What is the way guide someone.
I calculate the limit
Let me know if there are any errors in my calculations?
assume(a > 0)
limit(int(sin(x)/x, x = n .. n+a), n = infinity)
-Si(n)+Si(n+a)
plot3d(-Si(n)+Si(n+a), a = -5 .. 5, n = -5 .. 5)
limit(-Si(n)+Si(n+a), n = infinity)
limit(-Si(n), n = infinity)
-(1/2)*Pi
limit(Si(n+a), n = infinity)
(1/2)*Pi
Thank you in advance.
Download limit_int.mw
I have a polyhedron with A(1,1,0), B(-1,1,0), C(-1,-1,0), H(-1/2,0,1), K(1/2,-1/2,0). How can I calculate volume of polyhedron ABCHK?
How can a horizontal axis be curved in a plot? like this
plot(F*r*sin(theta) - m, theta = 0 .. Pi)
When I am setting up the coordinates in the physics package, I use the following command. And it sets it to (r,theta,phi,t).
Setup(dimension = 4, mathematicalnotation = true, coordinates = spherical)
Is there a way to change it to (t,r,theta,phi)?
It gets a bit more confusing when we are looking at rank 2 objects.
Hi, I am working on an activity about conic sections, but I have a small issue with the display of the ellipse and the circle. My outlines are not complete. Any ideas on how to identify my error? Thanks  SectionsConiquesTest.mw
Hi to every one. I have attached a maple for eigenvalues. Please see and tell be solution of problem.
Thanks for time.
Eigen_Values.mw
Hi, here is my question.
test:=v^3;
plot3d(test,u=0..1-v, v=0..1);
How can I  transform this plot in the right triangle into an equilateral triangle?
So that the three edges of the plot are the same length.
I wanna, squish it, or shear?
any tools i can use? Or can I do it using some tricks to change the function?
First 201 202 203 204 205 206 207 Last Page 203 of 2431
