If there is a list of operations that do not work properly in 2D notation, please add the expression sequence operator `$` which does not work with strings as demonstrated in the attached worksheet . sequenceoperastionfailure.mw
It seems to work properly with numeric sequences. I only noticed this in maple 2023, but it likely applies to earlier versions as well
Hi Maple friends,
Im new to Maple and Im struggeling with a problem.
I have the numbers of a bode plot (abs and phase) and I want to fit it in an equivalent circuit.
My problem is: I firstly want to calculate the real and imaginary part of the measured impedance of the bode plot (This works so far after a few hours of trying) and then I want wo calculate the values for each equivalent circuit component. For that I need the values of the impedance calculation to further process them.
The problem is: The impedance calculation returns the values as a list (I think). So Im wondering how can I get the values out of the list? My code so far is attached below.
Thanks in advance!
PS: Im sorry for the layout of the code. Im not sure how I can format the code right.
eq1 := diff(f(x), x, x, x)+(1/2)*cos(alpha)*x*(diff(f(x), x, x))+(1/2)*sin(alpha)*f(x)*(diff(f(x), x, x)) = 0;
eq2 := diff(g(x), x, x)+diff(g(x), x)+(diff(g(x), x))*(diff(h(x), x))+cos(alpha)*x*(diff(g(x), x))+sin(alpha)*f(x)*g(x) = 0;
eq3 := diff(g(x), x, x)+diff(h(x), x, x)+1/2*(cos(alpha)*x+sin(alpha)*f(x)) = 0
ics := f(0) = 0, (D(f))(0) = 1, ((D@@2)(f))(0) = a[1], g(0) = 1, (D(g))(0) = a[2], h(0) = 1, (D(h))(0) = a[3];
I am trying to give an input to an R program from an output the edge set of maple code
Now how to Build a function which takes a list of edge sets as inputs and returns a list on the below format
Show I want for one edge set of the list
Now I have edge set of a Graph G say {{1,2},{2,3},{3,4},{4,5}}
Now want to pick the first values of each index make one set
from<-c(1,2,3,4)
Similiarly first values of each index make one more set
to<-c(2,3,4,5)
Then I want to form a list [from<-c(1,2,3,4),to<-c(2,3,4,5),ft <- cbind(from, to),Graph1<-ftM2graphNEL(ft)]
Now it will take second graph in the Edge list say {{1, 2}, {1, 7}, {2, 3}, {3, 4}, {4, 5}, {5, 6}, {6, 7}}
It will append to the previous list like
[from<-c(1,2,3,4),to<-c(2,3,4,5),ft <- cbind(from, to),Graph1<-ftM2graphNEL(ft),from<-c(1,1,2,3,4,5,6),to<-c(2,7,3,4,5,6,7),ft <- cbind(from, to),Graph2<-ftM2graphNEL(ft)]
This time Graph1 is changed to Graph2 to be observed.
Like that it will need  increase graph number based on the number of edge sets in the list of edges.
To be done all edge sets in list
As then I can copy the entire contents in the list and paste in R so that i can run
As I can have 100 or more graphs done in maple doing for each of them manually typing may be difficult.
Kind help please
Your help will be surely Acknowledged
Kind help
A toy code i simply tried for graph attached
But I have errors some come with double quotes can something be done if possible please guide
Kind help
As with 100 of lines it will easy to copy paste
If the contents of the list can be written to txt file it would be helful
please help
toy_try.mw
I have tried something to my knoewledge please help
Someone added "Duplicate question" tag on this question.
How is this duplicate question? Where is the duplicate question?
Is this a bug?
Accoding to this help page
A derived class must not redeclare (via a local or export declaration) any members inherited from the base class
this example does not do this. But derived class gets an error when using ::static on a method declared in base class and this only shows up when using kernelopts('assertlevel'=2):
So it is either kernelopts('assertlevel'=2): is wrong or help is wrong.  Here is example
972100
interface(warnlevel=4);
module bank_account()
  option object;
  local account_id::integer:=0;
  export ModuleCopy::static:=proc(_self, proto::bank_account, account_id::integer,$)
         if nargs=2 then
            _self:-account_id := proto:-account_id;
            _self:-account_id := account_id;
         fi;
end module;
module bank_account () local account_id::integer; option object; end module
module saving_account()
  option object(bank_account);
  ModuleCopy::static := proc(_self, proto::saving_account, account_id::integer,$)
         if nargs=2 then
         fi;
end module;
Error, (in saving_account) type `static` does not exist
Download static_error.mw
Removing the line kernelopts('assertlevel'=2): the error goes away. Also keeping kernelopts('assertlevel'=2): but removing the ::static from the derived class the error goes way.
What is going on?
Maple 2023 on windows 10.
Does anyone know how to remove this boring notation? I would like to know why Maple does not give me "± 2x". Thanks in advance.
I am trying to define a Tensor expression in the physics package but it seems to be taking eons to do so, it has been running for quite some time but still no result to the point where I halt the computation.
Does anyone have any ideas on how I could accelerate the process?
I have attached the file I am working with.
Define.mw
If in a .mw file I have a Document Block with about 10 statements in it, what is a way to split it into two blocks that execute seperately? Currently, hitting enter all statements execute.
("Document Block" is the term that shows up when I hover to the left of the text of interest.)
(I know I can cut and paste the last five statements into a new document block, but it seem that there may be an easier way.)
Thanks and Cheers in advance . . .
There appears to be a bug in Maple 2023.0 (Build ID 1689885)  that does not allow you to access submenus when the window is maximized.  For example, trying to select "Insert --> Execution Group" does not work, nor does any other submenu (the submenu will not display and is not accessible).  The only workaround is to un-maximize the window, select the submenu (for example "Insert --> Execution Group --> Before Cursor"), and then re-maximize the window.  Everything works as it should as long as the window is not maximized.  This is on Microsoft Windows 11 with a 2160p monitor.  Any suggestions on how to fix this are appreciated.
I dont know if this is a well formulated question but if I had a set of PDES that have a constant appearing in them (say alpha), would there be a way to solve for the PDE such that the right had side is not zero but just has higher order order terms (say alpha^3 and higher).
For example consider (the random set of equations)
eq1 := alpha*diff(f(t, r), r,r) + diff(g(t, r), t) + alpha*g(t, r) = 0;
eq2 := alpha*diff(g(t, r), r) + diff(f(t, r), t,t) + f(t, r) = 0;
Is there a way to solve for the system of pde such that the right hand side is only terms of order alpha^3 and higher?
Example
diff(w(x), x, x) = F*((6*(-a^2/(2*L^2)+a^3/(3*L^3)))*x+2*a^2/L-a^3/L^2)/EI
diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI
Eval(lhs(diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI), x = L) = (`@`(simplify, eval))(rhs(diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI), x = L)
Eval(diff(diff(w(x), x), x), x = L) = -F*a^2*(L-a)/(L^2*EI)
Can the expression above be further shortened by function composition and function application (to a single group of arguments)? I tried
(`@`(Eval, lhs) = `@`(`@`(simplify, eval), rhs))(diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI, x = L)
Error, (in evalapply) invalid input: lhs expects 1 argument, but received 2
which does not work.
Since the error message is clear I am looking for a single argument command that could replace lhs and rhs.
Analog to evalf, which accepts an index, I tried to replace lhs by
op[1](diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI)
diff(diff(w(x), x), x), F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI
to do the same as
op(1, diff(diff(w(x), x), x) = F*(6*(-(1/2)*a^2/L^2+(1/3)*a^3/L^3)*x+2*a^2/L-a^3/L^2)/EI)
Unfortuenatly this does not work. Are there any other options or have I reached an end point?
Would a single argument variant of op make sense for other purposes than the example above?
Download replacement_of_lhs_and_rhs_by_single_argument_function.mw
I have been using the RaiseLowerIndices to go from covectors to contravariant vectors.
RaiseLowerIndices(Contravariant_form_of _metric, One_Form, [1])
The above gives me the right answer.
But the following also gives me an answer which is different. I just dont know what it is calculating.
RaiseLowerIndices(Contravariant_form_of _metric, One_Form, [1,1]).
Could someone tell me what it is calculating?
将枫叶文档传输到手机后如何打印?
Can I compute using maple intersection between discrete sets
intersection_sets.mw
thank you for your help
I compute some properties of some graphs and try to store their edge sets and their corresponding properties. I stored them using matrices, but now I want to export them to a file (csv format).
with(GraphTheory):
graphs := [seq(RandomGraphs:-RandomGraph(8, 9), 1 .. 10)]:
M0:=Edges~(graphs):
M1:=Girth~(graphs):
M2:=Diameter~(graphs):
B := Matrix(1..3,[M0,M1,M2]);
Export("E:/B.csv", B):
he exported file's data is messy, and it is difficult for me to observe the corresponding properties of the graphs.  I hope they can be sorted into three columns as shown below.
PS: I know that if the data has only one column, it can be done as discussed earlier
Export("E:/M.csv", M):
To make the data appear clearer, it is best to keep suitable spacing between columns.
multi_dimensional_data.mw
First 209 210 211 212 213 214 215 Last Page 211 of 2431
