Hi everyone, I'm studying physics at college and we have to do lab reports. Of course we have to fit data sets. They only taught us how to calculate errors of the parameters of lineaer distributions.
Unforutnately I have to fit points that follow these functions:
y=a+b*x^c
y=d+a*x/(sqrt(b*x^2+c^2))
First of all, which command do I use to fit for the second function? (Its the formula of abs(Vout/Vin) in function of the frequence in RC circuits)
I know for the first one there's the PowerFit command.
Also, is there a command that returns the errors for the variaous fit parameters? (i.e. a,b,c,d)
Or at least, someone knows the methods and formulas to find them?
Hello guys
I'm having trouble solving a PDE using pdsolve-numerical. Here's a notebook attached.
I'm grateful if anyone can help.
Oliveira
                   PDE1.mw
x := 19.073*Unit('m'^4*'kg'^2/('s'^6*'A'^2)); simplify(x); Units:-Simple:-simplify(x); Units:-Standard:-simplify(x); Units:-Natural:-simplify(x); convert(x, units, V^2); # None of the simplify commands do anything. Is there a way to get the last result?
This figure refuses to turn
Fig := proc(t) local a, b, P, Q, N, R, TG, x0, y0, p1, p2, p3, po, tp, sol; a := 11; b := 7; R := sqrt(a^2 + b^2); P := [R*sin(t), R*cos(t)]; x0 := P[1]; y0 := P[2]; TG := (a^2 - x0^2)*(y - y0)^2 + (b^2 - y0^2)*(x - x0)^2 + 2*y0*x0*(x - x0)*(y - y0) = 0; p1 := implicitplot(x^2/a^2 + y^2/b^2 - 1, x = -11 .. 11, y = -7 .. 7, color = blue); p2 := implicitplot(x^2 + y^2 - a^2 - b^2, x = -15 .. 15, y = -15 .. 15, color = blue); p3 := implicitplot(TG, x = -15 .. 15, y = -15 .. 15, color = red); sol := solve({x^2/a^2 + y^2/b^2 - 1 = 0, TG}, {x, y}, explicit); Q := [subs(sol[1], x), subs(sol[1], y)]; N := [subs(sol[2], x), subs(sol[2], y)]; po := plot([P, Q, N], style = point, symbolsize = 15, symbol = solidcircle, color = red); tp := textplot([[P[], "P"], [Q[], "Q"], [N[], "N"]], 'align' = {'above', 'left'}); display([p1, p2, p3, po, tp], scaling = constrained); end procnFig := 60;
Figs := seq(Fig(2*Pi*i/nFig), i = 0 .. nFig);
Error, (in Fig) invalid subscript selector
display(Figs, insequence = true);
NULL; Why this error message. Thank you.
Given matrix A, Please help me calculate A^100 by steps, without using Maple or calculators. Thank you so much!
I'm terribly sorry to ask such elementary questions.
I am getting started on Maple and the most trivial calculations are taking hours.
For example the expression:
b := exp(-i*varphi)*sin(theta/2)*cos(theta/2) + cos(theta/2)*exp(i*varphi)*sin(theta/2)
can be simplifed to           sin(theta)*Cos(Phi)
but no amount of commands such as simplify(b,trig) or combine(b, exp) will do it.
Any hits will be appreciated.
ode := diff(y(x),x)/y(x)-(3*(4*x^2+y(x)^2+1))/(2*x*(4*x^2+y(x)^2-2-2*x))=0;
DEtools:-odeadvisor(ode);
sol:=dsolve(ode,y(x));
(diff(y(x), x))/y(x)-(3/2)*(4*x^2+y(x)^2+1)/(x*(4*x^2+y(x)^2-2-2*x)) = 0
[_rational]
Error, (in dsolve) invalid subscript selector
Download error_jan_27_2023.mw
How do you modify the column widths in an already created table?
I want to create the groups (Z/nZ)+ and (Z/nZ)*.
I can do this in python for n=7. I want to do this with other values of n.
(Z/7Z)+
   0 1 2 3 4 5 6
0 0 1 2 3 4 5 6
1 1 2 3 4 5 6 0
2 2 3 4 5 6 0 1
3 3 4 5 6 0 1 2
4 4 5 6 0 1 2 3
5 5 6 0 1 2 3 4
6 6 0 1 2 3 4 5
(Z/7Z)*
   1 2 3 4 5 6
1 1 2 3 4 5 6
2 2 4 6 1 3 5
3 3 6 2 5 1 4
4 4 1 5 2 6 3
5 5 3 1 6 4 2
6 6 5 4 3 2 1
I tried creating a Cayley table but can not get that right.
I started to use maple recently and I do not know why fsolve does not work in this case:
Sol-NLSE.mw
I am wondering if the conjugate(x[j]) is the reason.
In the Physics package.
How do I define arbitrary non-standard coordinates.
All that is available is the standard trivial cartesian, spherical and such coordinate systems.
Setup(Coordinatesystems = cartesian)
See e.g.
https://www.maplesoft.com/support/help/maple/view.aspx?path=Physics%2FRicci
This question was inspired by https://www.mapleprimes.com/questions/235613-Convert-A-List-With-Nested-Ordered-Sets.
I want to replace several characters of a string separately.
s:="[ (0, 1), (1, 2), (1, 10), (2, 3), (3, 4), (4, 5), (4, 9), (5, 6), (6, 7), (7, 8),(8, 9), (10, 11), (11, 12), (11, 16), (12, 13), (13, 14), (14, 15), (15, 16)]"
Like this their will be many say n element then I need to a list as
{{0,1},{1,2},{1,10},......}
I took the for-loop as follows, but I'm wondering if there's a more concise way to deal with it.
with(StringTools):
L:="[ (0, 1), (1, 2), (1, 10), (2, 3), (3, 4), (4, 5), (4, 9), (5, 6), (6, 7), (7, 8),(8, 9), (10, 11), (11, 12), (11, 16), (12, 13), (13, 14), (14, 15), (15, 16)]":
L1:=["(",")","[","]"]:
L2:=["{","}","{","}"]:
X:=L:
for i from 1 to nops(L1) do
X:=SubstituteAll(X,L1[i],L2[i]);
parse(X)
{{0, 1}, {1, 2}, {1, 10}, {2, 3}, {3, 4}, {4, 5}, {4, 9}, {5, 6}, {6, 7}, {7, 8}, {8, 9}, {10, 11}, {11, 12}, {11, 16}, {12, 13}, {13, 14}, {14, 15}, {15, 16}}
I know that a function acting repeatedly can use f @@ n, for example,
(sin@@2)(x);
But if f  has some  arguments, can it still be used?
I am trying to call an optimization function for a set of operations where the object function contains integrals. i get this error when i try to do the optimization, i actually want to optimize a cost function, this is the error i get: Error, (in Optimization:-NLPSolve) integration range or variable must be specified in the second argument, got 1. = 4 .. 7
here is my work:
a2 := 18;
b2 := 5;
a1 := 3;
b1 := 2.5;
ci := 0.05;
cr := 1;
cf := 10;
p := 0.1;
L := 0.5;
S := 3;
T := 10;
cud := 50;
co := 0.02;
tr := 0.006;
ti := 0.0014;
tf := 0.014;
K := 2;
A := 2;
M := 7;
f01 := x -> b1*(x/a1)^(b1 - 1)*exp(-(x/a1)^b1)/a1;
f02 := x -> b2*(x/a2)^(b2 - 1)*exp(-(x/a2)^b2)/a2;
fx := x -> p*f01(x) + (1 - p)*f02(x);
fh := h -> L*exp(-L*h);
Fh := h -> 1 - exp(-L*h);
P1_1 := (K, A, M) -> sum(int(fx(x)*(1 - Fh(i*A - x)), x = (i - 1)*A .. i*A), i = 1 .. K);
L1_1 := (K, A, M) -> sum((i*A + tr + i*ti)*P1_1(K, A, M), i = 1 .. K);
C1_1 := (K, A, M) -> sum((ci*i + cr)*P1_1(K, A, M), i = 1 .. K);
NULL;
P2_1 := (K, A, M) -> sum(int(fh(h)*fx(x), [h = 0 .. i*A - x, x = (i - 1)*A .. i*A]), i = 1 .. K);
L2_1 := (K, A, M) -> sum((tf + (i - 1)*ti)*int((x + h)*fh(h)*fx(x), [h = 0 .. i*A - x, x = (i - 1)*A .. i*A]), i = 1 .. K);
C2_1 := (K, A, M) -> sum(((i - 1)*ci + cf)*P2_1(K, A, M), i = 1 .. K);
P3_1 := (K, A, M) -> int(fh(h)*fx(x), [h = 0 .. M - x, x = A*K .. M]);
L3_1 := (K, A, M) -> (K*ti + tf)*int((x + h)*fh(h)*fx(x), [h = 0 .. M - x, x = A*K .. M]);
C3_1 := (K, A, M) -> (K*ci + cf)*P3_1(K, A, M);
P4_1 := (K, A, M) -> int(fx(x)*(1 - Fh(M - x)), x = A*K .. M);
L4_1 := (K, A, M) -> (K*ti + tr + M)*int(fx(x)*(1 - Fh(M - x)), x = A*K .. M);
C4_1 := (K, A, M) -> (K*ci + cr)*int(fx(x)*(1 - Fh(M - x)), x = A*K .. M);
P5_1 := (K, A, M) -> int(fx(x), x = M .. infinity);
L5_1 := (K, A, M) -> (K*ti + tr + M)*int(fx(x), x = M .. infinity);
C5_1 := (K, A, M) -> (K*ci + cr)*int(fx(x), x = M .. infinity);
Ptotal_1 := (K, A, M) -> P1_1(K, A, M) + P2_1(K, A, M) + P3_1(K, A, M) + P4_1(K, A, M) + P5_1(K, A, M);
Ptotal_1(K, A, M);
evalf(Ptotal_1(K, A, M));
Ltotal_1 := (K, A, M) -> L1_1(K, A, M) + L2_1(K, A, M) + L3_1(K, A, M) + L4_1(K, A, M) + L5_1(K, A, M);
evalf(Ltotal_1(K, A, M));
Ctotal_1 := (K, A, M) -> C1_1(K, A, M) + C2_1(K, A, M) + C3_1(K, A, M) + C4_1(K, A, M) + C5_1(K, A, M);
Cost_rate_1 := (K, A, M) -> Ctotal_1(K, A, M)/Ltotal_1(K, A, M);
integralOF := int(Cost_rate_1(K, A, M), x = 1 .. 2);
evalf(integralOF);
                          0.2759938793
MTBOF := Ltotal_1(K, A, M)/(P2_1(K, A, M) + P3_1(K, A, M));
evalf(MTBOF);
                          159.4642167
rd := 1/MTBOF;
ro := 1/M + rd;
const1 := 0 <= K;
const2 := K*A <= M;
const3 := M <= 20;
const4 := 0 <= A;
const5 := 0 <= M;
totalconstr := {const1, const2, const3, const4, const5};
optimized_cost := Optimization:-Minimize(integralOF, totalconstr);
NULL;
please, i need assitance urgently.. thanks
  In my current worksheet mine.mw how do I automatically print/show the filename " mine.mw"
I have list say like this
[(0, 1), (1, 2), (1, 10), (2, 3), (3, 4), (4, 5), (4, 9), (5, 6), (6, 7), (7, 8), (8, 9), (10, 11), (11, 12), (11, 16), (12, 13), (13, 14), (14, 15), (15, 16)]
I want to convert it to
{{0,1},{1,2},{1,10},{2,3},.........}
And print the ouput to a file
This I want the output as
Graph({{0,1},{1,2},{1,10},{2,3},.........})
So that i can save the graph
like that all the order pairs in the above list
I have given one list above here
But if I have a list of lists like this below
[[(0, 1), (1, 2), (1, 10), (2, 3), (3, 4), (4, 5), (4, 9), (5, 6), (6, 7), (7, 8), (8, 9), (10, 11), (11, 12), (11, 16), (12, 13), (13, 14), (14, 15), (15, 16)], [(0, 10), (1, 2), (1, 9), (2, 3), (3, 4), (4, 5), (4, 9), (5, 6), (6, 7), (7, 8), (8, 9), (10, 11), (11, 12), (11, 16), (12, 13), (13, 14), (14, 15), (15, 16)],.......]
[{{0,1},{1,2},{1,10},......}, {{0,10},......}, ....]
I ask for a list of graphs as I want the first graph in the first place only , second in the second place only.
Kind help
First 241 242 243 244 245 246 247 Last Page 243 of 2431
