The loop for HFS _data_2 and SFS_data_2 and the loop for HFS _data_3 and SFS_data_3 do not seem to be terminated. I do not know what it is the issue here. Anyone who can help this?
Negativity_(v12_beta_gamma_mu).mw
Thank you in advance,
simplify(sqrt((x^2 + y^2)/x)/sqrt(x^2 + y^2)) assuming x>0, y>0
is not sqrt(1/x), why?
If we have two univariate polynomials $f(x)$ and $g(x)$ such that
$gcd(f(x),g(x))=1$
then we know there exist two other polynomials $a(x)$ and $b(x)$ such that $a(x)f(x)+b(x)g(x)=1$. For example, if $f(x)=x^3−1$ and $g(x)=x^2+2$, then we can set
$a(x)=\frac{2x−1}{9}$, $b(x)=\frac{−2x^2+x+4}{9}$
Here the polynomials $a(x)$ and $b(x)$ are known as Bezout polynomials and they can be found using the extended Euclidean algorithm, which I know how to do using pen and paper, but not in Maple.
So my question is: in Maple, is there a way, given $f(x)$ and $g(x)$, to solve for $a(x)$ and $b(x)$?
Another training example (number 2 and last) for finding all solutions to a system of equations:
f1 := x3^2-0.1*x1^4-0.05*x2^4+1;
f2 := x1^3+x2^3+0.05*x3^3-1;
f3 := -2*cos(3*x1)+2*cos(3*x2)-2*cos(3*x3)+1;
In my version, there are 116 solutions.
Is it so?
What kind of solution is it (see (3))? Why is there no solution when I put the initial condition v(0)=C1? Secondly, eq. (2) can be reduced to a first-order differential equation?
interface(showassumed = 0)
declare(v(y))
q := v(y)*(diff(diff(diff(v(y), y), y), y))+(2*v(y)-(diff(v(y), y)))*(diff(diff(v(y), y), y))+(diff(v(y), y))*(v(y)^3+v(y)-(diff(v(y), y))) = 0
dsolve(q)
v(y) = ODESolStruc(_a, [{(diff(diff(_b(_a), _a), _a))*_b(_a)^2+_b(_a)*((diff(_b(_a), _a))^2*_a+_a^3-(diff(_b(_a), _a))*_b(_a)+2*(diff(_b(_a), _a))*_a-_b(_a)+_a)/_a = 0}, {_a = v(y), _b(_a) = diff(v(y), y)}, {y = Int(1/_b(_a), _a)+_C1, v(y) = _a}])
dsolve({q, v(0) = C1})
v(y) = C1
Download CD_ode.mw
File:
PCA.mw
I am a student in the middle of a projekt, where math is an essential part of the task. I have done a lot of work in a maple document, but this document suddenly became corrupted. I've tried restarting and loading backups and f ollowed Can I repair a corrupted Maple document/worksheet file? (maplesoft.com) but the solutions didn't work on my document.
Also tried the DeleteBadCharacters() proccess, but i get the error "Error, (in XMLTools:-ParseString) Element type "Equation" must be followed by either attribute specifications, ">" or "/>"."
Is there a way to fix this issue, and prevent the same issue occuring in the future?
Thanks in advance!
This is a training example for finding all solutions to a system of equations. If you look at the graph, you can count 36 solutions, but I managed to find 20 relatively good approximations. No attempts to get more solutions, which are also visible as intersections of graphs, did not lead to success. Therefore, there is a suspicion that there are only 20 solutions.
Is it so?
 restart: with(plots):
 a:=8.:
 f1 := x1^4-1.999*x1^2*x2^2+x2^4-1;
 f2 := tan(x1+x2)-x2*sin(x1);
 implicitplot([f1, f2], x1 = -a .. a, x2 = -a .. a, numpoints = 25000, scaling = constrained,  color = [red, blue], thickness = 1);
   1, (3.192246883291975), (-3.0395187374365404)
   2, (3.0952031367176476), (-3.2447717313041897)
   3, (0.5881900748267959), (-1.160066226905079)
   4, (-0.936866718243322), (-1.3700058362814254)
   5, (-2.555853694651265), (-2.7399958564861953)
  6, (-3.2556241416421168), (-3.3964651254113774)
   7, (-3.583319843955091), (-3.7077839724189228)
   8, (-5.364827188794712), (-5.401998918608201)
   9, (-5.398295356665546), (-5.360818510223991)
  10, (-3.769206506106412), (-3.6477855329362683)
  11,(-1.3978806247566642), (-0.9772190664843745)
   12, (-1.192159295544978),(0.6492335177657542)
   13, (-3.0867255059416623),(2.927375855548188)
    14, (-3.18519036357835), (3.329801919022179)
   15, (2.0108268901120754), (2.243492422396739)
   16, (3.1133812329649766), (3.261937603184373)
   17, (4.0265558604742715), (4.130826167761226)
    18, (4.124539552922121), (4.019977762680433)
    19, (3.172338340844501), (3.018365965761908)
   20, (2.1945695320368097), (1.9558412553082192)
Hi !
I want to create a notation for a function, let's say :
f:=(x,y,z)->something
such that when I ask for
f(x,y,z)
Maple returns
fx,y(z) or anyother "nicer view" of that expression.
This is (I think) a similar action of replacing BesselJ(n,x) by Jn(x).
Many thanks for your answers !
Kevin
This is a follow-up to a previous question I asked that was answered with code that used "%.". From the documentation I can see that % is a nullary operator that gives us the value of "the last expression", which I think means the last result of an evaluated expression.
In my previous question, I wanted to be able to display for example, a constant times a matrix, without the product being evaluated.
For example, given A:=<1,2;3,4>:, we need to use Maple Input, and then we can write c__1.A and the output will be an expression that has c__1 then the dot product symbol and then the matrix A written out.
My question is simply: what exactly is "%."?
I am working with the physics package and I want to know if there is a difference between Physics:-CompactDisplay and PDEtools:-declare ?
As well as the difference between Physics:-Simplify and simplify.
For both cases, can they be used as the same ? Are they incompatible in some case?
Thanks !
Kevin
I would like to display an expression that is a matrix, the dot operator, and another matrix. That is, I want to display a multiplication of matrices, without the multiplication being evaluated.
Something like
<1,2;3,4> '.' <6,7,8,9>
Is this possible?
Here is some context around why I want to do this. Perhaps the main reason I use Maple is for the symbolic math capabilities using 2d math input. I want to create worksheets that look like what I would write on paper.
For example, let's say I have a matrix that is defined by <I, F;0,0>, where each of elements is actually another matrix. I want to multiply this matrix by its transpose, which would be something like <I, 0^T; F^T, 0^T>.
I would like to display <I, 0^T; F^T, 0^T> .  <I, F;0,0>.
Hello guys
I created a document recently and, the next day, when I tried to open it, I received the following message:
        Recover corrupted file and save as
Does anyone know how to recover a corrupted file?
Oliveira
First 252 253 254 255 256 257 258 Last Page 254 of 2431
