I have in internal procedure ppp that has an input prjpsn:=3. This set a Vector positions of x,y,z to either if prjpsn=1
zpsn=1,   xpsn=2,  ypsn=3
or if prjpsn =3
xpsn=1,   ypsn=2, zpsn=3
This then are used in another procedure. I can't get the values to transfere.  prjpsn would default to 3 in the module but can be set externally to 1 if needed.
The relevant parts are highlighted in green text. Cant get the worksheet to display.
Maple Worksheet - Errorprjpsn:=3
Failed to load the worksheet /maplenet/convert/Q_14-12-22_Module_internal_settings.mw .
Download Q_14-12-22_Module_internal_settings.mw
How do I calculate the conformal killing vectors of a metric tensor in GRTensorIII?
Why I get "Error, invalid subscript selector" error in my code?
y1 := Grid:-Seq(UP1(s, U, V, W, Phi, Xi, N, a, b, II, JJ, A, B, Dd, M, Ns), s = 1 .. 7);
UKt := add(y1[i], i = 1 .. 7);
As you can see y1 is defined without any problem and have 7 seqments, but the next line warns invalid subscript selector.
I have, for example,
> x(t) := sin(a)*cos(t) + cos(a)*sin(t)
            x := t -> sin(a) cos(t) + cos(a) sin(t)
> y(t) := combine(x(t))
            y := t -> combine(x(t))
>y(t);
            sin(a + t)
> x(t);
# wanted but cannot do this: x(t) := combine(x(t))
Any workaround?
why does the command Matrix(2, 2, undefined) create the following
Matrix(2, 2, [[undefined(1, 1), undefined(1, 2)], [undefined(2, 1), undefined(2, 2)]])
instead of simple undefined for each item?
There is a button at the top right corner that has an icon that seems to say 4pi/3. When I hover over it is says "Maple Math". I click on it, and insert an expression that I copy directly from Maple: a simple definition of a function. There is an error that says "You have entered an invalid Maple expression". Why? The function is defined as z__1 := (x,y) -> x+y. Perhaps the issue is the subscript. I don't know but the UI does not tell me.
Here is an example that does not give an error in the form when I click the aforementioned "Maple Math" button. However, what I see below is a broken icon and the equation f := (x,y) -> x + y (exactly like this).
f := (x, y) -> x + y
I am bewildered by the brokenness of this UI.
Example: After manipulating the following indefinite integral
Int(r^2, m)
I want to add ranges before evaluating the integral (for display purposes I keep the innert form). The op command or the IntegrationTools can be used for that (disassembling the expression and assembling it to new int expression) but require quite long code. Isn’t there a shorter  way to simply add ranges to the integration variable.
Update: Download Add_range.mw
Hi. I'm having a problem with the command phase portrait on maple when i'm trying to make a phase portrait of my autonomous differential equations. The problem is i can't get arrows on my phase portrait to see how the system behave with different intial value conditions, so my questions is how can i add arrows to the phase portrait? See below for a image of my code
Let a, b, c, d be real numbers. Define two geometric regions implicitly: abcd>0∧abacadbcbdcda2b2c2d2, and abcd>0∧abcabdacdbcd>0. Suppose that somebody wants to prove that the former region is a subset of the latter one. Can we implement such an implication simply using certain ready-made commands in basic Maple? In other words, it is hoped that
RealDomain:-simplify(forall([a, b, c, d], a + b​​​​​​​ + c + d > 0 and a*b + a*c + a*d + b*c + b*d + c*d > a^2 + b^2 + c^2 + d^2 implies a*b*c*d > 0 and a*b*c + a*b*d + a*c*d + b*c*d > 0));
Unfortunately, simplify just returns the statement unevaluated. So, how to address it in internal Maple?
Note. The desired result (or return value) is true (see below).
  1. restart; # Do not with(Logic): here
    RegularChains:-SemiAlgebraicSetTools:-QuantifierElimination(&A [d, c, b, a], ((d + c + b + a > 0) &and (b*a + c*a + d*a + c*b + d*b + d*c > a^2 + b^2 + c^2 + d^2)) &implies ((d*c*b*a > 0) &and (d*c*b + d*c*a + d*b*a + c*b*a > 0)));
  2. restart;
    not SMTLIB:-Satisfiable(`not`(a + b + c + d > 0 and a*b + a*c + a*d + b*c + b*d + c*d > a^2 + b^2 + c^2 + d^2 implies d*c*b*a > 0 and a*b*c + a*b*d + a*c*d + b*c*d > 0)); # assuming real
​​​​​​​​​​​​​​​​​​​​​Either ⒈ or ⒉ needs external calls. It seems that the Maple standard library functions in List of Commands still fail in simplifying expressions in the aforementioned form. Am I right?
Can Maple prove this simple identity  binomial(2*n, n)/2 = binomial(2*n-1, n-1) ,where n is integer and positive. Doing it manually is very easy. My attempt was unsuccessful:
is(binomial(2*n, n)/2=binomial(2*n-1, n-1)) assuming n::posint;
                                                       FAIL
In logic and computer science, the Boolean satisfiability problem (sometimes called propositional satisfiability problem and abbreviated SAT) is the problem of determining if there exists an interpretation that satisfies a given Boolean formula.
We can see that some graph problems such as the coloring problem and the problem of finding k-cliques can be transformed into SAT problem.  I am not familiar with how maple uses the sat solver. I am trying to use maple to solve the following game for a solution. The game is a good choice for understanding the SAT.
The game is won when at least one cell on each line is green.
Clicking on a number will color each cell with the same number in green, and each cell with the opposite number in red
For example:
If we choose ``1" as green(i.e. be chosen), then -1 is red (not be chosen) in any cell.  I guss that the maple function Satisfy can do it.
That is, we are looking for a set of solutions such that at least one number in any line is selected as green.
Here is a solution for winning this game:
How to use the SAT solver Satisfy in maple to find a solution from a sat game?
File:
Solution_Methods.mw
Download Solution_Methods.mw
So i have an exam right around the corner, and maple decided to corrupt my file. I get the error "There was a problem in the loading process, you worksheet may be incomplete." I've tried the following troubleshooting:
Restart - No luck
Other computer - No luck
Checked the backupfolder. - 10 backups have been made, but they are all corupt aswell
I've Followed Can I repair a corrupted Maple document/worksheet file? (maplesoft.com) It didn't really do anything
Also tried the DeleteBadCharacters() proccess, but i get the error "Error, (in XMLTools:-ParseString) Element type "Equation" must be followed by either attribute specifications, ">" or "/>"."
Anyone who can help me out here?
Please Help! I am a beginner in using maple, I am getting  error in theta(k+2).How to get  m1,m2,m3 values from theta(k+2) and how to plot a curve theta(eta) like,f(eta). pp_DTM.mw
Download pp_DTM.mw
Hi there,
I updated to Maple 2022 recently. One problem I am facing is how after I write the code and get the output, which can be text or equations or plots, etc, when I try to copy it to MS Word for example, I don't have the option of "Copy as Image" anymore. This option was available in previous versions. So was it taken out in this version? If yes, what's a subtitue for that?
I am using Maple for a school project and need to be able to copy the 2D output to MS Word just like the previous versions of Maples did.
First 254 255 256 257 258 259 260 Last Page 256 of 2431
