Not the first time that a question (OP's name  PhearunSeng ) is removed as I am writing an answer (I guess other people have already faced the same inconvenience).
Why doesn't exist a mechanism which prevents removing, deleting, displacing a question where someone (here Carl) has akready given an answer ???
Whatever the reason, here is my answer
Title: Can be done quickly if you write the matrix in a more abstract form
MyKGff := Matrix(5, 5,
    (1, 1) = A+(1/63368)*B,
    (1, 2) = -(1/63368)*B,
    (1, 3) = -(1/39605)*B,
    (1, 4) = 0,
    (1, 5) = 0,
    (2, 1) = -(1/63368)*B,
    (2, 2) = (1/63368)*B+C,
    (2, 3) = (1/39605)*B,
    (2, 4) = -C,
    (2, 5) = 0,
    (3, 1) = -(1/39605)*B,
    (3, 2) = (1/39605)*B,
    (3, 3) = (8/198025)*B,
    (3, 4) = 0,
    (3, 5) = 0,
    (4, 1) = 0,
    (4, 2) = -C,
    (4, 3) = 0,
    (4, 4) = C+(1/63368)*F,
    (4, 5) = -(1/39605)*F,
    (5, 1) = 0,
    (5, 2) = 0,
    (5, 3) = 0,
    (5, 4) = -(1/39605)*F,
    (5, 5) = (8/198025)*F
Then (Maple 2015.2)
PseudoInverse := CodeTools:-Usage( LinearAlgebra:-MatrixInverse(MyKGff, method=pseudo) ):
memory used=28.38MiB, alloc change=68.00MiB, cpu time=312.00ms, real time=314.00ms, gc time=24.90ms
To recover the pseudo inverse with original data do
Rewrite := [
             A = (D__pile*W[1] . E__c)/3000,
             B = (D__pile*W[2] . E__c)*89^(1/2),
             C = (D__pile*W[3] . E__c)/1000,
             F = (D__pile*W[4] . E__c)*89^(1/2)
eval(PseudoInverse, Rewrite):
InverseMatrix_mmcdara.mw
I would like to be able to use python's matplotlib from Maple. I am doing the following currently
with(Python)
Start('home' = "/opt/anaconda3/lib/python3.9", 'path' = "/opt/anaconda3/lib/python3.9/site-packages")
ImportModule("matplotlib as mpl")
and the error I get back is
Error, (in Python:-ImportModule) ModuleNotFoundError: No module named 'matplotlib'
['Traceback (most recent call last):\n', '  File "<string>", line 1, in <module>\n', "ModuleNotFoundError: No module named 'matplotlib'\n"]
The string I passed into path is the directory where matplotlib seems to be located as far as I can tell. I looked this up in my IDE Spyder, but using the command print(matplotlib__file__).
UPDATE: but actually if I open a new worksheet and execute
with(Python)
The error is that
Error, (in Python:-Start) unable to start Python: could not create process, mpython
So Maple isn't finding Python apparently.
I tried for 'home' also "/opt/anaconda3/bin", did not work.
Hello guys.
How to determine the gradient of the following vector field below:
with(VectorCalculus):
with(Student[VectorCalculus]):
SetCoordinates('cylindrical'[r, theta, z]):
V:=VectorField(<omega*r, 0, z*r>)
Gradient(V, [r, theta, z]);
Error, invalid input: too many and/or wrong type of arguments passed to Student:-VectorCalculus:-Gradient; first unused argument is Vector(3, [omega*r,0,z*r], attributes = [vectorfield, coords = cylindrical[r,theta,z]])
Oliveira
Working with a Document, I have a procedure which plots a graph and part of the procedure code looks like this:
with(plots)
A := Array(1)
A := plot(...plots two series...):
display(A)
The first time the procedure is called everything is as expected.  The second time the procedure is called (with different values to be plotted), the graph is not updated and therefore does not reflect the changed data
I am thinking that maybe, each time I call the procedure, I need to somehow "reset" or "release" something at the beginning of the procedure so that the plot is recreated?
I was working on a document to which I had made some changes which had not been saved.  When running Evaluate Worksheet I had to end the task because I couldn't stop the evaluation.  On re-opening the document my changes were lost, not surprisingly.
Does Maple keep any temporary files anywhere from which I might be able to salvage my changes?
Hello guys.
Is there any way to frame the styles: Input 2D, Output 2D and Text?
Oliveira.
I am collecting my coefficients with the below code. Since it is a huge data, i just give a some partion. So I want to write u11 to a text file. But when i use this command  save u11, "u111.txt" . It is writing to text but with big blanks. I show you at the below picture. So when i put it to matlab, it is again with spaces and matlab giving errors. So how can i save my long symbolic output (you can see in picture)  to a text file without spaces. I used
fd := "C:/double/u11.txt"
fprintf(fd, "%s", u11)
fclose(fd)
But it did not work. So if you could help me, i really appreciate. My best regards.
A robust largescale index-1 DAE (and stiff ODE) solver has been developed in Maple.
PS: These codes run only with the Java version of Maple. Codes are saved as *.mws for the ease of typing. One can download the files and save them as *.mw as well.
Details about our approach are provided in a paper just submitted.
See arxiv at
https://arxiv.org/abs/2212.02630
We encourage everyone to test these codes and report bugs. All the examples can be run with Intel's Pardiso (provided users have access to libraries) by calling DAESolverP.txt and by calling "IMPDAEP" instead of "IMPDAE". This is useful for large-scale problems. The symbolic capability and ListTools search capability of Maple are very good and can be used for developing optimization solvers as well.
I would like to know if CPU time/memory usage can be reduced significantly. In particular,  for examples 5 and 6. Some ways to contribute include
(1) Running the code in evalhf or compiled form. This may be hard.
(2) Providing options to run other parallel open-source linear solvers (eg., MUMPS).
(3) Other examples that show the use of the developed solver. We are able to solve > 100,000 DAEs.
(4) Helping in converting the code to Maple 14 or earlier (by doing sparse LU Decomposition. Just using LinearSolve will slow down the code).
Please avoid ~,*, etc (shortcuts) unless it improves the speed of calculation.
Dr. Venkat Subramanian
Download examples_1_3.mws
Download example_4.mws
Download example_5.mws
Download example_6.mws
mw format files are given below
DAESolver.txt
DAESolverP.txt
With
DrawGraph(G, stylesheet = [vertexpadding = 35], showlabels = false)
I get this
But if I wish emphasize the chromatic number, with
COLORS := [red, yellow, cyan, green, coral, blue, magenta, navy, orange, pink, plum, khaki, turquoise];
cn := ChromaticNumber(G, 'col');
for i to cn do
    HighlightVertex(G, col[i], COLORS[i]);
DrawGraph(G, stylesheet = [vertexpadding = 35], showlabels = false);
I get this
I want bigger vertices, any suggestions? Thanks
> expr[[(-.684-1.08*r+6.1*r^2-2*r^3+0.36e-1*ln(10.*r)-.3*r^2*ln(10.*r))/(-1.14+1.2*r+0.6e-1*ln(10.*r)), 1.290994449*sqrt((-.1296*r+1.512*r^2-.36*r^3+6.1*r^4-2*r^5-0.72e-1*r^2*ln(10.*r)-.3*r^4*ln(10.*r)+(-.684-1.08*r+6.1*r^2-2*r^3+0.36e-1*ln(10.*r)-.3*r^2*ln(10.*r))*(.216*r-2.52*r^2+.12*r^2*ln(10.*r))/(-1.14+1.2*r+0.6e-1*ln(10.*r)))/(-1.14+1.2*r+0.6e-1*ln(10.*r)))], [(-.684-1.08*r+6.1*r^2-2*r^3+0.36e-1*ln(10.*r)-.3*r^2*ln(10.*r))/(-1.14+1.2*r+0.6e-1*ln(10.*r)), -1.290994449*sqrt((-.1296*r+1.512*r^2-.36*r^3+6.1*r^4-2*r^5-0.72e-1*r^2*ln(10.*r)-.3*r^4*ln(10.*r)+(-.684-1.08*r+6.1*r^2-2*r^3+0.36e-1*ln(10.*r)-.3*r^2*ln(10.*r))*(.216*r-2.52*r^2+.12*r^2*ln(10.*r))/(-1.14+1.2*r+0.6e-1*ln(10.*r)))/(-1.14+1.2*r+0.6e-1*ln(10.*r)))]];
> plot([seq([expr[j][], r = 0 .. 1], j = 1 .. 2)], -6 .. 6, -10 .. 10, color = [blue, blue]);
 why I am getting error in this, please help
When I am differentiate the composite functions, I wanna make the output more elegant.
For example, from the following code:
A__1 := A__0 + k(e)*a__1;
diff(phi(A__1), a__1);
I define a function phi(A__1) and function A__1(a__1), and the latter is known.
But Maple output:
D(numtheory:-phi)(A__0 + k(e)*a__1)*k(e)
I think "D(numtheory:-phi)(A__0 + k(e)*a__1)" part can be simplified into d(phi)/d(A__1).
Do you have some ideas? Thanks!
Trying to use the following question dialog
with(Maplets[Elements]);
maplet := Maplet(QuestionDialog("Is x > 0?"));
result := parse(Maplets[Display](maplet));
Displays question with Yes and No buttons but whichever button is clicked the result is always false.  This was based closely on an example from the documentation.
So, how can I tell which button was clicked.  Also, the close button could have been clicked - how should that be dealt with?
In 1D worksheet mode I can't figure out how to insert a line between a and c.
a:=1
                             a := 1
c:=3
                             c := 3
Hello guys.
Is there any way to convert a worksheet to a document and vice versa?
Oliveira.
Hello, everyone. I have plotted a simple equation and now have the following observation regarding it.
1- How to change or control axis style mean style like bold, colour change etc?
2-  How to change or control the font, colour and style of numbers written automatically by maple while plotting on the axis (x-axis, y-axis)?
3- How to change the font, style and colours of labels?
The problem I am facing is that whenever I save or import any graph as png or jpeg and then paste it into MS word, it's quality or pixel changes and it looks very bad. is there any way to save and paste good-quality pictures into documents that means DPI?
Qaulity_Help.mw
First 256 257 258 259 260 261 262 Last Page 258 of 2431
