Hello everyone!
How do I get some information about my computer (eg Windows edition,System processor, Computer name, .....) with the Maple command?
Thanks for your help!
I can generate Bode Plots from a transfer function but I just need to know what the gain is at a specific frequency.  Is there a simple way to do that without having examine the plots?
Thank you,
David
Hello all,
I am fairly new to Maple and would like to programatically simplify the output form using Maple's pade function on an arbitrary function: Y := 1/(R__s + 1/(s*C__dl + 1/(R__ct + 1/(sqrt(s)/sigma + 1/R__w))))
I found that only Maple's pade function was able to convert my function into a rational expression which is quite interesting.
Now I would like to replicate using maple what was manually done in steps 2 - 4 of the attached solution pdf (which was done by hand).
I was only able to do step 1 (as shown in the attached maple worksheet) after which I got stuck.
kindly assist
with(numapprox)
[chebdeg, chebmult, chebpade, chebsort, chebyshev, confracform, hermite_pade, hornerform, infnorm, laurent, minimax, pade, remez]
s = I*omega
s = I*omega
Y := 1/(R__s+1/(s*C__dl+1/(R__ct+1/(sqrt(s)/sigma+1/R__w))))
1/(R__s+1/(s*C__dl+1/(R__ct+1/(s^(1/2)/sigma+1/R__w))))
padey := pade(Y, x = sqrt(s), [1, 1])
(C__dl*s^(3/2)*R__ct*R__w+C__dl*R__ct*s*sigma+C__dl*R__w*s*sigma+s^(1/2)*R__w+sigma)/(C__dl*s^(3/2)*R__ct*R__s*R__w+C__dl*R__ct*R__s*s*sigma+C__dl*R__s*R__w*s*sigma+s^(1/2)*R__ct*R__w+s^(1/2)*R__s*R__w+R__ct*sigma+R__s*sigma+sigma*R__w)
collect((C__dl*s^(3/2)*R__ct*R__w+C__dl*R__ct*s*sigma+C__dl*R__w*s*sigma+s^(1/2)*R__w+sigma)/(C__dl*s^(3/2)*R__ct*R__s*R__w+C__dl*R__ct*R__s*s*sigma+C__dl*R__s*R__w*s*sigma+s^(1/2)*R__ct*R__w+s^(1/2)*R__s*R__w+R__ct*sigma+R__s*sigma+sigma*R__w), s)
(C__dl*s^(3/2)*R__ct*R__w+(C__dl*R__ct*sigma+C__dl*R__w*sigma)*s+s^(1/2)*R__w+sigma)/(C__dl*s^(3/2)*R__ct*R__s*R__w+(C__dl*R__ct*R__s*sigma+C__dl*R__s*R__w*sigma)*s+(R__ct*R__w+R__s*R__w)*s^(1/2)+R__ct*sigma+R__s*sigma+sigma*R__w)
padey2 := collect((C__dl*s^(3/2)*R__ct*R__w+C__dl*R__ct*s*sigma+C__dl*R__w*s*sigma+s^(1/2)*R__w+sigma)/(C__dl*s^(3/2)*R__ct*R__s*R__w+C__dl*R__ct*R__s*s*sigma+C__dl*R__s*R__w*s*sigma+s^(1/2)*R__ct*R__w+s^(1/2)*R__s*R__w+R__ct*sigma+R__s*sigma+sigma*R__w), sigma)
((C__dl*R__ct*s+C__dl*R__w*s+1)*sigma+C__dl*s^(3/2)*R__ct*R__w+s^(1/2)*R__w)/((C__dl*R__ct*R__s*s+C__dl*R__s*R__w*s+R__ct+R__s+R__w)*sigma+C__dl*s^(3/2)*R__ct*R__s*R__w+s^(1/2)*R__ct*R__w+s^(1/2)*R__s*R__w)
Download maple_attempt.mw
solution.pdf
Why Maple returns empty solution (see eq. (5))? Also, is it possible that Maple not only gives us the explit solution but also the solution steps?
with(PDEtools, TWSolutions, declare)
[TWSolutions, declare]
with(DEtools, diff_table)
[diff_table]
U := diff_table(u(x, t))
table( [(  ) = u(x, t) ] )
sys := {U[]*U[x]+U[t]-pU[x, x]+qU[x, x, x] = 0}
{u(x, t)*(diff(u(x, t), x))+diff(u(x, t), t)-pU[x, x]+qU[x, x, x] = 0}
TWS_sol := TWSolutions(sys)
map(pdetest, [TWS_sol], sys)
Download twsol.mw
Dear maple user i am facing difficulty to plot the graph   for different values  of parameter M=2,4  and fixing t=j=0 to 2 and   y=i=0 to 4 on x axis and U on y axis. I am unable to plot 2D . I am enclosing the codes and sample graphs.
# Parameter values:
 Pr:=0.71:E:=1:A:=0:Sc:=0.02: K:=1:
a := 0: b := 1: N := 9:
h := (b-a)/(N+1): k := (b-a)/(N+1):
 lambda:= 1/h^2:  lambda1:= 1/k^2:
# Initial conditions
for i from 0 to N do
  U[i, 0] := h*i+1:
  T[i, 0] := h*i+1:
  C[i, 0] := h*i+1:
# Boundary conditions
for j from 0 to N+1 do
  U[0, j] := exp(A*j*lambda);
  U[N+1, j] := 0;
  T[0, j] := j*lambda1;
  T[N+1, j] := 0;
  C[0, j] := j*lambda1;
  C[N+1, j] := 0
#Discretization Scheme
for i to N do
  for j from 0 to N do
    eq1[i, j]:= lambda1*(U[i, j+1]-U[i, j]) = (Gr/2)*(T[i, j+1]+T[i,j])+(Gr/2)*(C[i, j+1]+C[i,j])+(lambda^2/2)*(U[i-1,j+1]-2*U[i,j+1]+U[i+1,j+1]+U[i-1,j]-2*U[i,j]+U[i+1,j])-(M/2)*(U[i,j+1]+U[i,j]) ;
    eq2[i, j]:= lambda1*(T[i, j+1]-T[i, j]) = (1/Pr)*(lambda^2/2)*(T[i,j+1]-2*T[i,j+1]+T[i+1,j+1]+T[i-1,j]-2*T[i,j]+T[i+1,j])+(E*lambda^2)*((U[i+1,j]-U[i,j])^2);
    eq3[i, j]:= lambda1*(C[i, j+1]-C[i, j]) = (1/Sc)*(lambda^2/2)*(C[i,j+1]-2*C[i,j+1]+C[i+1,j+1]+C[i-1,j]-2*C[i,j]+C[i+1,j])+(K/2)*((C[i,j+1]+C[i,j]))
  end do
# Determine the unknowns in the system
  `union`(  seq(seq( indets( eq1[i,j], name), i=1..N), j=0..N),
            seq(seq( indets( eq2[i,j], name), i=1..N), j=0..N),
            seq(seq( indets( eq3[i,j], name), i=1..N), j=0..N)
# And how many unknowns
   numelems(%);
# And the number of equations
  numelems(eq1)+numelems(eq2)+numelems(eq3);
# So if one supplies values for 'Gr' and 'M', and
# (assuming the equations are consistent), one ought
# to be able to get values for C[1..9, 1..10],
# T[1..9,1..10], and U[1..9,1..10]
# As an example below, choos Gr=1.0 and M=2, then the
# following obtains a 'solution` afer a minute or so
  fsolve( eval( [ seq(seq(eq1[i,j], i=1..N),j=0..N),
                  seq(seq(eq2[i,j], i=1..N),j=0..N),
                  seq(seq(eq3[i,j], i=1..N),j=0..N)
                [Gr=1.0, M=2]
Is there more or less simple way to generate magic and semi magic squares in maple by just giving the order and the magic constant?
It appears that using 2D math can generate hidden characters that make code not run.
It seems like a lot of people think that using 1D math is a no-brainer, as if it had all the advantages and no disadvantages.
I am trying to write code for an object. I was using 2D math, because the automatic formatting of the code (italics, bold) makes it much easier to see and understand the code. Then again, I ran into an issue I face sometimes which is that code that looks absolutely perfect can't be parsed.
I read that we can convert the code to 1D math and we will see hidden characters messing things up but that doesn't seem to be the case (or at least I can't seem to see the extra character). And in any case, it is just maddening and not a productive thing to have to do.
Is 1D math really the best user experience that is available? Is there really a tradeoff between legibility and useability in Maple 2022?
This ode from textbook, and the solution is given in back of book and I verified it is correct.
odetest gives zero also when asked to verify the solution.
but when asked to verify both the solution and the initial conditions, instead of returning [0,0] as expected, it returns [the_ode,0]
Here is an example
ode:=diff(y(x), x) = 2*(2*y(x) - x)/(x + y(x));
ic:=y(0) = 2;
booksol:=(x-y(x))^2/( y(x)-2*x)^3 = 1/2;
diff(y(x), x) = 2*(2*y(x)-x)/(x+y(x))
y(0) = 2
(x-y(x))^2/(y(x)-2*x)^3 = 1/2
#this returns zero, so maple agree the book solution is correct
odetest(booksol,ode)
#when adding ic, when does it not give [0,0] ?
odetest(booksol,[ode,ic])
[diff(y(x), x)-2*(2*y(x)-x)/(x+y(x)), 0]
How shoulld one interpret the above answer?
Download question_on_odetest_nov_14_2022.mw
Consider the following system of differential equations
sys := diff(y(x), x) = z(x)*f1(i), diff(z(x), x) = y(x)*f2(i)
where f1 and f2 are functions that depend on the current iteration. Ultimately, I'd like to index into an array that has the length of the number of iterations, to obtain a value that will be part of the differential equations. It's an array of random numbers, but I'd rather not have to generate them on the fly while dsolve is working.
I've been investigating the use of Events for this, but the documentation is quite atrocious and outdated (and I only know this because, for example, when I try to use certain arguments to dsolve some error messages show that the arguments have changed name)
Please help me to prove that the limit of the following function does not exist:
I've read the documentation on events, and as far as I can tell after an hour or two, I am doing exactly what is in the documentation but not getting the expected result.
Here is a worksheet illustrating the issue: dsolve_events.mw
Basically there is a very simply system of two differential equations and I would simply like to see an event triggered when the dependent variable is above 2.
This event has no useful interpretation, it was just my attempt at trying to get something to trigger (I have tried multiple things). As far as I can tell from the docs I am using an event specification of form
[0, c(t,y(x)) < 0]: discrete event with a conditional trigger
ie, [0,2-x<0]
and when that is triggered I set i(x) to something like i(x)+1 (but even something as simple as assigning it to some constant like 7, given that the initial value i(0)=0, would allow me to check when the event is being triggered), where i(x) is defined as a discrete variable (my ultimate goal is to trigger the event on every iteration and have i be the iteration counter. I want to use this iteration counter in the equations)
I run the dsolve command, assign the result to a variable and then call, for example p(3). I would expect to see the event triggered and i(3) not equal to the initial value i(0). But the value of i(x) doesn't change.
Hi got this set of error using the Plot package. Anyone here know what they mean?
Given any arbitrary function, say... cos(3t)+2sin(2t-3)
How can I generate data from said funciton. Precisely, I want to generat the dataset
t         value
0.1      value1
0.2      value2
10.0    value(@t=10)
Surely there has to be some easy way to do this but I cannot seem to find it. the plottool:-getdata does not seem to be able to export the data in the desired t increments.
The following example shows clearly that timelimit is still broken in Maple.
I tried this 10 times, and it hangs each time. I could wait 30 minutes and it still hangs. timelimit simply does not work. I set timelimit to 20 or 30 seconds.  This really makes developing software in Maple very difficult when timelimit itself hangs as it means the whole program comes to halt and becomes frozen and I see no workaround this problem.
ode:=1/2*sqrt((diff(y(x), x) - sqrt(-a^2*(a - b)*(a + b))/a^2)^2 + 2*sqrt(-a^2*(a - b)*(a + b))*(diff(y(x), x) - sqrt(-a^2*(a - b)*(a + b))/a^2)/a^2 + b^2/a^2)/a - 1/2*b^2*ln((2*b^2/a^2 + 2*sqrt(-a^2*(a - b)*(a + b))*(diff(y(x), x) - sqrt(-a^2*(a - b)*(a + b))/a^2)/a^2 + 2*sqrt(b^2/a^2)*sqrt((diff(y(x), x) - sqrt(-a^2*(a - b)*(a + b))/a^2)^2 + 2*sqrt(-a^2*(a - b)*(a + b))*(diff(y(x), x) - sqrt(-a^2*(a - b)*(a + b))/a^2)/a^2 + b^2/a^2))/(diff(y(x), x) - sqrt(-a^2*(a - b)*(a + b))/a^2))/(a^3*sqrt(b^2/a^2)) + 1/2*sqrt((diff(y(x), x) + sqrt(-a^2*(a - b)*(a + b))/a^2)^2 - 2*sqrt(-a^2*(a - b)*(a + b))*(diff(y(x), x) + sqrt(-a^2*(a - b)*(a + b))/a^2)/a^2 + b^2/a^2)/a - 1/2*b^2*ln((2*b^2/a^2 - 2*sqrt(-a^2*(a - b)*(a + b))*(diff(y(x), x) + sqrt(-a^2*(a - b)*(a + b))/a^2)/a^2 + 2*sqrt(b^2/a^2)*sqrt((diff(y(x), x) + sqrt(-a^2*(a - b)*(a + b))/a^2)^2 - 2*sqrt(-a^2*(a - b)*(a + b))*(diff(y(x), x) + sqrt(-a^2*(a - b)*(a + b))/a^2)/a^2 + b^2/a^2))/(diff(y(x), x) + sqrt(-a^2*(a - b)*(a + b))/a^2))/(a^3*sqrt(b^2/a^2)) - 1/2*b*ln(a^2*diff(y(x), x)^2 + a^2 - b^2)/a^2 - y(x) - _C1 = 0:
try
  print("Before calling timelimt on odeadvisor");
  timelimit(20,DEtools:-odeadvisor(ode,y(x)));
  print("Did not time out");
catch:
  print("TIMED OUT");
end try;
Does this hang on your version of Maple? I am using 2022.2 on windows 10.
I was hoping this problem with timelimit has finally been fixed in Maple 2022.2. From this post almost 2 years ago!  it says
"You will also be pleased to know that Maple 2021 addresses the timelimit() issue that you mentioned."
But it is clearly not yet fixed.
Some important observations
1) sometimes I noticed if timelimit is small (say 5 or 10), it does not hang. So it the above does timeout for you, please try with larger time out, say 40 or 60 seconds. Since it depens on how fast the PC is.
2)sometimes I  noticed if I close Maple and start new sesstion, the very first time it could timeout OK, but the second time it is called, it hangs. May be because the server caches something to cause this.
All this means, it is completely not predictable what wil happen when starting the maple run. I have no idea how long it will take from one time to another, or even if it will hang or not. For all the years I used Maple, I never had one single time where one run completed without having to restart it at least 2 or 3 times in order to reach the finish line.  This is in addition to all those server.exe crashing on its own many times in between. I noticed more and more of these in Maple 2022.2.  But that is for another topic.
The following screen shot showing one instance when I run the above timelimit (been wainting now for 15 minutes, using timeout of 30 second)., It shows Maple server taking 81% of the CPU
And the following is screen shot of the worksheet itself when I took the above screen shot
Download timelimit_hangs_on_odeadvisor.mw
Maple offers the dimension “lenght” whereas MapleSim offers two types.
What is the difference between the two types length and distance?
Can they always be used interchangeably?
First 265 266 267 268 269 270 271 Last Page 267 of 2431
