eval.mw This is the maple worksheet The regions are u<=-1, -1<=u<=1,u>=1
I want to plot a number created in a loop to monitor how it varies while keeping all previous ones on the figure. This is simply done in Matlab by hold on command, but I dont know how it is possible in Maple?
for i to 22 do
plot([i], [i^.5], style = point) :
end do
Note I want to monitor points during the loop running not after it finishes.
how to write
-a2/3 + a3 - (2*a4)/3 - (2*a5)/3
into the form
-(-3*a3 + a2 + 2*a4 + 2*a5)/2
No simplify works. Please help.
test.mw
How to collect the coefficient of epsilon^(1/2) from A.
Actually, I want to write A as A=c1*epsilon^(1/2) +c2*epsilon+c3*epsilon^(3/2)
How to do that? My collect command failed to do this.
A:=-epsilon^(3/2)*a2^3/4 - (5*epsilon^(3/2)*a4^3)/3 - (5*epsilon^(3/2)*a5^3)/3 + a3*sqrt(epsilon) - sqrt(epsilon)*a2/3 - (2*sqrt(epsilon)*a4)/3 - (2*sqrt(epsilon)*a5)/3 - (5*epsilon^(3/2)*a2)/36 + (5*epsilon^(3/2)*a4)/9 + (5*epsilon^(3/2)*a5)/9 + epsilon/12 + (4*epsilon^(3/2)*a2*a4*a5)/3 - (7*epsilon^(3/2)*a2*a3*a4)/12 - (7*epsilon^(3/2)*a2*a3*a5)/12 + 5*epsilon^(3/2)*a3*a4*a5 - (3*epsilon^(3/2)*a2^2*a4)/4 - (3*epsilon^(3/2)*a2^2*a5)/4 + (2*epsilon^(3/2)*a2*a4^2)/3 + (2*epsilon^(3/2)*a2*a5^2)/3 - 5*epsilon^(3/2)*a4^2*a5 - 5*epsilon^(3/2)*a4*a5^2 + epsilon^(3/2)*a2^2*a3/12 + (5*epsilon^(3/2)*a3*a4^2)/2 + (5*epsilon^(3/2)*a3*a5^2)/2
 Kind help Please It will be acknownoleged please please help
The conditions given the below PDF file link Please help it will be greatly acknowleged
to_maple.pdf
Hello im an amateur using maple for my hidraulics machines course at engineering school. Does anyone know how to use the degrees package on maple 2021, i called it out by using the short form. with(Degrees): and then try to use sind but it doesnt recognice the command.
Also when using RPMs the units that should be giving me m/s appear as m2/m*s(radious). I know that the software recognice it as angular speed but is there anyway to eliminate the (radious) so i can work with the speed as lineal?
We have the system with one discrete variable along x-axis (i.e. 'i' is discrete in the attached file) and other variable 't' is continuous. But maple return error.
CD.mw
Good day everyone,
Please, I need help on how to optimize the function above. I actually wanted to plot the function with respect to "eta", but, I need the optimum value(s) for "alpha". Anyone with useful information should please help.
Thanking you in anticipation for your help.                                                             f=((-0.111000111e-1*alpha^4+.109890109900000*alpha^3+0.110726700000000e-1*alpha^2+0.133899904900000e-3*alpha+0.136700000000000e-4)*exp(-alpha*eta)+(-0.683733733e-5+0.683733733e-5*alpha^2-0.676896396e-4*alpha)*exp(-2*alpha*eta)+0.111000111e-1*alpha^4-.109890109900000*alpha^3-0.110794990900000e-1*alpha^2-0.663221721200000e-4*alpha-0.683733733200000e-5)/(.1*alpha^5-.99*alpha^4-.1*alpha^3)
how to plot multivalued function in the region from  -a to a solving 2nd order ode in maple ?
d^x/du^2+1/2sech^2(u)*x(u)=0  . I have to find out the analytical value in three different regions like u<=-a , -a<=u<=a , u>=a . How to find out ?
with(geometry):
_EnvHorizontalName := x:
_EnvVerticalName := y:
a := 7:
b := a*(1/2 + 1/6*sqrt(45 - 24*sqrt(3)))^2:
r := b*sqrt(b)/(sqrt(a + b) + sqrt(a)):
point(A, -a, b): point(B, -a, -b):
point(C, a, -c): point(F, a, b):
Sq := square(Sq, [A, B, C, F]):
circle(C1, [point(P1, [r, 0]), r]):
circle(C2, [point(P2, [(1 + sqrt(3))*r, r]), r]):
circle(C3, [point(P3, [(1 + sqrt(3))*r, -r]), r]):
ellipse(E, x^2/a^2 + y^2/b^2 = 1, [x, y]):
solve({Equation(C1), x^2/a^2 + y^2/b^2 = 1}, {x, y}):
point(T, [5.349255162, 2.829908743]):
IsOnCircle(T, C1);
draw([E(color = cyan), C1(color = yellow, filled = true), T(symbol = solidcircle, symbolsize = 20, color = red), Sq, C2(color = red), C3(color = red),Sq(color=blue)], axes = normal, view = [-a .. a, -b .. b], scaling = constrained);
square: (196+(7*(1/2+(1/6)*(45-24*3^(1/2))^(1/2))^2+c)^2)^(1/2)-(196+196*(1/2+(1/6)*(45-24*3^(1/2))^(1/2))^4)^(1/2) = 0
square: (7/2)*(1/2+(1/6)*(45-24*3^(1/2))^(1/2))^2-(1/2)*c = 0
Error, (in geometry:-square) not enough information to define a square
Error, (in geometry:-draw) cannot determine the vertices for drawing .Why all these errors ? Thank you.
About a half hour ago, there was a Post titled "Read binary file" from a new user. I converted it to a Question. Now that I want to Answer the Question, I can't find it. If you are the author of that Question, and you still want an answer, please post it again, but put it in the Questions area.
(I think that there may be a bug in MaplePrimes that makes this happen. I've had it happen several times before.)
Anyway, please respond to this regardless of what you want regarding the Question. That'll help me figure out what went wrong.
i am a very new user of Maple.
is there an equivalent Mathematica function of
Transpose@Partition[BinaryReadList["Namefile","UnsignedInteger16"],8]
thank you very much and best regards
bruno
I'm seeking a way to test conditional statements for truth in Maple (2022).
The statements are like (\phi^2 > 2) implies (\phi > 1.4)
1) how can I input such kind of statements?
2) how can I get a result in form true/false
  a) for entire expression
  b) (depending on phi range)
Does anyone use the /= assignment operator?
I am trying to do a
while error  > error_tol do
sequence of ops,
# update error from last loop
# simple example of assignment test
error /= 2;    #to simulate decreasing error each loop.  Real equation on RHS is error(i) = error(i-1) + comparison of last iterates.
# Real operator assignment I'd like to use is error += comparison
the divide / keeps applying as the single divide and a long line under the variable before I can type =.   This happens in both 1-D and 2-D.   The "Operator Assignments" help page doesn't have a lot of help on syntax problems using these.
Bill
I am trying to find a fast method for integration of a function composed of several Heavisides. I used Quadrature-Romberg, but no success. What is the problem with it and what method do you recommend instead?
A := Heaviside(zeta__2-.6429162216568)*Heaviside(eta__2+.5050000000000-10.98537767108*sqrt(492.5151416233-zeta__2^2))+Heaviside(zeta__2-.9999999999936)*Heaviside(eta__2+.9875792458758+3.881485663812*10^9*sqrt(9.765625000000*10^22-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2-.4637698986762+2.327456686822*10^11*sqrt(2.777777777778*10^24-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2-.4637698986762-2.327456686822*10^11*sqrt(2.777777777778*10^24-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.1619291800251+3.018371923484*10^11*sqrt(4.000000000000*10^24-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.1619291800251-3.018371923484*10^11*sqrt(4.000000000000*10^24-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.7243706106403+1.382194833711*10^11*sqrt(1.562500000000*10^24-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.7243706106403-1.382194833711*10^11*sqrt(1.562500000000*10^24-zeta__2^2))+Heaviside(zeta__2-1.000000000000)*Heaviside(eta__2+.9875792458758-3.881485663812*10^9*sqrt(9.765625000000*10^22-zeta__2^2))-Heaviside(zeta__2-1.000000000000)*Heaviside(eta__2+.9875792458758+3.881485663812*10^9*sqrt(9.765625000000*10^22-zeta__2^2))+Heaviside(zeta__2-1.000000000000)*Heaviside(eta__2-.8341191288491-1.298592148442*10^10*sqrt(9.706617486471*10^21-zeta__2^2))-Heaviside(zeta__2-1.000000000000)*Heaviside(eta__2-.8341191288491+1.298592148442*10^10*sqrt(9.706617486471*10^21-zeta__2^2))-Heaviside(zeta__2-.9999999999796)*Heaviside(eta__2-.8341191288491-1.298592148442*10^10*sqrt(9.706617486471*10^21-zeta__2^2))-Heaviside(zeta__2-.5527964251744)*Heaviside(eta__2+.5050000000000-10.98537767108*sqrt(492.5151416233-zeta__2^2))+Heaviside(zeta__2-.5527964251744)*Heaviside(eta__2+.5050000000000+10.98537767108*sqrt(492.5151416233-zeta__2^2))+Heaviside(zeta__2-.7684252323012)*Heaviside(eta__2-.5050000000000-8.127372424924*sqrt(269.5813999936-zeta__2^2))-Heaviside(zeta__2-.6466146460206)*Heaviside(eta__2-.5050000000000-8.127372424924*sqrt(269.5813999936-zeta__2^2))-Heaviside(zeta__2-.7684252323012)*Heaviside(eta__2-.5050000000000+8.127372424924*sqrt(269.5813999936-zeta__2^2))+Heaviside(zeta__2-.6466146460206)*Heaviside(eta__2-.5050000000000+8.127372424924*sqrt(269.5813999936-zeta__2^2))-Heaviside(zeta__2-.9999999999936)*Heaviside(eta__2+.9875792458758-3.881485663812*10^9*sqrt(9.765625000000*10^22-zeta__2^2))+Heaviside(zeta__2-.9999999999796)*Heaviside(eta__2-.8341191288491+1.298592148442*10^10*sqrt(9.706617486471*10^21-zeta__2^2))+Heaviside(zeta__2+.9999999999972)*Heaviside(eta__2+.9842650870048-1.085166413462*10^10*sqrt(4.756242568371*10^23-zeta__2^2))-Heaviside(zeta__2+.9999999999972)*Heaviside(eta__2+.9842650870048+1.085166413462*10^10*sqrt(4.756242568371*10^23-zeta__2^2))+Heaviside(zeta__2+.9999999999990)*Heaviside(eta__2+.1619291800251-3.018371923484*10^11*sqrt(4.000000000000*10^24-zeta__2^2))-Heaviside(zeta__2+.9999999999990)*Heaviside(eta__2+.1619291800251+3.018371923484*10^11*sqrt(4.000000000000*10^24-zeta__2^2))+Heaviside(zeta__2+.9999999999988)*Heaviside(eta__2-.4637698986762-2.327456686822*10^11*sqrt(2.777777777778*10^24-zeta__2^2))-Heaviside(zeta__2+.9999999999988)*Heaviside(eta__2-.4637698986762+2.327456686822*10^11*sqrt(2.777777777778*10^24-zeta__2^2))+Heaviside(zeta__2+.9999999999984)*Heaviside(eta__2+.7243706106403-1.382194833711*10^11*sqrt(1.562500000000*10^24-zeta__2^2))-Heaviside(zeta__2+.9999999999984)*Heaviside(eta__2+.7243706106403+1.382194833711*10^11*sqrt(1.562500000000*10^24-zeta__2^2))+Heaviside(zeta__2+.9999999999984)*Heaviside(eta__2-.9031048925918-8.123652892875*10^10*sqrt(1.562500000000*10^24-zeta__2^2))-Heaviside(zeta__2+.9999999999984)*Heaviside(eta__2-.9031048925918+8.123652892875*10^10*sqrt(1.562500000000*10^24-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.9842650870048-1.085166413462*10^10*sqrt(4.756242568371*10^23-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.9842650870048+1.085166413462*10^10*sqrt(4.756242568371*10^23-zeta__2^2))-Heaviside(zeta__2-.6429162216568)*Heaviside(eta__2+.5050000000000+10.98537767108*sqrt(492.5151416233-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2-.9031048925918-8.123652892875*10^10*sqrt(1.562500000000*10^24-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2-.9031048925918+8.123652892875*10^10*sqrt(1.562500000000*10^24-zeta__2^2)):
plot3d(A, zeta__2 = -1 .. 1, eta__2 = -1 .. 1, color = green)
Digits := 22:
with(Student[NumericalAnalysis]):
Quadrature(Quadrature(A, zeta__2 = -1 .. 1, method = romberg[8]), eta__4 = -1 .. 1, method = romberg[8])
Float(undefined)*Heaviside(eta__2+1212964270000000000001.)+Float(undefined)*Heaviside(eta__2-1279401131003415700657.)-0.1513022270849353690226e-1*Heaviside(eta__2-133.8411610374164929382)+Float(undefined)*Heaviside(eta__2-7483906296259851792359.)+Float(undefined)*Heaviside(eta__2+7483906296259851792361.)+Float(undefined)*Heaviside(eta__2-0.1015456611625000000000e24)+Float(undefined)*Heaviside(eta__2+0.1015456611625000000000e24)+Float(undefined)*Heaviside(eta__2+0.3879094478488497112464e24)+Float(undefined)*Heaviside(eta__2+1279401131003415700655.)-0.4538512794872905686682e-1*Heaviside(eta__2-133.8360207224718595497)+0.4538512794872905686682e-1*Heaviside(eta__2+132.8260207224718595497)+0.4538512794872905686682e-1*Heaviside(eta__2+132.8042477794001150390)-0.4538512794872905686682e-1*Heaviside(eta__2-133.8253766167816064928)-0.4538512794872905686682e-1*Heaviside(eta__2-243.1883998382669648802)+0.1513022270849353690226e-1*Heaviside(eta__2+132.8311610374164929382)+Float(undefined)*Heaviside(eta__2-0.1727743542500000000000e24)-0.1513022270849353690226e-1*Heaviside(eta__2-243.2027260661341424950)+0.1513022270849353690226e-1*Heaviside(eta__2+244.2127260661341424950)+0.4538512794872905686682e-1*Heaviside(eta__2+244.1983998382669648802)-0.4538512794872905686682e-1*Heaviside(eta__2-243.1980716456433769010)+0.4538512794872905686682e-1*Heaviside(eta__2+244.2080716456433769010)+0.4538512794872905686682e-1*Heaviside(eta__2+132.8153766167816064928)+0.1513022270849353690226e-1*Heaviside(eta__2+132.8098727970154075001)+Float(undefined)*Heaviside(eta__2-0.3879094478488497112464e24)-0.4538512794872905686682e-1*Heaviside(eta__2-243.2072595071292620415)+Float(undefined)*Heaviside(eta__2+0.6036743846000000000000e24)+Float(undefined)*Heaviside(eta__2-0.6036743846000000000000e24)+Float(undefined)*Heaviside(eta__2+0.1727743542500000000000e24)-0.1916322521366165064753e-1*Heaviside(eta__2-133.8307592537082147847)+0.1916322521366165064753e-1*Heaviside(eta__2+132.8207592537082147847)-0.1916322521366165064753e-1*Heaviside(eta__2-243.2116719753798543789)+0.1916322521366165064753e-1*Heaviside(eta__2+244.2216719753798543789)-0.4538512794872905686682e-1*Heaviside(eta__2-133.8026340889186250133)+0.4538512794872905686682e-1*Heaviside(eta__2+132.7926340889186250133)-0.4538512794872905686682e-1*Heaviside(eta__2-133.8142477794001150390)-0.1513022270849353690226e-1*Heaviside(eta__2-133.8198727970154075001)+0.4538512794872905686682e-1*Heaviside(eta__2+244.2172595071292620415)-0.1903631769101229216919e-1*Heaviside(eta__2-133.8085015485931455736)+0.1903631769101229216919e-1*Heaviside(eta__2+132.7985015485931455736)+0.1903531841918040745676e-1*Heaviside(eta__2+244.2032962387251632874)-0.1903531841918040745676e-1*Heaviside(eta__2-243.1932962387251632874)+Float(undefined)*Heaviside(eta__2-1212964269999999999999.)
int(int(A, zeta__2 = -1 .. 1), eta__2 = -1 .. 1)
.4238607655960000000000
Download romberg.mw
First 291 292 293 294 295 296 297 Last Page 293 of 2431
