How do I make my Maple use delta instead of d for differential equations?
example:
The Document Tools, Tabulate command says this:
Calls to the Tabulate command cannot be nested within each other unless used with the option output=XML and other DocumentTools commands to construct your own content.
Is there an example of nesting Tabulate commands using output=XML ?
I have a polynomial in c & d.  I wish to extract the coefficients of lets say 3rd order i.e c^3+c^2d+c d^2+d^3.
The polynomials can be of 2,3,4.. variables.
coeffs(14*c^4 + 84*c^3*d + 180*c^2*d^2 + 165*c*d^3 + 55*d^4 + 5*c^3 + 21*c^2*d + 28*c*d^2 + 12*d^3 + 2*c^2 + 5*c*d + 3*d^2 + c + d + 1, [c, d], 'l');
     14, 84, 180, 165, 55, 5, 21, 28, 12, 2, 5, 3, 1, 1, 1
l[1];
                                4
                               c
l[2];
                              c  d
l;
 4   3     2  2     3   4   3     2     2   3   2        2
c , c  d, c  d , c d , d , c , d c , c d , d , c , d c, d , c, d,
hello everyone, i have an idea how to implement adomain decomposition method manually but want to transform the whole method on maple for any kind of non-linear ode.
Respected administration I already posted the same question for the other method, pls do not delete my question
help_adomian_decomposition_method.mw
I'm trying to use "Matlab()" command to convert Maple expression into Matlab's expression.
but for some reason it doesn't work.
it works for simple expressions but not this one. It is just a long expression with only some symbols, and the most basic math operations. I don't see why it fails.
It says: "Error, (in Translate) options... not recognized"
I'm attaching the maple code so you can see the error.
The reason I'm using it is because Matlab could not solve the equation in the file (even numerically). So I wrote the same equation symbolically in Maple so I can copy the symbolic solutions to matlab and use them instead of matlab's 'solve' command.
Hope anyone can help with it.
Here's the code attached:
calc_theta.mw
Rootfinding,Isolate seems to work on more that univariate expressions.
See https://www.mapleprimes.com/posts/215233-Another-Example-Of-A-Real-Manipulator-Model for example with a list of multivariate expressions.
Is there documentation/examples on that?
Hello, I don't succeed finding what is wrong. The file is a worksheet in 2D math
I always get 'error, invalid loop'. The text in bold is my simple program, the other text was added while copy-paste
som := 0
for i from 1 by 1 to 10 do
Error, invalid loop
 Typesetting:-mambiguous(Typesetting:-mambiguous(
   for i from 1 to 10 do, Typesetting:-merror("invalid loop")))
som := som + i;
od;
Error, unable to parse
      Typesetting:-mambiguous(Typesetting:-mambiguous(od,
        Typesetting:-merror("unable to parse")))
NULL;
NULL;
how to delete account from this site?
solve({-mu*a[1]+2*c[2]*a[1]*a[2]^2-a[1]*k^2*c[1]+2*c[2]*a[1]*a[0]^2+5*c[4]*a[0]^4*a[1]+5*c[4]*a[1]*a[2]^4+3*c[3]*a[1]*a[2]^2+3*c[3]*a[0]^2*a[1]+a[1]*c[1]+30*c[4]*a[0]^2*a[1]*a[2]^2-20*c[4]*a[1]*a[2]*a[0]^3-4*c[2]*a[1]*a[0]*a[2]-8*c[2]*a[1]^3*A*B+24*c[1]*a[1]*A*B-6*c[3]*a[0]*a[1]*a[2]-20*c[4]*a[0]*a[1]*a[2]^3+48*c[2]*a[1]*a[0]^2*A*B+176*c[2]*a[1]*a[2]^2*A*B-224*c[2]*a[1]*A*B*a[0]*a[2] = 0, -16*c[2]*a[1]^3-6*mu*a[1]+156*c[2]*a[1]*a[2]^2-6*a[1]*k^2*c[1]-20*c[2]*a[1]*a[0]^2+30*c[4]*a[0]^4*a[1]-20*c[4]*a[1]^3*a[2]^2+30*c[4]*a[1]*a[2]^4-6*c[3]*a[1]*a[2]^2+18*c[3]*a[0]^2*a[1]+20*c[4]*a[0]^2*a[1]^3+c[4]*a[1]^5+2*a[1]^3*c[3]-10*a[1]*c[1]-60*c[4]*a[0]^2*a[1]*a[2]^2-24*c[2]*a[1]^3*A*B+8*c[1]*a[1]*A*B+16*c[2]*a[1]*a[0]^2*A*B+336*c[2]*a[1]*a[2]^2*A*B+352*c[2]*a[1]*A*B*a[0]*a[2] = 0, -32*c[2]*a[2]*a[0]^2*A*B-8*c[2]*a[1]^2*a[0]*A*B+64*c[2]*a[2]^2*a[0]*A*B+8*c[2]*a[1]^2*a[2]*A*B-5*c[4]*a[0]^4*a[2]+10*c[4]*a[0]^3*a[2]^2-10*c[4]*a[0]^2*a[2]^3+5*c[4]*a[0]*a[2]^4-a[0]*k^2*c[1]+a[2]*k^2*c[1]-3*c[3]*a[0]^2*a[2]+3*c[3]*a[0]*a[2]^2-32*c[2]*a[2]^3*A*B-16*c[1]*a[2]*A*B+c[4]*a[0]^5-c[4]*a[2]^5+c[3]*a[0]^3-c[3]*a[2]^3-a[0]*mu+a[2]*mu = 0, 4*c[2]*a[1]^3-4*mu*a[1]-64*c[2]*a[1]*a[2]^2-4*a[1]*k^2*c[1]-8*c[2]*a[1]*a[0]^2+20*c[4]*a[0]^4*a[1]+10*c[4]*a[1]^3*a[2]^2-20*c[4]*a[1]*a[2]^4+12*c[3]*a[0]^2*a[1]+10*c[4]*a[0]^2*a[1]^3+a[1]^3*c[3]-4*a[1]*c[1]+40*c[4]*a[1]*a[2]*a[0]^3-72*c[2]*a[1]*a[0]*a[2]-8*c[1]*a[1]*A*B+12*c[3]*a[0]*a[1]*a[2]+20*c[4]*a[0]*a[1]^3*a[2]-40*c[4]*a[0]*a[1]*a[2]^3-16*c[2]*a[1]*a[0]^2*A*B-16*c[2]*a[1]*a[2]^2*A*B-32*c[2]*a[1]*A*B*a[0]*a[2] = 0, 4*c[2]*a[1]^3-4*mu*a[1]-64*c[2]*a[1]*a[2]^2-4*a[1]*k^2*c[1]-8*c[2]*a[1]*a[0]^2+20*c[4]*a[0]^4*a[1]+10*c[4]*a[1]^3*a[2]^2-20*c[4]*a[1]*a[2]^4+12*c[3]*a[0]^2*a[1]+10*c[4]*a[0]^2*a[1]^3+a[1]^3*c[3]-4*a[1]*c[1]-40*c[4]*a[1]*a[2]*a[0]^3+72*c[2]*a[1]*a[0]*a[2]+64*c[2]*a[1]^3*A*B+40*c[1]*a[1]*A*B-12*c[3]*a[0]*a[1]*a[2]-20*c[4]*a[0]*a[1]^3*a[2]+40*c[4]*a[0]*a[1]*a[2]^3+80*c[2]*a[1]*a[0]^2*A*B-624*c[2]*a[1]*a[2]^2*A*B+160*c[2]*a[1]*A*B*a[0]*a[2] = 0, 3*c[3]*a[0]*a[2]^2+6*c[2]*a[1]^2*a[0]-32*c[2]*a[2]^2*a[0]-5*a[0]*k^2*c[1]+10*c[4]*a[0]^3*a[2]^2-6*c[2]*a[1]^2*a[2]-15*c[4]*a[0]^4*a[2]-15*c[4]*a[0]*a[2]^4+10*c[4]*a[0]^2*a[2]^3+3*a[2]*k^2*c[1]-9*c[3]*a[0]^2*a[2]+16*c[2]*a[2]*a[0]^2-5*a[0]*mu+3*a[2]*mu-30*c[4]*a[0]^2*a[1]^2*a[2]+30*c[4]*a[0]*a[1]^2*a[2]^2+288*c[2]*a[2]^3*A*B+16*c[1]*a[2]*A*B+32*c[2]*a[2]*a[0]^2*A*B+104*c[2]*a[1]^2*a[0]*A*B-320*c[2]*a[2]^2*a[0]*A*B-216*c[2]*a[1]^2*a[2]*A*B+5*c[4]*a[0]^5+5*c[4]*a[2]^5+5*c[3]*a[0]^3+c[3]*a[2]^3-3*c[3]*a[1]^2*a[2]-10*c[4]*a[1]^2*a[2]^3+3*c[3]*a[0]*a[1]^2+10*c[4]*a[0]^3*a[1]^2+16*c[2]*a[2]^3+8*c[1]*a[2] = 0, -6*c[3]*a[0]*a[2]^2-22*c[2]*a[1]^2*a[0]+64*c[2]*a[2]^2*a[0]-10*a[0]*k^2*c[1]-20*c[4]*a[0]^3*a[2]^2-66*c[2]*a[1]^2*a[2]+10*c[4]*a[0]^4*a[2]+10*c[4]*a[0]*a[2]^4-20*c[4]*a[0]^2*a[2]^3-2*a[2]*k^2*c[1]+6*c[3]*a[0]^2*a[2]-16*c[2]*a[2]*a[0]^2-10*a[0]*mu-2*a[2]*mu+30*c[4]*a[0]^2*a[1]^2*a[2]-30*c[4]*a[0]*a[1]^2*a[2]^2+96*c[2]*a[2]^3*A*B+48*c[1]*a[2]*A*B+5*c[4]*a[1]^4*a[2]+5*c[4]*a[0]*a[1]^4+96*c[2]*a[2]*a[0]^2*A*B-40*c[2]*a[1]^2*a[0]*A*B+192*c[2]*a[2]^2*a[0]*A*B-40*c[2]*a[1]^2*a[2]*A*B+10*c[4]*a[0]^5+10*c[4]*a[2]^5+10*c[3]*a[0]^3-2*c[3]*a[2]^3+3*c[3]*a[1]^2*a[2]-30*c[4]*a[1]^2*a[2]^3+9*c[3]*a[0]*a[1]^2+30*c[4]*a[0]^3*a[1]^2+80*c[2]*a[2]^3-8*c[1]*a[2] = 0, -6*c[3]*a[0]*a[2]^2-22*c[2]*a[1]^2*a[0]+64*c[2]*a[2]^2*a[0]-10*a[0]*k^2*c[1]-20*c[4]*a[0]^3*a[2]^2+66*c[2]*a[1]^2*a[2]-10*c[4]*a[0]^4*a[2]+10*c[4]*a[0]*a[2]^4+20*c[4]*a[0]^2*a[2]^3+2*a[2]*k^2*c[1]-6*c[3]*a[0]^2*a[2]+16*c[2]*a[2]*a[0]^2-10*a[0]*mu+2*a[2]*mu-30*c[4]*a[0]^2*a[1]^2*a[2]-30*c[4]*a[0]*a[1]^2*a[2]^2-352*c[2]*a[2]^3*A*B+80*c[1]*a[2]*A*B-5*c[4]*a[1]^4*a[2]+5*c[4]*a[0]*a[1]^4+160*c[2]*a[2]*a[0]^2*A*B+72*c[2]*a[1]^2*a[0]*A*B-192*c[2]*a[2]^2*a[0]*A*B+312*c[2]*a[1]^2*a[2]*A*B+10*c[4]*a[0]^5-10*c[4]*a[2]^5+10*c[3]*a[0]^3+2*c[3]*a[2]^3-3*c[3]*a[1]^2*a[2]+30*c[4]*a[1]^2*a[2]^3+9*c[3]*a[0]*a[1]^2+30*c[4]*a[0]^3*a[1]^2-80*c[2]*a[2]^3+8*c[1]*a[2] = 0, a[0]^5*c[4]+5*a[0]^4*a[2]*c[4]+10*a[0]^3*a[2]^2*c[4]+10*a[0]^2*a[2]^3*c[4]+5*a[0]*a[2]^4*c[4]+a[2]^5*c[4]-k^2*a[0]*c[1]-k^2*a[2]*c[1]+a[0]^3*c[3]+3*a[0]^2*a[2]*c[3]+3*a[0]*a[2]^2*c[3]+a[2]^3*c[3]-mu*a[0]-mu*a[2] = 0, 5*a[0]^4*a[1]*c[4]+20*a[0]^3*a[1]*a[2]*c[4]+30*a[0]^2*a[1]*a[2]^2*c[4]+20*a[0]*a[1]*a[2]^3*c[4]+5*a[1]*a[2]^4*c[4]-k^2*a[1]*c[1]+2*a[0]^2*a[1]*c[2]+3*a[0]^2*a[1]*c[3]+4*a[0]*a[1]*a[2]*c[2]+6*a[0]*a[1]*a[2]*c[3]+2*a[1]*a[2]^2*c[2]+3*a[1]*a[2]^2*c[3]-mu*a[1]+a[1]*c[1] = 0, 5*a[0]^5*c[4]+15*a[0]^4*a[2]*c[4]+10*a[0]^3*a[1]^2*c[4]+10*a[0]^3*a[2]^2*c[4]+30*a[0]^2*a[1]^2*a[2]*c[4]-10*a[0]^2*a[2]^3*c[4]+30*a[0]*a[1]^2*a[2]^2*c[4]-15*a[0]*a[2]^4*c[4]+10*a[1]^2*a[2]^3*c[4]-5*a[2]^5*c[4]-5*k^2*a[0]*c[1]-3*k^2*a[2]*c[1]+5*a[0]^3*c[3]-16*a[0]^2*a[2]*c[2]+9*a[0]^2*a[2]*c[3]+6*a[0]*a[1]^2*c[2]+3*a[0]*a[1]^2*c[3]-32*a[0]*a[2]^2*c[2]+3*a[0]*a[2]^2*c[3]+6*a[1]^2*a[2]*c[2]+3*a[1]^2*a[2]*c[3]-16*a[2]^3*c[2]-a[2]^3*c[3]-5*mu*a[0]-3*mu*a[2]-8*a[2]*c[1] = 0}, {B, mu, a[0], a[1], a[2]})
A user asks what they're doing wrong in r/maplesoft with the attached screenshot:
How are constructed binary operators in Maple?
Is it possible to create a binary operator A that we can use this way z := x A y ?
TIA
hello I would like to ask how to implement phase singularities using wavelets in maple.
https://pdfs.semanticscholar.org/03cf/d388491c4fc7bc41c5f99a284feb7b2c34f1.pdf
http://mmlab.ie.cuhk.edu.hk/archive/2009/pami09_theory.pdf
Good day all.
If I generate a list containing (say) 100 elements or more, and each element is an ordered pair - is it possible to assign a letter to each element? The first 26 elements will have equal A to Z, the next 26 will take A1 to Z1, and so on.
For example if the list is [ [5,3], [2,5], ..., [3,1]], how do I construct it to become [A=[5,3], B=[2,5], ..., V3=[3,1]]?
Please see attached.
Thank's a lot for your time.
MaplePrimes_Label_Lists.mw
I'm new to the Maple software, and have been having difficulty figuring out how to plot a 3-D figure for given xyz values. Could anyone provide any guidance on this? I've attached the relevant document to provide the specific values in case that would be helpful.
Best,
Shane
Download Shane_Kreller_M6_Maple_Assignment.mw
What am I doing wrong? Seems like some unit compatibility problem when tryaing to solve simple task with momentum conservation rule...
with(Units);
Automatically loading the Units[Simple] subpackage
m__2 := 0.400*Unit('kg');
m__1 := 0.300*Unit('kg');
x__w := 0.700*Unit('m');
v__2p := 0.000;
v__1p := 2*Unit(('m')/('s'));
Download zadanie_z_jednostakim_-_problem.mw
m__1*v__1p + m__2*v__2p = m__1*v__1k + m__2*v__2k;
                                               /s\
             0.6 = (0.3 v__1k + 0.4 v__2k) Unit|-|
                                               \m/
subs(v__2p = 0, 0.600 = (0.300*v__1k + 0.400*v__2k)*Units[Unit](s/m));
                                               /s\
                                               \m/
v__1k := solve(0.600 = (0.300*v__1k + 0.400*v__2k)*Units[Unit](s/m), v__1k);
                                                  /m\
           v__1k := (-1.333333333 v__2k + 2.) Unit|-|
                                                  \s/
1/2*m__1*v__1p^2 + 1/2*m__2*v__2p^2 = 1/2*m__1*v__1k^2 + 1/2*m__1*v__2k^2;
Error, (in Units:-Simple:-+) the following expressions imply incompatible dimensions: {.1500000000*(-1.333333333*v__2k+2.)^2*Units:-Unit(J)+.1500000000*Units:-Unit(kg)*v__2k^2}
Sitting and trying find solution in help and on forum but no chance.
I hope if someone copy code into maple it will look lik on my screen. Anyway I have uploaded file and below You have screen picture.
If I remove units from variables on the top all is working like a charm.
Please help me find an error guys.
Reagrds
Marcin
First 390 391 392 393 394 395 396 Last Page 392 of 2432
