I have a transfer function:
xfer_mag := 1/sqrt((-1.0000 + 1.0772*10^(-14)*f^2)^2 + (1.9665*10^(-20)*f^3 - 3.6181*10^(-6)*f)^2)
if I do:  semiplotplot(20*log[10](xfer_mag),f=10..30e6) I get :
but if I do: plot(20*log[10](xfer_mag), f = 10 .. 0.30e6), and then use the menu options to the right to change the axes properties to Log, I get this:
what is going on here?  why is the magnitude not the same ?
Download demo.mw
Hi everyone,
There is an attached file below.
I am trying to solve the following equation and I get a numerical value with RootOf.
Do you know if it is possible to get the exact solution with RootOf? Do you know another method? In general, do you know a way to determine if Maple is able to get the exact value or not?
I know it is not always possible to get exact solutions, but maybe there is a way to do it for this polynomial... ? :--)
I hope my questions are clear. Thank you very much for your help and advices.
test.mw
Hey folks;)
I'm new to Maple and as I tried to export my first document to PDF the plots changed. I tried  everything I could think of but nothing  worked.
All the labels on my plots are now at wrong positions.
I hope you can help me.
...I have to say to that I haven't bought maple yet so that could be a reason to try other progamms.
So thank you for your help
I solve for a transfer function using Syrup, and want to operate on the Real part and Imagninary parts separately.  I've added "assumes" statements for every variable:
assume(Rsrc, real);
assume(C1, real);
assume(Lp, real);
assume(C2, real);
assume(f, real);
assume(RL, real);
additionally(0 < Rsrc, 0 < C1, 0 < Lp, 0 < C2, 0 < RL, 0 < f);
When I then do something like :
instead of gettting just the real part of the expression, I get :
as if one of the variables was still not assumed to be Real.  I'm not sure where all the '~' are coming from ---is that the issue?
I apologize, I can't insert content for some reason..., although I can add the worksheeet.
pi_filter_osc_anal.mw
I have a function
f(x)=2*2^x-2
g(x)=-1/2x^2+3/2+5
When I plot by, plot(f(x),g(x) - no problem there.
But I need the intersection to continue my task and when trying to do f(x)=g(x) I get x=RootOf... back.
I've tried solve and a lot of other things, can anyone please help?
Best
I need to find all the variants (I am not sure if this is the correct term to be used but I hope this will be clear in the example) of a specific indeterminate in a given expression.  Here is an example:
alpha[3, 5]*xi[1]*xi[8] + alpha[3, 5]*xi[4]*xi[5] + alpha[3, 3]
For this particular example, xi[1], xi[8], xi[4], and xi[5] are the variables I am looking for. The indexes of xi change depending on the previous calculation.  Also, in some cases, I need the alpha variables instead, that is, alpha[3,5], and alpha[3,3].
I could not figure out how to use indets in this case.
Many thanks for your help.
I have a question? from the link: https://www.maplesoft.com/applications/view.aspx?SID=5084&view=html
How can we solve equation 2.1 to achieve solution 3.1 with boundary conditions explained in section " 1) Gaussian solution " ?
is this possible with maple?
Download pdsolve.mw
Consider a function for a sample say
operations := proc(A)
local O1, O2, O3, O4, O5, O6, O7, O8;
O1 := A + 2;
O2 := 2*A;
O3 := A^2;
O4 := A mod 2;
O5 := A + 3;
O6 := 3*A;
O7 := A^3;
O8 := A mod 3;
First time when I call operations function as operations(3) the output should come in first row
second time when i call the same function as operations(8) the output should come in second row
5
6
9
9
27
16
64
24
512
Similiarly the third time i call in the third row of the rtable.
In generale senario The rtable can contain say k columns based on the number of outputs in that function called.
And each call of the same function the new output is written in a new row.
Finally we should be able to export this rtable to excel.
I may be misunderstanding the documentation of implicitplot.  Can someone set me straight?
This is extracted from the implicitplot's help page:
implicitplot(-x^2 + y, x = 0 .. 2, y = 0 .. x);
The plotting range is limited to y ≤ x, as intended.  Let us verify that it does the right thing:
display(
	implicitplot(-x^2 + y, x = 0 .. 2, y = 0 .. x, color=red),
	plot(x, x=0..2, color=blue)
Yes, indeed it does.
Now let us try limiting the plotting range to y ≤ 1 − x2. Here is what we get:
display(
	implicitplot(-x^2 + y, x = 0 .. 2, y = 0 .. 1-x^2, color=red),
	plot(1-x^2, x=0..2, color=blue)
I expected the red curve to lie entirely below the blue curve but it doesn't. Am I misunderstanding implicitplot?
Download worksheet: mw.mw
I prefer using the wotksheet envirionment
How do I make Maple input the default and 2D output the default?
SImilartly how do I change the default font size?
Using the VectorCalculus package in Maple 2020.2, the Jacobian does accept my target function, whereas the Hessian does not. Both the Jacobian and the Hessian need an algebraic expression for its input.
What can I do to make it work?
kind regards, Harry
vectorcalculus_question.mw
Sorry to bother you with a basic question again.
How do I get both the indexes and the values of a table?
Table.mw
The rational expression at the beginning of the code is approximant. p1-p5 are conditions imposed on t, and are to be solved simultaneously to obtain a[0]-a[4] which are then substituted into t to obtain Cf. S1-S4 are to be obtained from Cf and its derivative.
However, I observed that Cf is not providing the desired results. What have I done wrong? Please Can someone be of help?
Thank you and kind regards
t:=sum(a[j]*x^j,j=0..2)/sum(a[j]*x^j,j=3..4):
F:=diff(t,x,x):
p1:=simplify(eval(t,x=q))=y[n]:
p2:=simplify(eval(t,x=q+h))=y[n+1]:
p3:=simplify(eval(F,x=q))=f[n]:
p4:=simplify(eval(F,x=q+h))=f[n+1]:
p5:=simplify(eval(F,x=q+2*h))=f[n+2]:
vars:= seq(a[i],i=0..4):
Cc:=eval(<vars>, solve({p||(1..5)}, {vars}));
for i from 1 to 5 do
	a[i-1]:=Cc[i]:
Cf:=t;
M:=diff(Cf,x):
s4:=y[n+2]=collect(simplify(eval(Cf,x=q+2*h)),[y[n],y[n+1],f[n],f[n+1],f[n+2]], recursive);
s3:=h*delta[n]=collect(h*simplify(eval(M,x=q)),{y[n],y[n+1],f[n],f[n+1],f[n+2]},factor);
s2:=h*delta[n+1]=collect(h*simplify(eval(M,x=q+h)),{y[n],y[n+1],f[n],f[n+1],f[n+2]},factor):
s1:=h*delta[n+1]=collect(h*simplify(eval(M,x=q+2*h)),{y[n],y[n+1],f[n],f[n+1],f[n+2]},factor):
First 395 396 397 398 399 400 401 Last Page 397 of 2432
