Hi, Is it possible to convert a code written in Mathematica into maple correctly?
I need to check if an expression is polynomial in but with coefficients that are either symbolic, or do not include the complex numebr I.
The problem is that maple considers integers and reals complex also.
type(1,complex) gives true. so I can't use
type(1+2*x,polynom(Not(complex),x))
Since this gives false.
I could instead list all the types to be accepted using Or, like this
type(1+2*x,polynom(Or(float,realcons,rational,integer),x))
But I might overlook something if I have to enumerate every type accepted. It is easier to just exclude complex numbers.
What is the correct way to tell Maple to check if expression is polynomial in where coefficients do not have the complex I in them? It it ok if the coefficient are any other numeric value, or a known Maple constant, or a parameter (symbol). I just want to exclude complex numbers.
I know I could do this
the_poly:=1+2*x;
if not has(the_poly,I) then
   type(the_poly,polynom(anything,x))
   print("not allowed");
fi;
But I wanted to learn how to make a type which excludes complex numbers.
Maple 2021.1
Hi, Can one have look at my attached picture of the problem then solve in maple to get the required results mentioned in the picture.
help.mw
Given an expressions such as
expr:=sin(x)+cos(x)*exp(x)+x*tan(x)*f(x)+x+y;
I want to use indets to find only the mathematical functions in it, and also symbol but only x symbol in this above. I can do the following to find the mathematical functions and symbols, but I do not know how to tell it to find type symbol which happend to be x. Since x is not a type.
type_1:={function,typefunc(mathfunc)};
type_2:=symbol;
lis:=indets(expr,  Or( And(type_1),  type_2 ))
Which gives
But I really wanted this output
I know I can post process the outout using has or remove, to remove symbol y. But is it possible to do that using indets? something similar to specfunc but specsymbol ? I looked at the help page for Definition of a Structured Type in Maple but do not see anything there so far.
I tried
type_2:={symbol,identical(x)};
lis:=indets(expr,  Or( And(type_1),  And(type_2) ))
but it gives same output.
I need to calculate dozens of piecewise-defined  (but elementary) definite integrals of the following kind. Maple returns them unevaluated. Is there a trick to force evaluation?
u := piecewise(0 <= x and 0 <= y and y <= x, x-1, 0 <= x and 0 <= y and x <= y, x, 0);
v := piecewise(0 <= x and 0 <= y and y <= x, x-1, y <= 0 and 0 <= x and -x <= y, x-1, 0);
plot3d(u*v, x=-1..1, y=-1..1);
# integrating over (0,1)x(0,1) works
int(u*v, x=0..1, y=0..1);
# but integrating over (-1,1)x(-1,1) returns unevaluated.
# How to force evaluation on (-1,1)x(-1,1)?
int(u*v, x=-1..1, y=-1..1);
integration-problem.mw
Hi, I have a table-based package P I am working with and I would like to do the following:
Use a submodule (call it A) of the package. A uses another submodule (call it B) within the package to run a calculation. I'd like to replace B with my own subpackage C (independent of P) as another verification step. Is this possible? I would like to avoid making changes to A as much as possible.
Mark
given one equation where both sides are polynomials in one variable x, like this
eq:=c1*(x^2+x)+c2*(2+2*x)+c3=-4*x^2+2*x+6;
And we want to solve for the coefficients on the LHS, which are c1,c2,c3.  By hand, this is solved by expanding both sides, and then comparing the coefficient of each power of x. This generates 3 equations (in this example) and then these are solved for c1,c2,c3.
Is there a way to automatically do this in Maple without the user having to do the first manual step of generating the equations needed to solve for c1,c2,c3?
eq1:=c1=-4;eq2:=c1+2*c2=2;eq3:=2*c2+c3=6;
PDEtools:-Solve([eq1,eq2,eq3],[c1,c2,c3])
gives
              {c1 = -4, c2 = 3, c3 = 0}
But It will be nice if there is a command in Maple which will do it starting from the first equation. Ofcourse one has to tell Maple what to solve for. PDEtools:-Solve(eq,[c1,c2,c3]); or solve(eq,[c1,c2,c3]) does not work, because Maple does not know it needs to expand and compare coefficients as we do by hand.
It is not hard to write code to generate these equations, but I am asking if there is already a command in Maple which somehow does it automatically. I looked at SolveTools, but did not spot something yet there.
edit
Ok, I think this is easy to do. I found a command
eqs:=PolynomialTools:-CoefficientList((lhs-rhs)(eq),x);
PDEtools:-Solve(eqs,[c1,c2,c3])
I very new to Maple....I had problems getting the value of a slider and someone helped me with that
but how do a setup "commands,etc" to always get the latest value of the slider??  whenever I move the slider..
Thanks so much
Frank....I am also attaching screenshot
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/CreatingSlider_ac_-_Copy.mw .
Download CreatingSlider_ac_-_Copy.mw
I have tried everthing I know
Any suggestions would be appreciated
Suppose I have an expression denoted by Q3. I also have two other expressions such as Q1, Q2. I wanna write Q3 as a convex combination of Q1 and Q2, for example, Q3 = gamma*Q1 + (1-gamma)*Q2 where 0<gamma<1. How is it possible?
Q3 = 1/(v)*(    v*pi-  (   (1-alpha*gamma) *pi * r[0]  - (1-pi)*B*alpha  + (gamma*pi + (1-pi)*h)    )   )
Q2 = 1/v *(  v*pi    -  (   h - (1-pi)*B   )      )
Q1 = 1/v*(   v*pi     - (   pi*r[0]+ (1-pi)*h  )   )
I am not sure if is possible to write Q3 = gamma*Q1 + (1-gamma)*Q2 and it might be something like Q3 = gamma*Q1 + (1-gamma)*Q2 + constant
There is code at Maple app center  here  called "A Simple Expression Parser" which generates the actual tree structure of an expression. I tested it a little and it seems to work correctly on what I tried so far.
My question if some Graph expert could take the output of the above and generate an actual tree graph from it, to make it easier to see, similar to Mathematica TreeForm command which would make it much more useful.
I will show 2 examples, and the code from the above application and what the final graph should look like,. The code is (formatted a little to make it easier to read)
#code from https://www.maplesoft.com/applications/view.aspx?SID=4808
Op := proc(x)
    if 1 < nops(x) and not type(x, function) then
       [whattype(x), op(x)];
    elif type(x, function) then
       [op(0, x), op(x)];
        x;
    fi;
Parse := proc(expr)
   local tmp, i;
   tmp := Op(expr);
   for i from 2 to nops(tmp) do
       if 1 < nops(tmp[i]) or type(tmp[i], function) then
          tmp := subsop(i = Parse(tmp[i]), tmp);
   od;
   RETURN(tmp);
ps. I do not think using name Parse above is good idea, since I see it is an inert form of Maple build in command.
Now, lets look at this
first example
expr:=sin(x)+x*y + 1/x;
Parse(expr)
The above says the tree is rooted at `+` with three branches. The first is sin(x), the second is a tree rooted at `*` with two leafs x,y, and the third branch is roots at `^` with two leafs x,-1. Physically it looks like this
Second example
expr := sin(x)*(x + y) + 1/x;
Parse(expr)
Which physically will look like
So it is possible in theory to make a TreeForm command in Maple, using this Parse() command. May be using Graph package in Maple? by reading the output from the Parse() command, and generating nodes and arcs along the way.
How hard will such a task be? I never used the Maple 's Graph package.
Could may be  someone may be give this an attempt? I never understood why Maple do not have a build in similar command to TreeForm. It is very useful to understanding expressions.
Suppose you do this
save something, afile.m;
and that later someone else does this
read afile.m;
Let's assume that this person does not know the names of the variables you have saved.
A way to get these names could be
before := { anames('user') };
read file.m:
after := anames('user') minus before minus {'before'}
I thought after would only contain something, but it also contains all the elements of before, just as if
anames('user') minus before was not effective (see PS below)
Exemple
interface(version)
Standard Worksheet Interface, Maple 2015.2, Mac OS X, December
   21 2015 Build ID 1097895
a:=1:
before := {anames('user')};
                              {a}
b:=2:
after := {anames('user')} minus before minus {'before'}
                         {a, b}
How can I obtain the set of the new user-asigned names?
PS: Why does displaying  before give the value assigned to and not a itself?
before
                              {1}
The square root of x+8-square root of x+9-square root of 2x+4
I encountered a weird error while computing a set of integrals.
Here is my complete code in a .mw file
Download Inflow_distribution_for_forward_flight_(teetering_rotor).mwInflow_distribution_for_forward_flight_(teetering_rotor).mw
At the bottom I have an error message :"Error, Got internal error in Typesetting:-Parse : "invalid subscript selector".
When I try to get the magnitude of the transfer function in the uploaded file, I get this error:
Error, invalid input: `simpl/abs` expects its 1st argument, a1, to be of type algebraic, but received [0.15000e8/(-0.2137457857e-6*f^2+(2.909554620*I)*f-(0.1565896548e-13*I)*f^3+0.152600e8)]
How do I get the magnitude and phase of this transfer function so I can plot it as a function of frequency, f?  If you can show me how to plot it, that would help a lot as well.
Thank you,
Failed to load the worksheet /maplenet/convert/temp.mw .
Download temp.mw
Hi experts, I need your help to find higher-order prolongation(extended infinitesimals) with the help of infinitesimals. rhelp1.mw
Failed to load the worksheet /maplenet/convert/help1.mw .
Download help1.mw
in MAPLE. I have attached a worksheet please check it.
Kindly help me to find it
First 399 400 401 402 403 404 405 Last Page 401 of 2432
