EDIT
x*f'(x^2)  + g'(x) = cos(x)  - 3x^3 and f(x^2) + g(x) = sin(x) -x^4.
How to find the function f like this:
x*f'(x)  + g'(x) = cos(x)  - 3x^3 and f(x^2) + g(x) = sin(x) -x^4.
I know that, f(x) = -1/2*x^2 + C. But, I tried. This answer incorrec.
f := x -> -1/2*x^2 + C;
g := x -> sin(x) - 1/2*x^4 - C;
diff(f(x^2), x);
f(x^2) + g(x);
x*diff(f(x^2), x) + diff(g(x), x);
The uploaded worksheet describes a chain driven at constant speed by gears.
What math will describe its shape?
GearDrivenChain.mw
Greetings!
I am unable to evaluate an improper integral involving rational, exponential and Bessel functions. Can Maple do it? if not is there a way around.
test.mw
Would be nice if someone could add Maple 2021 to Software Change Requests list.
Right now Maple 2021 is unusable for us due to a big problem related to saving workbooks.
Hello there,
Would you allow me to ask this (perhaps simple) question?
My goal is to express an equation as 'desired', but with no success with algsubs()/subs()/simplify().
Would you please show me the correct way?
PowerBalanceEq := 0 = e1(t) * i1(t) + e2(t) * i2(t) + e3(t) * i3(t);
0 = e1(t)*i1(t)+e2(t)*i2(t)+e3(t)*i3(t)
eq_i1 := i1(t) = solve(PowerBalanceEq, i1(t));
i1(t) = -(e2(t)*i2(t)+e3(t)*i3(t))/e1(t)
n21eq := n21 = e2(t) / e1(t);
n21 = e2(t)/e1(t)
eq_i2 := algsubs(n21eq, eq_i1);
eq_i3 := subs(n21eq, eq_i1);
eq_i4 := simplify(eq_i1, {e2(t) / e1(t) = n21});
i1(t) = (-i2(t)*n21*e1(t)-e3(t)*i3(t))/e1(t)
desired := i1(t) = -n21*i2(t) - e3(t)*i3(t)/e1(t);
i1(t) = -n21*i2(t)-e3(t)*i3(t)/e1(t)
Best Regards,
In Kwon Park
Download Q20210316.mw
How do I solve completely the diferential equation and also speed up the compilation of  the time is over 3000sec:
eq1 := 2*m*(E + 8*Pi*epsilon/r)*f(r, t)/h^2 + R*diff(f(r, t), r $ 2)/r - diff(f(r, t), t $ 2)/(a^2*c^2) = 0;
iv1 := f(r, 0) = 0, f(R, t) = 0, D[1](f)(0, 0) = R;
Sol := pdsolve([eq1, iv1]);
Where f(r,t) is the function of variable r and t  in spherical coordinate and m, E, h, R, rb, a, and c are constants.
I also want to find the exact value of f(r,t) with the condition f(rb, 0) = 0; and diff(f(rb,t),t)=a*c for the value t=0 and if is possible the pulsation of the sinusoidal solution of f(r,t). [the solution is a combination of AiryAi ; AiryBi and sinusoidal sin(a*c*sqrt(-2*E*m - _c[1])*t/h)]. I didn't find the value of _c[1] for the 2 additional condition above.
The issue is the period of time between 2 consecutive zero of the f(r,t)=0
tks
I get the degree sequence of a graph, I want to create more graphs, but maple seems to only get the only graph.
Is there a good way to get more, a foolish dream, can we get all the graphs that satisfy this degree sequence condition?
with(GraphTheory):
L:=[7$1..22,6]:
IsGraphicSequence(L):
G := SequenceGraph(L):
DrawGraph(%)
What I mean by shortest distance between vertex and edge is
In the above petersen graph consider the vertex say 1 it's distance to
(1,6) will be 0 as 1 is part of the same edge
((1,2) will be 0 again
(1,5) it will zero again
(5,8) will be 1 that is (1,5)-(5,8)
(8,9) it will be 2 that is (1,5)-(5,8)-(8,9)
(5,4) it will be 1 that is (1,5)-(5,4)
(9,10) it will be 2 (1,5)-(5,4)-(9,10)
Etc for all edges the graph from a given vertex v given a Graph G
The order in which the edges are chosen to find the distances should be maintained so that each index in the list correspond to distance of that vertex from the same edge in different vertex lists in a order
Kind help I apologize to take your time
In output I need a list say T=[0, 0,1,2,..]
   Data given
   List Given
  L:=[A,B,A,C,A,B,D,E,A,F,G,H,H,G,I,P,Q,W,A]
    I want the output to be a frequency table
    Frequency says number of times each Data occurs in the list
    I want output in the form of a table
    Data need not be always A,B,C,D etc it can be any text.
Data
Frequency
A
5
B
C
D
E
F
G
H
I
P
Q
W
I want to export this outputed table to word or Excel
Anyone have a problem with non-appearance of the animation toolbar in Maple 2021????
Whilst coming up with a response for the problem here
https://www.mapleprimes.com/questions/231862-Have-You-Ever-Heard-Of-Vector-Asterisks-
I found an issue with the non-appearance of the animation toolbar in Maple 2021. This is rather difficult to illustrate without the use of screenshots, for which I apologise.
Normally(?) I would just select a plot and the animation toolbar appears "as if by magic"
First screen shot is using Maple 2020, The blue highlighting rectangle around the plot was visible when I initiated the snip, but disappeared when the snipping tool activated. However this shows that the animation toolbar is available (and works)
I do exactly the same thing in  Maple 2021 and I can't make the animation toolbar appear - see below. Aagain the plot wa highlighted when I initiated the snip but the highlighting disappeared when the snipping tool activated. Now there is no sign of the animation toolbar
It is still possible to do very basic animation in Maple 2021 by clicking on the plot and using the context menu - but this is very basic
The code used in the above plots is given supplied below
  kernelopts(version);
  plots:-display
         ( [ seq
             ( plot
               ( Vector([1, 3, 4, 6]),
                 Vector([8, 6, 2, 5]),
                 style = point,
                 symbol = j,
                 symbolsize = 40,
                 color = blue
               j in [ asterisk, box, circle, cross, diagonalcross,
                      diamond, point, solidbox, solidcircle, soliddiamond
           insequence = true
Is it just me?
From old memory, I recall some boolean algebra.  We have zeros and ones.
Some of us are familiar with logic gates.
The simplest is the simple inverter.  It inverts.
Very interesting.
https://en.wikipedia.org/wiki/Boolean_algebra
I have defined a function pp(x).  It plots correctly
but pp(2020); should return 410, and it returns 98000. Maybe I am doing something stupid, but I just can't figure out what!
a := 0.340699639252428*10^13;
b := -0.118229737138742*10^11;
c := 0.175816922773262*10^8;
d := -14523.7138112711;
e := 7.19782673654200;
f := -0.00214008825847444;
g := 0.353463615941623*10^(-6);
h := -0.250170509163729*10^(-10);
pp := x -> a + b*x + c*x^2 + d*x^3 + e*x^4 + f*x^5 + g*x^6 + h*x^7;
plot([pp(x)], x = 1960 .. 2100, gridlines = true, size = [900, 600])
Good day, all. I hope we are staying safe.
Please I need help with the regard to the following codes.
The major issue is with rho:=x[n]/h. The rho needs to change values as x[n] changes in the computation. This I think I have gotten wrong. Your professional modifications or/and corrections to the code would be appreciated.
Thank you and kind regards.
Digits:=20:
#assume(alpha>0,alpha < 1):
f:=proc(n)
	-y[n]-x[n]+(x[n])^2+(2*(x[n])^(2-alpha))/GAMMA(3-alpha)+((x[n])^(1-alpha))/GAMMA(2-alpha):
e2:=y[n+2] = y[n]+(1/2)*((alpha^2-alpha)*rho^2+(2*alpha^2-2)*rho+(4/3)*alpha^2-(2/3)*alpha)*(rho*h)^alpha*GAMMA(2-alpha)*f(n)/rho-alpha*GAMMA(2-alpha)*((-1+alpha)*rho^2+(2*alpha-2)*rho+(4/3)*alpha-8/3)*(h*(rho+1))^alpha*f(n+1)/(rho+1)+(1/2)*((alpha^2-alpha)*rho^2+2*(-1+alpha)^2*rho+(4/3)*alpha^2-(14/3)*alpha+4)*(h*(rho+2))^alpha*f(n+2)*GAMMA(2-alpha)/(rho+2):
e1:=y[n+1] = y[n]+(1/4)*((alpha^2-alpha)*rho^2+(alpha^2+3*alpha-4)*rho+(1/3)*alpha^2+(4/3)*alpha)*GAMMA(2-alpha)*f(n)/((rho*h)^(-alpha)*rho)-(1/2)*GAMMA(2-alpha)*((alpha^2-alpha)*rho^2+(alpha^2+alpha-2)*rho+(1/3)*alpha^2+(1/3)*alpha-2)*f(n+1)/((h*(rho+1))^(-alpha)*(rho+1))+(1/4)*((-1+alpha)*rho^2+(-1+alpha)*rho+(1/3)*alpha-2/3)*alpha*GAMMA(2-alpha)*f(n+2)/((h*(rho+2))^(-alpha)*(rho+2)):
alpha:=0.25:
inx:=0:
iny:=0:
#x[0]:=0:
h:=1/20:
N:=solve(h*p = 1, p):
n:=0:
c:=1:
rho:=x[n]/h:
err := Vector(round(N)):
exy_lst := Vector(round(N)):
for j from 0 to 2 do
	t[j]:=inx+j*h:
vars:=y[n+1],y[n+2]:
step := [seq](eval(x, x=c*h), c=1..N):
printf("%4s%15s%15s%16s\n",
	"h","Num.y","Ex.y","Error y");
st := time():
for k from 1 to N/2 do
	par1:=x[n]=t[0],x[n+1]=t[1],x[n+2]=t[2]:
	par2:=y[n]=iny:
	res:=eval(<vars>, fsolve(eval({e||(1..2)},[par1,par2]), {vars}));
	for i from 1 to 2 do
		exy:=eval(-c*h+(c*h)^2):
		printf("%5.3f%17.9f%15.9f%15.5g\n",
		h*c,res[i],exy,abs(res[i]-exy)):
		err[c] := abs(evalf(res[i]-exy)):
		exy_lst[c] := exy:
		numerical_y1[c] := res[i]:
		c:=c+1:
		rho:=rho+1:
	iny:=res[2]:
	inx:=t[2]:
		t[j]:=inx + j*h:
v:=time() - st;
printf("Maximum error is %.13g\n", max(err));
numerical_array_y1 := [seq(numerical_y1[i], i = 1 .. N)]:
time_t := [seq](step[i], i = 1 .. N):
numerical_plot_y1 := plot(time_t, numerical_array_y1, style = [point], symbol = [asterisk],
				color = [blue,blue],symbolsize = 15, title="y numerical",legend = ["Numerical"]);
exact_plot_y1 := plot(time_t, exy_lst, style = [line], symbol = [box],
				color = [red,red], symbolsize = 10, title="y exact",legend = ["Exact"]);
display({numerical_plot_y1, exact_plot_y1}, title = "Exact and Numerical Solution of Example 1 ");
how can i solve this operate differential equation
convert(expand((D[1] - 1)*(D[1]^2 + 2)*y(x) = 0), diff);
dsolve(%)
First 432 433 434 435 436 437 438 Last Page 434 of 2432
