I have a difficulty with a function used in procedure. The procedure uses a multivariable function and if the specific choice of the function is not made the procedure seems to give proper result, but In case I make a specific choice of the function and then try use this procedure gives me incorrect result.
To be more exact I use Physics package (there is a need to calcute combinations of covariant derivates ). The calculations are performed in a curved space with a defined metric.
So here is the procedure:
SD2 := proc (psi) SumOverRepeatedIndices(g_[`~kappa`, `~lambda`]*(d_[kappa](d_[lambda](psi(X)))-Christoffel[`~sigma`, kappa, lambda]*d_[sigma](psi(X))))^2-SumOverRepeatedIndices(g_[`~kappa`, `~rho`]*(d_[kappa](d_[lambda](psi(X)))-Christoffel[`~sigma`, kappa, lambda]*d_[sigma](psi(X)))*g_[`~lambda`, `~tau`]*(d_[rho](d_[tau](psi(X)))-Christoffel[`~gamma`, rho, tau]*d_[gamma](psi(X)))) end proc;
If I turn to the procedure :
SD2(psi);
the result is  correct.
But  then I specify a psi function:
psi:=(t,r,x,y,z)->chi(r)+q*t;(here q is supposed to be a constant)
and turn to the procedure once again:
SD2(psi);
It gives me a wrong result.
I don't know what is the reason.
How do you print [0,infinity) in Maple 13 like
RealRange does not seem to work.
mapleatha
This has always made me wonder everytime I type it.
The first command I always type on a new worksheet is restart.  I don't think I have never done this.
Is there a reason it needs to be manually entered and how many people DO NOT start a worksheet with a restart?
Is there a reason to not make this automatic with initial loading of a worksheet?
Bill
The plot command below results in the following graph:
However, I want the x-axis to go from 0..24 and the y-axis from 0..100. I can adjust the shafts temporarily via Axes-Properties so that I get the following plot:
However, as soon as I recalculate the plot command, I get back the original plot. Is there any parameter in the plot command where I can set x-min, x-max, ymin, ymax?
Christer
I'm adjusting a Maple 2015 code for it works correctly in Maple 2020.
A being some matrix, this command executed in Maple 2015 returns a plot with the desired color.
matrixplot(A, heights=histogram, color="X11 Thistle1")
When executed in Maple 2020 the color of the bars is desperatly black.
Note that syntaxes like color=red or color=ColorTools:-Color([1, 0, 0]), despite what seems to be said in the matrixplot help page (wherein the reference to plot:-color help page) keep returning a black plot.
The only thing I'm able to do to turn the plot to red is this
F := (x, y) -> 1:
matrixplot(A, heights=histogram, color=F)
How can I obtain a plot with the color I want?
PS: maybe I'm not very astute, but it looks like the help pages are not very explicit on this point.
Requesting a code to compute the following self referencing integer sequence :
a(1)=1, a(2)=0. Thereafter, if a(n) is a novel term then a(n+1)=Min{|a(n)-a(k)|; 1<=k<n}. Otherwise, if a(n) seen before (most recently at a(m)), then a(n+1)=n-m.
First few terms are:
1,0,1,2,1,2,2,1,3,1,2,4,1,3,5,1,3,3,1,3,2,10,5......
Desirable to have option for graphing results up to some value of n.
Thanks in advance for any assistance
David.
Hello, I'm a student in high-school, and i was wondering if it is possible to have multiple people writing in the same document at the same time. It would make groupwork a lot easier if I could do the writing like e.g.: google docs.
-Max
Hello there,
I would think that those two expressions are same as long as L::positive, omega::positive, R::positive, but when I tried in Maple, I could not get that result. The following worksheet shows my attempts. Would you please tell me how to get the answer, true, instead of false from the expression comparison?
arctan_expression := arctan(omega*L/R);
arctan(omega*L/R)
arctan_expression2 := arctan(R, L*omega);
arctan(R, L*omega)
evalb(arctan_expression = arctan_expression2) assuming L::positive, omega::positive, R::positive;
is(arctan_expression = arctan_expression2);
Best Regards,
In Kwon Park
Download Q20210308.mw
Here's another possible bug related to special characters (like ø, æ, å).
SubString considers each of the characters to be consisting of 2 different other ones.
Related to https://www.mapleprimes.com/questions/231765-Special-Characters-In-Maple-Workbook-Code.
with(StringTools)
a := "Øyeblikk"
"Øyeblikk"
SubString(a, 2 .. ())
"�yeblikk"
SubString(a, 1 .. ())
"Øyeblikk"
SubString(a, 3 .. ())
"yeblikk"
Download SubString.mw
PLs, correct my code about how to find the derivative by using the loop concept in maple?
help_derivative_in_loop.mw
I'm using Maple on a linux partition and for some time now I can't really use it anymore. For example, when I open a help window, I can't scroll through the content, and scrolling gets stuck if an image needs to be displayed. I think my partition is too full and does not have enough free space left. Doesn't Maple create a temporary file that is too big for the space available?  But I have another partition that is not in the same format as the linux partition but is nevertheless readable and writable. Is it possible, if the problem is a temporary file, that this file is written to this other partition to avoid this storage problem?
Or could it be due to a memory problem (RAM?) that did not occur before?
Say that we have three matrices X, Z, and A of equal size such that Size(X) = Size(Y) = Size(A) = [10 14].
Here, X[i, j] = X[i + 1, j] and Y[i, j] = Y[i, j + 1], i.e. X and Y are the grid in Matlab notation.
i found that countourplot can provide the contour plot for a bivariate function f(x,y). i was wondering whether this can also be done in Maple for matrices. Any help is highly appreciated – thank you,
Fede
I want to solve this system of PDEs. Please let me know how I can solve it.
Kindly find both my code written in Maple and the image of the problem.
Best,
PDE.mw
I needed to normalize the eigenvectors of a matrix. (I did not see an option to do this so far in LinearAlgebra). So I figured I just need to map LinearAlgebra:-VectorNorm(x,'Euclidean')  of each vector of the generated eigenvectors matrix,. Where here means the vector in the matrix. But do not see a way to do it.
I ended up just using seq, which works fine. But was wondering if there is a way to do it? map function on each column (or each row) and have the result be matrix ofcourse.
Will show my attempt using map, and then using seq
Sx:=1/sqrt(2)*Matrix([[0,1,0],[1,0,1],[0,1,0]]);
lam,v:=LinearAlgebra:-Eigenvectors(Sx);
Just doing the following does not work ofcourse
map( x->x/LinearAlgebra:-VectorNorm(x,'Euclidean'), v)
So I used seq
normalized:=[seq( v(..,i)/LinearAlgebra:-VectorNorm(v(..,i),'Euclidean'),i=1..LinearAlgebra:-RowDimension(v) )];
Will be nice if one can use map or variation of it, which works on either columns or rows at a time.
Maple 2021.2
I am doing some solution for pde :
with(PDEtools);
alias(u = u(x, y, t), w = w(x, y, t), f = f(w));
pde := diff(u, x, x, x, y) + 3*diff(u, y)*diff(u, x, x) + 3*diff(u, x)*diff(u, x, y) + 2*diff(u, y, t) = 0;
pde2 := subs(u = D(f)(w)*diff(w, x) + u0(x, y, t), pde);
pde3 := expand(pde2);
after this step i want to substitute
D(f)(w)*D^(3)(f)(w)= (-c/3)*D^(4)(f)(w)
so i apllied command as this :
pde33 := subs({D(f)(w)*(D^(3)(f)(w) = -c/3*(D^(4)(f)(w)}, pde3);
but i not able to replace it !
please help in it ! Thanks!
First 436 437 438 439 440 441 442 Last Page 438 of 2432
