restart; with(Student[LinearAlgebra]); A := Matrix([[2, 3, -4], [0, -4, 2], [1, -1, 5]]); for i to 3 do for j to 3 do print((-1)^(i+j)*Minor(A, i, j)) end do end do; How to code to get that is egal to Adjoint(A)? Thank you.
Whenever I open Maple 2020 and type one single letter or number (doesn't matter) Maple 2020 will "freeze" and load forever (i have had it open for a long time, just watching that f**king blue circle spin...
I have tried reinstalling, repairing, running as admin, and changing the compatibility mode, still, nothing works:(
I run Maple 2020 as a Student with WithGym
Pc specs:
Intel i5-10300h 2.6 ghz
Geforce 1660 ti 6gb
Windows 10 x64
Hello there,
Would you tell me how to check if the two expressions presented below are the same?
My simple attempt (at the end of the worksheet below) failed.
This page might be helpful to check the equality: https://www.myphysicslab.com/springs/trig-identity-en.html
subexpx := Ls*cos(omega*t + phi__l + theta)*omega + sin(omega*t + phi__l + theta)*Rs;
Ls*cos(omega*t+phi__l+theta)*omega+sin(omega*t+phi__l+theta)*Rs
subexpx2 := sqrt((omega*Ls)^2+Rs^2)*sin(omega*t + phi__l + theta + arctan(omega*Ls/Rs));
(Ls^2*omega^2+Rs^2)^(1/2)*sin(omega*t+phi__l+theta+arctan(omega*Ls/Rs))
is(subexpx - subexpx2 = 0) assuming omega::positive, Ls::positive, Rs::positive;
Thank you,
Download Q20201108.mw
I want to say maple convert this radicals to a single radical expr.
cos(sqrt(Lr1+Lr2)*t/(sqrt(Cr)*sqrt(Lr1)*sqrt(Lr2)))
convert to :
cos(sqrt((Lr1+Lr2)/(Cr*Lr1*Lr2))*t)
thank u .
I don't speak well in english but I 'll try
I can't print a matrix multiplication without maplke simplify it
i want
A*b=x
so
|1 2 3|     |x|        |1|
|4 5 6|  * |y|    =   |2|
|7 8 9|     |z|        |3|
but maple simplify A*x
so i have something like
|1x 2y 3z|            |1|
|4x 5y 6z|       =   |2|
|7x 8y 9z|            |3|
Thank a lot.
In this ODE
dsolve gives
When A=3 but  not when A=1 or A=2
ode:=(1+y(x))*diff(y(x),x$2)-A*diff(y(x),x)^2=x;
A:=1;
dsolve(ode):
A:=2;
dsolve(ode):
A:=3;
dsolve(ode):
The problem is not with the particular solution. Maple can find that
DEtools:-particularsol(ode,y(x))
And it can solve the homogeneous ODE for any A:
ode:=(1+y(x))*diff(y(x),x$2)-A*diff(y(x),x)^2=0;
A:=1;
dsolve(ode):
A:=2;
dsolve(ode):
A:=3;
dsolve(ode);
Is this a known issue and why it happens on some values?
Maple 2020.1 and Physics 861 on windows 10
i try to calculate the sum of  Eff elements , but i receive this message?
SumQuestion.mw
I try to remove first column from my df variable, but the command Remove(df,1) don't work. Ideas ?
SérieTabulateStat.mw
hello
I am beginner in maple.
I have a differential equation system with 17 equations. I used dsolve() function and my code worked.
Now, I want to integral from the dsolve answer.but I dont know how?
Hi, how to generate a matrix ( 6X2) with different random integers  ( between 10 and 20) in the first column and others random integers ( between 50 and 100) in the second column ?
Is it possible in one worksheet of a workbooks to access variables or embedded components in another worksheet programmatically?
As far as I can see it is possible to save and restore variables through the variable browser, so it is also possible to get them from one worksheet to another. This is however done by the user.
Now the question is, if it is somehow possible to e.g. access the contents of a embedded component like a Combobox in a different worksheet of the workbook - without opening the worksheet first?
[[1,1,["ab","xy"]], [0,1,["xy"]]]
how to sort by first number , second number , and list of string ?
how to count and group by third list of strings having first two number 0,0 or 0,1 or 1,0 or 1,1
for example
["xy"] at most count 4  , at least count 1
would like to find which is [1,1,... ] and only count 1
Is Prüfer's algorithm available in Maple (given a tree, produce the code, and vice versa)? If not, has anyone written the code for it?
I need to check if the solution of a polynomial system (for instance a set of polynomial equations in y and z) using two different approaches is the same (equal or symmetric).  I thought if I use simplify plus abs I could solve the problem, but that is not the case.   Here is an example;
The first method returns the following solution:
aa := {{y = -2*X1*X2*alpha[1, 8]*alpha[2, 6]/(sqrt((X1^4*alpha[1, 8]^2*alpha[2, 4]^2 + 2*X1*((-2*X1*X2*alpha[3, 6] - 2*X2*alpha[2, 2] + 2*X3)*alpha[2, 6] + X1*X2*alpha[2, 4]*(alpha[2, 8] + alpha[3, 9]))*alpha[1, 8] + X2^2*(alpha[2, 8] + alpha[3, 9])^2)*alpha[1, 8]^2) + alpha[1, 8]^2*alpha[2, 4]*X1^2 + X2*alpha[1, 8]*(alpha[2, 8] + alpha[3, 9])), z = (-sqrt((X1^4*alpha[1, 8]^2*alpha[2, 4]^2 + 2*X1*((-2*X1*X2*alpha[3, 6] - 2*X2*alpha[2, 2] + 2*X3)*alpha[2, 6] + X1*X2*alpha[2, 4]*(alpha[2, 8] + alpha[3, 9]))*alpha[1, 8] + X2^2*(alpha[2, 8] + alpha[3, 9])^2)*alpha[1, 8]^2) - alpha[1, 8]^2*alpha[2, 4]*X1^2 + (-alpha[3, 9] - alpha[2, 8])*X2*alpha[1, 8])/(2*alpha[1, 8]^2*alpha[2, 6]*X1)}, {y = -2*X2*alpha[1, 8]*alpha[2, 6]*X1/(-sqrt((X1^4*alpha[1, 8]^2*alpha[2, 4]^2 + 2*X1*((-2*X1*X2*alpha[3, 6] - 2*X2*alpha[2, 2] + 2*X3)*alpha[2, 6] + X1*X2*alpha[2, 4]*(alpha[2, 8] + alpha[3, 9]))*alpha[1, 8] + X2^2*(alpha[2, 8] + alpha[3, 9])^2)*alpha[1, 8]^2) + alpha[1, 8]^2*alpha[2, 4]*X1^2 + X2*alpha[1, 8]*(alpha[2, 8] + alpha[3, 9])), z = (sqrt((X1^4*alpha[1, 8]^2*alpha[2, 4]^2 + 2*X1*((-2*X1*X2*alpha[3, 6] - 2*X2*alpha[2, 2] + 2*X3)*alpha[2, 6] + X1*X2*alpha[2, 4]*(alpha[2, 8] + alpha[3, 9]))*alpha[1, 8] + X2^2*(alpha[2, 8] + alpha[3, 9])^2)*alpha[1, 8]^2) - alpha[1, 8]^2*alpha[2, 4]*X1^2 + (-alpha[3, 9] - alpha[2, 8])*X2*alpha[1, 8])/(2*alpha[1, 8]^2*alpha[2, 6]*X1)}}
and the second Method:
bb := {{y = -2*X2*alpha[2, 6]*X1/(-sqrt(X1^4*alpha[1, 8]^2*alpha[2, 4]^2 + 2*X2*alpha[1, 8]*((alpha[2, 8] + alpha[3, 9])*alpha[2, 4] - 2*alpha[2, 6]*alpha[3, 6])*X1^2 - 4*alpha[1, 8]*alpha[2, 6]*(X2*alpha[2, 2] - X3)*X1 + X2^2*(alpha[2, 8] + alpha[3, 9])^2) + (alpha[2, 8] + alpha[3, 9])*X2 + alpha[1, 8]*alpha[2, 4]*X1^2), z = (sqrt(X1^4*alpha[1, 8]^2*alpha[2, 4]^2 + 2*X2*alpha[1, 8]*((alpha[2, 8] + alpha[3, 9])*alpha[2, 4] - 2*alpha[2, 6]*alpha[3, 6])*X1^2 - 4*alpha[1, 8]*alpha[2, 6]*(X2*alpha[2, 2] - X3)*X1 + X2^2*(alpha[2, 8] + alpha[3, 9])^2) - alpha[1, 8]*alpha[2, 4]*X1^2 + (-alpha[3, 9] - alpha[2, 8])*X2)/(2*alpha[1, 8]*alpha[2, 6]*X1)}, {y = -2*X2*alpha[2, 6]*X1/(sqrt(X1^4*alpha[1, 8]^2*alpha[2, 4]^2 + 2*X2*alpha[1, 8]*((alpha[2, 8] + alpha[3, 9])*alpha[2, 4] - 2*alpha[2, 6]*alpha[3, 6])*X1^2 - 4*alpha[1, 8]*alpha[2, 6]*(X2*alpha[2, 2] - X3)*X1 + X2^2*(alpha[2, 8] + alpha[3, 9])^2) + alpha[1, 8]*alpha[2, 4]*X1^2 + (alpha[2, 8] + alpha[3, 9])*X2), z = (-sqrt(X1^4*alpha[1, 8]^2*alpha[2, 4]^2 + 2*X2*alpha[1, 8]*((alpha[2, 8] + alpha[3, 9])*alpha[2, 4] - 2*alpha[2, 6]*alpha[3, 6])*X1^2 - 4*alpha[1, 8]*alpha[2, 6]*(X2*alpha[2, 2] - X3)*X1 + X2^2*(alpha[2, 8] + alpha[3, 9])^2) - alpha[1, 8]*alpha[2, 4]*X1^2 + (-alpha[3, 9] - alpha[2, 8])*X2)/(2*alpha[1, 8]*alpha[2, 6]*X1)}}
Notice (if I am not mistaken) that the first pair of the first solution is equal to the second pair of the second solution.   If I compare them using evalb(simplify(aa[1,1])=simplify(bb[2,1])), Maple returns false.  Again, if I am not mistaken I think they are the same.
a) How can the solutions be compared?
b) I also need to determine if there are symmetric roots in a set of solutions (either in aa or in bb) and a procedure that returns just one solution.  Something like:
func:=(auxsolsx,varsx)->`if`(nops(map(v->op(map(w->abs(subs(w[ListTools:-Search(v,varsx)],v)),auxsolsx)),varsx))=2,ifelse(nops(auxsolsx)=1,auxsolsx,{auxsolsx[1]}),NULL):
Many thanks
I try to represent the successive derivatives of a function using a tabulation . How do I insert titles in the seq command options?
QuestionTabulation.mw
First 485 486 487 488 489 490 491 Last Page 487 of 2432
