Is there any programming or package to solve my problem. I am poor in programming.
Thanks sincerely!
I am trying to solve some coupled equations. however, I keep getting the error ' invalid subscript selector.
Does anybody have any solution for this?
here is the file : -
error.mw
Thanks !
Mota
I am so sorry for all of the questions. I am getting extremely frustrated with Maple.
I want to plot a 3D rendering of 4x^2+9y^2 but I want the full paraboloid to show. However, all I keep getting is cut off versions.
In some coordinate systems availiable in the plot command, there are constants specified symbollically, for example,for logarithmic, the constant "a" is specified (see ?coords help page) is there a simple way to retreve the numerical value for these transformation parameters, or does it need to be obtained by appropriate manipulation of the data set?
how can I obtain the corresponding polynomial for a  propositional formula ?
I must say that using the help for this package is not intuiative. ( in general for all )
Once on a page for command i can't  go back to the home page where the mainpage is for the package
Example i was doing something with gradient command and try figure out how to make a function out of it
At the examples nothing to find about this .. via contectpanel : evalVF (evaluate vectorfield)
So i want to look at the eval command in the student vectorcalculus package
This could be easy if there was a button to see all commands ( a home button) on the gradient page
Now i must type in help again ..
evalVF gives a column vector notation , but mixing both notations ? ( as vector , as column vector)
gf := Gradient(exp(x*y^3*z^2))
This i can evaluate via contectpanel for  f(x,y,z)  in a point and as output a colomn vector
Making a vectorfunction for gf is not possible via contectpanel ? , or do i miss something
Note: perhaps showing the package commands in the working document is a idea
buy := proc(ss,windowlength,syseq1,syseq2a,syseq2b)
try:
p := dualaxisplot(listplot(ma, color = red), listplot(me, color = blue), style = line, gridlines = false);
catch:
p := dualaxisplot(listplot(me, color = red), listplot(me, color = blue), style = line, gridlines = false);
end try:
return p:
CheckGraph := proc(text,graphparam1,graphparam2)
  local maplet, choice:
  maplet := Maplet(
      [Plotter['PL1'](graphparam1)],
      [Plotter['PL2'](graphparam2)],
      #[Plotter['PL2'](graphparam2)],
      [text, ComboBox['CoB1']("No Refund", sort(["Jackpot"], lexorder))],
      [Button("OK", Shutdown(['CoB1'])), Button("Cancel", Shutdown())]
  choice := Maplets[Display](maplet):
graph1 := buy(0,100,rhs(sol[parse(result1[1])][1]),rhs(sol[1][1]),rhs(sol[2][1]));
>graph1
can show graph but after using Plotter['PL1'] , it can not show graph in dialog
CheckGraph("Has Jackpot?",graph1,graph2):
how to plot dualaxisplot in dialog?
I would like to factor an algebraic expression that contains exponentials.
Maple spits it back unfactored. Did I enter it wrong?
factor(exp(4*y) + 2*exp(2*y) + 1);
Good afternoon everybody,
I am a beginer user in maple and I am having problems to plot a system of differential equations. My code is
restart; with(VectorCalculus); with(LinearAlgebra); with(DEtools);
> p := 2*u*x*y^2; q := (x-1)/x;
> doth := simplify(-(sqrt(6)*x^3*(y-1)^2+u*((3+sqrt(6))*x^3*(y-1)^2+3*y^2-9*x*y^2+3*x^2*(y^2+2*y-1)))/p); ddotphi := simplify((y-1)*(sqrt(6)*x*y^2*(x-1)+u*(3*y^2-(6+sqrt(6))*x*y^2+x^2*((3+sqrt(6))*y^2+6*y-3)))/p);
>ode1 := diff(x(t), t) = x(t)*(1-x(t))*doth-x(t)^2*ddotphi/sqrt(6); ode2 := diff(y(t), t) = y(t)*(y(t)-1)*doth; ode3 := diff(u(t), t) = sqrt(3/2)*u(t)*(1+u(t))*q;
>DEplot3d([ode1, ode2, ode3], [x(t), y(t), u(t)], t = -2 .. 2, x = 0 .. 1, y = 0 .. 1, u = -1 .. 0, [[x(0) = .9, y(0) = .25, u(0) = -.95], [x(0) = .9, y(0) = .25, u(0) = -.5], [x(0) = .85, y(0) = .2, u(0) = -.15], [x(0) = .25, y(0) = .5, u(0) = -.5], [x(0) = .7, y(0) = .5, u(0) = -.6]], linecolor = [red, green, black, navy, maroon], thickness = 2, axes = boxed, labels = [x(t), y(t), u(t)], arrows = medium, stepsize = 0.1e-1, orientation = [30, 65]);
and the next error appears
Error, (in DEtools/DEplot/direction3d) unable to store 'HFloat(HFloat(undefined))+HFloat(HFloat(undefined))*I' when datatype=float[8]
I have no idea what to do, and searching for solutions I have only found things that I dont understand.
Thank you very much in advance
I want the legend to be produced to look like the third to last example. https://fr.maplesoft.com/support/help/Maple/view.aspx?path=plots/contourplot
However, mine keeps coming out like this.
hello how do i solve these equations and what type exactly are they ? so i can find more information
(i dont understand if this is a partial-something)
for the following function
f(y,z)=y*sin(z) + 2*cos(y)
i need to evaluate it at the following point
fy(pi/2,pi)  and  fz(pi/2,pi)
this is the part i dont understand how to do, i keep getting 0 in the equation.
thanks for you! and your time
I would like to "run" or execute parts of my code that I put in a same section. Unfortunately, selecting "Execute" when right-clicking on a section does nothing...
For entering system of linear ode's, from textbook, such as this example
I can either use x[1],x[2]  or x__1 and x__2.
Maple dsolve works with both. The Latex generated is also exactly the same Which is x_{1} and x_{2}.
The only minor difference I see is on the screen in the worksheet (I only use 1D), where the subscript looks a little nicer in the case of x[1] vs. x__1
The subscript in the case of x[1] is upright while the one in x__1 is italic. I like the first one more.
Other than this cosmetic difference, Are there are subtle sematic differences between the two forms in terms of computation? I know x[1] create table x. OK.  While x__1 is a separate symbol. No table is created.,
Which would be  a safer/better option to use in this case?   Or is it just a matter of choice?
sys:=[ diff(x[1](t),t)=x[1](t)+x[2](t),diff(x[2](t),t)=x[1](t)+3*x[2](t)];
sys:=[ diff(x__1(t),t)=x__1(t)+x__2(t),diff(x__2(t),t)=x__1(t)+3*x__2(t)];
In some way, using x__1(t) might be a little easier to read on the eye than x[1](t) since there is only one type of paranthesis involved.
ps. I tried to search for __ in Maple help to read more about it, but ?__ do not show it. I am sure __ is in the help under some other name.
How do I insert an empty or null value into a matrix imported from a csv file?  The imported data assumes the value is zero.
First 506 507 508 509 510 511 512 Last Page 508 of 2432
