Any idea why Maple can simplify this expression only when multiplied by -1 but not otherwise?
expr:=sqrt(-2 + 2*I*sqrt(3));
simplify(expr)
But now
simplify(-1*expr)
Multiplying by -1 should not have mattered. Becuase -2 + 2*I*sqrt(3)=(1+I*sqrt(3))^2  Therefore sqrt(-2 + 2*I*sqrt(3)) is the same as 1+I*sqrt(3) and Maple knows this:
simplify((1 + sqrt(3)*I)-expr) gives zero.
But Maple only simplifies -expr  and not +expr.
Just wondering is someone can suggest why that is and if this is considered OK?
Maple 2020.1, Physics 724
I need to check if the solution (sols) of a (nonlinear) polynomial system of equations (the coefficients are not numeric) has only one solution for, let's say, y and (one solution for y and one solution for z).  I cannot use allvalues (not threadsafe according to CodeTools:-ThreadSafetyCheck) and then count the number of solutions.
I have removed all solutions that fit the command
ormap(x->x=true,map(has,rhs~(op~(sols)),_Z))
(RootOf works too).  (Please tell me if I am using ormap correctly).
Even using the above command and then checking if nops(sols)=1, not all one solutions are caught.
Many thanks
Ed
Any idea what this could mean?
I'm comparing 2 matrices where one of them is empty, and the other one is unitfree.
I want to ask, I have a system of equations...
eq1:=K_1=(((n_Cl-x)*u_Cl)*(n_H*u_H))/(n_HCl*m);
eq2:=K_2=(((n_Na-x)*u_Na)*(n_OH*u_OH))/(n_NaOH*m);
eq3:=K_w=(n_H*u_H/m)*(n_OH*u_OH/m);
eq4:=K_NaCl=((n_Na-x)*u_Na*(n_Cl-x)*u_Cl)/m^2;
eq5:=(n_NaCl-x)=(n_Na-x)+n_NaOH;
eq6:=(n_NaCl-x)=(n_Cl-x)+n_HCl;
eq7:=(n_Na-x)+n_H=(n_Cl-x)+n_OH;
eq8:=2*ionic=(n_H/m)+((n_Cl-x)/m)+((n_Na-x)/m)+(n_OH/m);
eq9:=u_H=0.4077*ionic^2-0.3152*ionic+0.9213;
eq10:=u_Na=0.0615*ionic^2-0.2196*ionic+0.8627;
eq11:=u_OH=0.1948*ionic^2-0.1803*ionic+0.8887;
eq12:=m=r*V;
eq13:=u_Cl=(1.417625986641341e-01)*exp^(-ionic/2.199955601666953e-02)+2.369460669647978e-01*exp^(-ionic/3.756472377688394e-01)+5.859738096037875e-01;
but when I use solve command, Maple starts computing, but suddenly gives message: Solutions may have been lost.
I guess problem is the last exponential equation. Is there any way how to make Maple to be able to compute this system?
What is the best way to get some one on one training in maple , has anyone done this?
Area of shadow : i have studied one way of solution by hand, but now in Maple ?
Note: for math illustrations : geogebra seems to be wel suited
I would like to plot a specific vector with an initial point of <4,3,-5> and a terminal point of <3,-1,4>. I have been searching through Maple Primes and Maple Soft.
M1 := 12.3:
M2 := 12.4:
M3 := 12.5:
R := 50:
EQ:={(diff(F(x), x $ 4)) - M1*diff(G(x),x$2) -2*R*F(x)*diff(F(x),x$3)=0, diff(G(x),x$2)+ M2*(diff(F(x),x$2)-2*G(x)) +M3*(diff(F(x),x)*G(x)-2*F(x)*diff(G(x),x))=0}:
IC:={D(F)(-1)=0, D(F)(1)=0,F(-1)=-1,F(1)=1,G(-1)=0,  G(1)=0}:
sol:= dsolve(EQ union IC,numeric,output=Array([-1,-0.9,-0.8,-0.7,-0.6,-0.5,-0.4,-0.3,-0.2,-0.1,0,0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1]));
Error, (in dsolve/numeric/bvp) uanble to achieve continuous solution with requested accuracy of 0.1e-5 with maximum 128 point mesh (was able to get 0.47e-5), consider increasing `maxmesh` or using larger `abserr`
plots:-odeplot(sol,[x,F(x)],x=-1..1,color=red,axes=box)
plots:-odeplot(sol,  [x, diff(F(x), x)], x = -1 .. 1, color =  green, axes = box)
plots:-odeplot(sol,[[x,F(x)],[x,diff(F(x),x)],[x,G(x)]],x=-1..1,color=[red,green,blue],axes=box):
plots:-odeplot(sol, [x, G(x)], x = -1 .. 1, color = blue, axes = box);
solve( sum((1/(1+x+x^2))*y^n, n=1..infinity) = 1, parametric=true, real);
How to solve two variables summation equation with parametric true or real triangularize?
how to solve for x and y?
I just wonder how it is possible to store data between sessions. What I found out is that if a matrix is connected with a datatable, the matrix data is stored. If it is not connected with a datatable, it is not.
In the attached example there are 2 matrices. If you run the worksheet, both variables are defined as visible in the variable overview.
After reopening without running the worksheet, just the variable connected with a datatable is.
Any ideas how to also get the second variable stored between sessions (obviously not with the same method as used for a)?
storetable.mw
Download Analisa_Dinamik_Limb_v1_(30).mwAnalisa_Dinamik_Limb_v1_(30).mw
So I have an equation that basically takes the component of vectors to be used as an equation. The variables that I after are FB1z, FB2x, and FB3y For example here is my equation:
EOM1:=(AFB1[1]+AFB2[1]+AFB3[1])=TEOM[1]
EOM2:=(AFB1[2]+AFB2[2]+AFB3[2])=TEOM[2]
EOM3:=(AFB1[3]+AFB2[3]+AFB3[3])-TEOM[3]:
FBBp1:=FBPP1=(EulP1[1]+EulP2[1]+EulP3[1]):
FBBp2:=FBPP2=(EulP1[2]+EulP2[2]+EulP3[2]):
FBBp3:=FBPP3=(EulP1[3]+EulP2[3]+EulP3[3]):
However there are unknown variable in AFB2[1] named FB2x and AFB3[1] named FB3y. Then AFB1[2] has unknown equation named FB1z and AFB3[2] has FB3y and so on. While in my FBBp1,FBBp2,and FBBp3 holds all of the variable of FB1z, FB2x, and FB3x
I have tried to use 'solve' command to find the variable but my computer won't stop processing it:
sls:=solve({EOM1,EOM2,EOM3,FBBp1,FBBp2,FBBp3},{FB1z,FB2x,FB3y}):
I tried to use the Gauss-Elimination by forming a matrix but it doesn't work as well since I am really confused how to take out the variables out of the vector component.
zzz:=Matrix([0,AFB2[1],AFB3[1],jjj[1]],[AFB1[2],0,AFB3[2],jjj[2]],[AFB1[3],AFB2[3],0,jjj[3]],[FBP1[1],FBP2[1],FBP3[1],EulP[1]],[FBP1[2],FBP2[2],FBP3[2],EulP[2]],[FBP1[3],FBP2[3],FBP3[3],EulP[3]]):
GaussElimination:=(zzz)
I would be very grateful If someone could help me. Thankyou
Edit: here are the .txt files and .mpl files that required to run the program
Inverse_Kinematics_ADRIAN2.mw
RotInertiax0_ADRIAN.txt
Download DisplacementXYZ.txt
inersia_platfrom.txt
There is an .mpl file that I couldn't upload so I will upload it in the comments
I have to find the distance between a point and a plot. The point is (2,-3,4) and the plane is x+2y+2z=13. How do I plot this?
i need to find a y(2) and than work with it in a loop
but i cant do it because i solved my equation with "dsolve" and "sol(2)" and its solution is list
really need a help
I am a new user to maple and I have tried to solve a partial differential equation.
The solution is shown in the figure above but I don't know how to make a 3d plot or contour plot of the solution. The code of solving pde is down below:
pde := diff(T(x, y), x $ 2) + diff(T(x, y), y $ 2) = 0;
bc := T(0, y) = T1, T(a, y) = T2, T(x, 0) = T2, k*D[2](T)(x, b) = h*(-T(x, b) + T3);
sol1 := simplify((pdsolve([pde, bc], T(x, y)) assuming (0 < a, 0 < b)));
and the constant value are:  a = 250, b = 4, k = 2.091, T1 = -5, T2 = 0, h = 100, T3 = 1000
the plot range is 0<x<250, 0<y<4.
Thank you for helping me!
From another question I asked, I learned that parse("string") returns an unevaluated Maple expression.
But in interactive mode (in worksheet), the result looks the same as normal evaluated expression. That is why I did not know this. For example
ode1:= :-parse("diff(y(x),x$2)=0");
ode2:= diff(y(x),x$2)=0;
it gives
There is no difference when looking at it.  That is why when I was in Maple debugger, I could not see why Maple was complaining about it. An eval  was needed.
I looked at the types to see if there is something like type(variable,`unevaluated`) or such, and could not find one.
If Maple can at least display unevaluated expression with different color, or different notations when in the worksheet interface,  I would have noticed that parse returns unevaluated expression.
In Mathematica, these things are done using wrappers, (called Hold or Inactive) but these are visible in the notebook and use different color shading or Hold is present and had to expliclity removed,  and so looking at them, one can see the differerence between the expressions.
How can one in Maple distinguish between unevaluated expression such as ode1 above and evaluated one such as ode2 above?  This can be useful to use inside a proc for example.  Is there an option in the GUI itself to tell Maple may be to color each differently?
First 527 528 529 530 531 532 533 Last Page 529 of 2433
