Hi there!
I am trying to save the coefficients of a polynomial in a list to work with them in a rather complicated procedure. It is about representing a polynomial via a set of orthogonal polynomials phi_n which change depending on the input. For example, phi_s*phi_0=1*phi_s, so the coefficient of phi_s is 1 and the rest is 0. I save this as a[s][0][s]:=1. In this procedure, however, the coefficient of phi_{s+1} or phi_{s+10} might come up, and I have not declared them as 0, so the procedure stops whenever something like a[s][0][s+2] or a[s][0][s+10] appears. I could work with polynomials I guess, saving x^s for the result of
phi_s*phi_0 and working with coeff (x^s,n), which would indeed return 0 if n is not s instead of aborting the entire procedure, however, to me, it's not quite beautiful coding to encrypt the needed coefficients in another polynomial instead of just extracting them into a list. Is there a way to tell Maple that anything unspecified, a[s][j][x], shall just be 0?
Thank you in advance, Daniel
I did two attempts with different ideas
Task (a) A list of numbers in Maple :
L:=[1,2,3,4,5];
[1, 2, 3, 4, 5]
In general summing up numbers sum(a, i = k .. n) = sum(a_i, i = 1 .. 5) and sum(a_i, i = 1 .. 5) = a1+a2+a3+a4+a5
underscript? ..i like to write a with underscore n : how to that
#S:={seq(L[i],i=1..5)};
#L:= [seq(L[i],i=1..5)];
For summing up numbers in a list of L i can use a ...
Sumlist := proc (L,N):
Sumlist:=proc(L,N)
   a:=1;
   for i from 1 to N do
      a:=seq(L[i],i=1..5);
Warning, (in Sumlist) `a` is implicitly declared local
Warning, (in Sumlist) `i` is implicitly declared local
L:=[1,2,3,4,5];
[1, 2, 3, 4, 5]
N:=3;
Sumlist(L,N);
1, 2, 3, 4, 5
And now to sum the number sequenze  from the procedure?
Sumlist:=proc(L,N)
   a:=1;
      #sum(a, i=1..5); # for this probably a second do loop nested ?
L:=[1,2,3,4,5];
[1, 2, 3, 4, 5]
N:=3;
Sumlist(L,N);
1, 2, 3, 4, 5
Also possible by? : a1 = 1, a2=a1+1, a3=a2+1, etc
Sumlist:=proc(L,N)
   a:=1;
      a:=L[i]+1;
L:=[1,2,3,4,5];
[1, 2, 3, 4, 5]
N:=2;
Sumlist(L,N);
L[1];
Try some things out, but summing up list ?
Download betounes_ex_set_2_task_5.mw
a := 10;
ff := proc()
       ##local a,b;
        b := a + 10:  #### implicit local
         return b:
ff();
output: 20
a := 10:
ff := proc()
       ##local a,b;
        a:=b:
        return b:
ff();
output: a+10
expected: 20
Please explain the reason
How can I create an even function, g, in Maple? I want Maple to give g(x) - g(-x) as 0.
Good day sirs, I write a system of DAE but giving me this code "(The use of global variables in numerical ODE problems is deprecated, and will be removed in a future release. Use the 'parameters' argument instead (see ?dsolve,numeric,parameters)". The code is attached below.
Thanking you in anticipating for your help.
Help!!!!.mw
Hello, I was given the problem "Set N:=100. (i) Form four lists L[1], L[3], L[5], L[7] where L[r] contains all primes 2< p < N such that p mod 8 = r ." and came up with the following code:
N := 100;
List1 := [];
List3 := [];
List5 := [];
List7 := [];
for p from 2 to N do
    if isprime(p) and p mod 8 = 1 then List1 := [op(List1), p]; end if;
    if isprime(p) and p mod 8 = 3 then
        List3 := [op(List3), p];
    if isprime(p) and p mod 8 = 5 then
        List5 := [op(List5), p];
    if isprime(p) and p mod 8 = 7 then
        List7 := [op(List7), p];
List1;
List3;
List5;
List7;
this gave me the answer I wanted, however using the above code I have to answer this second question:
In the notation of Problem 1, make a procedure with input = arbitrary  positive integer N and output = the list [nops(L[1]), nops(L[3]), nops(L[5]), nops(L[7])]. Do some experiments to see for which (if any) r, L[r] is largest.
I am unsure of how to create a procedure out of the code I already have. I created this:
F := proc(n)
local N, p, List1, List3, List5, List7;
List1 := [];
List3 := [];
List5 := [];
List7 := [];
for p from N do
if isprime(p) and p mod 8 = 3 then List3 := [op(List3), p]; end if;
if isprime(p) and p mod 8 = 5 then List5 := [op(List5), p]; end if;
if isprime(p) and p mod 8 = 7 then List7 := [op(List7), p]; end if;
return [nops(List1), nops(List3), nops(List5), nops(List7)];
however, when I input F(100) or any other value of N, I am receiving the error message "Error, (in F) initial value in for loop must be numeric or character"
Any ideas on how to improve my program to get the output I desire?
thank you
with(PDEtools):
with(plot):
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received plot
A1:=Matrix([[phi,(chi),conjugate(phi),conjugate(chi)],
          [chi,(phi),conjugate(chi),conjugate(phi)],
          [lambda*phi,-(lambda)*(chi),
           conjugate(lambda)*conjugate(phi),-conjugate(lambda)*conjugate(chi)],
          [lambda*chi,-(lambda)*(phi),
           conjugate(lambda)*conjugate(chi),-conjugate(lambda)*conjugate(phi)]]);
A1 := Matrix(4, 4, {(1, 1) = phi, (1, 2) = chi, (1, 3) = conjugate(phi), (1, 4) = conjugate(chi), (2, 1) = chi, (2, 2) = phi, (2, 3) = conjugate(chi), (2, 4) = conjugate(phi), (3, 1) = lambda*phi, (3, 2) = -lambda*chi, (3, 3) = conjugate(lambda)*conjugate(phi), (3, 4) = -conjugate(lambda)*conjugate(chi), (4, 1) = lambda*chi, (4, 2) = -lambda*phi, (4, 3) = conjugate(lambda)*conjugate(chi), (4, 4) = -conjugate(lambda)*conjugate(phi)})
d1 := LinearAlgebra:-Determinant(A1):
d1; length(%);
conjugate(lambda)^2*conjugate(phi)^2*chi^2-conjugate(lambda)^2*conjugate(phi)^2*phi^2-conjugate(lambda)^2*conjugate(chi)^2*chi^2+conjugate(lambda)^2*conjugate(chi)^2*phi^2+2*conjugate(lambda)*conjugate(phi)^2*chi^2*lambda+2*conjugate(lambda)*conjugate(phi)^2*lambda*phi^2-8*conjugate(lambda)*conjugate(phi)*conjugate(chi)*chi*lambda*phi+2*conjugate(lambda)*conjugate(chi)^2*chi^2*lambda+2*conjugate(lambda)*conjugate(chi)^2*lambda*phi^2+conjugate(phi)^2*chi^2*lambda^2-conjugate(phi)^2*lambda^2*phi^2-conjugate(chi)^2*chi^2*lambda^2+conjugate(chi)^2*lambda^2*phi^2
705
den:=simplify(d1,size); length(%);
-(-(conjugate(chi)-conjugate(phi))*(chi+phi)*conjugate(lambda)+lambda*(conjugate(chi)+conjugate(phi))*(chi-phi))*(-(conjugate(chi)+conjugate(phi))*(chi-phi)*conjugate(lambda)+lambda*(conjugate(chi)-conjugate(phi))*(chi+phi))
333
con1:=phi=exp(I*lambda*(x-t/(4*lambda^2)-w^2)):con2:=chi=exp(-I*lambda*(x-t/(4*lambda^2)-w^2)):
den1:=simplify(dsubs({con1,con2},den));
4*conjugate(lambda)^2*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2-4*conjugate(lambda)^2*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2+8*conjugate(lambda)*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2*lambda+8*conjugate(lambda)*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2*lambda+4*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2*lambda^2-4*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2*lambda^2-16*conjugate(lambda)*lambda
plot3d(subs(Re(lambda)=1, Im(lambda)=.2, w=1, rhs(den1)),x=-6..6, t=-6..6)
Warning, inserted missing semicolon at end of statement
Error, invalid input: rhs received 4*conjugate(lambda)^2*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2-4*conjugate(lambda)^2*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2+8*conjugate(lambda)*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda+t)/lambda)^2*lambda+8*conjugate(lambda)*cos((1/4)*(-4*w^2*lambda^2+4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*x+t)/lambda)*lambda-t)/lambda)^2*lambda+4*cos((1/4)*(4*w^2*lambda^2-4*x*lambda^2+conjugate((4*lambda^2*w^2-4*lambda^2*...
Download 23May(1).mw
Seems to make no difference with or without RETURN() for the procedure ?
vraag_op_forum_gesteld_over_boek_vb_binomium.mw
For to know what each graph is standing for in the plot legenda
Could not yet get it  in y , y' , y '' , to 5th derative
Better is perhaps to have vertical table with the names and function expression together , but that could be difficult betounes_ex_set_task_4def.mw
f := x -> exp(-x)*sin(x); intvx:= 0..3;
f := proc (x) options operator, arrow; exp(-x)*sin(x) end proc
intvx := 0 .. 3
And this one below ( i prefer this one ) , but got in worksheet now the one above
Probably a option issue ?
2 determinants equal, solve for the unknowns in one determinant/Linear Algebra
Hi guys, thank you for reading my question.
A is one determinant "Matrix(2, 3, [[1, 2, 3], [3, 1, 2]])".B is" Matrix(2, 3, [[1, x, 3], [y, 1, z]])"
I wrote 2 matrice in the maple
As I try to solve the unknowns,I wrote:
A:= B, solve(x, y, z) It doesn't work
I switch another phrase,
A = B;solve(B:x,y,z)    It doesn't work as well
Could you help me with it ?
Dear All.
Please kindly help to correct the attached code on discretization of fourth order PDE using method of line.
Thank you and kind regards.
Discretization of parabolic equation with method of line
diff(u(x, t), t) = -2*(diff(diff(u(x, t), x), x))-(diff(diff(diff(diff(u(x, t), x), x), x), x))-u(x, t)*(diff(u(x, t), x))
u(x, t)
u(x, t)
u(x, 0) = 0.3e-1*sin(x)
8
Convert the BC to finite difference
(1/2)*(u[m+1](t)-u[m-1](t))/h
(u[m-1](t)-2*u[m](t)+u[m+1](t))/h^2
(u[m-2](t)-4*u[m-1](t)+6*u[m](t)-4*u[m+1](t)+u[m+2](t))/h^4
Convert the governing equation to finite difference form
Error, invalid input: diff received 2*h, which is not valid for its 2nd argument
Error, invalid input: LinearAlgebra:-GenerateMatrix expects its 1st argument, eqns, to be of type ({list, set})({`=`, algebraic}), but received eqs
A
Download Discretization_of_PDE_Order_4.mw
ii := 50;
seq(ii, ii = 0 .. 5);
evalf(int(ii, ii = 0 .. 5))
For sequence the syntax is correct i.e the output is 0,1,2,3,4,5. is ii inside sequence command takes the value 5 assigned it then changes when ii ranges from 0 to 5?
ii:=50:
seq(ii)
output: 50
ii:=50:
seq(seq(ii),ii=1..5)
expected answer: 50,50,50,50,50
obtained: 1,2,3,4,5
please explain how seq command works
Trebuchet, Phase I, 2020-05-27 Ki restart; with(RealDomain); with(SolveTools); assume(h < r1); additionally(h < r2); [Im, Re, ^, arccos, arccosh, arccot, arccoth, arccsc, arccsch, arcsec, arcsech, arcsin, arcsinh, arctan, arctanh, cos, cosh, cot, coth, csc, csch, eval, exp, expand, limit, ln, log, sec, sech, signum, simplify, sin, sinh, solve, sqrt, surd, tan, tanh ] [AbstractRootOfSolution, Basis, CancelInverses, Combine, Complexity, Engine, GreaterComplexity, Identity, Inequality, Linear, Parametric, Polynomial, PolynomialSystem, RationalCoefficients, SemiAlgebraic, SortByComplexity] hz1 := g*(r3*m3*cos(phi1(t))-r1*m2*sin(phi2(t))/sin(phi2(t)-phi1(t)))/theta3; whattype(phi1(t)); whattype(phi2(t)); / r1 m2 sin(phi2(t)) \ g |r3 m3 cos(phi1(t)) + -----------------------| \ sin(-phi2(t) + phi1(t))/ hz1 := ------------------------------------------------ theta3 function function hz2 := phi1(t)+arcsin((h+r1*sin(phi1(t)))/r2); /h + r1 sin(phi1(t))\ hz2 := phi1(t) + arcsin|-------------------| \ r2 / subs(phi2 = hz2, hz1); / / | | 1 | | ------ |g |r3 m3 cos(phi1(t)) theta3 | | | | \ \ // /h + r1 sin(phi1(t))\\ \ \\ r1 m2 sin||phi1(t) + arcsin|-------------------||(t)| || \\ \ r2 // / || + ----------------------------------------------------------|| / / /h + r1 sin(phi1(t))\\ \|| sin|-|phi1(t) + arcsin|-------------------||(t) + phi1(t)||| \ \ \ r2 // /// deq := diff(phi1(t), t, t)-% = 0; / / / 2 \ | | | d | 1 | | deq := |---- phi1(t)| - ------ |g |r3 m3 cos(phi1(t)) | 2 | theta3 | | \ dt / | | \ \ / /h + r1 sin(phi1(t))\ \ \ r1 m2 sin|phi1(t)(t) + arcsin|-------------------|(t)| | \ \ r2 / / | + -----------------------------------------------------------| / /h + r1 sin(phi1(t))\ \| sin|-phi1(t)(t) - arcsin|-------------------|(t) + phi1(t)|| \ \ r2 / // \ | | | = 0 | | / ics := phi1(0) = -arcsin(h/r1), (D(phi1))(0) = 0; /h \ ics := phi1(0) = -arcsin|--|, D(phi1)(0) = 0 \r1/ dsolve({deq, ics}, phi1(t)); dsolve(deq); deq_numeric := subs(r1 = 8, r2 = 8, r3 = 1, h = 5, m2 = 1, m3 = 20, theta3 = 20, deq); / | / d / d \\ 1 | |--- |--- phi1(t)|| - -- g |20 cos(phi1(t)) \ dt \ dt // 20 | | \ / /5 \ \ \ 8 sin|phi1(t)(t) + arcsin|- + sin(phi1(t))|(t)| | \ \8 / / | + --------------------------------------------------------| = 0 / /5 \ \| sin|-phi1(t)(t) - arcsin|- + sin(phi1(t))|(t) + phi1(t)|| \ \8 / // ics_numeric := phi1(0) = 0, (D(phi1))(0) = -.63; ics_numeric := phi1(0) = 0, D(phi1)(0) = -0.63 hz1 := dsolve({ics, deq_numeric}, phi1(t), numeric); Error, (in dsolve/numeric/process_input) unknown arcsin(5/8+sin(phi1(t))) present in ODE system is not a specified dependent variable or evaluatable procedure sin(-phi1(t)-arcsin((h+r1*sin(phi1(t)))/r2)); / /h + r1 sin(phi1(t))\\ -sin|phi1(t) + arcsin|-------------------|| \ \ r2 //
How to convert expression below to LaTex:  $\lim _{x \rightarrow 2} \frac{2}{x+3}$
And How to convert expression below to LaTex:  $\int_{2}^{3} \frac{1}{x^{2}+2} d x$
file test: newLaTex.mw
First 554 555 556 557 558 559 560 Last Page 556 of 2433
