If we have an equation for the generalized Bloch sphere i.e.,
\partial_{t}(u^{2} + v^{2} + w^{2}) = 0,
where u, v and w are functions of x and t and the initial conditions u=v=0, w=-1. Then how to plot this equation on maple?
This is an interesting exercise in setting up triple integrals in cylindrical and spherical coordinates to obtain a formula that is immediate without any calculation using the theorem of Pappus. The cylindrical integral is easy. The spherical one is hard, but Maple gives me the result off by a factor of minus one half for generic values of the two radii, but the correct result for concrete numbers! I cannot figure out what I am doing wrong. Any ideas?
http://www34.homepage.villanova.edu/robert.jantzen/courses/mat2500/handouts/torusvolume.mw
I have an expression (functionx) that I want to convert it to a series of x with different powers. My only issue is that I cannot accept negative powers. For example, If I had functionx = cos(x) I want to convert it to 1 - 1/2*x^2 + 1/24*x^4, which can be done with a Taylor expansion.
Here the functionx is a bit complicated if I use Tylor expansion that means I only consider the approximation for a small range of x. Is there any other approximation I could use to convert functionx to a new function that has x to the power of positive values?
functionx:=(0.007334702136*x + 2.418028262*10^231*x^57 + 1.182475218*10^223*x^55 + 5.780663993*10^214*x^53 + 2.824838912*10^206*x^51 + 6.735888408*10^189*x^47 + 1.379783148*10^198*x^49 + 3.286285701*10^181*x^45 + 7.803772225*10^164*x^41 + 1.602116861*10^173*x^43 + 1.845464073*10^148*x^37 + 3.797245890*10^156*x^39 + 4.338988887*10^131*x^33 + 8.956080140*10^139*x^35 + 2.097852265*10^123*x^31 + 4.865844768*10^106*x^27 + 1.011819388*10^115*x^29 + 2.331704338*10^98*x^25 + 1.112530729*10^90*x^23 + 2.489476842*10^73*x^19 + 5.280116219*10^81*x^21 + 5.385068408*10^56*x^15 + 1.164024492*10^65*x^17 + 4.797076312*10^31*x^9 + 1.099976521*10^40*x^11 + 2.456776729*10^48*x^13 + 7.927675416*10^14*x^5 + 2.012154161*10^23*x^7 + 2.781719840*10^6*x^3)/(0.003667351068*x^2 + 695429.9599*x^4 + 4.737736934*10^(-11) + 4.169014245*10^229*x^58 + 1.070493332*10^213*x^54 + 2.111562890*10^221*x^56 + 5.432382523*10^204*x^52 + 1.403310085*10^188*x^48 + 2.759566295*10^196*x^50 + 7.144099350*10^179*x^46 + 1.858041006*10^163*x^42 + 3.641174684*10^171*x^44 + 9.493114726*10^154*x^40 + 4.856484403*10^146*x^38 + 1.276173202*10^130*x^34 + 2.487800039*10^138*x^36 + 6.555788327*10^121*x^32 + 3.372731292*10^113*x^30 + 1.737801703*10^105*x^28 + 8.968093608*10^96*x^26 + 4.635544704*10^88*x^24 + 1.244738421*10^72*x^20 + 2.400052827*10^80*x^22 + 9.166471012*10^38*x^12 + 1.754840521*10^47*x^14 + 3.365667755*10^55*x^16 + 6.466802735*10^63*x^18 + 1.321279236*10^14*x^6 + 2.515192701*10^22*x^8 + 4.797076312*10^30*x^10)^2:
plot(functionx, x=-0.001..0.001):
The reason that I look for an expression for functionx is:
I need to replace x with a series of sin and cos functions and then find specific coefficients that have that sin or cos. In the current form Maple cannot find the coefficients of sin and cos.
I hope it is clear. I have attached the main code.Expansion.mw
Baharm31
I have a couple of symbolic expressions that I need to compare for an underlying variable chi.
The expressions are too long to enter so I have added them in a maple worksheet attached with the post (They are assigned as SW and SR). I used the solve command but get an error as 'Warning, solutions may have been lost'. The help page states that I need to simplify the inequality to get to a solution so I tried using just the numerators (it will be a lot clearer from the worksheet) but still got the same result.
Could anyone help me with this?
ineq.mw
Being an absolut newbie to Maple I find some of the functions a bit strange and difficult.
One of the things is e.g. rounding numbers.
In Pyton and other languages it is quite simple and straightforward when rounding a number.
round(number, digits)
If you have digits = 0 then you get an integer, otherwise you get a number with the number of digits chosen.
In Maple the round function is just for rounding to an integer.
To round to something else currently I don't really know what I would use. There is the evalf function, which one can use like evalf[digits](number), but that doesn't give you the value with digits. It gives you a number with significant digits, which means, also including the numbers before the comma delimiter.
Python
round(15.76543,2) = 15.77
Maple
evalf[2](15.76543) = 16
Wouldn't it be much easier to expand the functionality of the round function in Maple?
As of last week using Maple 2019, and now with Maple 2020, I have begun to have issues trying to export rendered plots using plot3d. Even trying a simple example such as:
plot3d(x^2+y^2, x=0..1, y=0..1);
will return the correct 3D plot, but right-clicking the plot closes the program immediately. Has anyone else experienced a similar issue?
Hello,friends!
I try to calculate the limit of the function,
sin(x*sin(1/x))/(x*sin(1/x))  at point x=0,maple gives answer:1
However,actually it does not have a limit at x=0,because for the limit to exist at a point,there needs to exist a neighbourhood at the point so that all x in the neighbour have definition.
It means f(x) should have have definition at point x=0's negihbourhood,however small the neighbourhood is.If I choose x=1/(n*Pi), n belongs to integers,the function doesn't have definition.As n increase,there doesn't exist such a neighbourhood.So is it something maple should correct?
seems_wrong_answer.mw
I am doing this plot
loglogplot((.45*exp(-0.5e-1*t)+.1*exp(-.1*t))/exp(-0.5e-1*t), t = 1.4*10^4 .. 1.52*10^4);
and I got this weird abrupt change at some point: (please see the attached maple file)
1.mw
I guess it is due to how Maple implement those very large/small numbers.. Any thoughts?
Sort of revising fourier. I have a graph plot(sin(4*pi)+(1/3)*cos(6*pi)) however it gives result from -2pi to + 2pi. there must be a comand to modify plot to go from 0 to 2pi can someone give me a clue.
Rick
Got a question regarding numeric indices in tables. Apparently every index in a table is considered alfanumeric, which means that 90 is not the same as 90.0.
Or test["text", 90] is not the same as test["text", 90.0].
Here's the example.
Table.mw
Apparently I will need to do some numeric formatting before using the numbers as indices for the table, right?
I have a graph with 267 nodes and 727 edges. I am trying to produce an eligible visualization of my graph but I'm getting a very crowded network.
Code:
with(GraphTheory);
DrawGraph(Graph(M1), style = spring, symbolsize = 10, scaling = unconstrained);
I have attatched the a JPEG file to my question to show what it looks like. I would like to space out the nodes with a more zoomed out view. How would I go about this?
I am trying to graph x^(1/2) and (x^2/8) revolving around the y-axis using the ring method but I have not been able to do it. I only get the shell method. I have adjusted the functions to read x=y^2 and x=sqrt(8y). The bounds for this method is 0 to 2. No matter the commands I have tried I have not been able to get the washer method to show. I do not want to use the tutor program.
I applied the definition of a permutation matrix to a given matrix A to obtain a Tridiagonal Toeplitz matrix, but I haven't any idea why the final result looks strange.
Permutation_matrix.mw
Many thanks
"Frame your math" does not work on a new iPhone XS; however, surprisingly, it work just fine on an old iPad (4th gen).
I am logged in. The app has access to the camera. The companion app does allow manual entry of equation to upload to the Maple cloud.
I expect it's something simple--like some sort of permissions setting, but I cannot find it . . .
BTW: The error is "The request timed out. Check your Internet connection."
d/dt(n_2)+d/dx (n0u2)
First 574 575 576 577 578 579 580 Last Page 576 of 2433
