Sorry to bother you with another very basic question.
This very simple example shows that Maple gives the first value that is defined back, ignoring changes further down the definition chain.
Could someone explain why, and if there is a way to always get the updated values?
m := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 3, (2, 1) = 2, (2, 2) = 4})
Matrix(%id = 18446745932232999750)
a := 1
b := m[a, 1]
a := 2
b
m[2, 1]
Download VariableIndex.mw
I've been trying to replicate an example described in a book called "Quantum Mechanics Using Maple" by M. Horbatsch, but at the end, when I'm using fsolve it returns 0. instead .500 .
I'm using Maple 18, but I think this book was written using Maple V. I don't know if the syntax changes are causing this. I'm very new to maple. Here's my worksheet (qm_maple_-_periodic_potentials.mw) and book section (qm_maple_periodic.pdf). Thanks in advance!
I try to use phaseportrait to get the phase portrait of the following ode system, why it does not give the plot or the error reminding?
with(LinearAlgebra)
phaseportrait([diff(x(t), t) = -((y(t)^2*x(t)+x(t)^3+y(t)-x(t))*sqrt((y(t)^2+x(t)^2)/x(t)^2)-2*x(t))*x(t)/sqrt(y(t)^2+x(t)^2), diff(y(t), t) = -x(t)*((y(t)^3+y(t)*x(t)^2-y(t)-x(t))*sqrt((y(t)^2+x(t)^2)/x(t)^2)-2*y(t))/sqrt(y(t)^2+x(t)^2)], [x(t), y(t)], t = 0 .. 50, [[x(0) = -1, y(0) = -1], [x(0) = -5, y(0) = -5]], x = -10 .. 20, y = -10 .. 30, dirgrid = [40, 40], stepsize = 0.1e-2, numframes = 90, axes = BOXED, linecolor = black)
phaseportrait([diff(x(t), t) = -((y(t)^2*x(t)+x(t)^3+y(t)-x(t))*((y(t)^2+x(t)^2)/x(t)^2)^(1/2)-2*x(t))*x(t)/(y(t)^2+x(t)^2)^(1/2), diff(y(t), t) = -x(t)*((y(t)^3+y(t)*x(t)^2-y(t)-x(t))*((y(t)^2+x(t)^2)/x(t)^2)^(1/2)-2*y(t))/(y(t)^2+x(t)^2)^(1/2)], [x(t), y(t)], t = 0 .. 50, [[x(0) = -1, y(0) = -1], [x(0) = -5, y(0) = -5]], x = -10 .. 20, y = -10 .. 30, dirgrid = [40, 40], stepsize = 0.1e-2, numframes = 90, axes = BOXED, linecolor = black)
Download m40.mw
I was wondering if there was any way to reassign the "||" operator to calculate parallel resistors?
like this:
R1 || R2 = (1/R1+1/R2)^(-1)
solve it by Maple , get the following form solution, what's the Int(1,0)
ODE :=diff(r(t),t)=r(t)*(1-r(t)^2)+mu*r(t)*cos(t)
diff(r(t), t) = r(t)*(1-r(t)^2)+mu*r(t)*cos(t)
dsolve(ODE)
r(t) = ((_C1+2*(Int((exp(t))^2*(exp(mu*sin(t)))^2, t)))*exp(2*t+2*mu*sin(t)))^(1/2)/(_C1+2*(Int((exp(t))^2*(exp(mu*sin(t)))^2, t))), r(t) = -((_C1+2*(Int((exp(t))^2*(exp(mu*sin(t)))^2, t)))*exp(2*t+2*mu*sin(t)))^(1/2)/(_C1+2*(Int((exp(t))^2*(exp(mu*sin(t)))^2, t)))
g := unapply(sqrt((C1+2*(Int((exp(t))^2*(exp(mu*sin(t)))^2, t)))*exp(2*t+2*mu*sin(t)))/(C1+2*(Int((exp(t))^2*(exp(mu*sin(t)))^2, t))), t)
proc (t) options operator, arrow; ((C1+2*(Int((exp(t))^2*(exp(mu*sin(t)))^2, t)))*exp(2*t+2*mu*sin(t)))^(1/2)/(C1+2*(Int((exp(t))^2*(exp(mu*sin(t)))^2, t))) end proc
g(0)
1/(C1+2*(Int(1, 0)))^(1/2)
Download m39.mw
How can I  get the  phase portrait  and several trajectory of the following system(it is in polar coordinates )
r'=r(1 − r^2) + 2rcos(θ),
θ' = 1
I'm working along in Maple 2019 and then all of a sudden it freezes.  Anyone else have this?
Maple 2018 and earlier displayed an Array like this
In Maple 2019 I get this
How do I display Arrays in Maple 2019 like Maple 2018?
Why when I read a file in (image file - specifically a TIFF file) and then write the exact same file back out, it makes a file 30% larger.  Should it not be the same size??
Trying to solve this integral here.
with(Statistics);
X := RandomVariable(Normal(10, mu));
                            X := _R
dummy := int(PDF(X, mu), r = -infinity .. 500);
                         /   /           2\\
                         |   |  (mu - 10) ||
                         |exp|- ----------||
                         |   |        2   ||
                         |   \    2 mu    /|
          dummy := signum|-----------------| infinity
                         \       mu        /
solve(dummy = 0.05);
What am I missing? Any ideas ? :)
Please excuse this newbie question - but any idea what's wrong with this procedure?
I also wonder how text indent and formatting is done in Maple? Are there any tricks, or is it just doing formatting that it look good.
Last thing - what's the best procedure to post questions like this? Is it just attaching a short code example in original Maple file, or do I copy & paste as text?
Warning, premature end of input, use <Shift> + <Enter> to avoid this message.
assign('`f__t,90,k`', Property(Class, "f_t,90,k"));
       assign('`f__c,0,k`', Property(Class, "f_c,0,k"));
     assign('`f__c,90,k`', Property(Class, "f_c,90,k"));
     assign('`f__v,k`', Property(Class, "f_v,k"));
     assign('`f__r,k`', Property(Class, "f_r,k"));
     assign('`E__0,mean`', Property(Class, "E_0,mean"));
     assign('`E__0,05`', Property(Class, "E_0,05"));
     assign('`E__90,mean`', Property(Class, "E_90,mean"));
     assign('`E__90,0,05`', Property(Class, "E_90,0,05"));
     assign('`G__mean`', Property(Class, "G_mean"));
     assign('`G__0,05`', Property(Class, "G_0,05"));
     assign('`G__r,mean`', Property(Class, "G_r,mean"));
     assign('`G__r,0,05`', Property(Class, "G_r,0,05"));
     assign('`rho__k`', Property(Class, "rho_k"));
     assign('`rho__mean`', Property(Class, "rho_mean"))
Error, reserved word `end` unexpected
Download proc.mw
How Do I set the Command Line Font in Maple 2019?
The default font is strange.  eq is displayed as a a lower case char like '8' followed by 'q'.
I would like to have something like courier 10, etc.
Hi, I am using the GroupTheory package and I wanted to created the following group in Maple:
I stumbled across this link https://www.maplesoft.com/products/maple/features/grouptheory.aspx and then tried to use the following commands to define this group in Maple:
1. First a defined a 12x12 matrix:
ct := <<e | p | q | r | s | t | u | v | w | x | y | z>, <p | q | e | y | u | w | z | r | x | t | v | s>, <q | e | p | v | z | x | s | y | t | w | r | u>, <r | z | t | s | e | y | v | x | p | u | q | w>, <s | w | y | e | r | q | x | u | z | v | t | p>, <t | r | z | x | w | u | e | q | y | p | s | v>, <u | x | v | p | y | e | t | z | s | r | w | q>, <v | u | x | z | q | r | y | w | e | s | p | t>, <w | y | s | t | x | z | p | e | v | q | u | r>, <x | v | u | w | t | s | q | p | r | e | z | y>, <y | s | w | u | p | v | r | t | q | z | e | x>, <z | t | r | q | v | p | w | s | u | y | x | e>>
2. Then I tried to define my  group using:
G := Group(ct)
However this doesn't work because I get the following error:
Error, (in GroupTheory:-Group) invalid input: arguments to GroupTheory:-Group, [Matrix(12, 12, {(1, 1) = e, (1, 2) = p, (1, 3) = q, (1, 4) = r, (1, 5) = s, (1, 6) = t, (1, 7) = u, (1, 8) = v, (1, 9) = w, (1, 10) = x, (1, 11) = y, (1, 12) = z, (2, 1) = p, (2, 2) = q, (2, 3) = e, (2, 4) = y, (2, 5) = u, (2, 6) = w, (2, 7) = z, (2, 8) = r, (2, 9) = x, (2, 10) = t, (2, 11) = v, (2, 12) = s, (3, 1) = q, (3, 2) = e, (3, 3) = p, (3, 4) = v, (3, 5) = z, (3, 6) = x, (3, 7) = s, (3, 8) = y, (3, 9) = t, (3, 10) = w, (3, 11) = r, (3, 12) = u, (4, 1) = r, (4, 2) = z, (4, 3) = t, (4, 4) = s, (4, 5) = e, (4, 6) = y, (4, 7) = v, (4, 8) = x, (4, 9) = p, (4, 10) = ...  (12, 8) = s, (12, 9) = u, (12, 10) = y, (12, 11) = x, (12, 12) = e})], do not match any of the accepted calling sequences
I don't know what's going wrong. It doesn't give a 2D Plot. Thanks in advance.
Temperature over 24hr period
y := 0.26e-1*x^3-1.03*x^2+10.2*x+34, 0 <= x and x <= 24
Download temperature24hr.mw
BE312-1920-CW2-Amended-Maple-Codemw-46469mw-46557_(1).mw
How do you run this code in Maple 2019 to Maple 18 because I can't see the output?
First 587 588 589 590 591 592 593 Last Page 589 of 2433
