I want to define the co-ordianates (phi, PI, ....)  as functions of some variable eg:- x,y.
Hi everyone,
When my cursor is on an output, the paragraph style changes to 2D Output, as it most likely should. When I then go to a new executable line, it takes forever for all of my expressions to "light up" (meaning that it takes a while for me to be able to use them), and it takes forever for the paragraph to go from 2D Output to 2D Math.
I sadly don't remember when this happened, or what might have caused it, but if any of have any suggestions or answers, I'd greatly appreciate it.
Thanks for listening,
A confused highschool student.
,Hello dears
I have the following function
where L=10 and I want to plot this function, so I use
But it does not work.
Is there any help.
Amr
Im beginner in Maple so i need a help with the following differential equation:
y'' - y = 0 where y(0) = 0 and y(1) = 1
I solved this but im confused how can i solve it in Maple.
Thank you in advance.
Hello Users,
I have a question on my work.
I constructed two different equations that looks different.
Two constants the front of each equations (kappa_T and kappa_S)  have difference too much. (without an error)
 In my own calculations, I found that two expressions should be same.
Is there a possibility of operation error(or calculation error)?
I want to know which process cause this problem and how can i avoid.
Please open attached file. Thanks for reading!! :D
Question_Kappa_T_and_S.mw
How can I draw a "regular looking" histogram where all the bars adjacent to each other?
I tried looking into the options for histograms with no luck. I included a picture of what kind of output I am looking for.
I have a first-order complex ODE, I would like to use the polar coordinates to find the associated system of the ordinary differential equation then I determine the equilibrium point of the system and deduce that there is at least one limit cycle.
many thanks for your help
syestem_polar_cordinates.mw
I can't find a unique way to define a mixture of two random variables that enables at the same time to compute its PDF and generate a sample.
In the attached file you will find two methods :
  1. the first one is the most formal and only CAS are supposed to be able to allow its implementation:
     it enables computing the PDF and the CDF (trivial) but fails to generate a sample.
    (PS : in a first attempt I had defined only the PDF, which should have been enough for method=envelope does work... ... at my opinion)
  2. the second method is the one one would use in non CAS languages (for instance Matlab, R, ...). It enables generating a sample (of course) but fails to compute the PDF (which is not very surprising).
So my question: does anyone here would have some suggestions to make one these two methods capable to compute both the PDF (eventually the CDF) and generate samples ?
PS: still have this kind of problems (tomleslie suggested months ago that using interface(rtablesize=10) could help but it's not the case here)
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Mixture_of_random_variables.mw .
Download Mixture_of_random_variables.mw
the quartile function gives the wrong answers.
list := [1,2,3,4,5,6,7,8]
Q1 does NOT come back as 2.5 as it should, nor does Q3. I get these weird decimals.
I looked at the help for it but wasn't helpful. All the examples in the help are super complicated. No simple examples like the one I mentioned here.
Hi everyone:
I have two matrices T(t) and Y[i] :N is natural.how can I do it? tnx.
I am just confused to be getting this error seeings FileTools does not encounter this error when I use it's ListDirectory command:
error_for_primes.mw
with(ImageTools):
FileTools:-ListDirectory(currentdir())
["IMG_20200116_015953.jpg", "magetools commands.mw"]
Read("H:\\MAPLE\\Image_Project", format = JPEG)
Error, (in readbytes) permission denied
Download error_for_primes.mw
sigma(integral(F(w,cn1,ct1))+integral(F(w,cn2,ct2))+...+integral(F(w,cn80,ct80)))
integral.mw
In a do loop with a try... catch statement I had placed an assignment to a vector element after catch: but before the line printing the lastexception. That the loop didn't perform as expected, but resulted in an error about ListTools:-FormatMessage wanting its first argument to be a string surprised me. Putting the assigment to the vector after the exception printing worked fine.
It seems that rtables are the exception (no pun intended) to the order being irrelevant.
V:=Vector():
for j from 1 to 5 do
  try
   V(j):=j/(j-1)
  catch:
   V(j):=17; # clears lastexception apparently
   printf(cat(StringTools:-FormatMessage(lastexception[ 2 .. -1 ] ),"\n"));
  end try
V:=Vector():
  try
   V(j):=j/(j-1)
  catch:
   V(j):=17;
  end try
These simple lines confirm my observation:
lastexception;
5/0;
lastexception;
5/5;
lastexception;
x:=47;
lastexception;
table();
lastexception;
[1,2,3];
lastexception;
rtable();
lastexception; # Now cleared!
Hello Dear Brothers and Sistors,
Can you help me giving a maple program to plot cost function  of a an optimal control modeling ?
Looking forward.
hi everyone:
How can I define this matrix in Maple? N is a Natural number. Thank you.
First 604 605 606 607 608 609 610 Last Page 606 of 2433
