Dear maple users,
How to plot a figure for different values of rk?
like rk=5,10,15,20:
jb.mw
Thanking you,
Waiting for replay.
Recently I posted a question "how to insert a loop".
Without my knowledge, the post is deleted.
Mention the reason for deleting the post.
How would I turn this set into matrix form?
would it be possible to seperate the matrix form into:
v1e^(lamba*t) + v2e^(lambda2*t) .... + v^ne^(lambdan*t) where v1, v2, and vn are the eigenvectors and lamba1, lambda2, and lamban are their respective eigenvectors.
I have problem on RKF45 with result on
"unable to convert to an explicit first order system"
vf := .3:
kf := .2:
c := .2:
`Τt` := .3:
N := .1:
`φd` := .2:
`ρs` := 8933:
`ρf` := 997.1:
y := .1:
alpha := .5:
Pr := 6.2:
beta := .5:
`βT` := .2:
`ε` := .1:
ks := 400:
kf := .613:
cps := 385:
cpf := 4179:
delta := .5:
Ec := .2:
`Τv` := 1:
A := .5:
B := .5:
omega := 1.5:
K := (ks+2*kf-2*phi*(kf-ks))/(ks+2*kf+phi*(kf-ks))
(401.226+798.774*phi)/(401.226-399.387*phi)
Eq1 := (1-`φd`)*(diff(f(eta), eta, eta, eta))/(1-phi)^2.5-(1-`φd`)*(1-phi+phi*`ρs`/`ρf`)*((diff(f(eta), eta))^2-f(eta)*(diff(f(eta), eta, eta)))+alpha*beta*(diff(G(eta), eta)-(diff(f(eta), eta))) = 0
.8*(diff(diff(diff(f(eta), eta), eta), eta))/(1-phi)^2.5-.8*(1+7.958981045*phi)*((diff(f(eta), eta))^2-f(eta)*(diff(diff(f(eta), eta), eta)))+.25*(diff(G(eta), eta))-.25*(diff(f(eta), eta)) = 0
Eq2 := (diff(G(eta), eta))^2-G(eta)*(diff(G(eta), eta, eta))-beta*(diff(f(eta), eta)-(diff(G(eta), eta))) = 0
(diff(G(eta), eta))^2-G(eta)*(diff(diff(G(eta), eta), eta))-.5*(diff(f(eta), eta))+.5*(diff(G(eta), eta)) = 0
Eq3 := G(eta)*(diff(G(eta), eta))+beta*(f(eta)-G(eta)) = 0
G(eta)*(diff(G(eta), eta))+.5*f(eta)-.5*G(eta) = 0
Eq4 := K*(diff(theta(eta), eta, eta))/Pr+(1-phi+phi*`ρs`*cps/(`ρf`*cpf))*(f(eta)*(diff(theta(eta), eta))-2*(diff(f(eta), eta))*theta(eta))+alpha*`βT`*(H(eta)-theta(eta))+Ec*alpha*(diff(G(eta), eta)-(diff(f(eta), eta)))^2/`Τv`+(A*(diff(f(eta), eta))+B*theta(eta))/Pr = 0
.1612903226*(401.226+798.774*phi)*(diff(diff(theta(eta), eta), eta))/(401.226-399.387*phi)+(1-.1746332371*phi)*(f(eta)*(diff(theta(eta), eta))-2*(diff(f(eta), eta))*theta(eta))+.10*H(eta)-0.1935483870e-1*theta(eta)+.10*(diff(G(eta), eta)-(diff(f(eta), eta)))^2+0.8064516130e-1*(diff(f(eta), eta)) = 0
Eq5 := 2*(diff(G(eta), eta))*H(eta)-G(eta)*(diff(H(eta), eta))+y*`βT`*(H(eta)-theta(eta)) = 0
2*(diff(G(eta), eta))*H(eta)-G(eta)*(diff(H(eta), eta))+0.2e-1*H(eta)-0.2e-1*theta(eta) = 0
bcs1 := (D(f))(0) = `ε`+delta*((D@@2)(f))(0), f(0) = 0, (D(f))(10) = 0;
(D(f))(0) = .1+.5*((D@@2)(f))(0), f(0) = 0, (D(f))(10) = 0
bcs2 := (D(G))(10) = 0, G(10) = f(10);
bcs3 := theta(0) = 1+omega*(D(theta))(0), theta(10) = 0;
theta(0) = 1+1.5*(D(theta))(0), theta(10) = 0
bcs4 := H(10) = 0;
H(10) = 0
L := [0., 0.5e-1, .1, .15, .2]:
for k to 5 do R := dsolve(eval({Eq1, Eq2, Eq3, Eq4, Eq5, bcs1, bcs2, bcs3, bcs4}, phi = L[k]), [f(eta), G(eta), theta(eta), H(eta)], numeric, output = listprocedure); Y || k := rhs(R[3]) end do
plot([Y || (1 .. 5)], 0 .. 10)
Error, (in plot) procedure expected, as range contains no plotting variable
Download RKF45_A.mw
thank you in advance for your help and kindness.
I am using a maple workbook to develop, test, and install a package I am developing.  Several days ago, I noticed that the workbook was not updating the package to reflect the most recent versions of my source code (.mpl). I initially assumed the problem caused by some unintentional change I made to the file, but in the end I found there is a general problem with the URIs in the maple workbook. Everything worked in 2019.1 and I hadn't made any changes after I updated to 2019.2.1.
To confirm the problem, I created a new directory(in fully updated Windows 10 ) and copied my source file into the directory. Then I created a worksheet in maple and saved it into the directory as xx.mw. Using the Navigator panel I then saved the worksheet as a workbook creating xx.maple in the directory.  I then tried to attach the mpl file to the workbook.  In the Navigator menu, the item "attach a file" is unavailable( greyed out).  This is also the case in any of the other earlier workbooks I have created.  I have confirmed the problem is not affecting worksheets because I was able to read my mpl file into a worksheet and load the module using a with(modulename) command.
Please advise.
eqs := [II-(phi+mu)*DD+tau*D__g, phi*DD+lambda__2*D__a+lambda__3*D__H-(lambda__4+lambda__1*D__a/(S+D__g)+mu)*D__g, lambda__1*D__g*D__a/(S+D__g)-(lambda__2+beta+mu)*D__a, beta*D__a-(lambda__3+mu+gamma__t)*D__H+lambda__4*D__g, gamma__t*D__H-(delta+mu)*D__c];
Sol := {DD = (II+B*tau)/(phi+mu), D__H = E/P, D__a = ((lambda__3+mu+gamma__t)*E/P-lambda__4*B)/beta, D__c = gamma__t*E/((delta+mu)*P), D__g = B};
Inter := [B = S*(lambda[2]+beta+mu)/(lambda[1]-lambda[2]-beta-mu), C = 1/(S+B), E = lambda[2]*lambda[4]*B/beta+B*lambda[4]+mu*B-(lambda[4]*B/beta*B)*C-(phi*II+B*tau*phi)*P/(phi+mu) and lambda[2]*lambda[4]*B/beta+B*lambda[4]+mu*B-(lambda[4]*B/beta*B)*C-(phi*II+B*tau*phi)*P/(phi+mu) = lambda[2]*(lambda[3]+mu+gamma[t])/beta+lambda[3]-lambda[1]*(lambda[3]+mu+gamma[t])*C*B/beta];
[B = S*(lambda[2]+beta+mu)/(lambda[1]-lambda[2]-beta-mu), C = 1/(S+B), false]
simplify(eval(eqs, eval[recurse](Sol, Inter)))
Error, invalid input: eval expects its 2nd argument, eqns, to be of type {integer, equation, set(equation)}, but received Inter
Download tes.mwtes.mw
Dear experts
I have a complex equation (eq=0) which is a function of K, Q, p and s. K and Q can be complex variables and pa and s are parameters.
equation is
eq:= (K*( Q*sinh(K)*cosh(Q)-K*cosh(K)*sinh(Q))*(1+s*K^2)
   +p*(-4*K^2*Q*(K^2+Q^2)
       +Q*(Q^4+2*K^2*Q^2+5*K^4)*cosh(K)*cosh(Q)
       -K*(Q^4+6*K^2*Q^2+K^4)*sinh(K)*sinh(Q)))/(K^2*Q*cosh(Q)) =0 :
and we know that Q:= sqrt(K^2-I*omega); where omega is complex variable
i) How can I study and plot K vs p if Q is 1) real and 2) pure imaginary. 3) complex variable and vice versa
ii) How can I study and plot p vs s
How to display  3 figures (matrixplot(A),matrixplot(B),matrixplot(C)) in a row
plots:-matrixplot(A):
plots:-matrixplot(B):
plots:-matrixplot(C):
thanks in advance
Can anyone help me with the question? Keep getting the error. I don't know what is going on. Thank you in advance.
QUESTION_6.docx
Loading Student:-Calculus1
f := proc (x) options operator, arrow; (x-1)^2 end proc
g := proc (x) options operator, arrow; x+1 end proc
Pi*(int((f(x)-4)^2-(g(x)-4)^2, x = 0 .. 3))
(108/5)*Pi
``Error, (in plot) incorrect first argument HFloat(2.0)-HFloat(7.504824013780844e-232)*I
Download Question_6_maple.mw
matrixplot(A, style=surface,axes=normal, lightmodel=light2, labels=["n","d","C"], heights=histogram, gap=0.00000000000000000001, colorscheme=["xyzcoloring", (x,y,z)->x*y*z]);
For a matrix about 500x70. It doesn't seem that it should crap out with such a small matrix to plot. Maple seems to be slow in general even small plotting of 3D things. Specifically I'm talking about rendring and rotating.
Hi everybody:
I have an equation that attached with this question and my goal is to solve it, how can do it?
Note: in this equation must be considered 49.32883964 <= x and x is real.
solve_equation.mw
Hello all
I need to calculate the distance L in a curvefitting. The calculation has been made in MathCAD and I need to copy it in Maple, but I cant seem to make it solve.
Here are the two pictures of my problem:
In MathCAD:
In Maple:
Here is the copy of Maple:
V[Ed13] := [257.184, 230.4, 184.3, 138.2, 92.2, 46.1, 0];
x[12];
            [-149, 208, 567, 925, 1283, 1642, 2000]
L[1] := x[13];
         L[1] := [0, 358, 717, 1075, 1433, 1792, 2150]
solve(V[Rdc] = CurveFitting:-ArrayInterpolation(x[12], V[Ed13], L[1]), L[1]);
Error, invalid input: solve expects its 1st argument, eqs, to be of type {`and`, `not`, `or`, algebraic, relation(algebraic), ({list, set})({`and`, `not`, `or`, algebraic, relation(algebraic)})}, but received 153.25 = [HFloat(246.00524369747902), HFloat(211.1381615598886), HFloat(164.98435754189944), HFloat(118.92625698324022), HFloat(72.93816155988858), HFloat(26.784357541899443), HFloat(-19.315642458100548)]
Find
L[1];
Answer should be 808
Hope someone can help as I honestly have no idea how to do this :-)
Moving the sliders clean the plot.
Does any one can show me how to fix this (PS: this piece of code is a part of a procedure whose arguments are RV and SliderRanges and I need this unusual coding to make the procedure generic ... at least I guess so)
with(Statistics):
RV   := RandomVariable(Normal(a, b)):
law  := [attributes(RV)][3]:
pars := law:-Parameters;
[a, b]
SliderRanges := [-5.0..5.0, 1.0..3.0]:
[seq(pars[k]=SliderRanges[k], k=1..numelems(pars))]
[a = -5.0 .. 5.0, b = 1.0 .. 3.0]
f := PDF(RV, x);
# Explore(plot(f, x=-3..3), parameters=[seq(pars[k]=SliderRanges[k], k=1..numelems(pars))]);
(1/2)*2^(1/2)*exp(-(1/2)*(x-a)^2/b^2)/(Pi^(1/2)*b)
Download Explore_Problem.mw
I want to calculate the below triple integral numerically. I tried different methods and reduced accuracy but nothing works.
Anyone capable?
Digits := 15;
with(VectorCalculus);
v1 := <0, 0, 1>;
v2 := <sin(theta2), 0, cos(theta2)>;
v3 := <VectorCalculus:-`*`(sin(theta3), cos(phi3)), VectorCalculus:-`*`(sin(theta3), sin(phi3)), cos(theta3)>;
v1v2 := CrossProduct(v1, v2);
v2v3 := CrossProduct(v3, v2);
DotProduct(v1v2, v2v3);
(simplify(VectorCalculus:-`*`(%, VectorCalculus:-`*`(Norm(v1v2), Norm(v2v3))^VectorCalculus:-`-`(1))) assuming (0 < theta2, theta2 < Pi, 0 < theta3, theta3 < Pi));
evalf(VectorCalculus:-`*`(Int(VectorCalculus:-`*`(arccos(%), sin(theta3)), [theta2 = 0 .. Pi, theta3 = 0 .. Pi, phi3 = 0 .. VectorCalculus:-`*`(2, Pi)], epsilon = 0.001, method = _d01akc), VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(2, Pi), 2), Pi), 4), Pi)^VectorCalculus:-`-`(1)));
First 612 613 614 615 616 617 618 Last Page 614 of 2433
