Can any one find why the first code works and not the second code?
The same code, but not shown in the upload below.
reset; with(Plot)
plot(tan(x), x = -Pi .. Pi, y = -(1/2)*Pi .. (1/2)*Pi, color = ["blue"], legend = Graph*of*inverse*tan*`function"`, caption = " Domain = [-∞, ∞]; Principal range = [-π/2, π/2]")
"plot(tan^()(x),x=-Pi..Pi, y = -Pi/(2)..Pi/(2),color = ["blue"],legend = "\"inverse tan (""x"")\"", title= "Graph of inverse tan function", caption  =" Domain = [-infinity, infinity]; Principal range = [-π/2, π/2]")"
Error, invalid =
"plot(tan(x),x=-Pi..Pi, y = -Pi/2..Pi/2,color = ["blue"],legend = , title= "Graph of inverse tan function", caption  =" Domain = [-infinity, infinity]; Principal range = [-π/2, π/2]")"
Download SyntaxErrorinlegend.mw
Just a basic question, wanted to be clear.  When odeavisor returns a list of types (or classifications) of an ODE. This must mean the ODE can be of any one of these types?
For example, this ODE below, it says it is either homogeneous or rational or Abel or dAlembert.
I am asking because it can be much easier to solve an ODE if one knows if it is of one type vs. the other.
For example, for this one below, it is little easier to solve it if one sees it is Abel instead of dAelmbert.
The hard part is knowing what type of ODE one is trying to solve and so it is important to pick the right/easier type to use.
Which brings another question: When Maple is given an ODE to solve, and it can be of number of types, how does it select which type to use to solve the ODE? Since the method to solve the ODE depends on the type of the ODE. (At least, when solving it by hand it does make a big difference).
Is there any detailed document that explains more how odeadvisor determines the type of the ODE? This is a very powerful and a useful command but I can't find in help any hints on how it determines the type of ODE.
It must use some general method/algorithm to approach this problem instead of trying to match each different ODE type one by one. right?  I tried to trace the code in the debugger, but I do not fully understand the code flow.
Typesetting:-Settings(typesetprime=true):
ode:=x^2*(4*x-3*y(x))*diff(y(x),x) = (6*x^2-3*x*y(x)+2*y(x)^2)*y(x)
x^2*(4*x-3*y(x))*(diff(y(x), x)) = (6*x^2-3*x*y(x)+2*y(x)^2)*y(x)
DEtools:-odeadvisor(ode)
[[_homogeneous, `class A`], _rational, [_Abel, `2nd type`, `class C`], _dAlembert]
DEtools:-odeadvisor(ode,['dAlembert']);
DEtools:-odeadvisor(ode,['Abel']);
DEtools:-odeadvisor(ode,['homogeneous']);
[_dAlembert]
[[_Abel, `2nd type`, `class C`]]
[[_homogeneous, `class A`]]
new_ode := diff(y(x),x)=convert(solve(ode,diff(y(x),x)),parfrac); # y'= the following below. So it is Abel indeed
diff(y(x), x) = -50/27-(2/3)*y(x)^2/x^2+(1/9)*y(x)/x-(200/27)*x/(-4*x+3*y(x))
#But to solve it as dAlembert, one need to rewrite it as y=x*g(y')+f(y') and it gets messy
#becuase one has to solve for y(x) first, and this will generate more than one ODE
ode:=convert(ode,D);
map(z-> y(x)=convert(z,diff),[solve(ode,y(x))])
x^2*(4*x-3*y(x))*(D(y))(x) = (6*x^2-3*x*y(x)+2*y(x)^2)*y(x)
[y(x) = ((1/2)*(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)-2*((1/2)*(diff(y(x), x))+3/4)/(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)+1/2)*x, y(x) = (-(1/4)*(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)+((1/2)*(diff(y(x), x))+3/4)/(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)+1/2+((1/2)*I)*3^(1/2)*((1/2)*(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)+2*((1/2)*(diff(y(x), x))+3/4)/(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)))*x, y(x) = (-(1/4)*(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)+((1/2)*(diff(y(x), x))+3/4)/(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)+1/2-((1/2)*I)*3^(1/2)*((1/2)*(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)+2*((1/2)*(diff(y(x), x))+3/4)/(5*(diff(y(x), x))-5+(8*(diff(y(x), x))^3+61*(diff(y(x), x))^2+4*(diff(y(x), x))+52)^(1/2))^(1/3)))*x]
Download q1.mw
I have a simple expression  g1:=x^2+x;
Then its derivative D1:=diff(g1,x); which is 2x+1
Then I want to make a function with this derivative f1:=x->D1;
And I want to evalute this function at any point, for instance f1(3)
And what I get for f1(3) is the the derivative 2x+1 and not the value 7 as I would expect.
What am I missig?
I've got this strange error. Could anyone explain me where it comes from?
(PS My Maples's version is  Maple 2015.2, APPLE UNIVERSAL OSX, Dec 20 2015, Build ID 1097895 )
with(geometry):
RegularPolygon(gon,5,point(o,1,1),2);
gon
geometry:-RegularPolygon(gon,5,point(o,1,1),2);
Error, (in geometry:-RegularPolygon) wrong type of arguments
Download ErrorMessage.mw
Hey there.
I'm trying to fill out the entries of a matrix. Each matrix element is the result of a very complicated calculation. Currently, I am using nested do loops (two loops total) to scan through each row and column respectively. I find that this process racks up a ton of memory, and that I often run out of memory before the matrix has been completely specified (depending on how big a matrix I want).
First, why is this happening? And second, what is a smarter way to perform the calculation? I will attatch my code below.
Cheers!
MaplePrimes2MuchMemory.mw
I am studying Marine Engineer, and we are gonna work alot with vectors. I am using Maple as my mathematical software and i would like to know if you can do a simple vector addition in Maple?
I have tried to make a simple vector diagram to help understand my problem.
My vector U, is my reference vector, and my two vectors I1 and I2 are the vectors i would like to plus. I know the length of both I1 and I2, and i know the angle between I1 and U and I2 and U.
If i am using my TI-nspire, i can just type in the length and angle on both I1 and I2, to my reference vector, and then plus them together. Is this possible to do in maple?
For the vectors onmy example the result of vector additon of I1+I2 = 2.42 to an angle of 48.07 degree.
The image is just for representation and is not accurate according to the lengths and angles.
Hope someone out there can help me.
Dear Users,
I have a set of linear equations which can be presented as A(alpha,n) x(alpha)=b(alpha,n), where 'n' is the dimension of the square matric A.
For a particular value of "n" and "alpha", I can solve the unknown vector x. Further, I can differentiate Ax=b with respect to alpha to find out the rate of change of variable x with respect to alpha.
The above exercise reads, Ax'=b'-xA', which gives the unknown vector x', for a given value of alpha and n.
If I chose different values of n while fixing alpha=alpha0, the rate of change of x with alpha ( x' ) does not converge with 'n'. I noticed that x (alpha=alpha0) converges with n, also x(alpha=alpha0+ delta alpha) also converges with 'n'. I am interested in the query why x' does not converge, in spite of the fact that x converges? Any comments regarding the same are highly appreciated.
Grv
I realise this is probably a really obvious question...
I have this function:
(2^(1/3)*Pi*AiryAi(x))/(b*(a*AiryAi(x) + b*AiryBi(x)))
And I want to approximate it near to the root of the equation
a*AiryAi(x) + b*AiryBi(x)=0 (say the solution is x=x0)
The first term - I know - is a term for 1/(x-x0) for which the coefficient is
AiryAi(RootOf(AiryAi(_Z)*a + b*AiryBi(_Z)))*2^(1/3)*Pi/(b*a*AiryAi(1, RootOf(AiryAi(_Z)*a + b*AiryBi(_Z))) + b^2*AiryBi(1, RootOf(AiryAi(_Z)*a + b*AiryBi(_Z)))).
However the next term, which should be a constant, comes out as a really large term which I can't make sense of (I've included it at the bottom of this post but it is very large).
Am I doing something wrong? Because I feel that this should be easier than I'm making it.
The determined expansion was:
    (1/3)                                       2
-3 2      Pi RootOf(AiryAi(_Z) a + b AiryBi(_Z))
  AiryBi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  AiryAi(RootOf(
                                 3      (1/3)
  AiryAi(_Z) a + b AiryBi(_Z))) b  - 9 2      Pi
                                             2    2      (1/3)
  AiryAi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a b  - 9 2      Pi
  RootOf(AiryAi(_Z) a + b AiryBi(_Z))  AiryBi(RootOf(AiryAi(_Z) a
   + b AiryBi(_Z))) AiryAi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))
   2        (1/3)                                       2
  a  b - 3 2      Pi RootOf(AiryAi(_Z) a + b AiryBi(_Z))
                                             4  3      (1/3)
  AiryAi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a  - 4 2      Pi
   + b AiryBi(_Z)))
  AiryBi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  AiryAi(RootOf(
                                 3      (1/3)
  AiryAi(_Z) a + b AiryBi(_Z))) b  - 8 2      Pi RootOf(AiryAi(_Z) a
   + b AiryBi(_Z)) AiryBi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))
  AiryBi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z))) AiryAi(1,
  RootOf(AiryAi(_Z) a + b AiryBi(_Z))) AiryAi(RootOf(AiryAi(_Z) a
                       2      (1/3)
   + b AiryBi(_Z))) a b  - 4 2      Pi RootOf(AiryAi(_Z) a
  AiryAi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  AiryAi(RootOf(
                                 2        (1/3)
  AiryAi(_Z) a + b AiryBi(_Z))) a  b - 4 2      Pi RootOf(AiryAi(
                                             2    2      (1/3)
  AiryAi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a b  - 8 2      Pi
  RootOf(AiryAi(_Z) a + b AiryBi(_Z)) AiryBi(1,
                                             2  2        (1/3)
  AiryAi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a  b - 4 2      Pi
                                             2  3      (1/3)
  AiryAi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a  + 2 2      Pi
  AiryBi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  AiryBi(1,
                     3      (1/3)
   + b AiryBi(_Z))) b  + 2 2      Pi
  AiryBi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  AiryAi(1,
                       2      (1/3)
   + b AiryBi(_Z))) a b  + 4 2      Pi AiryBi(RootOf(AiryAi(_Z) a
   + b AiryBi(_Z))) AiryBi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))
                                             2    2      (1/3)
  AiryAi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a b  + 4 2      Pi
                                             2  2         (1/3)
  AiryAi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a  b + 12 2      Pi
                                        3       (1/3)
  RootOf(AiryAi(_Z) a + b AiryBi(_Z))) b  + 36 2      Pi
                                                2    2
  AiryAi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a b  + 36
   (1/3)
  2      Pi AiryBi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))
                                                3  2        (1/3)
  AiryAi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a  b + 2 2      Pi
                                             3  2
         (1/3)                                                  4
   + 12 2      Pi AiryAi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))
   3      (1/3)
  a  + 2 2      Pi AiryAi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))
                                             3  3\//
  AiryAi(RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a / \12
                                                4  4
  AiryAi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a  b + 48
  AiryAi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  AiryBi(1,
                                        3  2
  RootOf(AiryAi(_Z) a + b AiryBi(_Z))) a  b  + 72
                                                2  2  3
  AiryBi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  a  b  + 48
                                                3    4
                                                      4  5\
   + 12 AiryBi(1, RootOf(AiryAi(_Z) a + b AiryBi(_Z)))  b /
Let be given a cylinder with radius of the base circle is equal to 3 and the altitude of the cylinder is equal to 2. How can I draw square ABCD so that A, B and C, D lie on two base circles. How can I get one option of all vetices A, B, C, D ?
In my papers, I frequently use characters surmounted with a symbol, e.g., an "overbar" (used, for example, to denote a sample mean), a caret (or "hat") (used, for example, for Fourier transforms, or estimated value of a parameter), or a tilde.  Can one create surmounted symbols like this in Maple?  If so, please explain how.
I'm new to Maple, but somewhat competent in computer mathematics. Below is some code that I wrote. I start off with f, my original function, and try to simplify it. I tried defining some assumptions as best I could. When I calculate the integral, it gives me an odd range of validity.
I'm wondering if I can further add to my assumptions to make the integral result more concise, i.e. without the piecewise range of validity. All my variables in f and g are already real and positive, so there is no reason one of the expressions should be less than zero.
Thank you in advance for any insight.
 flat-geometry_recalc_Aug20_singleS.mw
f := (Pi*x+2*c+2*m)/(mu__c*S)+2*epsilon/(mu__a*S)+(Pi*x+2*c)/(mu__s*S)
g := simplify(f, symbolic)
(((Pi*x+2*c+2*m)*mu__s+2*((1/2)*Pi*x+c)*mu__c)*mu__a+2*epsilon*mu__c*mu__s)/(mu__c*S*mu__a*mu__s)
`assuming`([g], [S__s::positive]); 1; S__c::positive, S__a::positive, epsilon::positive, mu__s::positive, mu__c::positive, mu__a::positive, c::positive, m::positive
int(1/g, x = 0 .. w, AllSolutions)
`assuming`([int(1/g, x = 0 .. w)], [0 < w])
piecewise(And((c*mu__a*mu__c+c*mu__a*mu__s+epsilon*mu__c*mu__s+m*mu__a*mu__s)/(mu__a*(mu__c+mu__s)) < 0, -2*(c*mu__a*mu__c+c*mu__a*mu__s+epsilon*mu__c*mu__s+m*mu__a*mu__s)/(Pi*mu__a*(mu__c+mu__s)) < w), undefined, mu__s*S*mu__c*(-ln(2)-ln(c*mu__a*mu__c+c*mu__a*mu__s+epsilon*mu__c*mu__s+m*mu__a*mu__s)+ln(Pi*mu__a*mu__c*w+Pi*mu__a*mu__s*w+2*c*mu__a*mu__c+2*c*mu__a*mu__s+2*epsilon*mu__c*mu__s+2*m*mu__a*mu__s))/(Pi*(mu__c+mu__s)))``
Download flat-geometry_recalc_Aug20_singleS.mw
I want to insert the symbol ( infinity) in my graph, but I did not succeed . ideas? Thank you
TickmarkQuestion.mw
I am providing analysis for a Graph I have made using the GraphTheory kit. I am attempting to find a way to find the Betweeness Centrality. So far I have only found one example of the code which is being used to find the Betweeness Centrality of a Network found in a pdf (Attatched below). I have been able to alter the code accordingly to my data but the last line requires some further understanding of how Matrices work in Maple. This is the line I fail to understand completely:
"""""""" BetweenessCentrality_data := < node_data[1.., 1] | < seq(add (ad_mat[i, j] * wt_mat[i, j], j = 1.. num_characters), i = 1. . num_characters)> >: BetweenessCentrality_sorted := FlipDimension( x[2])))>, 1)  """"""""
And this is all the code leading up to the line in question:
"""""""" data := FileTools:-JoinPath(["Excel", "Inter station database (2).xls"], base = datadir);
M := ExcelTools:-Import(data, "Hoja2");
edge_data := Matrix(727, 3, (i, j) --> M[i, j+2] );
with(ListTools);
node_data := Matrix(727, 2, (i, j) -->M[i, j+2] );
convert(Matrix(<<node_data>>), list);
listednode_data := convert(Matrix(<<node_data>>), list);
MakeUnique(listednode_data);
UniqueListedNode_data := MakeUnique(listednode_data);
node_data := Matrix(numelems(UniqueListedNode_data), 1, (i, j) -->UniqueListedNode_data[i]);
num_edges := RowDimension(edge_data);
num_characters := RowDimension(node_data);
G := Graph(node_data[() .. (), 1], weighted);
for i from 1 to num_edges do
AddEdge(G, [{edge_data[i, 1], edge_data[i, 2]}, edge_data[i, 3]])
wt_mat := WeightMatrix(G);
ad_mat := AdjacencyMatrix(G); """"""""
To provide further context, my graph is strongly connected.
If anyone could kindly provide a breakdown of the line of code in question, It would be very appreciated.
Here is the link to the pdf I used as source for my code:https://www.maplesoft.com/applications/view.aspx?SID=154530
Hi MaplePrimes,
I'm trying to explore the polynomial r = n^2+n+39.  where n is an integer
I want restrictions on n such that r will factor into two trinomials.
Here is how far I got -
prime_poly_39_explore.mw
The 'has' function may be helpful.
Any help is appreciated.
Matt
I was wondering whether anyone could help me. I am trying to plot a large number of functions on the same graph and am struggling with a way of inputting this without having to manually enter each.
Basically, I have a for do loop that runs from i being 0 to n. Within the loop, it takes a[i] = some function of my variables so in essence I have n functions that I would like to plot on the same graph. Currently I'm working with a low number for n to make sure that the code is running how I want it to, however I'm looking to increase my n number significantly which will obviously mean I have a significant number of functions.
I am using:
plot3d({a[0], a[1], a[2], a[3], a[4], a[5], a[6], a[7], a[8], a[9], a[10], a[11], a[12], a[13], a[14], a[15], a[16], a[17], a[18], a[19], a[20]}, z = 0 .. m, x = -M .. M, lightmodel = none, orientation = [180, 0, 180], style = surfacecontour, shading = zhue)
to plot my functions however I don't want to have write out each of the a[ ] when increasing this n value. So I was wondering whether anyone has any ideas how to write this in a shorter form?
I hope that makes sense and any help would be greatly appreciated.
First 658 659 660 661 662 663 664 Last Page 660 of 2433
