Is there any way to automatically create a legend for a plot of a list of functions? The problem is, I'd rather not specify the legend and maple require the exact number so I cannot specify a generic length such as [1,2,3,4,5,6,7,8].
plot([f1(x), f2(x), f3(x), sin(x)*cos(x)*sin(3x^2 + cos(x))], x=1..34)
The point is that I do not want or care what the legend is(except the names shouldn't be long). I just want to be able to use it to select the plots easily and to be able to reference them(so the naming matters in that the order shoudl be obvious).
Sorry for bad english.
Hello. I can not realize such a thing. There is an equal tetrahedron NET on the plane. Choose a point on the edge and start a vector from it (the sum of red vectors with some integer coefficients). We obtain a closed geodesic. Depending on the coefficients, the geodesic will intersect the edges and faces in a different sequence. How to unNET into tetrahedron and so that the geodesic is displayed on it? Thank you in advance.
When I try to get a higher resolution plot using numpoints, the lines are jagged and look lower resolution.
plot(sin(x),x=-10..10,numpoints=3000,resolution=10000)plot(sin(x),x=-10..10,numpoints=400,resolution=10000)
You can see the difference, the first does not look anti-aliased whil ethe second does(although the 2nd looks far better on my comp)
A way to define a N *N matrix with the help of loop
with(inttrans):
sinc := x->piecewise(x = 0, 1, sin(Pi*x)/x/Pi):
S := x->sinc(x):
SE := x->sinc(x)*exp(-x^2):
plot(abs(fourier(SE(x),x,s)),s=0..5)
works fine for S but when trying to plot SE I get
I simply want to plot the fourier transform of a function so I can see it's frequency response. Maple seems to be breaking for more complex functions. It seems to be doing this when it can't evaluate the function exactly, which I don't care for plots.
Let s_n be the number of ternary strings (of 0s, 1s and 2s) of length n that have no
adjacent even digits.
For example, s_0 = 1 (the empty string),
s1 = 3 (the strings 0, 1 and 2),
while s2 = 5:  01; 10; 11; 12; 21;
We can compute by hand  Find s3; and we obtain 11
My question how can use maple to get a general recurrence relation for s_n.
many think for your help
Give the following functions find Domain, Range, Possible Asymptotes, Intercepts, Critical Points, Intervals of Increase, Decrease, Relative and Absolute Extrema, and Concavity.
A) f(x)=x(x^2-6x+8)
B) f(x) =x^3/4 -3x
After two days of trying to take the Jacobian of a multi-variable mapping in Maple, I'm still finding no way. Here is an example of what I mean by "multi-variable mapping":
(x,y) -> x^2-y^2
Every AP high-school student knows how to take the partial derivatives of that, but Maple's "Jacobian" feature doesn't work on mappings. It only works on expressions.
So I spent today trying to leverage off the "D" feature, only to find it rendered useless by bugs: https://mapleprimes.com/questions/227007-How-To-Take-Partial-Derivative-Of-A-Mapping
It took me less than two days to do it in Mathematica, by way of comparison.
On the website, they show a photo of a man elated to be doing math in Maple, but that's not how it's gone for me. I'm cursing outloud, and my blood pressure is high. I'm angry that I lost money on a product that can't take the Jacobian of a mapping, and I'm angry that I lost two days of my life doing tedious debugging while paying money instead of getting paid for my work.
Maple pays math PhD's to release a commercial CAS that can't take the Jacobian of a mapping. So much for the value of a PhD.
I need to find the intersection of 3 planes.
x+3*y-5*z=0
x+4*y-8*z=0
-2*x-7*y+13*z=0
I managed to get the intersection using LinearSolve but I keep getting an error when I try to plot out the planes using plot3d. What can I change in the commands for it to work?
with(LinearAlgebra)
[`&x`, Add, Adjoint, BackwardSubstitute, BandMatrix, Basis, BezoutMatrix, BidiagonalForm, BilinearForm, CARE, CharacteristicMatrix, CharacteristicPolynomial, Column, ColumnDimension, ColumnOperation, ColumnSpace, CompanionMatrix, CompressedSparseForm, ConditionNumber, ConstantMatrix, ConstantVector, Copy, CreatePermutation, CrossProduct, DARE, DeleteColumn, DeleteRow, Determinant, Diagonal, DiagonalMatrix, Dimension, Dimensions, DotProduct, EigenConditionNumbers, Eigenvalues, Eigenvectors, Equal, ForwardSubstitute, FrobeniusForm, FromCompressedSparseForm, FromSplitForm, GaussianElimination, GenerateEquations, GenerateMatrix, Generic, GetResultDataType, GetResultShape, GivensRotationMatrix, GramSchmidt, HankelMatrix, HermiteForm, HermitianTranspose, HessenbergForm, HilbertMatrix, HouseholderMatrix, IdentityMatrix, IntersectionBasis, IsDefinite, IsOrthogonal, IsSimilar, IsUnitary, JordanBlockMatrix, JordanForm, KroneckerProduct, LA_Main, LUDecomposition, LeastSquares, LinearSolve, LyapunovSolve, Map, Map2, MatrixAdd, MatrixExponential, MatrixFunction, MatrixInverse, MatrixMatrixMultiply, MatrixNorm, MatrixPower, MatrixScalarMultiply, MatrixVectorMultiply, MinimalPolynomial, Minor, Modular, Multiply, NoUserValue, Norm, Normalize, NullSpace, OuterProductMatrix, Permanent, Pivot, PopovForm, ProjectionMatrix, QRDecomposition, RandomMatrix, RandomVector, Rank, RationalCanonicalForm, ReducedRowEchelonForm, Row, RowDimension, RowOperation, RowSpace, ScalarMatrix, ScalarMultiply, ScalarVector, SchurForm, SingularValues, SmithForm, SplitForm, StronglyConnectedBlocks, SubMatrix, SubVector, SumBasis, SylvesterMatrix, SylvesterSolve, ToeplitzMatrix, Trace, Transpose, TridiagonalForm, UnitVector, VandermondeMatrix, VectorAdd, VectorAngle, VectorMatrixMultiply, VectorNorm, VectorScalarMultiply, ZeroMatrix, ZeroVector, Zip]
A := `<|>`(`<,>`(1, 1, -2), `<,>`(3, 4, -7), `<,>`(-5, -8, 13))
Matrix(%id = 18446745896624469046)
b := `<,>`(0, 0, 0)
Vector[column](%id = 18446745896624462294)
x := LinearSolve(A, b)
Vector[column](%id = 18446745896652349678)
P1 := x+3*y
P2 := x+4*y
P3 := -2*x-7*y
plot3d([P1, P2, P3], x = -8 .. 8, y = -20 .. 20, plotlist = true, color = [blue, red, green])
Error, (in plot3d) unexpected options: [(Vector(3, {(1) = -4*_t[3], (2) = 3*_t[3], (3) = _t[3]})) = -8 .. 8, y = -20 .. 20]
Download problem.mw
Here's how to break Maple's 'D' function:
~$ cmaple mapleBug.mpl
    |\^/|     Maple 2018 (X86 64 WINDOWS)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2018
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
> D[1]((x, y) ->x^2-y^2);
                                 (x, y) -> 2 x
> D[2]((x, y) ->x^2-y^2);
                                 (x, y) -> -2 y
> with(VectorCalculus):
> assume(x, 'real');
> assume(y, 'real');
                                  (x, y) -> 0
                                  (x, y) -> 0
> quit
memory used=2.4MB, alloc=8.3MB, time=0.06
What if a person needs to have these lines:
> assume(x, 'real');
> assume(y, 'real');
and then he wants to take partial derivatives? Not possible? Once you load VectorCalculus and declare x and y real, Maple stops doing partial derivatives? Why.
Sorry,
I have been away from Maple for a year.
Then, when I used op command, I am puzzed to notice the results were different from those I know.
>op((x+5)^2*(x+y));
      _EXPSEQ((x+5)^2, x+y)
Result I know is
        (x+5)^2, x+y
Has a modifire such as _EXPSEQ   automatically come to be attatched?
Or, can I have maple express it  in the form I know:  (x+5)^2, x+y?
taro
A mathematical friend wrote to me recently with the following problem:
a + b + c = 1
a² + b² + c² = 2
a³ + b³ + c³ = 3
Find the values of  a^4 + b^4 + c^4 and a^5 + b^5 + c^5.
Note the question doesn’t ask for the values of a, b and c, but can you find them?
Hi all, I would be most grateful if I could get some help with solving the tasks below using Maple.
Given the function: mx''(t)+cx'(t)+kx(t)= F_y(t)
  1. Rewrite the equation above to a system of 1. order differential equations, by defining the two variables x_1(t) = x(t) and x_2(t)=x'(t) (Hint what is x'(t)?) This gives the first differential equation in the system. What is x_2'(t)?
  2. Write the equations as a linear system when the outer force F_y(t) is the influence and the position x_1(t) is the answer, in other words give the system matrix A and the vectors b and r.
  3. I'm given the constants m = 5kg, c = 3Ns/m and k = 20 N/m and I'm trying to find the transfer function of the system.
  4. Give the systems transfer function H(s) and draw the graphs for the amplitude and phase characteristic.
I have triangle TAD. Now I want to take any point inside the triagle TAD. How can I take it? I tried
A := [1, 2, 3];
DD := [-2, 1, 0];
T := [1/2, 1/2, 3/2];
P := Plane(T, A, DD);
GetRepresentation(P)
I got the quation of the plane TAD is
-3*x-3*y+4*z = 3
With the point P(x,y,z). What is the condition of x, y, z?
Given the following functions and respective intervals graph them and determine all values of in the interval (a,b) such that
f'(c) =f(b)-f(a)/b-a (apply the Mean Value Theorem)
 Question 1: f(x)=x^3-2*x      [0,2]
 Question 2 : g(x)= cuberoot(x-3)^2     [-3,4]
Please HELP!!!
First 698 699 700 701 702 703 704 Last Page 700 of 2433
