For what its worth,
I want to make a graph of data.
Attached is file to show how far I got.
multiplication_table_list_to_graph.mw
multiplication_table_list_to_graph.pdf
Matthew
Gretting from me. I am Md. Abubakar Siddik from Bangladesh.
I have 20 equations  and 20 variables for a system. I want to solve it numerically
Any advice ?
system_equation.mw
Thank you in advance for your cooperation. I look forward to hearing from you.
I read a string from file which contains a sequence of Maple commands, all in one string. The commands are separated by ";" in the string. I need to then evaluate all the commands in the string as if I typed them one after the other.
Here is an example
data:="x:='x';y:='y';sol:=dsolve(diff(y(x),x)=1,y(x));"; #read from database
parse(data);
Warning, extra characters at end of parsed string
x := 'x'
I want the result to parse to be as if I typed
x:='x';
y:='y';
I looked at help in parse page, but I do not see what I need to do. It says that
If the option 'statement' is specified, the string must consist of exactly one Maple statement (which includes expressions). The statement is parsed and evaluated, and the result is returned.
But I am not using the statment option. I also tried using this option, no change, same problem.
Is there a way to prase such a string?
  SALUT,
J'ai exécuté la procédure suivante, afin de tracer une courbe (Bézier), mon objectif final est de construire "à l'aide de Maple" une théière (avec des révolutions et des rotations certainement), y at-il des suggestions?
The conditional trigger in the code below does not cause a halt although odeplot shows x dipping to a value below 2.
What is the correct coding of this event to cause a halt when x becomes less than 2?
Does any Maple documentation show examples of working discrete events with conditional triggers?
DE1 := diff(x(t), t, t) = -x(t)-(diff(x(t), t))+y(t);
DE2 := diff(y(t), t, t) = y(t)-(diff(y(t), t))+x(t);
ICs := x(0) = 2, (D(x))(0) = 1, y(0) = 0, (D(y))(0) = 1;
sol1 := dsolve({DE1, DE2, ICs}, {x(t), y(t)}, numeric, event_initial = true, events = [[[0, x(t) < 2], halt]]);
plots:-odeplot(sol1, [t, x(t)], t = 0 .. 3);
In the following case evalhf Int not working. Please help
evalhf.mw
In two lines below Command1 and Command2 have the same value
Command1 := subs([a=1, b=2], a*x+b);
Command2 := eval(a*x+b, [a=1, b=2]);
Are there pros and cons of using one over the other?
I have the following equation
diff(m(t, x), t)+diff((u(t, x)^2-(diff(u(t, x), x))^2)*m(t, x), x) = 0
How I can change it by using this transform
m(t,x)=u(t,x)-diff(u(t, x), x,x)
to get a new PDE only with u(t,x)
then I need to change u(t,x) by
u(t,x)=u(y)
where y=x−at
How I can do this in Maple?
Hello everyone!
I am struggling to figure out the cause of the problem with Explore command. To put it as simple as possible:
 a := <3, 4, 5>
Explore(a[i], i = 1 .. 3);
Error, (in Explore) bad index into Vector
I am pretty sure that this has to do with an attempt to evaluate A[i] with i not yet defined, but why does Explore behave this way? seq has no such problem:
seq(a[i], i = 1 .. 3);
3, 4, 5
But as soon as I put it into Explore, seq seems to forget all its "special evaluation rules":
Explore(seq(a[i], i = 1 .. 3), b = 1 .. 2);
It is probably for the same reason that I can't solve the problem with unevaluation quotes such as:
Explore('a[i]', i = 1 .. 3);
What am I doing wrong??
How to find characterstics for the PDE  yzp+2xq=xy  using maple.....plz help me
I am trying to  solve the system of equations
with(RealDomain);
solve(x^2+y^2+z^2-4*x+6*y-2*z-11 = 0, 2*x+2*y-z = -18], [x, y, z]);
I didn't get the result x = - 4/3, y = -19/3, z = 8/3.
How can I get the solution?
With Mathematica, I tried
Solve[{x^2 + y^2 + z^2 - 4*x + 6*y - 2*z - 11 == 0,
  2*x + 2*y - z == -18}, {x, y, z}, Reals]
And got the correct solution.
How to plot the solution of pde
pde:=diff(u(x,t),t) =K*diff(u(x,t),x, x);
I can't step further,  i can't insert boundary value problem, plz help me to solve pde.
Hear u(x,t)->infinity  when t->infinity  and diff(u(x,t),x) =0 when x=0 for all t
Please ignore my mistake,
If I have a procedure that for example produces a list of times it takes to work out the eigenvectors of a random nxn matrix from n=2..9.
Times:=[seq([n,time(LinearAlgebra[Eigenvectors](RandomMatrix(n)))],n=2..9)]:
If I want to make my data more accurate so that it works out the time it takes to find the eigenvector for each different sized matrix multiple times and then takes an average time (for each n), how would I do that?
Hi I'm trying to make a procedure that will multiply all the diagonal entries of any random matrix together, this is what I have tried so far:
with(ListTools):
Diag := proc(A)
local aux,V,i,n;
V:=[];
n:=RowDimension(A):
for i from 1 to n do
aux := 1;
aux := aux*U2(i,i);
but this just produces the last diagoinal entry of the matrix - how do I make the loop multiply the previous number by the next diagonal entry?
another option I've done is to make a list of the diagonal entries, but then I encounter the same problem with multiplication:
Diag:=proc(A)
local n, List;
n:=RowDimension(A);
List:=[seq(A(i,i),i=1..n)]:
any help would be greatly appreciated!
I need to convert a maple code into a clickable user interface one. How to do it?. Thank you.
First 712 713 714 715 716 717 718 Last Page 714 of 2433
