Hello, is it possible to have a document synchronized in the same way as Onenote? We're a group of engieneer students wanting to share documents, however the only way we can figure out a way to do it. Is uploading to maplecloud groups, sharing a "base" document, and everytime someone "updates" the document you save a new one. So it kind of defeats the purpose of making it a smart idea of collaborating on one document, am i missing something or is this really how oldschool it works?
     I'm trying to simplify an expression involving signum and sqrt using assumptions:
assumptions := { A>0,psi::real,1+A*cos(psi)<sqrt(1+sin(psi)),1+sin(psi)>0 }:
signum(1+A*cos(psi)-sqrt(1+sin(psi))):
simplify(%) assuming op(assumptions);
It seems to me that, given these assumptions, we can safely conclude that the result should be -1. However, I can't get Maple to show this. Interestingly, setting A=1 does allow maple to simplify the result to -1. Is there something I'm missing?
I recently corresponded with maplesoft on whether the program Groebner:-Basis always produces reduced Groebner bases or not. They say it does. This mw appears to show it producing a non reduced Groebner Basis for a set of polynomials.
More specifically, the coefficient of the lead term of the first polynomial generated is not 1.
I'd like to be shown wrong here, but I am struggling to see what i could be doing wrong.
alias(epsilon = e, omega = w, omega[0] = w0, t[1] = t1, t[2] = t2, alpha[1] = a1, alpha[2] = a2, alpha[3] = a3); e := proc (t1, t2) options operator, arrow; e end proc; w0 := proc (t1, t2) options operator, arrow; w0 end proc; f := proc (t1, t2) options operator, arrow; f end proc; mu := proc (t1, t2) options operator, arrow; mu end proc
ode := (D@@2)(u)+u+e*a1*D(u)+e*a2*u^3-f0*cos(omega*t) = 0
(D@@2)(u)+u+epsilon*alpha[1]*D(u)+epsilon*alpha[2]*u^3-f0*cos(omega*t) = 0
e_oredr := 1:
ode := subs(D = sum('e^(i-1)*D[i]', 'i' = 1 .. e_oredr+1), ode);
((epsilon*D[2]+D[1])@@2)(u)+u+epsilon*alpha[1]*(epsilon*D[2]+D[1])(u)+epsilon*alpha[2]*u^3-f0*cos(omega*t) = 0
u := sum('q[i]*e^i', 'i' = 0 .. e_oredr);
q[1]*epsilon+q[0]
ode := collect(ode, e):
ode:=simplify(%,{e^3=0,e^2=0});
-f0*cos(omega*t)+D[1, 1](q[1])*epsilon+D[1, 1](q[0])+2*D[1, 2](q[0])*epsilon+D[1](q[0])*alpha[1]*epsilon+(alpha[2]*q[0]^3+q[1])*epsilon+q[0] = 0
for i from 0 to e_oredr do eq[i] := coeff(lhs(ode), e, i) = 0 end do;
-f0*cos(omega*t)+D[1, 1](q[0])+q[0] = 0
alpha[2]*q[0]^3+alpha[1]*D[1](q[0])+2*D[1, 2](q[0])+D[1, 1](q[1])+q[1] = 0
eq[1]:=convert(eq[1](t1, t2), diff);
alpha[2](t[1], t[2])*q[0](t[1], t[2])^3+alpha[1](t[1], t[2])*(diff(q[0](t[1], t[2]), t[1]))+2*(diff(diff(q[0](t[1], t[2]), t[1]), t[2]))+diff(diff(q[1](t[1], t[2]), t[1]), t[1])+q[1](t[1], t[2]) = 0
q[0] :=A(t2)*exp(I*t1)+b*exp(I*w*t1)+conjugate(A)(t2)*exp(-I*t1)+b*exp(-I*w*t1); convert(%, 'exp'); q[0] := unapply(%, (t1, t2)):  # Chage the value
A(t[2])*exp(I*t[1])+b*exp(I*omega*t[1])+(conjugate(A))(t[2])*exp(-I*t[1])+b*exp(-I*omega*t[1])
expand(lhs(eq[1])):
eq:=combine(%, exp):
eq:=simplify(%, power):
eq:=combine(subs(w=1/3+e*sigma,%),exp):   ## substituting the detuning parameter
expand(%):
eq:=algsubs(t1*e=t2,%):
eq:=collect(%, exp(I*t1)):
coeff(%, exp(I*t1),1):
simplify(combine(%,exp));
exp((3*I)*sigma*t[2])*alpha[2](t[1], t[2])*b^3+3*alpha[2](t[1], t[2])*A(t[2])^2*(conjugate(A))(t[2])+6*alpha[2](t[1], t[2])*b^2*A(t[2])+I*A(t[2])*alpha[1](t[1], t[2])+(2*I)*(diff(A(t[2]), t[2]))
subs({A(t2)=a(t2)*exp(I*beta(t2))/2,conjugate(A)(t2)=a(t2)*exp(-I*beta(t2))/2},%);
exp((3*I)*sigma*t[2])*alpha[2](t[1], t[2])*b^3+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3*(exp(I*beta(t[2])))^2*exp(-I*beta(t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])*exp(I*beta(t[2]))+((1/2)*I)*a(t[2])*exp(I*beta(t[2]))*alpha[1](t[1], t[2])+(2*I)*(diff((1/2)*a(t[2])*exp(I*beta(t[2])), t[2]))
combine(%,exp);
exp((3*I)*sigma*t[2])*alpha[2](t[1], t[2])*b^3+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3*exp(I*beta(t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])*exp(I*beta(t[2]))+((1/2)*I)*a(t[2])*exp(I*beta(t[2]))*alpha[1](t[1], t[2])+(2*I)*((1/2)*(diff(a(t[2]), t[2]))*exp(I*beta(t[2]))+((1/2)*I)*a(t[2])*(diff(beta(t[2]), t[2]))*exp(I*beta(t[2])))
map(x->x*exp(-I*beta(t2)),%);
exp((3*I)*sigma*t[2])*alpha[2](t[1], t[2])*b^3*exp(-I*beta(t[2]))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3*exp(I*beta(t[2]))*exp(-I*beta(t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])*exp(I*beta(t[2]))*exp(-I*beta(t[2]))+((1/2)*I)*a(t[2])*exp(I*beta(t[2]))*alpha[1](t[1], t[2])*exp(-I*beta(t[2]))+(2*I)*((1/2)*(diff(a(t[2]), t[2]))*exp(I*beta(t[2]))+((1/2)*I)*a(t[2])*(diff(beta(t[2]), t[2]))*exp(I*beta(t[2])))*exp(-I*beta(t[2]))
simplify(%,exp);
alpha[2](t[1], t[2])*b^3*exp(-I*(-3*sigma*t[2]+beta(t[2])))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3-a(t[2])*(diff(beta(t[2]), t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])+((1/2)*I)*a(t[2])*alpha[1](t[1], t[2])+I*(diff(a(t[2]), t[2]))
subs({3*sigma*t2-beta(t2)=C(t2),beta(t2)=3*sigma*t2-C(t2)},%);
alpha[2](t[1], t[2])*b^3*exp(I*C(t[2]))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3-a(t[2])*(diff(3*sigma*t[2]-C(t[2]), t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])+((1/2)*I)*a(t[2])*alpha[1](t[1], t[2])+I*(diff(a(t[2]), t[2]))
convert(%,trig);
alpha[2](t[1], t[2])*b^3*(cos(C(t[2]))+I*sin(C(t[2])))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3-a(t[2])*(3*sigma-(diff(C(t[2]), t[2])))+3*alpha[2](t[1], t[2])*b^2*a(t[2])+((1/2)*I)*a(t[2])*alpha[1](t[1], t[2])+I*(diff(a(t[2]), t[2]))
(14)
cond1 := collect(coeff(%, I, 0), [diff(C(t2), t2), cos(C(t2))]);
a(t[2])*(diff(C(t[2]), t[2]))+alpha[2](t[1], t[2])*b^3*cos(C(t[2]))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3-3*a(t[2])*sigma+3*alpha[2](t[1], t[2])*b^2*a(t[2])
(15)
cond2 := collect(coeff(%%, I, 1), [diff(A(t2), t2), sin(C(t2))]);
alpha[2](t[1], t[2])*b^3*sin(C(t[2]))+(1/2)*a(t[2])*alpha[1](t[1], t[2])+diff(a(t[2]), t[2])
(16)
a(t2):= a; C(t2):=C; cond1 = 0; cond2 =0;
a
C
alpha[2](t[1], t[2])*b^3*cos(C)+(3/8)*alpha[2](t[1], t[2])*a^3-3*a*sigma+3*alpha[2](t[1], t[2])*b^2*a = 0
alpha[2](t[1], t[2])*b^3*sin(C)+(1/2)*a*alpha[1](t[1], t[2]) = 0
(17)
alpha[1]:=unapply(alpha[1],[t1,t2]);alpha[2]:=unapply(alpha[2],[t1,t2]);
proc (t1, t2) options operator, arrow; alpha[1] end proc
proc (t1, t2) options operator, arrow; alpha[2] end proc
(18)
remove(has, cond1, cos)^2+remove(has, cond2, sin)^2 = select(has, cond1, cos)^2+select(has, cond2, sin)^2;
((3/8)*alpha[2]*a^3-3*a*sigma+3*alpha[2]*b^2*a)^2+(1/4)*a^2*alpha[1]^2 = alpha[2]^2*b^6*cos(C)^2+alpha[2]^2*b^6*sin(C)^2
(19)
simplify(%,'trig');
(9/64)*a^2*(a^2*alpha[2]+8*alpha[2]*b^2-8*sigma)^2+(1/4)*a^2*alpha[1]^2 = alpha[2]^2*b^6
(20)
af_eq:=%;
(21)
b:=0.5*f0/(1-(1/3)^2);
.5625000000*f0
(22)
with(plots, implicitplot):
 f0 :=1; alpha[1]:=0.0087;alpha[2]:=2.5871;   b:=0.5*f0/(1-(1/3)^2);#change the value
0.87e-2
2.5871
.5625000000
(23)
af_eq;
curve1,curve2:=solve(af_eq, sigma):
A0:=2:
(9/64)*a^2*(2.5871*a^2-8*sigma+6.548596875)^2+0.1892250000e-4*a^2 = .2120125612
(24)
pu1:=implicitplot([sigma=curve2,sigma=curve1],sigma =-5..20, a = 0 .. A0,  numpoints = 200000, axes = box, axesfont=[SYMBOL, 14],labels = [sigma, a], labelfont = [SYMBOL, 16],color="red",tickmarks=[9,12],thickness=3,'view' = [-5 .. 20, 0 .. 6]):
pu2:=implicitplot([sigma=curve2,sigma=curve1],sigma =-5..20, a = A0 .. 10,linestyle=[1,3],  numpoints = 20000, axes = box, axesfont=[SYMBOL, 14],labels = [sigma, a], labelfont = [SYMBOL, 16],color="red",tickmarks=[9,12],thickness=3,'view' = [-5 .. 20, 0 .. 6]):
A0:=-2:
pu3:=implicitplot([sigma=curve2,sigma=curve1],sigma =-5..20, a = -10 .. A0, linestyle=[3,1], numpoints = 200000, axes = box, axesfont=[SYMBOL, 14],labels = [sigma, a], labelfont = [SYMBOL, 16],color="red",tickmarks=[9,12],thickness=3,'view' = [-5 .. 20, -6 .. 0]):
pu4:=implicitplot([sigma=curve2,sigma=curve1],sigma =-5..20, a = A0 .. 0,  numpoints = 20000, axes = box, axesfont=[SYMBOL, 14],labels = [sigma, a], labelfont = [SYMBOL, 16],color="red",tickmarks=[9,12],thickness=3,'view' = [-5 .. 20, -6 .. 0]):
pp1:=display([pu1,pu2,pu3,pu4]);
(25)
How can I merge these pictures into one
Like this one
Download merege_two_diagram.mw
I was wondering how Maple cope with piecewise functions during forward integration and if it's preferable to use dsolve events option in place of defining a piecewise discontinuos function.
As far as I understood dsolve/events halts the integration each time an event is triggered and subsequently restarts the integration using the pre-trigger outputs as new initial conditions. I suppose that by using a piecewise, if a discontinuity is detected, dsolve proceeds exactly in the same way halting and restarting the integration.
Here a toy example of a 2D rolling dice (idea of a rolling dice from the rolling cube by @one man :P ) in which the reaction forces of the floor can be seen as function of the compenetration dice/ground
Both the appraches (events and piecewise) give the same results
falling_dice.mw
First, I want to say thank you to all who contributed to previous questions. God bless you.
I need Maple code in solving first order differential equation using Langrange and Newton's Interpolation Method.
The aim is to compare these two numerical result with the exact in tabular form and also to plot the graph.
Some questions are attached.
ODE_Questions.pdf
I have to take limit of the HeunG function at infinity.
Here is what I tried
This is clearly not working. I have to take limit of a function which consist multiple HeunG functions at infinities.
how do I make second power of integers in a list?
e. g.: L1:=[-3,-2,-1,0,1,2,3]
and i want
L2:=[9,4,1,0,1,4,9]
I am trying to solve a second order differential equation but getting error. The differential equation valid for r>0.
Vr.mw
Hi, I'm quite a beginner in Maple.
Currently, I'm solving several complex ODE using maple. When I run the code, it gives me some results. However, when I re-run the code using exactly the same equations and parameter, I somehow got completely different results. Using the same input sometimes it gives float(undefined), complex number, or real number.
Could anyone explain what's happening here? Does it mean that my set of ODE is not independent of each other?
Any helps would be greatly appreciated.
I have two lists, A and B, with the same number of elements and I want A to be on the Y-axis and B on the X-axes and do a point plot
I am making calculations on a block matrix of the form Matrix([[A,B],[-B,-A]])
with A real and symmetric and B real and antisymmetric. (For the physics savvy, this is the Bogoliubov-de Gennes form of the coefficient matrix for doing calculations.)
But this says if I have an eigenvector of the form (u,v) with eigenvalue E, then there is another eigenvector (v,u) with eigenvalue -E.
Now, my problem.. I have a problem that has two zero eigenvalues, but the numerical solver is giving one as zero and one as just very small. This is problematic because my eigenvectors don't have the symmetry that they should. For the non-zero eigenvectors, the error is small and doesn't matter so much. But the eigenvector corresponding to the zero eigenvalues are not guaranteed to be close.
Is there a way to demand my eigenvalues come in pairs for my matrices? Something that dependings on A,B being even or odd dimensional is fine. I care more about the symmetry than even/oddness.
When I use the Groebner package I normally use it something like this:
with(Groebner):
F≔[x3−3xy,x2y−2y2+x]
Basis(F,plex(x,y))
Does this calculate a reduced Groebner basis or just a Groebner basis? The output looks reduced to me, and I'm sure that I've seen people treat it is as a reduced GB; but the help page doesn't confirm this. Interestingly i can't seem to find any other mention of reduced bases in the help documentation - which makes me think that this method does it (because otherwise people would want a seperate algorithm specifically for getting reduced GBs)
How do I simulate the mathematical model of infectious disease using MapleSm? Is it possible? because I had search through the tool in MapleSim is full of engineering tools.
We know that Grid:-Map(x->f(x),[x1..xn]) is for parallel computing f(xi)'s but when some xi's are equal I think Maple copies one result for the others. But maybe my function f has some random sampling inside and so will have different output for same inputs. So I need to do parallel computations for same inputs without cheating of copying the result of one for the rest. For a very simple case that Maple copies while it is wrong to copy, see the following.
I will be happy if someone tells me how to solve this issue. Thanks.
More surprising to me is that if I try to use different xi's and then typing same xi's, I will see some new patterns of copying.
For example in output (3) and (4), first random point of one parallel computation is the second random point of another computation. Or in output (6) only the two last computations are copy of each other!
I may need to add that I did this computations on a computer with 4 core processor. Is Maple producing random numbers using something like processor's time? Or something like this?
I can't report Maple computations if they don't really produce random points independently in seperate parallel computations.
First 786 787 788 789 790 791 792 Last Page 788 of 2433
