      I've run into a strange problem with pdsolve. I'm attempting to solve a small PDE system. It seems pdsolve is quite capable of handling it, as it will occasionally return a valid answer. However, equally often, it returns a NULL result. And this is without changing anything else in the code: consecutive runs randomly produce a valid or NULL result.
      The only possible explanation I have is that, since this is a part of a larger code (~2k lines), perhaps something is going on with memory management? This is being run on a server (24 cores, 50GB RAM), so the total memory usage never rises above 0.5%. The cpu usage does hover around 100%-105% of a single core, but I doubt that's a problem. I've tried increasing stacklimit, processlimit, and cacheclearlimit, but it didn't seem to help.
      So, my question is, what sort of debugging or testing can I try? Are there any standard "tricks" to use here?
restart; Digits := 7; r := 2.5; Q := proc (n) options operator, arrow; int(simplify(1/(x*r^2*cos(x-y)+z*r^2*sin(z-y))^n, symbolic), y = 0 .. Pi) end proc; HH := eval(Q(5))
int(0.1048576e-3/(x^5*cos(x-1.*y)^5-5.*x^4*cos(x-1.*y)^4*z*sin(-1.*z+y)+10.*x^3*cos(x-1.*y)^3*z^2-10.*x^3*cos(x-1.*y)^3*z^2*cos(-1.*z+y)^2-10.*x^2*cos(x-1.*y)^2*z^3*sin(-1.*z+y)+10.*x^2*cos(x-1.*y)^2*z^3*sin(-1.*z+y)*cos(-1.*z+y)^2+5.*x*cos(x-1.*y)*z^4-10.*x*cos(x-1.*y)*z^4*cos(-1.*z+y)^2+5.*x*cos(x-1.*y)*z^4*cos(-1.*z+y)^4-1.*z^5*sin(-1.*z+y)+2.*z^5*sin(-1.*z+y)*cos(-1.*z+y)^2-1.*z^5*sin(-1.*z+y)*cos(-1.*z+y)^4), y = 0 .. Pi)
Download integral_unknown.mw
Can any one help to find the value of sigma(r,z) and theta(r,z) from the differential equations analytically,
ODEs:= <
      diff(theta(r),r$2) = -(1/r)*diff(theta(r),r) - diff(sigma(r),r)*diff(theta(r),r)-diff(theta(r),r)^2,
   diff(sigma(r),r$2) = -(1/r)*diff(sigma(r),r) -diff(theta(r),r$2)-(1/r)*diff(theta(r),r)>;
boundary conditions
'diff((theta),r)=0','diff((sigma),r)=0'; # at r=0
and theta=0, sigma=0; #at r=h(z)
I want to solve a set of parametric inequalities with constraints but it takes too much time to processing. do you know any faster solution?
thanks in advance
I need to plot this system of differential equations but I don't know how.. Can anyone help?
S_(n+1)(t)=S_n(t)-int_0^t[d/dw S_n(w)- mu*N+beta*S_n(w)*J_n(w)+mu*S_n(w)] dw
E_(n+1)(t)=E_n(t)-int_0^t[d/dw E_n(w) - beta*S_n(w)*J_n(w)+mu*E_n(w)+sigma*E_n(w)]dw
J_(n+1)(t)=J_n(t)-int_0^t[d/dw J_n(w)- sigma*E_n(w)+mu*J_n(w)+gamma1*J_n(w)] dw
R_(n+1)(t)=R_n(t)-int_0^t[d/dw R_n(w)-gamma1*J_n(w)+mu*R_n(w)] dw
with initial value
beta=0.00001
mu=0.02
sigma=45.6
gamma1=73
S(0)=12500000
E(0)=50000
J(0)=30000
R(0)=37420000
S_0(t)=S(0) and the same with E_(0). J_(0), and R_(0). And n is the n-th approximation.
I have problem with the diff and sum inside the integral..
I downloaded alglib from
http://algo.inria.fr/libraries/obsolete-releases.html
Downloaded the .mla and the .hdb files. Put them in current directory where my worksheet .mw is.
Opened the .mw and typed
libname := currentdir(), libname;
_algolibcontent();
Content of algolib (version 14.0), as of October 2010:
+ encyclopedia.            [Written by Stéphanie Petit, with contributions by Bruno Salvy and Michèle Soria.]
+ gdev.                [Written by Bruno Salvy.]
+ gfun (version 3.53).        [Maintained and extended by Bruno Salvy, with contributions by Ludovic Meunier, Marc Mezzarobba, Marni Mishna, and Eithne Murray, original version by Bruno Salvy and Paul Zimmermann.]
+ Holonomy (version 3.4).    [Written by Frédéric Chyzak.]
+ MAD (version 1.445).        [Written by Ludovic Meunier.]
+ Mgfun (version 4.1).        [Written by Frédéric Chyzak, with contributions by Shaoshi Chen, Cyril Germa, Lucien Pech, and Ziming Li.]
+ MultiSeries.            [Written by Bruno Salvy.]
+ regexpcount (version 1.5).    [Written by Pierre Nicodème.]
Ok. Now how to obtain help? I can call one of its functions, like this
MADLaTeX:-latex(1/2);
    \frac{1}{2}
But I do not know how to find help on MADLaTeX:-latex since ?MADLaTeX does nothing and ?MADLaTeX:-latex does nothing.
How to obtain the help pages for this package? I looked online and do not see anything. I do not know what to do with the .hdb file that I downloaded. I am using Maple 2018 and it does not seem to support .hdb files anyway.
Does I need to go through all the conversion steps described in
https://www.maplesoft.com/support/help/Maple/view.aspx?path=HelpTools%2fMigrate
just to see help on one function?
I just need to find how to call is Latex function and if it has any options. Any one knows an online page that have these on it?
How can I check six numbers: a, b, c, d, e, f are length six sides of a tetrahedron?
I am working with sequences and sometimes need to calculate the sum of prime factors (with multiplicity) of a number n. Example, n=12, answer = 2+2+3 = 7.
Any suggestions?
David.
i need to plot this equation but can't find a way to do so. Can anyone help?
beta parameter and initial value of S(k), E(k) is known, but i have problems at the sum and (k+1)..
I would like animate a function with multiple variables. At the moment my code in maple is:
plots[animate]( plot, [A*sin(B*x), x=0..10], A=0..2, B=0..2 );
I would like it to increase in amplitude when I run the A animation, and increase in frequency when I run the B animation. I want them to both be in the same graph , say have A=0.5 while B=0.5. then I could run the B animation with the amplitude fixed.
It would also be great to run them both at the same time.
Can someone help me?
-Thanks!!!
P.S: I'd eventually like to manipulate "implicitplot3d" with multple variables being animated at the same time.
hallo everyone, I'm working on a project for the Uni, and I'm facing the flowing problem.
I have Test-Matrix [3*12] called Testna it contains random nummbers( random because i wantend test the loop, the real matrix is much complexer ).
Testna := RandomMatrix(3, 12)
and I have a Vektor called Z
> Z:=Vector[row](5, {(1) = z, (2) = z-2, (3) = z-4, (4) = z-6, (5) = z-8})
>k:=4
Z and K are paramter previously in the worksheet
and I want to create a Matrix CC[3*3] using a nested loop so that the cofficient of CC(i,j) are as following
so for i =1 , j=1 and n from 1 to k=4  I wanted to have
CC(1,1):= Testna(1,1)*(Z(1,1)-Z(1,2))  +  Testna(1,4)*(Z(1,2)-Z(1,3) +Testna(1,7)*(Z(1,3)-Z(1,4))  +  Testna(1,10)*(Z(1,4)-Z(1,5)
so for i =1 , j=2 and n from 1 to k=4  I wanted to have
CC(1,2):= Testna(1,2)*(Z(1,1)-Z(1,2))  +  Testna(1,5)*(Z(1,2)-Z(1,3) +Testna(1,8)*(Z(1,3)-Z(1,4))  +  Testna(1,11)*(Z(1,4)-Z(1,5)
so for i =1 , j=3 and n from 1 to k=4  I wanted to have
CC(1,3):= Testna(1,3)*(Z(1,1)-Z(1,2))  +  Testna(1,6)*(Z(1,2)-Z(1,3) +Testna(1,9)*(Z(1,3)-Z(1,4))  +  Testna(1,12)*(Z(1,4)-Z(1,5)
so for i =2 , j=1 and n from 1 to k=4  I wanted to have
CC(2,1):= Testna(2,1)*(Z(1,1)-Z(1,2))  +  Testna(2,4)*(Z(1,2)-Z(1,3) +Testna(2,7)*(Z(1,3)-Z(1,4))  +  Testna(2,10)*(Z(1,4)-Z(1,5)
so for i =2 , j=2 and n from 1 to k=4  I wanted to have
CC(2,2):= Testna(2,2)*(Z(1,1)-Z(1,2))  +  Testna(2,5)*(Z(1,2)-Z(1,3) +Testna(2,8)*(Z(1,3)-Z(1,4))  +  Testna(2,11)*(Z(1,4)-Z(1,5)
CC(2,3):= Testna(2,3)*(Z(1,1)-Z(1,2))  +  Testna(2,6)*(Z(1,2)-Z(1,3) +Testna(2,9)*(Z(1,3)-Z(1,4))  +  Testna(2,12)*(Z(1,4)-Z(1,5)
and so on.. for i=3, j=3 and n from 1 to K=4
the Problem is that the loop doesnt work as I wanted(above)  and I dont know why, so insted of having a Matrix CC:=[  [C(1,1), C(1,2) C(1,3),], [C(2,1), C(2,2) C(2,3),], [C(3,1), C(3,2) C(3,3)]  ] I become a Matrix CC:=[ [C(1,1), C(1,1) C(1,1),],[C(2,2), C(2,2) C(2,2),],[C(3,3), C(3,3) C(3,3),]]
here is the Maple code
Test := proc ()
local i, j, n; global CC, Testna, Z, k:
CC := Matrix(3, 3);
for i from 1to 3 do for
j from 1 to 3 do
for n from 1 to k do
CC(i, j) := CC(i, j)+Testna(i, 1+(n-1)*3)*(Z(1, n)-Z(1, n+1))
end do
end do
end do
end proc():
CC
please Help
After solving something, sometimes the result comes in piecwise. I'd like to just obtain all those results which are not undefined, into a list, so I can process them more easily. I am not sure what is the correct way to do this in Maple.
Here is an example.
f := piecewise(x>-1 and x<=0, x^3,
               x>0 and x<=Pi/2, sin(x),
               x>Pi/2, undefined,
               x=20, 5,
               x=50, undefined);
I need to pick all entries that do not have "undefined". I do not need the rhs condition  which is x<=1. So for the above, I'd like to obtain
                               sol:=[ x^3, sin(x), 5]
If there more entries which are also not undefined, they go into the list in order.
when I do
sol:=convert(sol,pwlist,x);
This gives
sol := [0,-1,x^3,0,sin(x), (1/2)*Pi,undefined,20,undefined,20,undefined,50,undefined,50,undefined]
Now it gets confusing. How to change the above to
I do not even understand the conversion result above. I do not know why it gives 50 twice. And I do not even see the "5" in there. So I do not know how to decode this now.
Update:
I found this solution. But it might not be best:
contents :=[op(f)];
[seq(`if`(contents[i]=undefined,NULL,contents[i]),i=2..nops(contents),2)];
gives
              [x^3, sin(x), 5]
Using Typesetting:-Suppress(f(t)) I can suppress the dependency of f(t) in the differential equation eq := {diff(f(t), t) = f(t)}; in the output when I type eq
However, when I want to export the output to LaTeX or MathML using latex(eq) and MathML[ExportPresentation](eq), the dependency on t is still there!
How to remove the dependency on t?
When I have an Operator like
eq:=1/r*diff(r*diff(f(r),r),r)
typically maple evaluates/expands it by product rule.
How can I tell him to not do it?
I tried using the inert operator % but probably i didn't do it right.
Hi everybody,
I want to compare the performances of a set of codes that realize the same operation.
The worksheet I use is organized this way
Code1 := proc(...) ... end proc:
CodeTools[Usage](Code1(...))
Code2 := proc(...) ... end proc:
CodeTools[Usage](Code2(...))
and so on.
It appears that the execution of the whole worksheet doesn't always return the same values for the different indicators, which means that the ranking of the codes can be affected
To obtain more precise indicators I thought do do some statistics.
I then replace each bloc by :
CodeX := proc(...) ... end proc:  # here X stands for 1, 2, ...
N := "some positive integer"
for n from 1 to N do
   CodeTools[Usage](CodeX(...))
   "catch the values of the indicators"
"compute some statistics on the samples ot these indicator"
The problem is that Usage doesn't return any values but only does a printf.
I investigated two ways to circumvent this problem:
  1. - redirect the printings to file MyFile by using writeto(MyFile)
    - read MyFile
    - extract the numerical values of the indicators
    - compute the desired statistics
      It works well but it is far from being elegant
  2. - insert with(CodeTools) after the restart (within a separate block)
    - copy-paste the output of showstat(Usage) to define a new function, let's say MyUsage
    - insert at the correct place some lines like
             Tcpu := CodeTools:-FormatTime(result:-cputime)  (if my time of interest is the cpu time)
                          (this for all the indicators)
    - insert the line  [..., Tcpu, ...]; before the 'end proc' declaration;
      More elegant but it doesn't work
      I get the error   error (in T) DoUsage is not a command of the CodeTools package
Do you have some idea (beyond the first method above) of the way to catch the performance indicators that Usage computes ?
First 822 823 824 825 826 827 828 Last Page 824 of 2434
