hi,i used ifsolve  comand in my sheat and i have aloop over it  but some times my equations   can't be  solved .My question is how i give an order to maple to stop the loop if the equations can't solve
Hi.
I am attempting to obtain a solution to, what appears to be a simple PDE system (3 equations) and have encountered an error with the initial / boundary conditions. Can anyone provide and guidance / help with this?
The worksheet follows.
PDE_System.mw
I'm  trying to converting an infinite series from several terms to sigma form.
The series in question is:
x-x^2/(t*Log[t])+(2/3)*x^3/(t^2*Log[t]^2)+(-1/(2*t^3*Log[t]^3)-1/(4*t^3*Log[t]^2)-1/(6*t^3*Log[t]))*x^4+(2/(5*t^4*Log[t]^4)+2/(5*t^4*Log[t]^3)+4/(15*t^4*Log[t]^2))*x^5+(-1/(3*t^5*Log[t]^5)-1/(2*t^5*Log[t]^4)-5/(12*t^5*Log[t]^3)-5/(36*t^5*Log[t]^2)-1/(15*t^5*Log[t]))*x^6+(2/(7*t^6*Log[t]^6)+4/(7*t^6*Log[t]^5)+25/(42*t^6*Log[t]^4)+1/(3*t^6*Log[t]^3)+46/(315*t^6*Log[t]^2))*x^7+(-1/(4*t^7*Log[t]^7)-5/(8*t^7*Log[t]^6)-19/(24*t^7*Log[t]^5)-19/(32*t^7*Log[t]^4)-19/(60*t^7*Log[t]^3)-7/(80*t^7*Log[t]^2)-1/(28*t^7*Log[t]))*x^8+(2/(9*t^8*Log[t]^8)+2/(3*t^8*Log[t]^7)+1/(t^8*Log[t]^6)+25/(27*t^8*Log[t]^5)+163/(270*t^8*Log[t]^4)+106/(405*t^8*Log[t]^3)+88/(945*t^8*Log[t]^2))*x^9+(-1/(5*t^9*Log[t]^9)-7/(10*t^9*Log[t]^8)-73/(60*t^9*Log[t]^7)-4/(3*t^9*Log[t]^6)-149/(144*t^9*Log[t]^5)-691/(1200*t^9*Log[t]^4)-18569/(75600*t^9*Log[t]^3)-761/(12600*t^9*Log[t]^2)-1/(45*t^9*Log[t]))*x^10I've attached the worksheet 1.mw.
The example below works but not for the above I just get:
Error, invalid arguments to coeffs
Not sure where I'm going wrong any idea how to do this?
EXAMPLE that works from https://math.stackexchange.com/questions/2786296/strategy-or-software-for-representing-infinite-series-in-sigma-form
I've also attached the worksheet for this 2.mw
S:= 1-x+4/3*(x^2)-2*x^3+16/5*(x^4)-16/3*(x^5)+64/7*(x^6)-16*x^7+256/9*(x^8)-256/5*(x^9)+1024/11*(x^10);
Coeffs:= [seq(coeff(S, x, j), j=0..10)];
g:= gfun:-guessgf(Coeffs,x);
convert(g[1], FPS, x);
results in:
Sum((-1)^k*2^k*x^k/(k+1), k = 0 .. infinity)
or
rec:= gfun:-listtorec(Coeffs, a(n));
aa:= rsolve(rec[1],a(n));
Sum(aa*x^n, n=0..infinity);
results in the same desired result.
Hellow , Any body can help me to write the codes for the differential equation to solve by Galerkin finite element method by four elements by taking step size h=pi/2 and compare with homotropy method by plotting the graph of Galerkin method, homotropy method and exact, here is my codes
ode := diff(y(x), x, x) + y(x)-1=0:
ics := y(0) = 0, y(2*pi) = 0:
dsolve({ics, ode}):
How to do a full reinstall so that no settings are kept?
I tried deleting the maple 2017 folder in program files after I uninstalled but that did not help.
Hello everybody!
I just wrote my first Maple Worksheet for a Uni course and was trying to export it to LaTeX for the report that I have to hand in, but sadly it isn't working properly. I managed to get it to produce an output PDF in LaTeX, but the formatting is horrible and for some reason all text appears twice.
I already searched for other threads on this topic, but all of them appear to be pretty old and I wanted to aks if anyone has andy advice/experiences on how to make the LaTeX export work with more current Maple versions.
I'd be grateful for any advice!
- Chris
Hi everyone
I need help, I have downloaded Maple, and I have read about the student package, which can show the step by step solution, I would like to see the step by step solution than just a final solution to the equation problem.
I have the maple 2017, but does anyone know, how to download this package, and use it in maple?
https://www.maplesoft.com/support/help/maple/view.aspx?path=Student%2FBasics%2FLinearSolveSteps
There is several links to this, but I cant find it where to download the package, I hope that someone is able to help me
Helo, guys, i am a beginner here I want solve a system of first order differential equation using RK4. Please I need help please.
I need my results are nice and neat in final presentation so how can I change the way it present matrix in maple, its so messy in hear like picture . It happend resulted in Maple can reduce the same ratio such as As^2+Bs^2=(A+B)s^2, I tried all my best to find way to simply it but its so hard due to my noob in maple. Please help me make it nice and neat in array of matrix [    ].
I am wondering how to plot a function and a histogram together on the same set of axis.
1-Write a Maple ProcInserer procedure (x, pos, L) that inserts the element x into L at position pos.
 2- Write an inverse procedure (L) taking as argument a list L and returning the list obtained by inverting L in the decreasing direction of the indices.
The function given is f(x)= x3/4-sin x +1/2, interval=[0,2*pi]
a) plot the function over the interval to see its general behaviour.
f := x -> x^(3/4)-sin(x)+1/2;
plot(f(x), x=0..2*Pi);
b)FInd the interior points where f'=0.You may want to plot the f' as well.
d1:=D(f)(x);
plot (d1, x=0..2*Pi);
fsolve(d1=0, x);
       5.231279862
c) Find the interior points where f' does not exist.I don't know how to show question c) in Maple. Please help?plot(x^(3/4)-sin(x)+1/2, x=0..2*Pi)    plot(3/4*x^(-1/4)-cos(x) , x=0..2*Pi)
When i do this,
d2:=solve(d1=infinity,x);
Is this the correct way to shoe f' does not exist? How to I get the numerical value of the RootOf....?
Write a procedure that says whether or not an item a is in a  list L, and at which place (if there are several times the same item, you can return the place of the first, or the list of places of all the occurrences of a).
I got a double sum as a solution to heat equation in 2d. How do I plot that för different time values?
I can't get the right syntax for add, op
Can anyone tell me why the following command
restart; with(plots): with(Statistics):  with(numapprox):
 create an error of this type?
Error, Got internal error in Typesetting:-Parse : "cannot determine if this expression is true or false: membertype(specfunc(Typesetting:-mspace),Typesetting:-mempty(Typesetting:-mspace(depth = "0.0ex",height = "0.0ex",width = "0.0em",linebreak = "newline")))"
First 828 829 830 831 832 833 834 Last Page 830 of 2434
