Hi, There is a problem in solving ODE using dsolve/numeric code. You people would like to help me in resolving the error, here is in attached file,
Latif_paper.mw
In part of my program I defined variable Delta bar(`#mover(mi("Δ"),mo("-"))`), and used it and other parameters in a matrix named K (K=f(Delta_bar, x,y,...) then by using some mathematical operations, I initialled parameters to get my matrix named K.
Now I want to convert datatype of my matrix K with following command
M := Matrix(`~`[convert](K, float[8]), datatype = float[8]):
but receive following error:
Error, (in `convert/float`[8]) cannot handle unevaluated name ``#mover(mi("Δ"),mo("&uminus0;"))`` in evalhf
Do anyone know where the problem is?
Ok, so i have this functions
where f(x) represent urban population and g(x) represent the rural population.
And i have to implement an algortihm in Maple to find out after what period of time x the rural population will be with 20% bigger than urban population.
I'm new in Maple and is a little bit hard for me to implement algorithms in this program.If you can help me with any idea, i will really apreciate.Thank you :).
The following is the PDE I need to solve.
(x*y+1)*(diff(h(x, y), y, y, y))+(x+h(x, y))*(diff(h(x, y), y, y))-(diff(h(x, y), y))^2+k(x, y) = 0, (10.*(x*y+1))*(diff(k(x, y), y,y))+(10.*x+h(x,y))*(diff(k(x, y), y))-(diff(h(x, y), y))*k(x, y) = 0
This is the original boundary condition:
h(0, y) = f(y), h(x, 0) = 0, k(0, y) = g(y), k(x, 0) = 1, k(x, 25) = 0, (D[2](h))(x, 0) = 0, (D[2](h))(x, 25) = 0
After using pdsolve it come out the error:
pdsolve(eval(pde2, P = .1), pdebc4, numeric, [h(x, y), k(x, y)], spacestep = .1)
Error, (in pdsolve/numeric/par_hyp) Incorrect number of initial conditions, expected 0, got 2
If I remove one of the boundary condition when x=0, maybe h(0,y)=f(y), then the error will be this:
Error, (in pdsolve/numeric/par_hyp) Incorrect number of initial conditions, expected 0, got 1
However if I remove both when x=0, it come out this error:
Error, (in pdsolve/numeric) initial/boundary conditions must be defined at one or two points for each independent variable
May I know what is the problem of this equations?
P/S: I know its only differentiate with respect to y and is consider to be an ODE( I need more explantion on this please) and I'm still new to maple. Thanks!!
int(exp(I*x(2-y)),[x=-infinity..infinity, y=0..2]);
how to calculate this integral? where I is imaginary part?
I would like to solve the two dimensional heat equation in the square [-1,1]^2  using finite difference.
The following code  does not gives me the right answer.
  I appreciate any help
heat2dequation.mw
I solved a complex PDE equation in maple but I can not plot the output.
The manner was like bellow:
PDE := [diff(A(z, t), z)+(1/2)*alpha*A(z, t)+(I*beta[2]*(1/2))*(diff(A(z, t), t, t))-(I*beta[3]*(1/6))*(diff(A(z, t), t, t, t))-I*(GAMMA(omega[0]))(abs(A(z, t))^2*A(z, t)) = 0];
IBC := {(D[2](A))(z, 1), A(0, t) = -sin(2*Pi*t), A(z, 0) = sin(2*Pi*z), (D[2](A))(z, 0) = 2*z};
pds := pdsolve(PDE, IBC, type = numeric, time = t, range = 0 .. 1);
pds:-plot3d(A(z, t)*conjugate(A(z, t)), t = 0 .. 1, z = 0 .. 10, shading = zhue, axes = boxed, labels = ["x", "t", "A(z,t)"], labelfont = [TIMES, ROMAN, 20], orientation = [-120, 40]);
It is solved but there is an error like:
Error, (in pdsolve/numeric/plot3d) unable to compute solution for z>INFO["failtime"]:
unable to store 11.2781250000000+4390.00000040000*I when datatype=float[8]
could you please help me?
what is the problem?
Hi everyone,
I seek for creating a discrete random variable with the following characteristics. Let i be an integer between 1 and 100. The random variable is an integer, among i-x, i-x+1, i-x+2..., i-1, i+1, i+2... i+x. For example, with i=20 and x=5, the random variable is an integer between 15 and 25; with i=23 (and again x=5), the random variable is an integer between 18 and 28; and with i=98, the random variable is an integer among 93, 94... 97 and then 99, 100, 1, 2, 3.
Each possible value has the same probability, that is, 1/2x.
Any tips? Thank you in advance.
I have a differential equation which it seems not be solvable. can anyone help me to solve?
difeq.mw
I am trying to evaluate the following double integral where hypergeom([x,1/2],[3/2],C) is gauss hypergeometric function 2f1. maple gives back it unevaluated. I doubt it may be due to slow convergence of hypergeometric function.
restart; x := (1/6)*Pi; evalf(int(evalf(int(cos(x)*hypergeom([x, 1/2], [3/2], sin(x)/(r*cos(x)+k-2*r*sin(x))^2)/(r*sin(x)^2+r*cos(x)+k)^4, k = 0 .. 10)), r = 1 .. 2))
Int(Int(.8660254040*hypergeom([.5000000000, .5235987758], [1.500000000], .5000000000/(-.1339745960*r+k)^2)/(1.116025404*r+k)^4, k = 0. .. 10.), r = 1. .. 2.)
Download DOUBLE_INT_2.mw
I have tried to compile a simple program looking for counterexamples to a conjecture by Goldbach that every odd number is a sum of a prime and twice a square. Stern gave the counterexamples 5777 and 5993 a long time ago, so this is mainly for instruction purposes.
My program
othergoldbachFCi:=proc(sieve::Array(1..10000,datatype=integer[4]))
   local i,j,M;
   M:=10000;
   for i from 1 to M do
      if(sieve[i] mod 2=0) then
         for j from 1 to iquo(M-i,2*i+1) do
            sieve[i+j*(2*i+1)]:=2*iquo(sieve[i+j*(2*i+1)],2)+1;
         for j from 1 to floor(sqrt(M-i)) do
            sieve[i+j*j]:=2+sieve[i+j*j] mod 2;
         if(sieve[i]<2) then
            printf("%d is a counterexample\n",2*i+1);
works fine and compiles without problems. (I have to pass the array for the sieve because compiled program cannot declare memory, and it has to be 4 bytes even though I only need to use the lower 2 bit).  But the compiled version breaks with
   Error, (in compiledOGi) array index out of bounds
already in the first instance of the for loop. After a lot of trial and error I found out that if I replaced the line
by
   temp:=iquo(sieve[i+j*j],2);
   sieve[i+j*j]:=2+(sieve[i+j*j]-2*temp);
then the problem goes away and the compiled version works beautifully. It is not enough to do the mod 2 computation in temp, and not enough to replace mod by iquo in one line.
This makes very little sense to me. Can anybody explain? I'm still using Maple 2016 and do not know if the issue has been resolved in Maple 2017.
Best,
Soren
The equation
                     -sqrt(k x) = sqrt(k x)
 is solved correctly by Maple:
solve(-sqrt(k*x) = sqrt(k*x));
                 {k = k, x = 0}, {k = 0, x = x}
However, the equation
                 -sqrt(k x) = sqrt(k x + k - 1)
 is apparently not solved correctly:
solve(-sqrt(k*x) = sqrt(k*x+k-1));
                         {k = 1, x = x}
The variable
                               x
 can not be arbitrary since this equation reduces to the former equation
-sqrt(k*x) = sqrt(k*x);
 when  k = 1
Maple should return something similar to (4) below.
eval(-sqrt(k*x), k = 1) = eval(sqrt(k*x+k-1), k = 1);
                          (1/2)    (1/2)
                        -x      = x
solve({-x^(1/2) = x^(1/2)});
                            {x = 0}
Can this be explained in some way, or is this a bug?
Hi everybody,
I am presently developing a MAPLE-based application and I need to trace its evolutions through a “version control process”.
For codes written in other languages I use to use GIT (it acts with text files and it has syntactic coloring for different languages).
I suspect the development teams routinely face this version control issue.
Could you advise me,  on the versioning tools you use ?
Great thanks in advance
Let be the number z so that |z+3-2*I| + |z-3-8*I| = 6*sqrt(2). Find min and max of the modulus of z. How can I find min and max of modulus of z with Maple.
Thank for your help!
right_file.mw
i want to start i from 0 ,1 ,2 , 3 but it does not work I rhink the defaul value is from 1 to 4. can we begin it with zero.
First 1002 1003 1004 1005 1006 1007 1008 Last Page 1004 of 2464
