How do I mute the action of an accent applied to a symbol so that the accented symbol is itself an inert object? See the attached example.
How_do_I_make_an_accented_symbol_inert.mw
As a newbie in Maple2024, my next step is to try to solve a Diophantine equation. Attempts with isolve failed. It is the famous task B3 from the IMO of 1988:
If for integers x and y the fraction (x^2+y^2)/(1+x*y) is a positive integer, then it is actually a square number.
The solution is well known. But I would like to learn how to use Maple using this example and would like some advice.
Best regards, Alfred_F
I was trying to odetest one of my solutions to this ode when I got this internal Maple error I have not seen before.
Is this a legitimate error? my solution could be wrong ofcourse but strange to get internal error in this case.
Does this happen on earlier versions of Maple?
`The "Physics Updates" version in the MapleCloud is 1798 and is the same as the version installed in this computer, created 2024, August 29, 14:22 hours Pacific Time.`
libname;
sol:=Intat(1/(u^n/((1/((a*g(x)+b)^n)/(f(x)^n)*diff(g(x),x)*f(x))^(-n-1))/((f(x)*diff(g(x),x))^(-2*n+1))/((1/((a*g(x)+b)^n)/(f(x)^n)*diff(g(x),x)*f(x)*(diff(f(x),x)*diff(g(x),x)+f(x)*diff(diff(g(x),x),x))-(-1/((a*g(x)+b)^n)/(f(x)^n)*diff(g(x),x)^2*f(x)*n*a/(a*g(x)+b)-1/((a*g(x)+b)^n)/(f(x)^n)*diff(g(x),x)*n*diff(f(x),x)+1/((a*g(x)+b)^n)/(f(x)^n)*diff(diff(g(x),x),x)*f(x)+1/((a*g(x)+b)^n)/(f(x)^n)*diff(g(x),x)*diff(f(x),x))*f(x)*diff(g(x),x)-f(x)*diff(f(x),x)/((a*g(x)+b)^n)/(f(x)^n)*diff(g(x),x)^2*n)^n)/(n^(-n))-u+1),u = a/f(x)/(a*g(x)+b)*y(x))-ln(a*g(x)+b)+_C1 = 0;
Intat(1/(u^n/(((diff(g(x), x))*f(x)/((a*g(x)+b)^n*f(x)^n))^(-n-1)*(f(x)*(diff(g(x), x)))^(-2*n+1)*((diff(g(x), x))*f(x)*((diff(f(x), x))*(diff(g(x), x))+f(x)*(diff(diff(g(x), x), x)))/((a*g(x)+b)^n*f(x)^n)-(-(diff(g(x), x))^2*f(x)*n*a/((a*g(x)+b)^n*f(x)^n*(a*g(x)+b))-(diff(g(x), x))*n*(diff(f(x), x))/((a*g(x)+b)^n*f(x)^n)+(diff(diff(g(x), x), x))*f(x)/((a*g(x)+b)^n*f(x)^n)+(diff(g(x), x))*(diff(f(x), x))/((a*g(x)+b)^n*f(x)^n))*f(x)*(diff(g(x), x))-f(x)*(diff(f(x), x))*(diff(g(x), x))^2*n/((a*g(x)+b)^n*f(x)^n))^n*n^(-n))-u+1), u = a*y(x)/(f(x)*(a*g(x)+b)))-ln(a*g(x)+b)+_C1 = 0
ode:=diff(y(x),x)-f(x)^(1-n)*diff(g(x),x)*y(x)^n/((a*g(x)+b)^n)-diff(f(x),x)*y(x)/f(x)-f(x)*diff(g(x),x) = 0;
diff(y(x), x)-f(x)^(1-n)*(diff(g(x), x))*y(x)^n/(a*g(x)+b)^n-(diff(f(x), x))*y(x)/f(x)-f(x)*(diff(g(x), x)) = 0
odetest(sol,ode,y(x));
Error, (in PDEtools/NumerDenom) invalid input: PDEtools/NumerDenom expects its 1st argument, ee, to be of type Or(algebraic,table,rtable), but received {Intat(1/(u^n*(f(x)^(1-n)*diff(g(x),x)*(a*g(x)+b)^(-n))^n*(f(x)*diff(g(x),x))^(2*n)*n^n-u*(a*g(x)+b)^n*f(x)^n*(a*n*f(x)^(2-n)*diff(g(x),x)^3*(a*g(x)+b)^(-n-1))^n+(a*g(x)+b)^n*f(x)^n*(a*n*f(x)^(2-n)*diff(g(x),x)^3*(a*g(x)+b)^(-n-1))^n),u = _Z) = Intat(1/(u^n*(f(x)^(1-n)*diff(g(x),x)*(a*g(x)+b)^(-n))^n*(f(x)*diff(g(x),x))^(2*n)*n^n-u*(a*g(x)+b)^n*f(x)^n*(a*n*f(x)^(2-n)*diff(g(x),x)^3*(a*g(x)+b)^(-n-1))^n+(a*g(x)+b)^n*f(x)^n*(a*n*f(x)^(2-n)*diff(g(x),x)^3*(a*g(x)+b)^(-n-1))^n),u = _Z)}
Download internal_error_PDEtools_NumerDenom_sept_4_2024.mw
Is there a way to re-index an existing dataframe? See attachment for example.
how_do_i_re-index_a_dataframe.mw
So I have this Maple document that I worked on yesterday, and now when I open it it just opens as the start-up screen where I can choose between document and worksheet mode. I can see that the file is much larger (900 kb) than an empty document, so it should definitely have the data still in there, but opening it with a text editor I couldn't manage to fix my issue. Does anyone have any tips? I have a back-up of the file (from the restore backup menu), but most of the content is not there, so it would be very helpful to get this one fixed.
Exercises.mw
Thanks in advance,
Kristian.
The problem arose while playing with inscribed circles, as in this post. If anyone is interested, try to find a circle of maximum radius inscribed between the curves
x1^2 + 2*x2^2 - 1 = 0 and (x1 - sin(x1))^2 + (x2 - sin(x2))^2 - 1 = 0.
Curve graphs.
By using the second order ODE and its solution how i can get thus changing Rule?  i am looking for equation (8) by assumption of the paper he did, there is a trick but i don't know
idea.mw
I see here
https://mathematica.stackexchange.com/questions/306634/how-can-i-use-dihedralangle-to-get-correct-result/306638?noredirect=1#comment751373_306638
Let $S.ABCD$ be a pyramid, $ABCD$ is a square with $AB = 1$. The line $SA$ perpendicular to the plane $ABC$.
Calculate dihedral angle of two halfplanes `SBC` and `SCD` if: $SA = 1$, $SA = \dfrac{\sqrt{2}}{2}$.  I tried
a := 1;
h := 1;
pA := [0, 0, 0];
pB := [a, 0, 0];
pC := [a, a, 0];
pD := [0, a, 0];
pS := [0, 0, h];
I am attempting to obtain an equation for battery discharge.
I have data from a battery that will supply 25 amps for 210 minutes. I want to fit this to an equation and then try to adjust the curve to match a battery that will supply 25 amps for 160 minutes.
Here is what I have:
restart; with(Statistics):
## Amps
A := Vector([444, 218, 74,312/10,209/10,119/10,625/100]):
## Time until battery discharges to 10.5 volts
T := Vector([5,15,60,3*60,5*60,10*60,20*60]):
f := x -> a*exp(1-x/b); f(x)
eqset := {seq(T[idx] - f(A[idx]), idx=1..7)}
sol := NonlinearFit(a*exp(1-x/b),A, T, x)
evalf(subs(x=A[6],sol))
P1 := plot(A,T): P2 := plot(sol,x=0..450): plots[display]({P1,P2})
I want the 'knee' of the fitted curve to more closely match the measured data.
How do I do this?
Dear Power Users, Dataframes are a powerful tool within Maple. However, when I have 'undefined' in cells "Aggregate" or "DataSummary" does not provide answers. However, when I use "Statistics:-Mean" with the additional option "ignore=true" I can get an answer for one column (see attached worksheet). Adding "ignore" to aggregate apparently does not work. What is the method for ignoring the undefined data? In Excel when a cell is blank it will be ignored. Thank you for any help given.MP_Aggregate.mw
Hello. I am trying to use the Remove() command to remove a column of a dataframe. I applied the command like its shown in the help section and I get an error. I don't see how I am applying this command incorrectly. Where am I going wrong? Below is a screenshot of the error output and the .mw file used to generate the output.
Remove_a_column_from_a_dataframe.mw
I attempted to create a phase plot using the Odeplot command in Maple, but the resulting plot isn't as smooth as I'd like. To improve the smoothness, I tried increasing the numpoints parameter to 20,000, but this resulted in the error message: [Length of output exceeds limit of 1000000]. What adjustments should I make to obtain a smoother phase plot without encountering this error?
r := 1;
b := 1;
c := 0.01;
a := 0.36;
mu := 0.4;
beta := 0.75;
sys := {diff(x(t), t) = r*x(t) - b*x(t)^2 - c*x(t)*y(t) - beta*x(t)*y(t)/(a + x(t)), diff(y(t), t) = -mu*y(t) + beta*x(t)*y(t)/(a + x(t))};
ics := {x(0) = 0.2, y(0) = 0.05};
sol := dsolve(sys union ics, {x(t), y(t)}, numeric, range = 0 .. 20000, maxfun = 0, output = listprocedure, abserr = 0.1e-7, relerr = 0.1e-7)
with(DEtools);
DEplot3d(sys, {x(t), y(t)}, t = 0 .. 20000, [[x(0) = 0.2, y(0) = 0.05]], maxfun = 0, numpoints = 35000, thickness = 1, linestyle = solid);
phaseplot := odeplot(sol, [x(t), y(t)], 0 .. 20000, numpoints = 10000, color = red, thickness = 2, axes = boxed, gridlines, title = "Phase-space Diagram");
Download extra_steps.mw
I am facing some problems. This kind of error has been shown "Error, (in Engine:-Dispatch) badly formed input to solve: not fully algebraic"
eqn1 := {((1+1/beta).(diff(f(eta), eta, eta, eta))-(1+F[s]).((diff(f(eta), eta))^2)+(diff(f(eta), eta, eta)).f(eta)+M.(A-(diff(f(eta), eta)))-1/(R.D[a]).(diff(f(eta), eta)) = 0, diff(theta(eta), eta, eta)+4/3.N.(diff((1+(K-1).theta(eta))^3.(diff(theta(eta), eta)), eta)))+Pr.f(eta).(diff(theta(eta), eta))+(1+1/beta).Pr.Ec.((diff(f(eta), eta, eta))^2)+M.Ec.((diff(f(eta), eta)-A)^2) = 0, f(0) = 0, theta(0) = 1+alpha.(D(theta))(0), theta(10) = 0, (D(f))(0) = 1+(1+1/beta).lambda.(D(D(f)))(0), (D(f))(10) = 0};
sys1 := eval(eqn1, {A = 1, Ec = .2, K = 2.5, M = .5, N = .5, Pr = 6.5, R = 1, alpha = .5, beta = 2, lambda = .5, D[a] = .3, F[s] = 1});
sol1 := dsolve(sys1, numeric);
t1 := odeplot(sol1, [eta, diff(f(eta), eta)], eta = 0 .. 10, numpoints = 65, thickness = 0, color = green, linestyle = solid);
plots[plots:-display]({t1})
MAXR.mw
If I have an equation:
-2*a[0]*((x^3*a[1] + 42)*diff(y(x), x, x) - 6*y(x)*x*a[1])*sqrt(-a[0]*(a[1]^2 + 3)) - 3*x^2*((1/3*a[1]^3 + a[0] + a[1])*x + (8*a[1]^2 + 24)*a[0])*diff(y(x), x, x)
I want to obtain a differential algebraic equation for y(x)without the parameters a[1] and a[0]. My idea is to first compute the derivative of U to get:
V:=-2*a[0]*(3*x^2*a[1]*diff(y(x), x, x) + (x^3*a[1] + 42)*diff(y(x), x, x, x) - 6*diff(y(x), x)*x*a[1] - 6*a[1]*y(x))*sqrt(-a[0]*(a[1]^2 + 3)) - 6*x*((1/3*a[1]^3 + a[0] + a[1])*x + (8*a[1]^2 + 24)*a[0])*diff(y(x), x, x) - 3*x^2*(1/3*a[1]^3 + a[0] + a[1])*diff(y(x), x, x) - 3*x^2*((1/3*a[1]^3 + a[0] + a[1])*x + (8*a[1]^2 + 24)*a[0])*diff(y(x), x, x, x)
Then, compute the resultant: resultant(U,V,a[0]). However, since a[0] is algebraic, we cannot compute the resultant directly. I want to substitute:
algsubs((−a[0](a[1]2+3))2=c2,U)
Then, eliminate c, a[0], and a[1] using the resultant. However, I find that this substitution command does not work. Is there a method to help eliminate the parameters a[0]and a[1]?
This expression is easy i think but i can't get any results with same shape  how i can simplify to the same equation in the paper
i am looking for equation 9 and every thing is clear how i can get
mp1.mw
First 106 107 108 109 110 111 112 Last Page 108 of 2457
