I want to run a specific color red outside and yellow inside on my equation here using MAPLE 8.00:
plot3d([(0.5+cos(5*u))*sin(2*v),(0.5+cos(5*u))*cos(2*v),0.5*(cos(5*u)-0.3*cos(15*u)+0.02*cos(25*v))],u=0..2*Pi,v=0..2*Pi,axes=FRAMED);
is there some one here can help me? thanks...here is the example of color I want Eg:
I got a set like this one:
g:={{3, 4, 5}, {5, 12, 13}, {6, 8, 10}, {7, 24, 25}, {8, 15, 17},
  {9, 12, 15}, {9, 40, 41}, {10, 24, 26}, {12, 16, 20},
  {12, 35, 37}, {14, 48, 50}, {15, 20, 25}, {15, 36, 39},
  {16, 30, 34}, {18, 24, 30}, {20, 21, 29}, {21, 28, 35},
  {24, 32, 40}, {27, 36, 45}}
And i want to count how many time a number apper in this set. Like an example:
3 appear 1
4 appear 1
5 appear 2.
Thank for your reading, :)
Sorry for my bad english :)
equation 1 : xi+1=xi− (f·gy−fy·g)/(fx ·gy −fy ·gx)
equation 2: yi+1=yi− (fx·g−f·gx)/(fx·gy-fy·gx)
My quesiton are, deriving equations (1) and (2) above and constructing a single Maple function called newt2d that implements both of these recurrence relation.
I apolgize in advance if I don't write my question correctly.  This is my first time posting a question.
i wrote this problem to solve
Delta= Sum(j=1 to n)SUM(i=j to n)(pi*hj/Ad(t,ij)*Et,ij))
Where n=70,  G= ftj (t)/(4+0.85*t) , where (t =8, 16, 24,…….up to 8*n), hj= 13 for all j except j1 =18
Ad= (Aj+s(mij-1)), where Aj varies
Mij=ES/E(G),          where E(G)= 57sqrt(1000*G)
n := 70;
70
i := seq(1 .. n, 1);
1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70
t := proc (i) options operator, arrow; 8*i end proc;
j := i;
F = f(j);
F = f(1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70)
F(1 .. 30) := 8;
8
F(31 .. 40) := 7;
7
F(41 .. 70) := 6;
6
G := proc (F, i) options operator, arrow; F*t/(4+.85*t) end proc;
A := f(j);
A(1 .. 30) := 5184;
5184
A(31 .. 50) := 3600;
3600
A(51 .. 62) := 1936;
1936
A(63 .. 70) := 1024;
1024
(14)
s := f(j);
proc () option remember; table( [( 31 .. 50 ) = 3600, ( 63 .. 70 ) = 1024, ( 1 .. 30 ) = 5184, ( 51 .. 62 ) = 1936, ( 31 .. 40 ) = 3600 ] ) 'procname(args)' end proc
(15)
s(1 .. 10) := 128.0448;
128.0448
(16)
s(11 .. 20) := 63.763;
63.763
(17)
s(21 .. 30) := 79.92;
79.92
(18)
s(31 .. 40) := 64.08;
64.08
(19)
s(41 .. 50) := 47.88:
s(51 .. 62) := 31.944;
31.944
(20)
s(63 .. 70) := 12.49;
12.49
(21)
E := proc (G) options operator, arrow; 57*sqrt(1000*F) end proc;
(22)
Es := 29000;
29000
(23)
m := proc (E) options operator, arrow; Es/E(G) end proc;
(24)
Ad := proc (j, m) options operator, arrow; A+s*(m(E)-1) end proc;
(25)
P := f(j);
proc () option remember; table( [( 21 .. 30 ) = 79.92, ( 31 .. 50 ) = 3600, ( 41 .. 50 ) = 47.88, ( 63 .. 70 ) = 12.49, ( 1 .. 30 ) = 5184, ( 51 .. 62 ) = 31.944, ( 11 .. 20 ) = 63.763, ( 31 .. 40 ) = 64.08, ( 1 .. 10 ) = 128.0448 ] ) 'procname(args)' end proc
(26)
P(1 .. 68) := 254.7;
254.7
(27)
P(69 .. 70) := 196.8;
196.8
(28)
h := f(j);
(29)
h(1) := 18;
18
(30)
h(2 .. 70) = 13;
h(2 .. 70) = 13
(31)
delta := sum(sum((P.h)/(E(G)*Ad)), i = 1 .. n, j = i)
Error, invalid input: sum uses a 2nd argument, k, which is missing
Download short.mw
Hi All,
I have a fucntion f(x,y,z) = exp(-x^2 -y^2 - z^4) and would like to plot the probabity density in real space. One method would be to randomly sample points in a grid based on f(x,y,z). The function f(x,y,z) is clearly peaked around x=y=z=0, so you would expect many points to lie around there. So the plot would look like a clump near (0,0,0) which gets less dense away from (0,0,0).
In the worksheet below, I sampled points from the Uniform distribution to file in the 3d-plot. I would like these points to be sampled from f instead, but am not sure how to do this.
Any help is appreciated,
with(Statistics):
R := 10; # x-axis size
N := 100; # Number f points to sample
10
100
# Unnormalized Probability distrubution
f := (x,y,z) -> exp(-x^2 -y^2 - z^2);
proc (x, y, z) options operator, arrow; exp(-x^2-y^2-z^2) end proc
# Clearly f is peaked at (0,0,0) and decays. Therefore I want a plot a lot of points near (0,0,0), and fewer points away from (0,0,0)
plot3d(f(x,y,0), x = -1..1, y = -1..1);
X := Sample(Uniform(-R, R), N):
Y := Sample(Uniform(-R, R), N):
Z := Sample(Uniform(-R, R), N):
XYZ := Matrix([[X], [Y], [Z]])^%T;
XYZ := Matrix(100, 3, {(1, 1) = 9.758694699049908, (1, 2) = 2.6237746853802246, (1, 3) = 5.657441459582465, (2, 1) = -6.591359538862333, (2, 2) = -2.89852696242302, (2, 3) = 3.875752299737945, (3, 1) = -4.844154988559739, (3, 2) = 9.940065432132954, (3, 3) = -9.803954954738758, (4, 1) = -2.0640136273371272, (4, 2) = -5.516570020337457, (4, 3) = 6.864266760210192, (5, 1) = -8.52010460846124, (5, 2) = 3.049021459372298, (5, 3) = 8.446639955925516, (6, 1) = 3.68192133924018, (6, 2) = 2.099812838165187, (6, 3) = 5.41908441347849, (7, 1) = -1.9522333460767616, (7, 2) = -2.2550913703373006, (7, 3) = -9.146802881299026, (8, 1) = 9.65670402787902, (8, 2) = -7.156256814189918, (8, 3) = -2.4362772589956228, (9, 1) = -1.9563202955503058, (9, 2) = -9.497300285795937, (9, 3) = 4.086792489667353, (10, 1) = 2.4134389439915687, (10, 2) = -1.5777549246951743, (10, 3) = 4.590260910092939, (11, 1) = -6.912603890414553, (11, 2) = -6.317994211449776, (11, 3) = -5.514458586709711, (12, 1) = -2.3730959111105605, (12, 2) = 4.515505349389063, (12, 3) = -4.618905364532699, (13, 1) = -6.777320563012783, (13, 2) = -2.592746269696038, (13, 3) = 3.4606233000823785, (14, 1) = 5.162248626548372, (14, 2) = 6.831201749364123, (14, 3) = -.45015604546277466, (15, 1) = 7.422222438307784, (15, 2) = 4.684593823866264, (15, 3) = 2.4743282533488493, (16, 1) = -2.9844651022821473, (16, 2) = 1.4205174564875769, (16, 3) = -5.2711013471817925, (17, 1) = 3.710714174950745, (17, 2) = -6.462898847493945, (17, 3) = -6.457524910033669, (18, 1) = -4.117027324643008, (18, 2) = 9.147680451914468, (18, 3) = 6.592867713951691, (19, 1) = .6125860771377116, (19, 2) = -4.693559276141599, (19, 3) = 5.338433358705297, (20, 1) = 6.648467725703679, (20, 2) = 8.491617904792019, (20, 3) = 8.68956546236539, (21, 1) = 1.9498038374515865, (21, 2) = -5.52459190605918, (21, 3) = -7.842221898312729, (22, 1) = -3.2937733858950775, (22, 2) = -2.5287238471471003, (22, 3) = -6.355449887978885, (23, 1) = -4.015499533337867, (23, 2) = -8.249993008468286, (23, 3) = -8.01809435155083, (24, 1) = -.9481491686135186, (24, 2) = 2.802330964934301, (24, 3) = -.20472396153106232, (25, 1) = -1.5470869355907517, (25, 2) = -6.387662244937832, (25, 3) = -6.13509339062259, (26, 1) = -2.8078736405552878, (26, 2) = -9.098977850528517, (26, 3) = 7.917831475851365, (27, 1) = 1.1663839973859425, (27, 2) = 4.4634695836619045, (27, 3) = -8.01820700636371, (28, 1) = 4.850907314038782, (28, 2) = -3.051247088364198, (28, 3) = -9.116688564746777, (29, 1) = -1.5133043274861873, (29, 2) = 3.2123364900580764, (29, 3) = 1.145903116095237, (30, 1) = -1.4128842284758996, (30, 2) = -2.322627978560572, (30, 3) = 5.449901343752481, (31, 1) = -7.502544825603743, (31, 2) = 2.5469300488693403, (31, 3) = -3.7611988500746225, (32, 1) = -9.511319678992521, (32, 2) = -9.567003707393871, (32, 3) = -6.420350413713298, (33, 1) = -4.196294697385456, (33, 2) = 8.21139977046057, (33, 3) = -3.220886435045635, (34, 1) = -3.6495883420154733, (34, 2) = 6.011173125576221, (34, 3) = -5.7970872591289595, (35, 1) = 3.0738026793295035, (35, 2) = 4.916949686854423, (35, 3) = .20305039530500402, (36, 1) = 9.138718481413683, (36, 2) = 6.262256272215215, (36, 3) = 8.127286465304294, (37, 1) = 8.71461745569761, (37, 2) = -2.3338736274894156, (37, 3) = 2.578478773046358, (38, 1) = -.8422733229126642, (38, 2) = 2.345584646328984, (38, 3) = -7.969322223753757, (39, 1) = -5.190432063358308, (39, 2) = 1.5098971940562773, (39, 3) = -2.1829049454729077, (40, 1) = 5.277958885729566, (40, 2) = .6010340953003119, (40, 3) = -8.907667695526849, (41, 1) = 5.186547662621926, (41, 2) = -4.498604883561299, (41, 3) = 0.25658264064304603e-1, (42, 1) = 4.812961299572285, (42, 2) = -5.027420806760592, (42, 3) = -1.3655765623150558, (43, 1) = 4.87376682974652, (43, 2) = -.9672245909605444, (43, 3) = 9.951206990243783, (44, 1) = -7.881591665344693, (44, 2) = -5.445743479469048, (44, 3) = 6.232051619906457, (45, 1) = 3.631208609406313, (45, 2) = 6.0889916722614, (45, 3) = -.2869666020396462, (46, 1) = -.7347884281256167, (46, 2) = 9.722084837919404, (46, 3) = 7.888955111347865, (47, 1) = -5.756735894901313, (47, 2) = -9.4001609946122, (47, 3) = -7.249068104658704, (48, 1) = -8.029625246237833, (48, 2) = .7132838133447539, (48, 3) = -2.1999017110942916, (49, 1) = 6.471489478556769, (49, 2) = -8.258455601982153, (49, 3) = 8.547124499962496, (50, 1) = -6.499805252358408, (50, 2) = 6.04182881111608, (50, 3) = 8.34987664832234, (51, 1) = -6.728601804300136, (51, 2) = 9.782898194006798, (51, 3) = 4.271480231886315, (52, 1) = 3.319744328222212, (52, 2) = -8.661074832044998, (52, 3) = 2.3667476724388, (53, 1) = 7.887787507084855, (53, 2) = 8.787967237690697, (53, 3) = -3.1342421951730914, (54, 1) = .33116416702540796, (54, 2) = -9.636449327266085, (54, 3) = 8.720546533795396, (55, 1) = 4.054046139009506, (55, 2) = 3.6767722749271066, (55, 3) = -7.504519186790148, (56, 1) = -6.9281924676119955, (56, 2) = 5.674729601664373, (56, 3) = 4.611707230114142, (57, 1) = 9.069141397724955, (57, 2) = .6827513576545652, (57, 3) = 2.929548648516276, (58, 1) = .8176816248295289, (58, 2) = 7.7071890186228345, (58, 3) = 6.663039713385899, (59, 1) = 3.594677964209339, (59, 2) = 7.980097978122803, (59, 3) = -2.034355435624491, (60, 1) = -9.268739639030944, (60, 2) = 2.518752521609917, (60, 3) = 4.9964441872127185, (61, 1) = 6.184077025875865, (61, 2) = -7.242620151748835, (61, 3) = 6.70441020956261, (62, 1) = 4.972377435523942, (62, 2) = -5.6439681257575085, (62, 3) = -3.5507920527548116, (63, 1) = -7.596259640258387, (63, 2) = -6.357178482191326, (63, 3) = 1.0452323371671, (64, 1) = .5009032952521757, (64, 2) = -9.163602720540913, (64, 3) = 9.582582648677842, (65, 1) = -3.483327424735016, (65, 2) = -7.86116682899586, (65, 3) = .9861706603660547, (66, 1) = .9289887980613702, (66, 2) = 2.328869701713703, (66, 3) = -3.391527807867945, (67, 1) = -2.0223849523360204, (67, 2) = 8.793220203221335, (67, 3) = 2.389431103555598, (68, 1) = -1.6981322677390676, (68, 2) = -2.910885380653423, (68, 3) = -2.7872685799559456, (69, 1) = -6.3852447949041125, (69, 2) = -1.7874181988097213, (69, 3) = 5.130190870038886, (70, 1) = -4.892265190238985, (70, 2) = 9.68698833968903, (70, 3) = -1.7219850261962062, (71, 1) = -9.589284506836309, (71, 2) = 8.911583780705254, (71, 3) = -.15309791230124503, (72, 1) = 8.473512252408145, (72, 2) = 3.532893568670783, (72, 3) = 3.8948646626522017, (73, 1) = 3.073997780165058, (73, 2) = 9.766045246265726, (73, 3) = 9.454677701595681, (74, 1) = 8.652271440971283, (74, 2) = 5.336627744331885, (74, 3) = -3.4449007901318645, (75, 1) = -6.729752629449488, (75, 2) = -3.2660147121704775, (75, 3) = 6.756063661571513, (76, 1) = 8.42194511784395, (76, 2) = 3.2476372079896247, (76, 3) = 4.781444545470562, (77, 1) = 5.893157707775064, (77, 2) = -5.116694264194415, (77, 3) = 9.083489127590862, (78, 1) = 1.5478839341329742, (78, 2) = -4.089854983368064, (78, 3) = -9.361547409920432, (79, 1) = -1.1992880847949277, (79, 2) = 3.6035674246100413, (79, 3) = -2.8626202763491593, (80, 1) = -4.8477252657512455, (80, 2) = .5569366083759579, (80, 3) = 3.25307668574429, (81, 1) = 5.038927877349, (81, 2) = -1.7681297318493083, (81, 3) = -4.369968817030188, (82, 1) = -5.426610357889972, (82, 2) = 2.0527643607279433, (82, 3) = -5.392338653650725, (83, 1) = -8.716258252162028, (83, 2) = 5.010401118474713, (83, 3) = 4.222571023606502, (84, 1) = 5.346590215531489, (84, 2) = 1.6706634852391726, (84, 3) = 2.4914583398661705, (85, 1) = 3.4240437071307106, (85, 2) = 1.0358502987193496, (85, 3) = 1.8121730583927196, (86, 1) = 4.304250295716802, (86, 2) = 1.6714123751542882, (86, 3) = 3.2087593262520375, (87, 1) = 2.8412165686770443, (87, 2) = .236398399169504, (87, 3) = -9.04890653772268, (88, 1) = -1.6190341275023385, (88, 2) = -8.348145460026013, (88, 3) = -3.0243038297988223, (89, 1) = -2.184758355916509, (89, 2) = 4.391402697189795, (89, 3) = -.9731883928851364, (90, 1) = 6.322802057506454, (90, 2) = 9.923122225937387, (90, 3) = -5.181900057597786, (91, 1) = -3.6514427268830074, (91, 2) = -2.909313900861563, (91, 3) = 4.300900265923531, (92, 1) = 6.290795458013026, (92, 2) = 9.425176303668113, (92, 3) = 7.123645840125757, (93, 1) = 5.7814702987791655, (93, 2) = -3.071024773992807, (93, 3) = -4.369846097628933, (94, 1) = 7.045277806876914, (94, 2) = 7.730877235206126, (94, 3) = 4.621016594474829, (95, 1) = .11273235143512395, (95, 2) = -.9061027001618438, (95, 3) = -7.244742149609673, (96, 1) = 2.7132277772275373, (96, 2) = -1.7314542195836946, (96, 3) = 6.734455634994351, (97, 1) = 9.017888307562703, (97, 2) = -5.645358632853991, (97, 3) = -7.2279656851528, (98, 1) = -1.1207168996237922, (98, 2) = -7.486908252747475, (98, 3) = 1.7641877077898727, (99, 1) = -8.799623604410481, (99, 2) = -3.821708128663694, (99, 3) = -2.6768639909012437, (100, 1) = 7.334997939986373, (100, 2) = 4.522088633296637, (100, 3) = 6.135190893222113}, datatype = float[8])
ScatterPlot3D(XYZ, color = blue, symbolsize = 20);
Download Sample_Test.m
I have the following code in Maple 13:
SYS := {diff(T(x, t), t) = diff(T(x, t), x, x)};
IBC := {T(1, t) = 0, T(x, 0) = 1, (D[1](T))(0, t) = -exp(t)};
SOL := pdsolve(SYS, IBC, numeric, time = t, timestep = 1/10);
R := SOL:-value(output = listprocedure); temperature := subs(R, T(x, t));
It integrates the heat equation in the interval x=0..1 and it seems to work ok.
However, I have problems trying to obtain the temperature derivative at the boundaries (this is at x=0 and x=1). I'm using different commands and it seems the derivative is evaluated ok inside the domain but not at the boundaries.
If I try
fdiff(temperature(x, t), [x], {x = 1,t=0.5});
or
evalf((D[1](temperature))(1, .5));
I don't get any numerical answer. Any idea how I could obtain the value of the derivative at the boundaries?
Thanks in advance,
Javier
When I write an conditional command I come back and press enter again and again but I need only last one for example
>f:=x->x^2+x+1
>g:=y->y^2+2*y+6
>x:=0;y:=0
>if f(x) <g(x) then;
>x:=x+1 elif f(x) >g(x) then;
>y:=y+1 elif f(x)=g(x) then;
>x;
>y;
>f(x) end if;
I push enter and it write x:=1 then I click if command and push enter again and it writes x:=2 and continues like y:=1, x:=3, y:=2, x:=4,  y:=3 and lastly
4
21
But I only need last one. Can I do this only push enter once. Of course my problem is more complicated than this f(x) , g(x) . Thanks
Is there any possibility for taking the negative sign outside a function, like factorization of -1?
Say I have.
2*Pi^2*(-1+delta)/r^(1+delta),
How do i get this output?
-2*Pi^2*(1-delta)/r^(1+delta)
> restart;
pr := .72; p := 0; n := [.5, 1, 1.5]; s := 0; a := .2; b := 0; L := [red, blue, green]; l := 0; k := 1;
for j to nops(n) do R1 := 2*n[j]/(1+n[j]); R2 := 2*p/(1+n);
sol1 := dsolve([diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))+R1*(1-(diff(f(eta), eta))^2) = 0, diff(diff(theta(eta), eta), eta)+pr*k*f(eta)*(diff(theta(eta), eta))+R2*pr*k*(diff(f(eta), eta))*theta(eta)+(2*(a*(diff(f(eta), eta))+b*theta(eta)))/(1+n[j]) = 0, f(0) = 1, (D(f))(0) = b*((D@@2)(f))(0), (D(f))(1.8) = 0, theta(0) = 1+s*(D(theta))(0), theta(1.8) = 1], numeric, method = bvp);
fplt[j] := plots[odeplot](sol1, [eta, diff(diff(f(eta), eta), eta)], color = L[j], axes = boxed); tplt[j] := plots[odeplot](sol1, [[eta, theta(eta)]], color = L[j], axes = normal) end do; plots:-display([seq(fplt[j], j = 1 .. nops(n))]);
plots:-display([seq(tplt[j], j = 1 .. nops(n))]);
staganation_point1.mw
can we chage the axis sir ?? like  f'' vs eta to f'' vs lambda.
l := 1:
.5
[blue, green, red, yellow]
for j to nops(p) do R1 := 2*n/(n+1); R2 := 2*p[j]/(n+1); R3 := 2/(n+1); sol1 := dsolve([diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))+R1*(1-(diff(f(eta), eta))^2)-M*(diff(f(eta), eta)) = 0, diff(diff(theta(eta), eta), eta)+pr*f(eta)*(diff(theta(eta), eta))-R2*pr*(diff(f(eta), eta))*theta(eta)+R3*(A*(diff(f(eta), eta))+B*theta(eta)) = 0, f(0) = 1, (D(f))(0) = L+b*((D@@2)(f))(0), (D(f))(7) = 1, theta(0) = 1+s*(D(theta))(0), theta(7) = 0], numeric, method = bvp); plots[odeplot](sol1, [eta, ((D@@2)(f))(eta)], color = red); fplt[j] := plots[odeplot](sol1, [eta, f(eta)], color = K[j], axes = boxed); tplt[j] := plots[odeplot](sol1, [[eta, theta(eta)]], color = K[j], axes = normal); fplt[j] := plots[odeplot](sol1, [eta, diff(f(eta), eta)], color = K[j], axes = boxed) end do:
sol1(0)
sol1(0)
sol1(.1)
[eta = .1, f(eta) = 1.05958091104306206, diff(f(eta), eta) = .643210624614908300, diff(diff(f(eta), eta), eta) = .881482678165403044, theta(eta) = .623284688471349546, diff(theta(eta), eta) = -.578039450700496560]
sol1(.2)
[eta = .2, f(eta) = 1.12800452943200891, diff(f(eta), eta) = .722346769554029544, diff(diff(f(eta), eta), eta) = .706526135439307756, theta(eta) = .568123251856343492, diff(theta(eta), eta) = -.525530979400813946]
sol1(.3)
[eta = .3, f(eta) = 1.20351830506746449, diff(f(eta), eta) = .785511903074783246, diff(diff(f(eta), eta), eta) = .561442941644520022, theta(eta) = .518103974464032668, diff(theta(eta), eta) = -.475257424178228970]
sol1(.4)
[eta = .4, f(eta) = 1.28466826824405134, diff(f(eta), eta) = .835505660630676662, diff(diff(f(eta), eta), eta) = .442470716586289281, theta(eta) = .472985640642506311, diff(theta(eta), eta) = -.427567049032814172]
sol1(.5)
[eta = .5, f(eta) = 1.37026161183094430, diff(f(eta), eta) = .874752886901313142, diff(diff(f(eta), eta), eta) = .345911467377074400, theta(eta) = .432494259338694842, diff(theta(eta), eta) = -.382764248064397461]
sol1(.6)
[eta = .6, f(eta) = 1.36678221814533528, diff(f(eta), eta) = .771028661281065508, diff(diff(f(eta), eta), eta) = .407805382194403932, theta(eta) = .876413930517023876, diff(theta(eta), eta) = -.197648778495384870]
sol1(2)
[eta = 2., f(eta) = 2.66120522956795602, diff(f(eta), eta) = .991532161353848585, diff(diff(f(eta), eta), eta) = 0.251405465681268682e-1, theta(eta) = .635967939441598018, diff(theta(eta), eta) = -.144641270049362308]
Download staganation_point1.mw
dear all,
how can I plot
 u:=(3*x-1)*(1-x):
v:=2*x*(1-2*x):
in (u,v)-plane
where x from 0..1
Hi !
This is my code : Ass2.mw
and I don't know why I have this warning : Warning, The use of global variables in numerical ODE problems is deprecated, and will be removed in a future release. Use the 'parameters' argument instead (see ?dsolve,numeric,parameters)
and I can't plot my curve after :) If you guys have any ideas... thank you!
I am trying to solve a system of ODE's numerically but the problem is with the condition f(0)+g(0)=1.
Here is the system with the initial conditions,
ode1:=diff(f(x), x,x)+(f(x)+g(x))*diff(f(x),x)=0;
ode2:=diff(g(x), x,x)+(f(x)+g(x))*diff(g(x),x)=0;
ics:=f(0)+g(0)=1,D(f)(0) =0,D(g)(0) =1;
dsolve({ode1,ode2,ics},numeric);
which give an error
Error, (in DEtools/convertsys) invalid specification of initial conditions
The above system is a simplified form of a very complicated one.
Hi Maple expert,
May I ask your time little bit, I am struggling with the 3D plot in maple, for basic 3D plot in maple is no problem for me, but this is a new case for me actually I want to perform a 3D plot based on these 3 different type of plots (or equations), here they are:
1. plot(2*(exp(-0.15*(u)^1.5))*(u)^0.5,u=0..2);
2. plot([0.2*(x-sin(x)),0.5*(1-cos(x)),x=0..10*Pi]);
3. polarplot(4+1*cos(5*x),x=0..2*Pi);
Can someone help me for this, many thanks for your help and time.
http://www.sciencedirect.com/science/article/pii/S100757041300508X> restart;
> l := 1; p := 1; A := .5; B := .5; pr := 1; n := [.5, 1, 1.5]; M := 0; b := .5; L := 0; s := .5; K := [blue, green];
                                [0.5, 1, 1.5]
                                [blue, green]
> for j to nops(n) do R1 := 2*n[j]/(n[j]+1); R2 := 2*p/(n[j]+1); R3 := 2/(n[j]+1);
fplt[j] := plots[odeplot](sol1, [eta, diff(diff(f(eta), eta), eta)], color = K[j], axes = boxed); fplt[j] := plots[odeplot](sol1, [eta, f(eta)], color = K[j], axes = boxed);
tplt[j] := plots[odeplot](sol1, [[eta, theta(eta)]], color = K[j], axes = normal) end do;
Dear sir
I am trying to plot the following link paper graphs for practice but I getting the plots for only one set of values here in this paper they plotted many so if you dont muned can help in this case. For example in this first graph named as Fig.1. please can you do this favour... and the paper link is  http://www.sciencedirect.com/science/article/pii/S100757041300508X
If I want to clear the screen what command I must use?
First 1091 1092 1093 1094 1095 1096 1097 Last Page 1093 of 2462
