I try to get the first ten fractions of Pi with the commands "seq" and "nthconver".
I tried this:
a:= cfrac(Pi);
CFRAC([3, 7, 15, 1, 292, 1, 1, 1, 2, 1, 3, ...])
sec(nthconver(a,i),i=1..10);
But it doesn't work.
Who can help me?
It took me a while to figure out what was causing this unusual sort result;
I loaded the MTM package because I want to convert numbers to integers for indexing. This sort result seem like it could be a bug.
Sort a List of Floats
with(MTM):
x := [1/3, 0, 4] = [1/3, 0, 4]``
sort(x) = [0, 1/3, 4]``
f_x_MTM := [seq(convert([x[n], n], float), n = 1 .. 3)] = [[.3333333333, 1.], [0., 2.], [4., 3.]]NULL
sort(f_x_MTM) = [[.3333333333, 1.], [0., 2.], [4., 3.]]NULL
unwith(MTM):
f_x := [seq(convert([x[n], n], float), n = 1 .. 3)] = [[.3333333333, 1.], [0., 2.], [4., 3.]]
sort(f_x) = [[0., 2.], [.3333333333, 1.], [4., 3.]]
Download MTMsort.mw
f=2*x*(int(sqrt(1+y^2*(t*x-1)^2/(1-(t*x-1)^2)), t = 0 .. 1))    ,0<x<2,   0<y<1,
I want to Determine the value of f for the various values of x,y For a domain So that x , y Changing with steps 0.1. for example:
x y f
0.1 0.1
0.2 0.1
0.3 0.1
0.4 0.1
0.5 0.1
0.6 0.1
0.7 0.1
0.8 0.1
0.9 0.1
0.2 0.2
0.3 0.2
Hello Everybody,
I was trying to apply the Newton-Raphon method("Newton" in maple) for the following problem to obtain the constants (c1...cM) without success.
eq[1] := -0.0139687 c[2] - 0.0132951 c[1] = 0
eq[2] := 24806.4 c[2] - 0.0139687 c[1] = 0
If anybody has experience with it or knows how to use it I would really appreciate your help.
Just to introduce the previous steps of calculations leading to the problem:To calculate the critical buckling force N and the shape of a rectangular uniformly loaded plate the governing diff. equation is the following
D11*w''''(x)+(2*D12+4*D66)*w''(x)''(y)+D22*w''''(y)+N*w''(x)=0
For the follwing solution of a boundary value problem(Boundary conditions:clamped-clamped: w(x=0,x=a)=0 & w'(x=0,x=a)=0) I applied the Ritz method:
w:=sum(c[i]*(cos(2*i*Pi*x/a)-1)),i=1..M)
Thus the Potential Energy P is:
P:=16537.6*c[2]^2-0.0139687*c[2]*c[1]+1033,60*c[1]^2-9.86960*N*c[2]^2-2.46740*N*c[1]^2
 deriving P to each constant c and setting them =0 leads to:
eq[1] := -0.0139687 c[2] + 2067.20 c[1] - 4.93480 N c[1] = 0
eq[2] := 33075.2 c[2] - 0.0139687 c[1] - 19.7392 N c[2] = 0
After calculating N=418,902  and feeding eq1 and eq 2,the follwing equations if two terms are considered:
Everything I tried resulted in any c1 = c2 = 0 which is not  realistic. Maybe I made a mistake earlier.
Thanks a lot in advance.
Sam
 Plate_Buckling.mw
Does anyone know how to find the repeated part of a fraction. I know the command cfrac, but I have
heard there should be another command which give the repeated part of a fraction as a result.
Who can help me?
 3/11+3*sqrt(3) = [5, 2, 7, 1, 1, 6, 1, 627, 1, 6, 1, 1, 7, 2, 9, 1, 12, 16, 1, 10, 1, 4, 3, 1, 1, 2, 1, 14, 2, 3, 10, 9, 1, 1, 139, 5, 5, 3, 2, 3, 6, 1, 1, 1, 9, 1, 2, 1, 6, 1, 2, `...`]
Hi guys,
I can not convert a series with label.
If anyone can confirm this?
Maybe-Bug.mw
Another_way_to_calculate_the_definite_integral.mw
ptin the file I upload is a complicated expression containing θ and r. Will the accuracy of the result be affected if I use the second method in the file to calculate the definite integral?
Hi guys,
I can not execute any command in worksheet. I even can't set a variable to a number. When I write some lines and hit enter, it does not respond in anyway. Basicly I can't enter anything it doesn't do anything. How cold I solve this?
Dear Maple users
I know how to fit a function with some parameters to some data, but how can it be done if the data is 2-dimensional? I mean: I have some time array T, some X array and some Y array. How do I fit a function with certain parameters to the data: (x(t),y(t)) to fit (X(T), y(T)), ...
Erik
I've this equation ,what is displacement,
U := sum(C[i]*lambda[i]*h^2*M*(C[13]+C[55])*exp(Z*lambda[i]*M)*cos(M*x)/C[11], i = 1 .. 4);
 But when I used the data ,I do not get the right result
the datas are
h := .25;
M := Pi/L; L := 1;
E[3] := 1; E[1] := 40; E[2] := 1;
V[13] := .25; V[31] := .25; V[12] := .25; V[23] := .25; V[32] := .25; V[21] := .25;
G[44] := .2; G[55] := .2; G[66] := .2;
G[13] := .5;
C[55] := G[13];
Omega := -2*V[13]*V[21]*V[32]-V[12]*V[21]-V[13]*V[31]-V[23]*V[32]+1;
C[11] := (-V[23]*V[32]+1)*E[1]/Omega;
C[12] := (V[13]*V[32]+V[12])*E[2]/Omega;
C[33] := (1-V[12]*V[12])*E[3]/Omega;
C[1] := -.2596702449; C[2] := -2.411545729; C[3] := -0.6051254981e-1; C[4] := .4085627399;
lambda[1] := .6891428810; lambda[2] := -.6891428810; lambda[3] := 9.177422410; lambda[4] := -9.177422410;
could you help me plase
I'm trying to plot a piecewise function whose return value has units, but I get an error saying that it found a "name" (i.e., the unit symbol).
Example:
> f := t -> 2*t;
> fp := piecewise(f(tt) <= 4, 1*Unit(W), f(tt) > 4 and f(tt) <= 8, 2*Unit(W), f(tt) > 8, 3*Unit(W));
> plot(fp, tt = 0..10);
I've tried using the option useunits, but no success. Any help will be appreciated.
Limitation of Maple spreadsheet is only 100 x 52
I don't know why there's a limitation on the size but there's no way of increasing it either.  Is there?
Just to be sure that some outside operation wouldn't nudge the spreadsheet size I tried
with(Spread):
a:=CreateSpreadsheet():
b:=Matrix(100,100):
SetMatrix(a,b)
                           Error, (in Spread:-SetMatrix) spreadsheets cannot exceed 52 columns
So unfortunately until the feature gets built into Maple I don't believe there is a workaround.
Hello.
When I click to start simulation button maple start counting but after that don't open visualization. When I open visualization manually, there aren't results of simulation. Program don´t show any error. It does not work with my models and examples to. Thanks for your help.
I read research paper about elasticity, and I don't not how can get the results for displacment ant shaer stress,, could you help me please.
please help me
Kind Regards
First 1228 1229 1230 1231 1232 1233 1234 Last Page 1230 of 2470
