Consider the following worksheet (perhaps it is better to download the worksheet and execute since the contents below aren't showing the commands used to plot the last two plots).
T = log(R)/(a+b*log(R))^2
plot(log(R)/(-1.16+.675*log(R))^2, R = 1000 .. 30000)
10^log[10](T) = log(R)/(a+b*log(R))^2
log[10](T) = log[10](log(R)/(a+b*log(R))^2)
w = log[10](z/(b*z+a)^2)
w = ln(z/(b*z+a)^2)/ln(10)
plot(log[10](z/(-1.16+.675*z)^2), z = log(1000) .. log(30000))
plots:-loglogplot(log(R)/(-1.16+.675*log(R))^2, R = 1000 .. 30000)
My question is about making a loglog plot of the equation
for R between 1000 and 30000.
The second to last plot is of w as a function of z, as in the last equation below
and the plot command is (where I have subbed in a=-1.16 and b=0.675)
In the second to last plot, of course we have negative values of w. If we were to consider the underlying values of T, they would never be negative of course.
The last plot is the command
I think this last plot is what I want (though I am not sure because I am not totally sure what plots:-loglogplot is doing).
My question is how to obtain this loglog plot manually. That is, I want the axes to show values of R on the x axis and T on the y axis (just like a usual loglog plot shows).
In other words, how to go from the second to last plot to the same plot but showing the corresponding R and T values instead of z and w.
Download loglog.mw
I would like to get the solution of a system : pde with boundary and initial condition. Everything well coded, but the code does not return the solution
sol_heat.mw
Thanks for your help
Here is a small worksheet to illustrate my question
Consider the expression
solve(sqrt(log[10](R)/T) = a+b*log[10](R), T) = ln(R)*ln(10)/(ln(10)^2*a^2+2*ln(10)*ln(R)*a*b+ln(R)^2*b^2)NULL
Can we somehow tell Maple to keep the logarithms in base 10?
I'd like for the final expression to have only base 10 logarithms.
When I do it with pen and paper, I get
It is this last expression that I would like Maple to output.
Download log10.mw
Hello.
I want to check my analytical calculations and to compare my results with the series expansion for x=0 and y=0 of the function
R0 := -(1-tanh((1/2)*l*sqrt(k*y^2+x^2)*d)^2)*x/(k*y^2+x^2)+2*tanh((1/2)*l*sqrt(k*y^2+x^2)*d)*x/(l*(k*y^2+x^2)^(3/2)*d)
by means of the command
mtaylor(R0, [x, y], 5);
However, I have a message from Maple 17
Error, (in mtaylor) does not have a taylor expansion, try series()
I read here a little bit about some bugs of mtaylor function, but how to resolve this issue?
Hi, I'm looking to create a discovery activity to introduce the cosine . Any ideas for using Maple components with a slider to vary the position of a point on a line while displaying distances and their ratios? Thank you
Doc2.pdf
How can one obtain the principal measurement of an angle (which belongs to the interval ]-π;π]?
QuestionMesPrincipale.mw
Equation:=int(y'(x)*w(x)) = [int([y(x)^(1/2)]*w(x))]^(-2/3) When plugging this Equation into dsolve, Maple provides the following implicit solution: Solution:= [3*y(x)^(4/3)]/4 + int[(2*y(x)^(5/6)/[3*int([(y(x)^(1/2))*w(x)]/[3*int[(y(x)^(1/2))*w(x)]^(5/3) When going to odeadvisor, the suggestion was to first convert to the form y = G(x,y'(x) and then utilize the method of 'patterns', which I could not apply to this equation. If anyone can fill in the steps between 'Equation' and 'Solution', it would be greatly, appreciated. P.S.Sadly, I am unable to attach the actual Maplesoft worksheet.
Can anyone assist with this error please?
#Clear memory and load package.
#Initialise variables,matrices and vectors.
b:=<<18>,<-2>>:
c:=<<1>,<1>>:
i:=0:
P:=<1.08,1.37,1.56,1.61>;
t:=<5,10,15,20>;
tol:=1e-6:
#Initialise Gauss-Newton matrices.
n:=Dimension(t):
f:=Matrix(n,1):
J:=Matrix(n,2):
#Display initial parameter values.
printf("Gauss-Newton Method\n");
printf("-------------------\n");
printf("Before iterations,A = %f and B = %f\n",b(1),b(2));
#Perform the Gauss-Newton method.
while max(abs(evalf(c)))>tol do
  i:=i+1;
  for r from 1 to n do
     f(r,1):=evalf((In(b(1)+t[r])+b(2))-P[r]);
     J(r,1):=evalf(1/b(1)+t[r]);
     J(r,2):=evalf(1);
c:=Multiply(MatrixInverse(Multiply(Transpose(J),J)),Multiply(Transpose(J),f));
b:=b-c;
printf("After iterations %d, A = %f and B = %f\n",i,b(1),b(2));
Vector(4, {(1) = 1.08, (2) = 1.37, (3) = 1.56, (4) = 1.61})
Vector[column](%id = 36893488152076174028)
Gauss-Newton Method
Before iterations,A = 18.000000 and B = -2.000000
After iterations 1, A =
Error, (in fprintf) number expected for floating point format
Download Asst_3_Q4b.mw
The x region is z<x<1 and y region is 0<y<pi//3, I think there is an error in the j values in the loop
Can anyone assist please?
#Clear memory.
#Initialise variables and arrays.
h:=0.1;
k:=Pi/30;
c:=1:
iter:=0:
tol:=1e-5;
w:=1.5;
u:=Array(0..10,0..10):
U:=Array(0..10,0..10):
#Calculate boundary u values.
for i from 0 to 10 do
   u[i,Pi/3]:=0;
   u[i,0]:=0;
for j from 0 to Pi/3 do
   u[0,j]:=0;
   u[10,j]:=sin(3*j*k)/2;
#Perform the Gauss-Seidel method.
while c>tol do
   iter:=iter+1;
   if iter>99 then
      printf("\nGauss-Seidel method did not converge,change w.\n");
   break;
end if:
for i from 1 to 9 do
     U[i,j]:=u[i,j];
     u[i,j]:=(10*Pi^2*u[i-1,j]+9*u[i,j-1]+9*u[i,j+1]+2*Pi^2*u[i+1,j])/20;
     u[i,j]:=w*u[i,j]+(1-w)*U[i,j];
c:=max(abs(u[1..9,1..9]-U[1..9,1..9]));
printf("After iteration %2d,the maximum change in u is %7.1e\n",iter,c);
#Display the final u values if method converged.
if iter<100 then
    printf("\nGauss-Seidel Method\n");
    for j from 10 by -1 to 0 do
        printf("%6.4f",u[i,j]);
    printf("\n");
end if:
.1
(1/30)*Pi
0.1e-4
1.5
Error, bad index into Array
Error, final value in for loop must be numeric or character
Gauss-Seidel Method
0.00000.00000.00000.00000.00000.00000.00000.00000.00000.00000.0000
Download Asst_3_Q3c.mw
Hello. I have a problem with the phaseportrait and I hope could help me with this:
can you do groupwork on a single documet
Can anyone assist with the error please?
#Clear memory.
h:=0.1;
n:=10;
k:=0.1;
m:=10;
t:=Array(0..m):
x:=Array(0..n):
u:=Array(0..n,0..m):
#Initialise the x array and the initial u(x,0) boundary.
for i from 0 to n do
    x[i]:=i*h;
    u[i,0]:=exp(x[i]);
#Initialise the t array and the u(x,t) side boundaries.
for j from 0 to m do
   t[j]:=j*k;
   u[0,j]:=0;
   u[n,j]:=t[j];
#Use the 2D CTCS explicit wave method.
for i from 1 to n-1 do
   u[i,1]:=(9*u[i-1,0]+14*u[i,0]+9*u[i+1,0])/32+[i]/10;
for j from 1 to m-1 do
  for i from 0 to n-1 do
   u[i,j+1]:=(9*u[i-1,j]+14**u[i,j]+9*u[i+1,j])/16-u[i,j-1];
#Display the u(x,t)values.
printf("2D CTCS Explicit Wave Method\n");
printf("----------------------------\n");
printf("x\t\t t\t\t u\n");
   printf("% f\t% f\t% f\n",x[i],t[m],u[i,m]);
.1
10
.1
10
Error, Array index out of range
x                 t                 u
 0.000000         1.000000         0.000000
 0.100000         1.000000         0.000000
 0.200000         1.000000         0.000000
 0.300000         1.000000         0.000000
 0.400000         1.000000         0.000000
 0.500000         1.000000         0.000000
 0.600000         1.000000         0.000000
 0.700000         1.000000         0.000000
 0.800000         1.000000         0.000000
 0.900000         1.000000         0.000000
 1.000000         1.000000         1.000000
Download Asst_3_Q2b.mw
HI,
I want to simplify an algebraic experssion. How do I do this with Maple?
A1.mw
In the code below I do not understand why f(3,1) cannot be computed : it returns the conjugate of D1[2,2] although I have defined it as a random number. Maybe you understand this ? Actually I first got an error message of the type "bad index into matrix". Thus I wrote ''D1''[t, t] instead of D1[t, t] to fix the issue in the product.
Many thanks in advance for your help
with(LinearAlgebra);
D1 := evalf(RandomMatrix(3));
f := (i, j) -> if i = j then D1[i, i]; elif i = j + 1 then (1 - abs(D1[i, i])^2)^(1/2)*(1 - abs(D1[j, j])^2)^(1/2); elif j + 1 < i then (1 - abs(D1[i, i])^2)^(1/2)*(1 - abs(D1[j, j])^2)^(1/2)*product(-conjugate(''D1''[t, t]), t = j + 1 .. i - 1); else 0; end if;
f(1, 1);
f(1, 2), f(1, 3);
f(2, 2);
f(2, 3);
f(3, 3);
f(2, 1);
f(3, 2);
f(3, 1);
Modu := evalf(Matrix(3, (i, j) -> f(i, j)));
f(3,1) is given by 3222.984487*conjugate(D1[2, 2]): I do not get why the value of D1[2,2] is ignored.
First 195 196 197 198 199 200 201 Last Page 197 of 2457
